Cracks In Abaqus
Всем доброго времени суток!
Собственно тоже занимаюсь проблемой развития трещины в рамках XFEMa.
И есть такие вопросы:
- что такое damage evolution? Каков физический смысл этого параметра?
- в использование traction separation laws критерия maxps(maximal principal stress) - это максимальное главное напряжение при достижении которого начинается разрушение, или же какой-то очередной параметр?
Буду признателен за любой ответ. Спасибо
*DAMAGE EVOLUTION
Specify material properties to define the evolution of damage.
This option is used to provide material properties that define the evolution of damage leading to eventual failure. It must be used in conjunction with the *DAMAGE INITIATION option. It can be utilized for materials defined for cohesive elements, for enriched elements, for elements with plane stress formulations (plane stress, shell, continuum shell, and membrane elements) used with the damage model for fiber-reinforced materials, for ductile bulk materials associated with any element type in a low-cycle fatigue analysis, and, in Abaqus/Explicit, for elastic-plastic materials associated with any element type. It can also be used in conjunction with the *SURFACE INTERACTION and *DAMAGE INITIATION options to define a contact property model that allows modeling of progressive failure for cohesive surfaces.
Products: Abaqus/Standard Abaqus/Explicit Abaqus/CAE
Type: Model data
Level: Model
Abaqus/CAE: Property module
References:
“Damage evolution and element removal for ductile metals,” Section 21.2.3 of the Abaqus Analysis User's Manual
“Damage evolution and element removal for fiber-reinforced composites,” Section 21.3.3 of the Abaqus Analysis User's Manual
“Damage evolution for ductile materials in low-cycle fatigue,” Section 21.4.3 of the Abaqus Analysis User's Manual
“Defining the constitutive response of cohesive elements using a traction-separation description,” Section 29.5.6 of the Abaqus Analysis User's Manual
“Surface-based cohesive behavior,” Section 33.1.10 of the Abaqus Analysis User's Manual
“Modeling discontinuities as an enriched feature using the extended finite element method,” Section 10.6.1 of the Abaqus Analysis User's Manual
Required parameter:
TYPE
Set TYPE=DISPLACEMENT to define the evolution of damage as a function of the total (for elastic materials in cohesive elements) or the plastic (for bulk elastic-plastic materials) displacement after the initiation of damage.
Set TYPE=ENERGY to define the evolution of damage in terms of the energy required for failure (fracture energy) after the initiation of damage.
Set TYPE=HYSTERESIS ENERGY to define the evolution of damage in terms of the inelastic hysteresis energy dissipated per stabilized cycle after the initiation of damage in a low-cycle fatigue analysis.
Optional parameters:
DEGRADATION
Set DEGRADATION=MAXIMUM (default) to specify that the current damage evolution mechanism will interact with other damage evolution mechanisms in a maximum sense to determine the total damage from multiple mechanisms.
Set DEGRADATION=MULTIPLICATIVE to specify that the current damage evolution mechanism will interact with other damage evolution mechanisms using the same value of the DEGRADATION parameter in a multiplicative manner to determine the total damage from multiple mechanisms.
DEPENDENCIES
Set this parameter equal to the number of field variables included in the definition of damage evolution. If this parameter is omitted, it is assumed that properties defining the evolution of damage are constant or depend only on temperature. See “Specifying field variable dependence” in “Material data definition,” Section 18.1.2 of the Abaqus Analysis User's Manual, for more information.
MIXED MODE BEHAVIOR
This parameter is meaningful only when the *DAMAGE EVOLUTION option is used to define the evolution of damage for materials associated with cohesive elements or for surface-based cohesive behavior. If this parameter is omitted, Abaqus assumes that the damage evolution behavior is mode independent.
Set MIXED MODE BEHAVIOR=TABULAR to specify the fracture energy or displacement (total or plastic) directly as a function of the shear-normal mode mix for cohesive elements. This method must be used to specify the mixed-mode behavior for cohesive elements when TYPE=DISPLACEMENT.
Set MIXED MODE BEHAVIOR=POWER LAW to specify the fracture energy as a function of the mode mix by means of a power law mixed mode fracture criterion.
Set MIXED MODE BEHAVIOR=BK to specify the fracture energy as a function of the mode mix by means of the Benzeggagh-Kenane mixed mode fracture criterion.
MODE MIX RATIO
This parameter can be used only in conjunction with the MIXED MODE BEHAVIOR parameter. The specification of the damage evolution properties (fracture energy or effective displacement) as a function of the mode mix depends on the value of this parameter. See “Defining damage evolution data as a tabular function of mode mix” in “Defining the constitutive response of cohesive elements using a traction-separation description,” Section 29.5.6 of the Abaqus Analysis User's Manual, or “Defining damage evolution data as a tabular function of mode mix” in “Surface-based cohesive behavior,” Section 33.1.10 of the Abaqus Analysis User's Manual, for further details.
Set MODE MIX RATIO=ENERGY (default) to define the mode mix in terms of a ratio of fracture energy in the different modes. This definition must be used when MIXED MODE BEHAVIOR=POWER LAW or BK.
Set MODE MIX RATIO=TRACTION to define the mode mix in terms of a ratio of traction components.
POWER
This parameter can be used only in conjunction with MIXED MODE BEHAVIOR=POWER LAW or MIXED MODE BEHAVIOR=BK.
Set this parameter equal to the exponent in the power law or the Benzeggagh-Kenane criterion that defines the variation of fracture energy with mode mix for cohesive elements.
