Error. Помогите пожалуйста
Elena Rukavichko
Здравствуйте, у меня такая проблема. Я веду расчет в Abaqus, и он выдает мне такую ошибку:
  Abaqus/Explicit Analysis exited with an error - Please see the  status file for possible error messages if the file exists.
Job Job-6itog aborted due to errors
Объясните пожалуйста, в чем причина ошибки?
Посмотрите файл *.sta , что там написано.
А также откройте *.dat и *.msg  файле текстовым редактором и найдите там "error".
Я не понимаю, что он от меня хочет. Может подскажете пожалуйста.
Могу отправить вам файл *.sta
The double precision Abaqus/Package executable will be used in this analysis.
Abaqus/Explicit 6.14-4                           DATE 29-фев-2016  TIME 16:40:08
 PREPROCESSOR WARNING MESSAGES
***WARNING: There are 538 warning messages in the data (.dat) file.  Please
            check the data file for possible errors in the input file.
***WARNING: The nodes in node set WarnNodeCnsIntersectKinC are part of a
            kinematic contact surface definition as well as participate in a
            kinematic constraint (or distributing coupling). Nodes that
            participate in a kinematic constraint definition should not be
            used in a kinematic contact surface definition. If a
            degree-of-freedom participates in both types of constraints, the
            kinematic contact constraint will most often override the
            kinematic constraint. Abaqus/Explicit will not prevent the user
            from defining these conditions, but the results cannot be
            guaranteed. It is suggested that the penalty contact algorithm be
            used.
***WARNING: Each of the nodes listed below (and included in node set
            "WarnNodeBcIntersectKinCon") participates in a boundary condition
            definition (*BOUNDARY) as well as being part of a kinematic
            contact definition (*CONTACT PAIR, MECHANICAL CONSTRAINT =
            KINEMATIC). If a degree-of-freedom participates in both types of
            constraints, the boundary condition will override the kinematic
            contact constraint. In case of a conflict, it is suggested that
            the penalty contact algorithm be used instead.
Intersecting Nodes:
node: 50     instance: PART-1-1
node: 99     instance: PART-1-1
node: 148     instance: PART-1-1
node: 197     instance: PART-1-1
node: 246     instance: PART-1-1
node: 295     instance: PART-1-1
node: 344     instance: PART-1-1
node: 393     instance: PART-1-1
node: 442     instance: PART-1-1
node: 491     instance: PART-1-1
node: 540     instance: PART-1-1
node: 589     instance: PART-1-1
node: 638     instance: PART-1-1
node: 687     instance: PART-1-1
node: 736     instance: PART-1-1
node: 785     instance: PART-1-1
node: 834     instance: PART-1-1
node: 883     instance: PART-1-1
node: 932     instance: PART-1-1
node: 981     instance: PART-1-1
node: 1030     instance: PART-1-1
node: 1079     instance: PART-1-1
node: 1128     instance: PART-1-1
node: 1177     instance: PART-1-1
node: 1226     instance: PART-1-1
node: 1275     instance: PART-1-1
node: 1324     instance: PART-1-1
node: 1373     instance: PART-1-1
node: 1422     instance: PART-1-1
node: 1471     instance: PART-1-1
node: 1520     instance: PART-1-1
node: 1569     instance: PART-1-1
node: 1618     instance: PART-1-1
node: 1667     instance: PART-1-1
node: 1716     instance: PART-1-1
node: 1765     instance: PART-1-1
node: 1814     instance: PART-1-1
node: 1863     instance: PART-1-1
node: 1912     instance: PART-1-1
node: 1961     instance: PART-1-1
node: 2010     instance: PART-1-1
node: 2059     instance: PART-1-1
node: 2108     instance: PART-1-1
node: 2157     instance: PART-1-1
