Loaded and displayed "C:\Siemens\NX10\UGII\templates\Drawing-A3-Size2D-template.prt": CPU time:   0.016 secs, Real time:  0.027 secs
Displayed in: CPU time:   0.108 secs, Real time:  0.112 secs
!!!&MACRO MESSAGE_BOX -2, Unable to load preferences values file.
UNDO_UG_delete_mark: Mark 64 (Unspecified) not found
!!!&MACRO ASK_ITEM 53018626 (1 BOOL 0) = 1  ! Preview
!!!&MACRO ASK_ITEM 1048576 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 2621440 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 4718592 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 4915200 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 6029312 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 851968 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 7602176 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 9175040 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 11272192 (1 STRN 0) = "dwg1.prt"  ! Name
!!!&MACRO ASK_ITEM 11468800 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 12582912 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 7405568 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 14155776 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 15728640 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 17825792 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 18022400 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 19136512 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 13959168 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 20709376 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 22282240 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 24379392 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 24576000 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 25690112 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 20512768 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 27262976 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 28835840 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 30932992 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 31129600 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 32243712 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 27066368 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 27066368 (1 OPTM 0) = 1  ! Reference Existing Part
!!!&MACRO ASK_ITEM 33816576 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 35389440 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 37486592 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 37683200 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 38797312 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 33619968 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 40370176 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 41943040 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 44040192 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 44236800 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 45350912 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 40173568 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO ASK_ITEM 46923776 (1 OPTM 0) = 0  ! Millimeters
!!!&MACRO ASK_ITEM 48496640 (1 OPTM 0) = 0  ! Model
!!!&MACRO ASK_ITEM 50593792 (1 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 50790400 (1 STRN 0) = "C:\Siemens\NX10\UGII"  ! Folder
!!!&MACRO ASK_ITEM 51904512 (0 STRN 0) = ""  ! Name
!!!&MACRO ASK_ITEM 46727168 (1 OPTM 0) = 0  ! Stand-alone Part
!!!&MACRO EVENT FOCUS_IN 0 0, 11272192, 0, 0, 0! (Application CB Nested)
+++QuickAccess: AutoComplete/AutoCancel Unsuccessful
&MACRO EVENT FOCUS_IN 0 0, 11272192, 0, 0, 0! Name
&MACRO CANCEL 0 0 ! Cancel Callback
&MACRO DIALOG_END -3, 0 ! ##84New: CANCEL
UNDO_UG_delete_mark: Mark 62 (Unspecified) not found
&MACRO WINDOW RESIZE 1.000000 13.604167 6.989583 -1.000000 -0.513783 1.000000 0.513783
UNDO_UG: Recyclable status of mark 74  set to False
&MACRO ASK_ITEM 458752 (1 BOOL 0) = 1  ! Блокировка
&MACRO ASK_ITEM 458752 (1 BOOL 0) = 0  ! Блокировка
&MACRO ASK_ITEM 655360 (1 STRN 0) = ""  ! Метка ячейки
&MACRO ASK_ITEM 655360 (1 STRN 0) = "Approved By"  ! Метка ячейки
&MACRO ASK_ITEM 851968 (1 STRN 0) = ""  ! No Title
&MACRO ASK_ITEM 655360 (1 STRN 0) = "First Issued"  ! Метка ячейки
&MACRO ASK_ITEM 851968 (1 STRN 0) = ""  ! Approved By
&MACRO EVENT FOCUS_IN 0 0, 851968, 0, 0, 0! First Issued
&MACRO ASK_ITEM 851968 (1 STRN 0) = ""  ! First Issued
&MACRO DIALOG_BEGIN "Populate Title Block" 0 ! DA2
&MACRO BEG_ITEM 458752 (1 BOOL 0) = 0  ! Блокировка
&MACRO BEG_ITEM 655360 (1 STRN 0) = "First Issued"  ! Метка ячейки
&MACRO BEG_ITEM 851968 (1 STRN 0) = ""  ! First Issued
&MACRO BEG_ITEM 3801090 (1 BOOL 0) = 1  ! Preview
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR <RibbonTopBar->MenuBar->UG_HELP> ## !
В конце вот это пишет.
1 час назад, NailKo сказал:
В системе кроме 10 есть еще инсталляции NX'а?
Нет, установлена лицензионка. Но в силу обстоятельств не могу обращаться напрямую в поддержку сименса, только через управляющую компанию. На нашем предприятии никто не знает что за ошибка. Установлен тимцентр еще, но при запуске через него тоже появляется данная ошибка. При запуске через тимцентр в журнале другие записи.
Может я куда то не туда нажал или настройку какую то сбил? Можно ли сбросить все настройки к исходным?
