Что с ЕСКД в NX6/NX7?
caddy
К слову. Есть честно содранные мною форматки с компаса в таком составе:
Скрытый текст: Шаблоны и форматки в templates
A0-2D-layout-template.prt
A0-drawing-template.prt
A0-sheet-template.prt
A0-views-template.prt
A0x3-2D-layout-template.prt
A0x3-drawing-template.prt
A0x3-sheet-template.prt
A0x3-views-template.prt
A1-2D-layout-template.prt
A1-drawing-template.prt
A1-sheet-template.prt
A1-views-template.prt
A1x3-2D-layout-template.prt
A1x3-drawing-template.prt
A1x3-sheet-template.prt
A1x3-views-template.prt
A1x4-2D-layout-template.prt
A1x4-drawing-template.prt
A1x4-sheet-template.prt
A1x4-views-template.prt
A1x5-2D-layout-template.prt
A1x5-drawing-template.prt
A1x5-sheet-template.prt
A1x5-views-template.prt
A2-2D-layout-template.prt
A2-drawing-template.prt
A2-sheet-template.prt
A2-views-template.prt
A2x3-2D-layout-template.prt
A2x3-drawing-template.prt
A2x3-sheet-template.prt
A2x3-views-template.prt
A2x4-2D-layout-template.prt
A2x4-drawing-template.prt
A2x4-sheet-template.prt
A2x4-views-template.prt
A2x5-2D-layout-template.prt
A2x5-drawing-template.prt
A2x5-sheet-template.prt
A2x5-views-template.prt
A3-2D-layout-template.prt
A3-drawing-template.prt
A3-sheet-template.prt
A3-views-template.prt
A3x3-2D-layout-template.prt
A3x3-drawing-template.prt
A3x3-sheet-template.prt
A3x3-views-template.prt
A3x4-2D-layout-template.prt
A3x4-drawing-template.prt
A3x4-sheet-template.prt
A3x4-views-template.prt
A3x5-2D-layout-template.prt
A3x5-drawing-template.prt
A3x5-sheet-template.prt
A3x5-views-template.prt
A4-2D-layout-template.prt
A4-drawing-template.prt
A4-sheet-template.prt
A4-views-template.prt
A4x3-2D-layout-template.prt
A4x3-drawing-template.prt
A4x3-sheet-template.prt
A4x3-views-template.prt
A4x4-2D-layout-template.prt
A4x4-drawing-template.prt
A4x4-sheet-template.prt
A4x4-views-template.prt
A4x5-2D-layout-template.prt
A4x5-drawing-template.prt
A4x5-sheet-template.prt
A4x5-views-template.prt
assembly-mm-template.prt
model-plain-1-mm-template.prt
ugs_drawing_templates.pax
ugs_model_templates.pax
ugs_sheet_templates.pax
Скрытый текст: Шаблоны в localisation
ugs_drawing_templates_russian.pax
ugs_model_templates_russian.pax
ugs_sheet_templates_russian.pax
Надо - выложу) Изменено пользователем dvr
если речь идет про это
пробовал с самого начала, потом разобрался сам, что лучше настроить индивидуально, что и было сделано. Вопрос открыт: что такое dpx?
Это файлы в которых все храниться
Я не устаю просить прощения за своё непонимание)
post-9003-1307080894_thumb.png post-9003-1307080925_thumb.png post-9003-1307080937_thumb.png post-9003-1307080946_thumb.png
В видео показано как это реализовать, но не сказано, что это за модуль. По небольшому опыту работы с компасом могу озвучить, что существует отдельный модуль библиотеки материалов, который не транслируется в надстройки NX. По крайней мере явно. В компасе существует масса библиотек по ЕСКД, ибо это, имхо, единственный флагман в этом направлении. Неужели Вам не инетересно интегрировать такую полезную игрушку в любимый продукт?
Модуль Библиотека Материалы и Сортаменты, стоит 10 900.00 руб., но я не знаю сколько стоит интеграция
Может быть по незнанию вопроса по дефолту выставлял следующее:
...не помогло :(
Очень жаль, но я боролся с этим и победил. Проблема еще была в шаблоне. Как я уже говорил некоторые настройки зависят от шаблона. Т.е. пришлось создавать новые шаблон и переносить настройки.