node: 2206     instance: PART-1-1
node: 2255     instance: PART-1-1
node: 2304     instance: PART-1-1
node: 2353     instance: PART-1-1
node: 2402     instance: PART-1-1
node: 2451     instance: PART-1-1
node: 2500     instance: PART-1-1
node: 2549     instance: PART-1-1
node: 2598     instance: PART-1-1
node: 2647     instance: PART-1-1
node: 2696     instance: PART-1-1
node: 2745     instance: PART-1-1
node: 2794     instance: PART-1-1
node: 2843     instance: PART-1-1
node: 2892     instance: PART-1-1
node: 2941     instance: PART-1-1
node: 2990     instance: PART-1-1
node: 3039     instance: PART-1-1
node: 3088     instance: PART-1-1
node: 3137     instance: PART-1-1
node: 3186     instance: PART-1-1
node: 3235     instance: PART-1-1
node: 3284     instance: PART-1-1
node: 3333     instance: PART-1-1
node: 3382     instance: PART-1-1
node: 3431     instance: PART-1-1
node: 3480     instance: PART-1-1
node: 3529     instance: PART-1-1
node: 3578     instance: PART-1-1
node: 3627     instance: PART-1-1
node: 3676     instance: PART-1-1
node: 3725     instance: PART-1-1
node: 3774     instance: PART-1-1
node: 3823     instance: PART-1-1
node: 3872     instance: PART-1-1
node: 3921     instance: PART-1-1
node: 3970     instance: PART-1-1
node: 4019     instance: PART-1-1
node: 4068     instance: PART-1-1
node: 4117     instance: PART-1-1
node: 4166     instance: PART-1-1
node: 4215     instance: PART-1-1
node: 4264     instance: PART-1-1
node: 4313     instance: PART-1-1
node: 4362     instance: PART-1-1
node: 4411     instance: PART-1-1
node: 4460     instance: PART-1-1
node: 4509     instance: PART-1-1
node: 4558     instance: PART-1-1
node: 4607     instance: PART-1-1
node: 4656     instance: PART-1-1
node: 4705     instance: PART-1-1
node: 4754     instance: PART-1-1
node: 4803     instance: PART-1-1
node: 4852     instance: PART-1-1
node: 4901     instance: PART-1-1
node: 4950     instance: PART-1-1
node: 4999     instance: PART-1-1
node: 5048     instance: PART-1-1
node: 5097     instance: PART-1-1
node: 5146     instance: PART-1-1
node: 5195     instance: PART-1-1
node: 5244     instance: PART-1-1
node: 5293     instance: PART-1-1
node: 5342     instance: PART-1-1
node: 5391     instance: PART-1-1
node: 5440     instance: PART-1-1
node: 5489     instance: PART-1-1
node: 5538     instance: PART-1-1
node: 5587     instance: PART-1-1
node: 5636     instance: PART-1-1
node: 5685     instance: PART-1-1
node: 5734     instance: PART-1-1
node: 5783     instance: PART-1-1
node: 5832     instance: PART-1-1
node: 5881     instance: PART-1-1
node: 5930     instance: PART-1-1
node: 5979     instance: PART-1-1
node: 6028     instance: PART-1-1
node: 6077     instance: PART-1-1
node: 6126     instance: PART-1-1
node: 6175     instance: PART-1-1
node: 6224     instance: PART-1-1
node: 6273     instance: PART-1-1
node: 6322     instance: PART-1-1
node: 6371     instance: PART-1-1
node: 6420     instance: PART-1-1
node: 6469     instance: PART-1-1
node: 6518     instance: PART-1-1
node: 6567     instance: PART-1-1
node: 6616     instance: PART-1-1
node: 6665     instance: PART-1-1
node: 6714     instance: PART-1-1
node: 6763     instance: PART-1-1
node: 6812     instance: PART-1-1
node: 6861     instance: PART-1-1
node: 6910     instance: PART-1-1
node: 6959     instance: PART-1-1
node: 7008     instance: PART-1-1
node: 7057     instance: PART-1-1
node: 7106     instance: PART-1-1
node: 7155     instance: PART-1-1
node: 7204     instance: PART-1-1
node: 7253     instance: PART-1-1
node: 7302     instance: PART-1-1
node: 7351     instance: PART-1-1
node: 7400     instance: PART-1-1
node: 7449     instance: PART-1-1
node: 7498     instance: PART-1-1
node: 7547     instance: PART-1-1
