Converting files from SketchUp to SolidWorks
cecicenov
Hello,
I'm looking for solution to the following problem and I hope you can help me: I have a file extension of SketchUp (.skp) and I want to take the dimensions of the model in SolidWorks. Can I convert the file into an appropriate format? And what are the steps?
Thanks in advance!
You can. Do theese steps:
- export to OBJ file from SketcUp
- open SW and check in add-ins menu "ScanTo3D"
- open OBJ file from SW menu (in combobox select type which end to Mesh Files)
- follow the wizard
3 часа назад, cecicenov сказал:
Hello,
Thanks in advance!
It it?
Yes
59 минут назад, streamdown сказал:
- follow the wizard
Thanks!
Hi Tsvetomir,
You can also use STL or OBJ files from SketchUp in Geomagic Design X for measurement and building of surfaces/solids
and then export results (LiveTransfer(TM) with feature tree) in Solidworks...
PS
I almost forgot about the plugin Geomagic for Solidworks ))
Изменено пользователем GS
You can do this in two ways (listed above),
but using the method with geomagiс you can use cross-sections, as simple 2D sketches, plus (if you use geomagic not separately as a plugin) you have wizards for automating builds (sweeping, pipes, etc.) Geomagic (former Rapidform) has a separate topic, but here it is offtopic.
Solidworks with the plugin can also build a sketch by section but less quality :thumbdown:  and very slows down the work and sometimes crashes :wallbash: ((
You can also use the Materialise Magic for measuring coordinates of points and the assembly / disassembly of large stl files.
Yes, I will keep my files in 2D graphics Sketchup, but the image at an angle and then I will not be sure of the dimensions of the model. I have several restraining image SolidWorks.
I'm looking for this solution because of the attachment size is not correct.
The same result would be if transferred model in dwg format.