>>>> Error code  3550004 caught in file "D:\workdir\reference\NX1003_5\src\assy\no\ind\Assy_ProductContentBuilder.cxx" at line number 2659
>>>> Error code  3550004 caught in file "D:\workdir\reference\NX1003_5\src\part\no\ind\Gateway_FileNew.cxx" at line number 330
>>>> Error code  3550004 caught in file "D:\workdir\reference\NX1003_5\drv\part\no\ind\ja_builder_jam.cxx" at line number 84
>>>> Error code  3550004 caught in file "D:\workdir\Patches\nx1003_patch\src\uifw\no\ind\uifw_definitions.c" at line number 2377
>>>> Error code  3550004 caught in file "D:\workdir\Patches\nx1003_patch\src\uifw\no\ind\uifw_definitions.c" at line number 2531
&MACRO FOCUS CHANGE OUT 1
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2, Error recovery failed because:
&MACRO MESSAGE_TEXT  Потеряна метка отмены
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT  This occurred attempting to recover from the following error:
&MACRO MESSAGE_TEXT  Невозможно загрузить файл задания значений.
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT  Parts in this session may be corrupt.  Do not save your parts.
&MACRO MESSAGE_TEXT  Restarting NX is recommended.
UNDO_UG_delete_mark: Mark 4 (Unspecified) not found
&MACRO ASK_ITEM 15007746 (1 BOOL 0) = 1  ! Preview
&MACRO ASK_ITEM 655360 (1 OPTM 0) = 0  ! Millimeters
&MACRO ASK_ITEM 2031616 (1 OPTM 0) = 0  ! Model
&MACRO ASK_ITEM 4521984 (1 OPTM 0) = 0  ! No Title
&MACRO ASK_ITEM 5242880 (1 OPTM 0) = 0  ! Millimeters
&MACRO ASK_ITEM 6619136 (1 OPTM 0) = 0  ! Model
&MACRO ASK_ITEM 9109504 (1 OPTM 0) = 0  ! No Title
&MACRO ASK_ITEM 12582913 (1 STRN 0) = ":Новое"  !
&MACRO ASK_ITEM 10289152 (1 OPTM 0) = 0  ! CAE анализ
&MACRO ASK_ITEM 10616832 (1 OPTM 0) = 0  ! master
&MACRO ASK_ITEM 10616832 (1 OPTM 0) = 1  ! specification
&MACRO ASK_ITEM 9830400 (1 BOOL 0) = 0  ! Alternative Representation
&MACRO ASK_ITEM 10027008 (1 BOOL 0) = 0  ! Add Master Part as Component
&MACRO ASK_ITEM 13762560 (1 STRN 0) = ""  ! ##64Number
&MACRO ASK_ITEM 13959168 (1 STRN 0) = ""  ! Revision
&MACRO ASK_ITEM 14155776 (1 STRN 0) = ""  ! Name
&MACRO ASK_ITEM 13565952 (1 STRN 0) = ""  ! Item Name
!!!&MACRO EVENT FOCUS_IN 0 0, 12582913, 0, 0, 0! (Application CB Nested)
!!!&MACRO ASK_ITEM 12582913 (1 STRN 0) = ":Новое"  !
UNDO_UG_delete_mark: Mark 2 (Unspecified) not found
&MACRO DIALOG_BEGIN "Persistent Dialog" 7201 ! Persistent
&MACRO BEG_ITEM  0 (1 BOOL 7201) = 0  ! ##01Detailed View
&MACRO DIALOG_PERSISTENT_END 7201
&MACRO DIALOG_BEGIN "Persistent Dialog" 7202 ! Persistent
&MACRO DIALOG_PERSISTENT_END 7202
Successfully loaded dynamic module C:\Siemens\NX10\ugii\libuserdefinedtemplate.dll
Loaded module c:\siemens\nx10\ugii\libuserdefinedtemplate.dll 7fff5f730000 5d000 fcc07454-40b28e26-25d7a095-dde4b5bc-1=libuserdefinedtemplate___147928706664 version = 10.0.3.5
Successfully loaded dynamic module C:\Siemens\NX10\ugii\libmodldirect.dll
Loaded module c:\siemens\nx10\ugii\libmodldirect.dll 7fff5f5b0000 174000 787efc8b-417b4f1a-a2096c8f-d450a337-1=libmodldirect___148188889064 version = 10.0.3.5
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_gateway.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_modeling.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_synchronous.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_direct_sketch.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_modeling_sketch_tools.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_part_module.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\nx_aerodesign.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugweld\application\add_ug_weld.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugautomotive\packaging\application\ug_vd.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugautomotive\bodydes\application\bodydes.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugautomotive\dieeng\application\dieeng.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugautomotive\diedes\application\diedes.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugautomotive\diedes\application\presslinesim.men
