Вышел Sp для Sw 2005
...Поставил sw2005-3.0-3.1ev-i!!!!
Что бросилось в глаза, так это наконец пропал глюк с менюшками!...
<{POST_SNAPBACK}>
Дык и в 3.0 этого глюка (с менюшками), помнится, уже не было! :blink:
Подождем...
SolidWorks 2005 SP 4.0
SPR # Description
141219 Diameter dimensions from revolved features' sketches do not come into drawing centered on features when Insert>Model Items is used. For FIX to take effect, Ctrl+Q after opening the drawing file
171645 Adding coincident relation between Hole center point (3D Sketch) and plane incorrectly causes sketch to go over-defined.
174246 Cannot hide silhouette edges of hidden holes in this assembly drawing.
184637 Unable to use Fold sheet metal feature on a lofted helix after using the Unfold feature
230629 Part gives errors on rebuild in any build later than 2004 sp2.1
246038 Display problems with View..Display->section view. Sectioned faces do not higlight when selected. Removed edges still highlight
247895 Unfolded bend cannot be folded again in this sheet metal part.
252894 API - Changing a HW hole through the API, causes loss of parent-child references
256251 API - Instability when calling InstallQuickTipGuide when the application has been compiled with _ATL_DEBUG_INTERFACES defined
257950 Instability editing face colours in this part
259624 Fixing sub-assembly components and then saving main assembly does not save this change.
259936 Cannot add an ordinate dimension if the sheet focus is locked
260801 Instability when inserting centerline to this drawing.
262046 Custom material database with error message: 'Illegal qualified name character' after trying to add a new material
263099 Instability unsuppressing flat-pattern feature
263573 Parametric note to an assembly feature hole wizard hole inserts the syntax of the dim rather than the actual dimension value
264176 Effect of real view in not present in the print priview. For FIX to take effect, Force Regen (Ctrl+Q) after opening the file.
Ну это пока все на уровне слухов т.к. SP4 официально еще не выложен на сайте Solidworks
Подождем... :rolleyes:
to SB.il
Ну как на уровне слухов... Информация с официального сайта SW о
предстоящем SP4. Так что скорее о ведущейся работе над SP4.
Мне почему-то мечталось, что в Sw2005 появится возможность делать виды чертежей с горизонтальными и вертикальными разрывами одновременно.
Оказалось - что нет :(((
А в Sw2006 такая фишка будет, интересно...
Всем привет.
А на счет "умных деталей" в SW2006, кто нибудь обьяснит суть.
<{POST_SNAPBACK}>
К примеру, при вставке в сборку "умная" деталь адаптирует автоматически свой размер к сопрягаемым поверхностям.
<{POST_SNAPBACK}>
Коротко, это то, что у Inventor'а заложено изначально. Будем посмотреть, как это реализует SW, и за какое время это ЗАРАБОТАЕТ.
Есть мелкие такие радости в Инвенторе которые бы не помешали в SW ... были бы просто рады таким примочкам
<{POST_SNAPBACK}>
:thumbdown: А полная замена математического ядра в Инвенторе тоже была заложена изначально???
Оговорюсь сразу, не знаю что реализовано в последних версиях
Inventor-а. Может там уже все само проектируется.
Поэтому приведу пример из тех возможностей и реализации данной
функции по знакомым мне версиям.
Для того чтобы лучше понять, возмем Фунцию сечения по стандартным
плоскостям. Раньше в SW она тоже существовала. Выбрав нужную плоскость
можно было рассечь деталь, задав угол поворота изменить сечение ну
и т.д. Начиная с 2004 появился динамическое сечение. Теперь просто
схватив сечение за маркер можно свободно вращать, передвигать
просматривая динамически меняющееся сечение модели.
Похожее поведение и в отношение " умных деталей". То как это
реализовано Inv и будет реализовано в SW2006. Назовем это статической
и динамической реализацией.
На зимней презентации SW2006 демонстрировался такой пример .
Есть вал состоящий из нескольких цилиндрических участков разного
диаметра. "Умная деталь" - шайба . Перемещаем шайбу на вал. Срабатывает
автоматическая привязка соосность. А далее , перемещая шайбу по
валу получаем динамическую адаптивность. Т.е по мере продвижения
получаем равенство внутреннего диаметра шайбы текущему значению
диаметра вала.
Привет !
31.05.2005 вышел SP3.1
Для апгрейда с SP0 до SP3.1 - размер 141 Mb
Для апгрейда с SP3 до SP3.1 - размер 40 Mb
Там-же Solidworks 2006 Beta 4 от 16.05.2005
<noindex>http://www.solidworks.com/pages/services/downloads.html</noindex>
__________
ну и как ощущения? приятно или не очень?