node: 7596     instance: PART-1-1
node: 7645     instance: PART-1-1
node: 7694     instance: PART-1-1
node: 7743     instance: PART-1-1
node: 7792     instance: PART-1-1
node: 7841     instance: PART-1-1
node: 7890     instance: PART-1-1
node: 7939     instance: PART-1-1
node: 7988     instance: PART-1-1
node: 8037     instance: PART-1-1
node: 8086     instance: PART-1-1
node: 8135     instance: PART-1-1
node: 8184     instance: PART-1-1
node: 8233     instance: PART-1-1
node: 8282     instance: PART-1-1
node: 8331     instance: PART-1-1
node: 8380     instance: PART-1-1
node: 8429     instance: PART-1-1
node: 8478     instance: PART-1-1
node: 8527     instance: PART-1-1
node: 8576     instance: PART-1-1
node: 8625     instance: PART-1-1
node: 8674     instance: PART-1-1
node: 8723     instance: PART-1-1
node: 8772     instance: PART-1-1
node: 8821     instance: PART-1-1
node: 8870     instance: PART-1-1
node: 8919     instance: PART-1-1
node: 8968     instance: PART-1-1
node: 9017     instance: PART-1-1
node: 9066     instance: PART-1-1
node: 9115     instance: PART-1-1
node: 9164     instance: PART-1-1
node: 9213     instance: PART-1-1
node: 9262     instance: PART-1-1
node: 9311     instance: PART-1-1
node: 9360     instance: PART-1-1
node: 9409     instance: PART-1-1
node: 9458     instance: PART-1-1
node: 9507     instance: PART-1-1
node: 9556     instance: PART-1-1
node: 9605     instance: PART-1-1
node: 9654     instance: PART-1-1
node: 9703     instance: PART-1-1
node: 9752     instance: PART-1-1
node: 9801     instance: PART-1-1
node: 9850     instance: PART-1-1
node: 9899     instance: PART-1-1
node: 9948     instance: PART-1-1
node: 9997     instance: PART-1-1
node: 10046     instance: PART-1-1
node: 10095     instance: PART-1-1
node: 10144     instance: PART-1-1
node: 10193     instance: PART-1-1
node: 10242     instance: PART-1-1
node: 10291     instance: PART-1-1
node: 10340     instance: PART-1-1
node: 10389     instance: PART-1-1
node: 10438     instance: PART-1-1
node: 10487     instance: PART-1-1
node: 10536     instance: PART-1-1
node: 10585     instance: PART-1-1
node: 10634     instance: PART-1-1
node: 10683     instance: PART-1-1
node: 10732     instance: PART-1-1
node: 10781     instance: PART-1-1
node: 10830     instance: PART-1-1
node: 10879     instance: PART-1-1
node: 10928     instance: PART-1-1
node: 10977     instance: PART-1-1
node: 11026     instance: PART-1-1
node: 11075     instance: PART-1-1
node: 11124     instance: PART-1-1
node: 11173     instance: PART-1-1
node: 11222     instance: PART-1-1
node: 11271     instance: PART-1-1
node: 11320     instance: PART-1-1
node: 11369     instance: PART-1-1
node: 11418     instance: PART-1-1
node: 11467     instance: PART-1-1
node: 11516     instance: PART-1-1
node: 11565     instance: PART-1-1
node: 11614     instance: PART-1-1
node: 11663     instance: PART-1-1
node: 11712     instance: PART-1-1
node: 11761     instance: PART-1-1
node: 11810     instance: PART-1-1
node: 11859     instance: PART-1-1
node: 11908     instance: PART-1-1
node: 11957     instance: PART-1-1
node: 12006     instance: PART-1-1
node: 12055     instance: PART-1-1
node: 12104     instance: PART-1-1
node: 12153     instance: PART-1-1
node: 12202     instance: PART-1-1
node: 12251     instance: PART-1-1
node: 12300     instance: PART-1-1
node: 12349     instance: PART-1-1
node: 12398     instance: PART-1-1
node: 12447     instance: PART-1-1
node: 12496     instance: PART-1-1
node: 12545     instance: PART-1-1
node: 12594     instance: PART-1-1
node: 12643     instance: PART-1-1
node: 12692     instance: PART-1-1
node: 12741     instance: PART-1-1
node: 12790     instance: PART-1-1
node: 12839     instance: PART-1-1