MB_LOADED_MENU_FILE Successfully loaded menu file: C:\Siemens\NX10\ugii\menus\ug_direct_sketch_view_popup.men
Successfully loaded dynamic module C:\Siemens\NX10\ugii\libspsdint.dll
Loaded module c:\siemens\nx10\ugii\libspsdint.dll 7fffb2750000 16000 f3ca5b5c-4afb9851-12ebd8b1-9ba7fa99-1=libspsdint___148188554664 version = 10.0.3.5
Successfully loaded dynamic module C:\Siemens\NX10\ugii\libhelpint.dll
Loaded module c:\siemens\nx10\ugii\libflat.dll 7fff5f160000 5c000 3a84daa5-4d66d5c1-3c99c492-710cf60d-1=libflat___148188734064 version = 10.0.3.5
Loaded module c:\siemens\nx10\ugii\libsmdint.dll 7fff5f1c0000 27f000 e96751cf-4e236fd1-b69e3b8e-fc131b4f-1=libsmdint___148188117464 version = 10.0.3.5
Loaded module c:\siemens\nx10\ugii\libhelpint.dll 7fff5f440000 164000 3c3e408a-4d6bef4d-ce6d28af-cac8f77-1=libhelpint___148188430864 version = 10.0.3.5
есть ли в этом журнале переменная  "UGII_SITE_DIR" ?
если есть каково её значение ?
аналогично "UGII_GROUP_DIR" - есть? (значение -?)
Как верно заметил @IgP, проверяйте уровни настроек SITE/USER/Standard, смотрите не переопределены ли они в ugii_env.dat. Если нет желания ковыряться, но есть права администратора - выполните repair installation.
Изменено пользователем Lockdain
  • 1 год спустя...
В 29.08.2016 в 09:48, ART сказал:
Не нужно жизнь облегчать, и переносить методы работы SW в NX. У этих программ отличная друг от друга методология работы. Вал в NX  начинают строить с цилиндра, для этого есть отдельный фитчер Cylinder, потом от него отсекают ненужный объем, используя фитчер Groove (проточка).
В NX не может быть такого что размер начинается или заканчивается на воображаемых кривых т.е. "в никуда"
Хотите поставить  размер диаметра в эскизе? Тогда постройте одну половину линиями, потом там же в эскизе сделайте зеркальные линии и расставляйте ваши диаметры. Причем авторазмер при построении зеркальных линий перестраивается сам.
Здравствуйте, пытаюсь сам освоить NX, скачал и установил NX 12. Просматривая видеоуроки сталкнулся с тем что не все фитчеры присутствуют в моей версии, например "бобышка" пишет что это устаревшее, а "проточки" нет и программа не предлагает никаких подсказок. Подскажите что я делаю не так, может их нужно загружать дополнительно. Заранее спасибо за помощь.
1 час назад, Syomik сказал:
Простите за беспокойство, я все-таки нашел, в NX12 эта функция называется "стыковое соединение".
  • 1 год спустя...
Тоже с таким вопросом столкнулся в NX18 уже,
"стыковое соединение" а как по английски этот инструмент называется? можете скрин иконки этого инструмента скинуть?
Изменено пользователем ShifuCheng
50 минут назад, ShifuCheng сказал:
Groove.
Menu: Insert - Design Feature - Groove.
Home Tab: Feature Group - More Gallery - Design Feature Gallery - Groove.
Groove это же только для тел вращения (цилиндрических или конических), а как сделать проточку например на блоке (прямоугольном теле)? Можно конечно Sketch построить и затем Extrude сделать, теперь только так?
Вопрос вот в чем, есть инструменты в статусе "Устарели" Pad и Slot - что в замен их использовать? В замен использовать Extrude + Скетчи (эскизы)?
В ‎25‎.‎05‎.‎2018 в 00:58, Syomik сказал:
Да, так - но это явный косяк с переводом - 20 лет (даже 25) до этого было Groove - Проточка
3 минуты назад, ShifuCheng сказал:
Тут, как оказывается, прикол.
В интерфейсе пишет "Legacy" - в документации, об этом, ни слова ...
https://docs.plm.automation.siemens.com/tdoc/nx/12.0.2/nx_help#uid:xid1128417:index_modeling:xid867532:id651611:create_features_feat_slot
Legacy не значит, что нельзя использовать - команда всего лишь скрыта (смотрите/изучайте настройку интерфейса),
найдите её через "Command Finder" - отсюда её можно и запустить.