Сегодня поставил и в конце дня стер и вернулся SP3.
Возможно, что это так мне повезло, но появились проблемы. Сделал изменения в модели детали, созданной 3 дня назад, перешел в чертеж и Solidworks завис. Закрыл программу при помощи Ctrl+Alt+Del.
Потом это повторилось. Повторилось это и после перезагрузки компа.
Вопрос: Стоит ли ставить проблемный SP3.1, если до конца месяца выйдет SP4?... :g:
Подскажите, где конкретно слить SP3 , только железно работающие ссылки, а не неизвестно что.
To _Chapaev_
Для лицензионной версии ссылка только одна, повторяю ее. <noindex>http://www.solidworks.com/pages/services/downloads.html</noindex>
Это ссылка на следующий шаг. В окне введи серийный номер и нажми кнопку "LOGIN"
<noindex>http://www.solidworks.com/pages/services/s.../downloads.html</noindex>
      а он там вообще есть? станок какого года 2023? у него поди  еще гарантия не кончилась так чего вас напрягают?
      Последнии версии программы требуют завести в организации штат шаманов и не менее трёх бубнов, т.к. работы програмы часто требует риуталов Вуду, что бы хоть что-то работало нормально.   Так могут пропадать резьбы в сборках (частично или все), даже если вы их хотите или пытаетесь включить разнообразными способами, а если вам их удалось включить, то они могут отображаться не так как нужно. В вычислениях и уравнениях из-за вычислений с плавующей точкой два одинаковых числа могут быть не равны.   В чертежа на массивы обычно не надо задавать размеры каждого отверстия, а достаточно образмерить одно, шаг и максимальный размер.   Что подразумевается под правильно? Можно пример картинок, что это за отверстия и что значит правильно и как получается не правильно? Картинки или другие файлы в архиве можно вставлять прямо на форум после 10 сообщения на форуме.
    • kinovari
      Панель в виндовс не выходит... проект .ap18 по инфе производителя создан в тиа 18
    • OliverTwist
    • Alexandr97
    • Shura762
      Ну не знаю. У нас в свое время было таких ИС-800 8 шт. Один из них самый первый был с круглым магазином на 32 инструмента, привода сименс, ЧПУ балт систем. Если к чпу и приводам претензий не было, то к механике были серьезные вопросы. А вот остальные 7 все как один, 64 инструмента, фанук везде и вся, датчики, линейки, энкодеры ханденхайн, к механике особых претензий уже нет, да, бывают поломки, периодически по мере необходимости меняем опоры качения и прочее... Да, есть слабые места, например упорный подшипник ШВП оси Z, периодически дохнет из за попадания сож и Z начинает дергаться как эпилептик, приходится менять. Все эти станки работают с 2007-2010 годов в три смены без остановок. Из крупных поломок за все это время, материнка в одном УЧПУ померла, на одном стол вырвало, на одном PSM смачно взорвался и вот сейчас похоже этот же восстановленный PSM взбрыкнул. Мелочовку типа порванных РВД и ремонтов по причине естественного износа, типа замены опор качения я не считаю. Бывает индуктивные датчики летят, приходится менять, но это еще мельче и устраняются в течение часа со всеми перекурами когда карта сигналов и мест установки датчиков есть. К тому же эти станки до сих пор держат свою геометрическую точность, периодически проверяем их. Точнее сначала оператор начинает замечать что то не то, потом мы смотрим что не то, ремонтируем и проверяем  Но у нас преимущество, у нас есть очень грамотный и опытный станочник, он с закрытыми глазами находит неисправности, да и станки эти знает вплоть до каждого винтика. Ну и само собой по мере необходимости и шпиндели отправляем в ремонт. Правда последний раз эта организация нам так восстановила шпиндель на токарный LEADWELL, что точил вместо круга непонятно что. Разобрали и ужаснулись, подшипники стоят неправильно, кольца вообще не там где должны быть, какие то медные проставки, которых там сроду не должно быть... Пришлось самим в срочном порядке пересобирать правильно и каким то чудом шпиндель заработал как и должен. Каким чудом я не знаю, но тем не менее работает уже год. Претензий нет. В те времена, когда их было 8 шт, а токарных LEADWELLов больше 20, еще некоторые и с барфидерами, так я чаще ремонтировал барфидеры, чем ИС-800. Да, сейчас настал кризис, часть станков продали, часть работников сократили, и их осталось всего 3 штуки.
    • Tad