node: 12888     instance: PART-1-1
node: 12937     instance: PART-1-1
node: 12986     instance: PART-1-1
node: 13035     instance: PART-1-1
node: 13084     instance: PART-1-1
node: 13133     instance: PART-1-1
node: 13182     instance: PART-1-1
node: 13231     instance: PART-1-1
node: 13280     instance: PART-1-1
node: 13329     instance: PART-1-1
node: 13378     instance: PART-1-1
node: 13427     instance: PART-1-1
node: 13476     instance: PART-1-1
node: 13525     instance: PART-1-1
node: 13574     instance: PART-1-1
node: 13623     instance: PART-1-1
node: 13672     instance: PART-1-1
node: 13721     instance: PART-1-1
node: 13770     instance: PART-1-1
node: 13819     instance: PART-1-1
node: 13868     instance: PART-1-1
node: 13917     instance: PART-1-1
node: 13966     instance: PART-1-1
node: 14015     instance: PART-1-1
node: 14064     instance: PART-1-1
node: 14113     instance: PART-1-1
node: 14162     instance: PART-1-1
node: 14211     instance: PART-1-1
node: 14260     instance: PART-1-1
node: 14309     instance: PART-1-1
node: 14358     instance: PART-1-1
node: 14407     instance: PART-1-1
node: 14456     instance: PART-1-1
node: 14505     instance: PART-1-1
node: 14554     instance: PART-1-1
node: 14603     instance: PART-1-1
node: 14652     instance: PART-1-1
node: 14701     instance: PART-1-1
node: 14750     instance: PART-1-1
node: 14799     instance: PART-1-1
node: 14848     instance: PART-1-1
node: 14897     instance: PART-1-1
node: 14946     instance: PART-1-1
node: 14995     instance: PART-1-1
node: 15044     instance: PART-1-1
node: 15093     instance: PART-1-1
node: 15142     instance: PART-1-1
node: 15191     instance: PART-1-1
node: 15240     instance: PART-1-1
node: 15289     instance: PART-1-1
node: 15338     instance: PART-1-1
node: 15387     instance: PART-1-1
            used.
Intersecting Nodes:
 MODEL INFORMATION (IN GLOBAL X-Y COORDINATES)
   Total mass in model = 2.06742E-04
   Center of mass of model = ( 1.411433E-15,-5.891107E-17, 0.000000E+00)
    Moments of Inertia :
                 About Center of Mass              About Origin
      I(XX)          2.908757E-01                  2.908757E-01
      I(YY)          2.908757E-01                  2.908757E-01
      I(ZZ)          5.816473E-01                  5.816473E-01
      I(XY)          9.505404E-18                  9.505404E-18
      I(YZ)          0.000000E+00                  0.000000E+00
      I(ZX)          0.000000E+00                  0.000000E+00
 STABLE TIME INCREMENT INFORMATION
  The stable time increment estimate for each element is based on
  linearization about the initial state.
   Initial time increment = 4.32925E-09
   Statistics for all elements:
      Mean = 1.19616E-07
      Standard deviation = 6.55270E-08
   Most critical elements:
    Element number   Rank    Time increment   Increment ratio
    (Instance name)
       15180          1       4.329252E-09      1.000000E+00
    PART-1-1
       15279          2       4.329252E-09      1.000000E+00
    PART-1-1
       15122          3       4.329252E-09      1.000000E+00
    PART-1-1
       15337          4       4.329252E-09      1.000000E+00
    PART-1-1
       15119          5       4.329253E-09      9.999998E-01
    PART-1-1
       15340          6       4.329253E-09      9.999998E-01
    PART-1-1
       15183          7       4.329253E-09      9.999998E-01
    PART-1-1
       15276          8       4.329253E-09      9.999998E-01
    PART-1-1
       15106          9       4.329254E-09      9.999996E-01
    PART-1-1
       15353         10       4.329254E-09      9.999996E-01
    PART-1-1
  Instance name for the most critical element will be printed if the critical
  element changes or at the beginning of a new page.