Похоже это очередной косяк Siemens-а из разряда: разработчики ПО выполнили план,
а разработчики документации нет (или там что-то ещё по этому поводу произошло ...)
Вроде, Siemens-ы где-то говорили, что сейчас, вместо всяких карман, бобышка, паз и т.д - Emboss.
Все верно, через поиск на панель можно добавить любую устаревшую команду в статусе Legacy и продолжить ее использовать, инструмент пропасть не может из NX если он пропадет то мы не сможем отрывать старые модели, при постороении которых эти инструменты были использованы.
Так же вы читаете документация на старую версию NX, но это уже не суть.
Слышал такое, совершенно не понятно как пользоваться Emboss по описанию не понятно, что это прямо замена, надо изучать, есть где нормальное видео про Emboss?
5 минут назад, ShifuCheng сказал:
не верю что Solidworks в этом моменте уделал NX
Ну да. В построении бобышек Солид уделал и Крео тоже. Вообще Солид очень хорошо приспособлен для разных бобышек. Ну и что? Должен же Солид быть хоть в чем-то лучше других. Вот в построении бобышек он лучше. А во всём остальном - увы...
NX я пока как вижу в плоскостях хорош.
На самом деле в Extrude в NX можно отсут задать, но нельзя указать явным образом от какой поверхности стартануть.
7 часов назад, ShifuCheng сказал:
Можно. Вместо значения указать "до выбранного", "до расширенного". Есть ещё пара опций безотносительно к поверхностям
Работает, в аншлийской версии это Until Extend, можно задать как в Start так и в End
Теперь никаких притензий к функционалу Extrude, так что Boss от Solidworks тут ничего не уделывает :)Capture.thumb.PNG.056c533ffbaf93acf0d60fedf5ac899e.PNG
В продожение про Extrude, все же столкнулся с моментом который опять же есть в инструменте Boss от Solidworks, но не могу понять как это в NX сделать.
Мне нужно вятянуть тело до указанной поверхности с Offset (другими словами мне нужно задать поверхность до которой буду вятягивать тело но так же нужно задать отступ, например отступить в + или в - на столько то милиметров от указанной поверхности)
В NX в инструменте Extrude есть параметр Offset, но это совсем не то, это offset в плоскости в которой находится Sketch.
      Ты до сих пор не понял, что тебе уже три-четыре раза сказали. Все кроме тебя поняли и успокоились.:=) Копирую для тебя еще раз, что нужно сделать. Или ты опять не понял. :=) Напиши как ты будешь решать эту задачу методом Ланцоша или методом итераций подпространства.  Матрицу масс найдешь выше по тексту. Только не пиши много лишних букв и слов. А в прочем пиши. Интересно наблюдать как ты подгораешь...;=) Сам себя заводишь, пяткой себя в грудь бьешь доказывая, что все знаешь и умеешь  и при этом еще глубже себя закапываешь и подгораешь.
    • Maxim.Oi TF
      Биение есть это точно. Фреза режет не равномерно, слышно по звуку
      Нагуглил старый список отличий профкарт от GTX, кому интересно   А тут - полный список важных для производительности карты настроек на потыцкать https://www.goengineer.com/blog/optimizing-solidworks-for-faster-performance Если солид жёстко привязан к OpenGL - логично поискать любую доступную карту с наилучшим быстродействием в OpenGL.
      @eljer0n, в настройках драйвера и графики игровой карты попробуйте вручную выставить на максимум все видеоэффекты и привязать карту к приложению принудительно (а то у Вас симптомы как софтверного рендера на CPU). Пример: https://www.mlc-cad.com/solidworks-help-center/how-to-force-solidworks-to-use-your-graphics-card/ По дефолту там что-то среднее, скорее всего. Не поможет - установить дрова к профкартам и там покрутить настройки, сменить версию Windows с 11 на 10. И только потом можно смотреть на профкарты. Также потестить опции в самом солиде. Вот тут ниже рекомендуют включить Enable petformance pipeline и не юзать SW 2018 https://www.engineering.com/story/20-to-30-times-faster-graphics-response-with-solidworks-2019s-new-graphics-engine
      Лихой Вы, однако....   Да, это уже сильно сложнее.
    • neon0404
      Да, действительно, огромное спасибо! Ошибка новичка) Не тот режим визуализации был
    • Максим604
      @Killerchik ну да, пишу реальную и стойка переправит, а если пишу руками, то считать для центра.  Просто резьбу писал или через переменные или через turn. И подачу считал как на обычную фрезеровку.   Ещё раз спасибо)
    • Alexejswt
      Все работает.  Job-1.inp
