Вдруг кому будет интересно,я нашла как список менять. Это в настройках по умолчанию-моделирование-установка элемента
И еще рас здравствуйте, может знаете что делает этот файл:
nx502_Screw_Clearance_Hole_Standard.xml;
ну то есть я понимаю что это для  резьбового отверстия, а вот что именно от него зависит чего то не понимаю
The following standard data tables are provided to set the default parameters for Drill Size HoleScrew Clearance HoleThreaded Hole, and Hole Series features:
  • nx6_Drill_Size_Hole_Standard.xml
  • nx502_Screw_Clearance_Hole_Standard.xml
  • nx502_Threaded_Hole_Standard.xml
Column names in the nx502_Screw_Clearance_Hole_Standard.xml file
This data table is applicable for Screw Clearance Hole and Hole Series type of Hole features.
Column name
Description
Unit
Specifies the unit used to create the Hole feature.
Note:
You must ensure that all values in a particular row that define the Hole parameters have the same unit.
Standard
Specifies the list of standards to be used to create the Hole feature.
Lets you specify the standards available in the Standard list under the Settings group in the Hole dialog box.
Form
Specifies the Form of the Hole feature (SimpleCounterbored, or Countersunk).
ScrewType
Specifies the screw head types corresponding to the selected standards.
Size
Specifies the Size of the screw clearance hole.
Fit
Specifies the Fit of the screw clearance hole (CloseNormalLoose, or Custom).
ThreadStd
ThreadSize
ThreadEngage
Applicable only for End Holes of Threaded form in a Hole Series when the Match Dimensions of Start Hole check box is selected.
Specifies the Thread StandardSize, and Radial Engage options.
Depending on the StandardFormScrew TypeScrew Size, and Fit the following columns specify the default values for the corresponding options in the Hole dialog box.
You can edit these values directly in the dialog box only when Form is set to Custom.
HoleDiameter
Specifies the value for the Diameter option.
CBoreDia
Specifies the value for the C-Bore Diameter option.
CBoreDepth
Specifies the value for the C-Bore Depth option.
CSinkDia
Specifies the value for the C-Sink Diameter option.
CSinkDepth
Specifies the value for the C-Sink Depth option.
CSinkReliefDepth
(For Countersunk holes with a relief).
Specifies the value for the Depth option available under Relief in the Form and Dimensions group.
StartChamferOffset
Specifies the value for the Offset option available under Start Chamfer under Form and Dimensions.
StartChamferAngle
Specifies the value for the Angle option available under Start Chamfer in the Form and Dimensions group.
NeckChamferOffset
(For Counterbored holes)
Specifies the value for the Offset option available in the Neck Chamfer subgroup under Form and Dimensions.
NeckChamferAngle
Specifies the value for the Angle option available under Neck Chamfer in the Form and Dimensions group.
EndChamferOffset
Specifies the value for the Offset option available under End Chamfer in the Form and Dimensions group.
EndChamferAngle
Specifies the value for the Angle option available under End Chamfer in the Form and Dimensions group.
А в итоге вот этот фичер с таким типом:
Изменено пользователем Lockdain
screw clearance hole - отверстие под проход винта (болта/шпильки/...)
Изменено пользователем Bully
доброго дня. как поправить "артефакт" в рендеринге размера? все облазил. не вижу в упор.
разобрался.  изменил шрифт на шрифт выше и фсе сломалось в мгновенье ока. ну вы там поосторожнее)))))
Изменено пользователем ra99
для древнего нх4 написал тулбар. его врезал. тепереча не соображу как вытащить переработанный тулбар на закладку ленты НХ10. поделитесь алгоритмом :rolleyes:  иль рыбой
День добрый уважаемые знатоки, кто нибудь знает возможно ли изменить ось вдоль которой детали должны быть ориентированы для Установки крепежа.
Из документации:
Все детали должны быть ориентированы таким образом, чтобы их верхняя сторона была направлена в направлении +Z. Например, верхняя сторона головки винта должна быть расположена в направлении +Z.