  INFORMATION REGARDING INITIAL CONTACT PAIR OVERCLOSURES THAT Abaqus/Explicit
  WILL ATTEMPT TO RESOLVE WITH STRAIN-FREE ADJUSTMENTS TO POSITIONS OF
  DEFORMABLE
  SLAVE NODES Step   1
  Maximum overclosure between surface ASSEMBLY_M_SURF-17 and surface
  ASSEMBLY_S_SURF-17 is 0.71184.
Maximum adjustment for initial overclosure is: 0.71184 at node 35 of instance PART-1-1.
***NOTE: You can view the deformed configuration due to the resolution of
         initial overclosures.  In increment 0, draw the deformed shape or
         draw a symbol plot of vector displacements.
More detailed overclosure adjustment information can be found in the message file.
***WARNING: For contact surface ASSEMBLY_S_SURF-17, some facets are thicker
            than 0.6 times an edge or diagonal length of the facet (for
            example, the thickness is 48.9761      times the element size for
            the facet on parent element PART-1-1.5137). This may lead to
            unstable contact involving the bull-nose extension on the surface
            perimeter, which could be avoided by using the MAXRATIO parameter
            on *SURFACE.
***WARNING: Jumps in displacement boundary conditions have been detected at
            the beginning of step 1.  The maximum jump is 55.756 at node 242
            of instance PART-4-1.  The node set "WarnNodeDispBCJump" has been
            written to the database file.  Check the .msg file for more
            detailed information.
***NOTE: Displacement boundary conditions with prescribed jumps will be
         enforced as defined, minus the value of the jump. The jumps might be
         caused by:
            1) A discontinuous *BOUNDARY, TYPE=DISPLACEMENT definition.
            2) Initial contact adjustments at the beginning of the first
               step.
            3) Locating the rigid body reference node with the POSITION=CENTER
               OF MASS parameter.
            4) Use of an amplitude curve to prescribe the boundary conditions
               in an analysis with a large number of increments; precision
               error may cause a small drift from the prescribed displacement.
Abaqus/Explicit 6.14-4                           DATE 29-фев-2016  TIME 16:40:31
The double precision Abaqus/Explicit executable will be used in this analysis.
 SOLUTION PROGRESS
 STEP 1  ORIGIN 0.0000
  Total memory used for step 1 is approximately 119.5 megabytes.
  Element by element stable time estimation algorithm will be used.
  Scaling factor:  1.0000
  Variable mass scaling factor at zero increment: 1.0000
              STEP     TOTAL       CPU      STABLE    CRITICAL    KINETIC      TOTAL
INCREMENT     TIME      TIME      TIME   INCREMENT     ELEMENT     ENERGY     ENERGY
        0  0.000E+00 0.000E+00  00:00:02 4.329E-09       15279  0.000E+00  0.000E+00
INSTANCE WITH CRITICAL ELEMENT: PART-1-1
ODB Field Frame Number      0 of     20 requested intervals at increment zero.
***WARNING: THE ANALYSIS NEEDS AN EXTREMELY LARGE NUMBER OF INCREMENTS (MORE
            THAN 2,000,000). CHECK THE PROPERTIES OF THE MOST CRITICAL
            ELEMENTS AND THE DATA FILE FOR WARNING MESSAGES.