SOFTENING
Set SOFTENING=LINEAR (default) to specify a linear softening stress-strain response (after the initiation of damage) for linear elastic materials or a linear evolution of the damage variable with deformation (after the initiation of damage) for elastic-plastic materials.
Set SOFTENING=EXPONENTIAL to specify an exponential softening stress-strain response (after the initiation of damage) for linear elastic materials or an exponential evolution of the damage variable with deformation (after the initiation of damage) for elastic-plastic materials.
Set SOFTENING=TABULAR to specify the evolution of the damage variable with deformation (after the initiation of damage) in tabular form. SOFTENING=TABULAR can be used only in conjunction with TYPE=DISPLACEMENT.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=LINEAR without the MIXED MODE BEHAVIOR parameter:
First line:
Effective total or plastic displacement at failure, measured from the time of damage initiation.
Temperature, if temperature dependent.
First field variable.
Second field variable.
Etc., up to six field variables.
Subsequent lines (only needed if the DEPENDENCIES parameter has a value greater than six):
Seventh field variable.
Etc., up to eight field variables per line.
Repeat this set of data lines as often as necessary to define the total or the plastic displacement at failure as a function of temperature and other predefined field variables.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=LINEAR without the MIXED MODE BEHAVIOR parameter:
First line:
Fracture energy.
Repeat this set of data lines as often as necessary to define the fracture energy as a function of temperature and other predefined field variables.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=LINEAR, MIXED MODE BEHAVIOR=TABULAR:
First line:
Total displacement at failure, measured from the time of damage initiation.
Appropriate mode mix ratio.
Appropriate mode mix ratio (if relevant, for three-dimensional problems with anisotropic shear behavior).
Etc., up to four field variables.
Subsequent lines (only needed if the DEPENDENCIES parameter has a value greater than four):
Fifth field variable.
Repeat this set of data lines as often as necessary to define the total displacement at failure as a function of mode mix, temperature, and other predefined field variables.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=LINEAR, MIXED MODE BEHAVIOR=TABULAR:
First line:
Fracture energy.
Repeat this set of data lines as often as necessary to define the fracture energy as a function of mode mix, temperature, and other predefined field variables.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=EXPONENTIAL without the MIXED MODE BEHAVIOR parameter:
First line:
Exponential law parameter.
Etc., up to five field variables.
Subsequent lines (only needed if the DEPENDENCIES parameter has a value greater than five):
Sixth field variable.
Repeat this set of data lines as often as necessary to define the total or the plastic displacement at failure and the exponential law parameter as a function of temperature and other predefined field variables.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=EXPONENTIAL without the MIXED MODE BEHAVIOR parameter:
First line:
Fracture energy.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=EXPONENTIAL, MIXED MODE BEHAVIOR=TABULAR:
First line:
Third field variable.
Subsequent lines (only needed if the DEPENDENCIES parameter has a value greater than three):
Fourth field variable.
Repeat this set of data lines as often as necessary to define the total displacement at failure and the exponential law parameter as a function of mode mix, temperature, and other predefined field variables.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=EXPONENTIAL, MIXED MODE BEHAVIOR=TABULAR:
First line:
Fracture energy.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=TABULAR without the MIXED MODE BEHAVIOR parameter:
First line:
Damage variable.
Effective total or plastic displacement, measured from the time of damage initiation.
Repeat this set of data lines as often as necessary to define the damage variable as a function of the total or the plastic displacement, temperature, and other predefined field variables.
Data lines to specify damage evolution for TYPE=DISPLACEMENT, SOFTENING=TABULAR, MIXED MODE BEHAVIOR=TABULAR:
First line:
Damage variable.
Effective total displacement, measured from the time of damage initiation.
Repeat this set of data lines as often as necessary to define the damage variable as a function of the total displacement, mode mix, temperature, and other predefined field variables.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=LINEAR or EXPONENTIAL, MIXED MODE BEHAVIOR=POWER LAW or BK:
ture energy for failure in the first shear direction.
Shear mode fracture energy for failure in the second shear direction.
Data lines to specify damage evolution for TYPE=ENERGY, SOFTENING=LINEAR for the damage model for fiber-reinforced materials:
First line:
Fracture energy of the lamina in the longitudinal tensile direction.
Fracture energy of the lamina in the longitudinal compressive direction.
Fracture energy of the lamina in the transverse tensile direction.
Fracture energy of the lamina in the transverse compressive direction.
Repeat this set of data lines as often as necessary to define the dependence of fracture energies on temperature and other predefined field variables.
Data lines to specify damage evolution for TYPE=HYSTERESIS ENERGY in a low-cycle fatigue analysis:
First line:
Material constant . (Units of )
Material constant .
Etc., up to five field variables per line.
Repeat this set of data lines as often as necessary to define the dependence of material constants on temperature and other predefined field variables.
First line:
Normal mode fracture energy.
Shear mode frac
Спасибо, за выложенную документацию :rolleyes:
В принципе я уже разобрался сам, один непонятный момент - что такое field variables?
  • 3 года спустя...
 Здравствуйте. Я новичок в абакусе. Решаю задачу о ламинантном композите с внутренним расслоением (20 однонаправленных слоев, расслоение между 4 и 16 слоями). Образец подвергается сжатию до локальной потери устойчивости (local buckling) . Моделирую задачу c использованием VCCT в абакусе как трещину в условиях плоской деформации. Сжатие осуществляется посредством начального смещения (displacement control). К сожалению, программа абортится. Подскажите, пожалуйста, как улучшить в абакусе параметры сходимости.