можно ли +Z поменять?
В какой документации вы это нашли ?
Делайте как удобно, вставка в СЕ от СК детали никак не зависит,
Задаются условия сопряжения, опирающиеся на объекты,
по правильному на грани и ребра Solid Body детали.
Меня интересует в данном случае настройка Установки крепежа из библиотеки повторного использования, а не просто вставка деталей в сборку...
Это из документации:
There is an alternative method of communicating the orientation and position for a component to be used with fastener assemblies.
Create a correctly positioned and oriented Datum CSYS feature with the name "ORIGIN_CSYS" in each of the component files.
If there is a Datum CSYS with the name "ORIGIN_CSYS" in a fastener assembly
component this will primarily be used for orientation and positioning.
Добрый день. Подскажите пожалуйста как в nx правильно задать контакт типа поверхность-поверхность для оболочки. Опишу алгоритм для полного понимания.
Из твердотельной модели создаю срединные поверхности. между ними получается расстояние 6мм. затем разбиваю сетки на поверхностям с заданными толщинами и свойствами. Потом с помощью функции задаю болтовое соединение. Как правильно задать контакт между двумя поверхностями. Какое выбрать в параметрах контакта  начальное проникновение?? и не будет ли мешать болтовое соединение контактировать? Так как оно задается 1д элементами то позволяет ли оно сближаться поверхностям, или фиксирует жестко относительно друг друга?
Изменено пользователем Tema32
Для задания толщины оболочки надо задавать ''Смещение толщины оболочки (SHLTHK)''.
Это следующая строчка на Вашем первом рисунке.
Начальное проникновение/зазор в данном случае использовать не корректно. Обычно оно используется для имитации посадок или преднатяга болтовых соединений, посадок валов и т.п.
Вниматеьно следите за направлениями контактных пар! Отсчет указанных выше величин делается по их направлению.
Есть несколько методов моделирования болтов. Можно применять разные элементы. Если речь идет о 1D, то посмотрите какой тип 1D элемента установлен. Выберите соответствующий тип. Если это не RBE (у Вас на рисунке не RBE), то позволяет сдвигаться и задавать преднатяг в виде силы или величины сжатия тела болта.
Изменено пользователем 0Q0
Спасибо, а по начальному проникновению? Имеет ли смысл выбирать установить в ноль?, или достаточно задавать ''Смещение толщины оболочки (SHLTHK)''.
Это из документации:There is an alternative method of communicating the orientation and position for a component to be used with fastener assemblies.
Огромное спасибо, сработало))) правда карман, который получается от болта все равно не туда повернут(
Если используете специальное граничное условие для задания преднатяга болтового соединения, думаю, начальное проникновение будет лишним.
Оно больше подходит для имитации посадок с натягом, чем для резьбовых соединений.
да мне болт не особо важен. я его использую только как элемент скрепления. мне важно чтоб контакт правильно работал. Я посмотрел параметр SHLTHK. но там можно включить или отключить. Смещение задается в контактных парах? и как определить его величину?
В контактных парах по моему. Свойства же контактной пары, а не контактной поверхности. А вот симметричный это размер (тоесть задается как половина зазора) или полный - не знаю. Надо хелп рыть. Вероятнее второе.
Без преднатяга болта при наличии сдвиговых нагрузок лажа будет. Или вообще расчет не сойдется.
Может чего не то делаю помогите люди добрые
Необходимо чтобы элементы эскиза меняли цвет при их ограничении (цвет я установил-черный)
В прикрепленном файле линия ограничена, но она становится черной только когда заходишь в размер
Круг же не ограничен (по диаметру), т.к. можно взять и потащить за окружность, но он тоже становится черным при заходе в размер
В дереве эскиз полностью ограничен (столбец состояние)
Что нужно (если это возможно в NX10): как только я зашел в эскиз - вижу черную линию (ограничена), круг соответственно зеленый (не ограничен/частично ограничен). В SW это реализовано.
Заранее спасибо
P.S. все что выше прочитано, но не помогло
model1.rar