зы. Хочу начать параллельно поковыряться в спецификациях. Просьба направить несведующего - стоит ли углубляться в директорию UGII\table_files? Может лучше по пути наименьшего сопротивления создать шаблоны СП как шаблоны чертежа, а тексты вводить как в экселе? Кто-нибудь пытался это дело автоматизировать стандартными средствами в обход NX Open?
Считаю данную тему бесперспективной. Спецификацию либо делать в ПДМ системе либо просто руками
Подскажите как в чертеже вставить ЕСКДшную рамку.
ПС Позволю себе отвлечься. Был спор по поводу внедрения 3Д моделирования в отеч. авиапроме. Было восхваление ГСС как флагмана 3Д моделирования. Так вот, у меня есть эскизный проект Ил-112, где все наглядные материалы (каркас самолета, система управления, интерьер кабины и т.д.) ничто иное, как 3Д модели, сделанные в NX1. Этот эскизный проект датируется 2003 годом. Вот так.А что касается КБ Ильюшина, оно всегда выпускало востребованные самолеты.
Еще раз извиняюсь за отклонение от темы.
Изменено пользователем Рус_85
Запамятовал, выкладывали уже набор чертежных утилит от Сименса для 64-х битной Винды в других ветках или нет.
Делюсь ;-)
Utilities.zip
Добрый день, avd. А попросить у Вас шаблон, с которым проставляются русские буквы в обозначении сечений и видов, возможно?
Делюсь ;-)
Utilities.zip
Эти утилиты в NX5 не работают!? И ещё может у вас есть тоже самое но для 32 битной
на всем нам известном месте они есть в 32 битном исполнении
Работают даже в NX4, насколько мне память не изменяет.
Для 32-х битной выложил
utilities32.rar
Уменя панелька "Утилиты" появляется, правда иконок нет только пустые квадратики. Когда нажимаю на кнопку пишет"Указанное для этой клавиши действие не найдено". Пробывал просто dll запустить тоже ругается.
Чтобы библиотеки не ругались необходимо установить дополнительно
MS VC++ 2005 Redistributable
MS VC++ 2005 SP1 Redistributable
MS .NET Framework 2.0 SP1
После установки этих компонент некотрые Dll запускаются даже на NX3
Установил, даже всю студию 2005- ничего не хочет работать. А может исходники у кого нибуть есть))?
скиньте логи...
Такое чувство, что не регистрируются калбаки
Нашол почему картинки на кнопочках не высвечивались- переменная UG_UTILS_DIR не на ту директорию ссылалась. А вот запустить dll так и не получилось.
В журнале пишит
The reason c:\Program Files\UGS\NX 7.5\Utilities\Dimension\dim_edit.dll failed to load was:
Cannot classify image c:\Program Files\UGS\NX 7.5\Utilities\Dimension\dim_edit.dll
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2 Невозможно загрузить изображение - см. журнал
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT Имя файла: c:\Program Files\UGS\NX 7.5\Utilities\\Dimension\dim_edit.dll
&MACRO MESSAGE_TEXT
&MACRO MESSAGE_TEXT Имя функции: ufusr
&MACRO MESSAGE_TEXT
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR ! <MB/Toolbar>
В журнале пишит
у меня на 7.5.4.4 все встало и заработало win7 32 bit
Срочно нужна помощь! Тема такая. Босс выбирает крутую CAD/CAM систему для всего подразделения. Помимо моделирования интересуется оформлением чертежей по ЕСКД. Просит продемонстрировать, как это делается в NX (КД выпустить на небольшую сборку). Затык в том, что у меня шаблоны форматок только буржуйские есть, нужны наиболее востребованные форматки оформленные по ЕСКД для NX8 (шаблоны и pax). Знаю, что можно самому посидеть, разобраться и наваять любую, но времени в обрез, честно. Да и создание их в NX8 говорят несколько отличается от NX7.5 Может кто поделится?
