Программа CE-TOL для Pro/E
SVB
Коллеги, давно приходилось мне читать про чудеса оптимизации допусков на детали с помощью программы CE-TOL.
Есть ли среди здесь пользователи этой программы? Поделитесь, пожалуйста впечатлениями о ней! Есть ли версия этой программы под Prop/E WF?
Я о существовании этой программы даже не догадывался.
What Is CE/TOL 6 Sigma?
CE/TOL 6 Sigma is a complete tolerance management solution for Total Quality
and Process Improvement programs. CE/TOL 6 Sigma has been created to aid design
engineers in performing tolerance studies and optimizing tolerance budgets.
Seamlessly integrated with Pro/ENGINEER, CE/TOL 6 Sigma allows users to model,
analyze and allocate tolerances based on product performance requirements while
considering manufacturing process capabilities on any Pro/ENGINEER assembly. The
result is faster development of higher quality products, at a lower cost.
CE/TOL 6 Sigma is the key software component for implementing Design for Manufacture, Concurrent Engineering and Six Sigma methodologies.
CE/TOL 6 Sigma HELPS USERS OPTIMIZE TOLERANCES
CE/TOL 6 Sigma helps users to quickly perform tolerance analysis and optimize tolerance budgets. The optimal
tolerance zone is quickly determined taking into consideration the functional requirements, fabrication capabilities and assembly yields.
Optimization is now as simple as setting your quality objectives and picking the Optimization button. The optimization feature of CE/TOL 6 Sigma eliminates hours
of trial-and-error manual tolerance adjustments by automatically modifying
tolerances while assuring the required performance.
PRODUCT HIGHLIGHTS
Realism is Added to Tolerance Management Without Sacrificing Speed
Advanced Bi-Directional Associativity with Pro/ENGINEER
CE/TOL 6 Sigma fully utilizes feature definitions and parameters from the Pro/ENGINEER model,
including the ability to write-back the updated values.
Automatic Joint Recognition
By selecting two mating surfaces in Pro/ENGINEER, CE/TOL 6 Sigma automatically identifies the appropriate tolerance-model joint and places it in the proper location and orientation.
Tolerance Model Visualization
An interactive assembly-network diagram provides an immediate confirmation of the active joints, parts and specifications in the model.
Handles Non-Normal Distribution for Input Variables
Analyze Multiple Specifications Simultaneously
Fully Automated Pin-Hole Analysis
New Re-Engineered Interface
The new re-engineered graphic user interface simplifies problem modeling and provides clear and precise graphic output. Reports are generated automatically as part of the analysis session. Motif and Windows standard user interface design make optimization tasks intuitive.
Instant graphical feedback of design specifications, assembly yield predictions and feature fabrication process capabilities are simultaneously displayed. Graphical displays of sensitivity and contribution plots by feature are also available.
Unique Analysis Reports
The fully automated analysis module generates 4 unique analysis summaries:
Worst Case - 100% assembly fit under all tolerancing conditions.
Statistical Analysis - Based on Motorola's Six Sigma methods considering normal and non-normal probability distribution.
Contribution-Pareto of all tolerances and features.
Sensitivity-Identifies driving tolerances and features.
Есть.
Они неоднозначные. Как таковой нет оптимизации допусков :thumbdown: . Есть анализ (то бишь решение прямой задачи). При этом выводятся все характеристики влияния на замыкающее звено - качественный, количественный характер влияния каждого звена, весовой коэффициент. Вот пользуясь этими параметрами в интерактивном режиме подгоняешь допуска звеньев под замыкающее звено.
Крутизна в подвязке к каждому допуску технологии. :clap_1: То есть, можно указав на размер, выбрать способ его получения - мехобработка, литье, штамповка - соотвественно при включаются разные распределения (помним, да? гауссово там, нормальное и т.д.).
Очень здорово, в отдельных случаях для получения требуемого замыкающего звена можно даже прикикнуть экономическую целесообразность перехода на другой производственный процесс (мы так не делали, правда :rolleyes: ).
Ну и в техмерке он работает, то есть схемы могут быть пространственные. Ручками такие затрах....ой! что я говорю? :rolleyes: замучаешься считать.
А как же! Изменено пользователем SHARit
Для SHARit
Под "оптимизацией допусков" я понимал именно как у Вас "подгоняешь допуска звеньев под замыкающее звено". В более поздней статье от того же "Солвера" кажется о тульском тендере был пример как используется одновременно и CE-TOL и Pro/Mechanica с оптимизацией усилий в сочленениях. Кто-нибудь делал что-либо подобное? В смысле в совместном использовании CeTol и Pro/Mechanica?
Я читал статью от "Солвера" о ней ещё в апрельском 1999 года "САПР т графике". Возможно эта статья есть на сайте "СиГ".
Была, кстакти, и в Observere недавно о ней статья.
Изменено пользователем SVB
Хотелось бы все-таки поиметь автоматическую оптимизацию. Матрицу Парето-то он вычисляет, а по ней с учетом весовых коэфициентов почему бы в автомате не запустить автоматизацию? :wallbash: Ну и ладно... :rolleyes: Иногда копаясь ручками, начинаешь лучше соображать, что на что влияет и почему. :g: Наводит на правильные мысли по поводу изменения конструкции. :beer: Изменено пользователем SHARit
у кого нть есть крякала?
По Инету пошарил - даже не нашел ссылок. А так было бы интересно пошупать.
....у кого то я видел ссылочку...хм...укого не помню :rolleyes:
но у меня она есть
без кряка...положить чтоль на сайт?
сам не ставил...
но знаю что ставили...пробовали во всяклм случае..не получилась халява :wallbash:
Вот что пишут в инструкции по установке сами разработчики:
CETOL 6. Version 6.0 can use the same license file and server as Version 5.1. If you already have a valid CETOL 5.1 license, there is no need for you to obtain a new license file for Version 6.0
Может быть всё не так страшно. У меня пока результат отрицательный.
Aleksandr
If you already have a valid CETOL 5.1 license...... так не ее у меня, а попробовать хочется Aleksandr не поможешь?
CETOL 6. Version 6.0 can use the same license file and server as Version 5.1. If you already have a valid CETOL 5.1 license Хотелось бы поиметь license Version 5.1
Читали, пробовали. Результат отрицательный.
Поставил пока 5.1, но не пробовал работать.
Для остального нужно мыло давать. Через почту форума файлы не пересылаются.
Не используйте PTC host id или cpu_id утилиты для получения host id (при лицензировании CETOL). Этот метод может не дать корректного host id и лицензия не будет работать. Всегда используйте утилиту lmhostid.
Это тоже из руководства по установке.
    • Irukanjii
    • anykeyto
    • Sivolap36
    • Рома калужский
    • Горыныч