     2070  8.962E-06 8.962E-06  00:02:00 4.329E-09       15080  6.385E+05 -2.130E+04
     3599  1.558E-05 1.558E-05  00:04:00 4.329E-09       15183  8.699E+05 -1.062E+05
     5779  2.502E-05 2.502E-05  00:06:00 4.329E-09       15073  1.067E+06 -1.363E+05
     7928  3.432E-05 3.432E-05  00:08:00 4.329E-09       15379  1.264E+06 -2.374E+05
    10152  4.395E-05 4.395E-05  00:10:00 4.329E-09       15088  1.751E+06 -2.655E+05
    12407  5.371E-05 5.371E-05  00:12:00 4.328E-09       15088  1.559E+06 -3.855E+05
    14597  6.319E-05 6.319E-05  00:14:00 4.328E-09       15259  2.160E+06 -4.113E+05
    16701  7.229E-05 7.229E-05  00:16:00 4.328E-09       15260  1.792E+06 -5.023E+05
    18466  7.993E-05 7.993E-05  00:18:00 4.327E-09       15109  2.472E+06 -5.717E+05
    19701  8.528E-05 8.528E-05  00:20:00 4.330E-09       15299  2.300E+06 -6.276E+05
    20902  9.048E-05 9.048E-05  00:22:00 4.329E-09       15284  2.043E+06 -6.652E+05
    22098  9.566E-05 9.566E-05  00:24:00 4.331E-09       15233  2.616E+06 -6.922E+05
    23284  1.008E-04 1.008E-04  00:26:00 4.337E-09       15216  2.665E+06 -7.566E+05
    24447  1.058E-04 1.058E-04  00:28:00 4.340E-09       15220  2.329E+06 -7.776E+05
    25582  1.108E-04 1.108E-04  00:30:00 4.346E-09       15225  2.558E+06 -7.783E+05
    26803  1.161E-04 1.161E-04  00:32:00 4.376E-09       15219  3.017E+06 -8.223E+05
    27962  1.212E-04 1.212E-04  00:34:00 4.388E-09       15224  2.650E+06 -8.829E+05
    29053  1.260E-04 1.260E-04  00:36:00 4.423E-09       15223  2.659E+06 -8.686E+05
    30253  1.314E-04 1.314E-04  00:38:00 4.507E-09       15221  3.134E+06 -8.954E+05
    31351  1.363E-04 1.363E-04  00:40:00 4.462E-09       15242  3.064E+06 -9.189E+05
    32404  1.410E-04 1.410E-04  00:42:00 4.484E-09       15224  2.739E+06 -9.054E+05
    33455  1.457E-04 1.457E-04  00:44:00 4.535E-09       15215  3.089E+06 -8.989E+05
    34496  1.504E-04 1.504E-04  00:46:00 4.428E-09       15267  3.508E+06 -9.375E+05
    35537  1.550E-04 1.550E-04  00:48:00 4.479E-09       15250  3.167E+06 -9.706E+05
    36569  1.596E-04 1.596E-04  00:50:00 4.438E-09       15264  2.963E+06 -9.805E+05
    37585  1.642E-04 1.642E-04  00:52:00 4.347E-09       15298  3.505E+06 -9.951E+05
    38610  1.686E-04 1.686E-04  00:54:00 4.352E-09       15300  3.811E+06 -1.009E+06
    39643  1.732E-04 1.732E-04  00:56:00 4.431E-09       15275  3.464E+06 -9.980E+05
    40663  1.777E-04 1.777E-04  00:58:00 4.392E-09       15289  3.421E+06 -1.022E+06
    41669  1.821E-04 1.821E-04  01:00:00 4.517E-09       15294  3.982E+06 -1.044E+06
    42680  1.866E-04 1.866E-04  01:02:00 4.413E-09       15277  4.130E+06 -1.050E+06
    43685  1.910E-04 1.910E-04  01:04:00 4.398E-09       15284  3.778E+06 -1.101E+06
    44682  1.954E-04 1.954E-04  01:06:00 4.387E-09       15306  3.541E+06 -1.030E+06
    45698  1.999E-04 1.999E-04  01:08:00 4.423E-09       15154  3.318E+06 -9.821E+05
    46758  2.043E-04 2.043E-04  01:10:00 3.747E-09       10261  3.107E+06 -9.596E+05
    48079  2.098E-04 2.098E-04  01:12:00 4.477E-09       15329  2.986E+06 -8.430E+05