Изменено пользователем Andryha
Здесь много говорилось об утилитах (см. пост выше), пробуй их поставить для NX8 может заработают. В них есть и форматки и многое другое
Попробовать то можно, но вероятней всего ничего не получится, уж очень далеко отстали эти утилиты от развития NX. Кроме того чтобы убедить босса в пользу NX нужен "красивый" вариант, без дополнительных обвесов. Вообщем нужно именно то о чём я спрашивал.
Если быстро, то утилиты, я попробовал в 8-ке форматки работают. По поводу обвесов. Эти утилиты разработка масковсого офиса Siemens PLM Software, т.е. их собственная разработка, которая распространяется бесплатно.
Если у вас есть свободный вечер, терпение и базовый английский (или переводчик), то можно и новые шаблоны поднастроить, тока все равно шероховатость кривая, есть некоторые еще пакости. ИМХО эти утилиты (http://fsapr2000.ru/index.php?s=&showtopic=32321&view=findpost&p=417405) лучший выбор сейчас
Уважаемый avd, терпение у меня есть, но вот свободного времени пока к сожалению нет. Метнулся вот только к компьютеру проверить может кто что скинул?
Какая именно? Вроде в 8-ке с шероховатостями порядок навели.
    • Максим604
      Спасибо!))  То есть правильно же понял- что при резьбофрезеровании подачу надо считать для центра инструмента?
    • Maxim.Oi TF
      А вы какой бы режим резания посоветовали? Материал 14Х17Н2(нержавейка) Фреза грибковая P6M5. диаметр 20мм. 14 зубов Ширина 1.8 мм. Глубина фрезировки паза 4.4 мм. (Я фрезировал за 2 прохода по 2.2мм.) Какую выбрать скорость резания, подачу, глубину резания(Ap.)?
      а в чем риски то. мало ли кто и где налоговый идентификатор умыкнуть может и почту может это хакеры сделали а вы сразу 14-й пакет санкций на свою голову обрушиваете. а интересного там ничего и  нет....
      судя по всему, у вас разные детали построены в разных системах единиц
      Вам бы схему смотреть на станок. Что понять, почему силовое не приходит
      выкиньте призмы из расчёта.. считайте балочными конечными элементами, ограничив на концах лишь перемещения, как на картинке выше. Тогда всё будет збс..))
      хз, запустил расчёт с вашими дефолтными настройками, всё посчитало. Но я бы упростил модель. Трубу можно точно исключить из расчётной модели (можно юзануть опцию "рассматривать как удалённую массу"). Всё остальное можно сделать оболочками, временно выкинув болты из модели. Также лучше использовать "Сетка на основе смешанной кривизны". Вот результаты. Напряжения небольшие, 09Г2С спокойно выдержит..))
      Смысл в том, что подача должна указываться для фактического перемещения режущего клина. При одинаковой угловой скорости, в зависимости от радиуса траектории линейная скорость движения точки будет пропорциональна радиусу.
      Вероятно, я не совсем понятно написал. почта "имя@домен компании.com", хостер почты - Гугл.   Я, быть может, был бы готов из интереса рискнуть своей компанией - но точно не чужой.
    • Turgenev
      Не, греться будет, конкретно, потому что разъем будет прямо на стенке "стакана", а сам "стакан" будет нагреваться от нагревателя до 300 градусов. 3Д модель в процессе. погуглил, это разъемы типа таких: У них все круто, но нет фланца, чтобы хоть как-то закрепить разъем на стенке "стакана". По вашей наводке нагуглил еще разъемов, стоят дорого и очень большой габарит: Есть интересные варианты, но я не смог найти к ним ответную часть:   Это что-то типа такого: Мне не подходит по форм-фактору. Нагреватель должен быть в форме диска- плоский цилиндр диаметром 75мм и высотой около 10-20мм То есть запах идет от обгорания металла нагревателя? Вариант с заливкой нагреватель термостойким бетоном был, я даже его опробовал, но очень уж трудозатратно выходит. Любой металл будет иметь запах при нагреве, если его никуда не засовывать?