    49604  2.166E-04 2.166E-04  01:14:00 4.439E-09       15121  2.744E+06 -7.342E+05
    51153  2.236E-04 2.236E-04  01:16:00 4.516E-09       15160  2.619E+06 -6.213E+05
    52841  2.311E-04 2.311E-04  01:18:00 4.254E-09       11602  2.388E+06 -5.727E+05
    54548  2.379E-04 2.379E-04  01:20:00 4.278E-09       11602  2.286E+06 -4.769E+05
    56247  2.432E-04 2.432E-04  01:22:00 2.390E-09       11602  2.169E+06 -3.798E+05
    57924  2.469E-04 2.469E-04  01:24:00 2.683E-09       11602  2.124E+06 -3.662E+05
    59609  2.534E-04 2.534E-04  01:26:00 4.015E-09       11748  2.094E+06 -2.647E+05
    61244  2.594E-04 2.594E-04  01:28:00 3.160E-09       13715  1.993E+06 -1.615E+05
    62651  2.635E-04 2.635E-04  01:30:00 2.706E-09       13715  1.917E+06 -1.176E+05
    64121  2.673E-04 2.673E-04  01:32:00 2.456E-09       13715  1.889E+06 -5.015E+04
    65383  2.703E-04 2.703E-04  01:34:00 2.352E-09       13715  1.825E+06 -3.342E+04
    66794  2.736E-04 2.736E-04  01:36:00 2.277E-09       13715  1.830E+06 -1.031E+04
    68177  2.767E-04 2.767E-04  01:38:00 2.236E-09       13715  1.776E+06  6.401E+04
    69562  2.798E-04 2.798E-04  01:40:00 2.204E-09       13715  1.826E+06  1.121E+05
    70933  2.828E-04 2.828E-04  01:42:00 2.179E-09       13715  1.787E+06  1.235E+05
    72333  2.858E-04 2.858E-04  01:44:00 2.153E-09       13715  1.740E+06  1.455E+05
    73727  2.888E-04 2.888E-04  01:46:00 2.128E-09       13715  1.742E+06  1.572E+05
    75092  2.917E-04 2.917E-04  01:48:00 2.113E-09       13715  1.720E+06  2.073E+05
    76708  2.951E-04 2.951E-04  01:50:00 2.155E-09       13715  1.706E+06  2.363E+05
    78338  2.988E-04 2.988E-04  01:52:00 2.342E-09       13715  1.702E+06  3.200E+05
    80033  3.027E-04 3.027E-04  01:54:00 2.330E-09       13715  1.708E+06  3.488E+05
    81822  3.069E-04 3.069E-04  01:56:00 2.300E-09       13715  1.658E+06  4.356E+05
    83633  3.105E-04 3.105E-04  01:58:00 2.195E-09        4020  1.626E+06  4.804E+05
    85433  3.146E-04 3.146E-04  02:00:00 2.293E-09       13715  1.581E+06  5.791E+05
    87223  3.187E-04 3.187E-04  02:02:00 2.292E-09       13715  1.540E+06  6.308E+05
    89057  3.229E-04 3.229E-04  02:04:00 2.287E-09       13715  1.587E+06  6.437E+05
    90868  3.270E-04 3.270E-04  02:06:00 2.295E-09       13715  1.584E+06  7.563E+05
    92687  3.312E-04 3.312E-04  02:08:00 2.350E-09       13715  1.585E+06  7.894E+05
    94489  3.356E-04 3.356E-04  02:10:00 2.516E-09       13715  1.632E+06  8.751E+05
    95973  3.394E-04 3.394E-04  02:12:00 2.624E-09       13715  1.639E+06  9.732E+05
    97159  3.426E-04 3.426E-04  02:14:00 2.730E-09       13715  1.634E+06  9.741E+05
    98877  3.474E-04 3.474E-04  02:16:00 2.806E-09       13715  1.650E+06  1.089E+06
   100613  3.523E-04 3.523E-04  02:18:00 2.830E-09       13715  1.597E+06  1.327E+06
   102428  3.561E-04 3.561E-04  02:20:00 2.149E-09       11602  1.611E+06  1.340E+06
   104308  3.613E-04 3.613E-04  02:22:00 3.191E-09       13715  1.586E+06  1.419E+06
   106196  3.677E-04 3.677E-04  02:24:00 3.583E-09       13715  1.671E+06  1.542E+06
   108063  3.746E-04 3.746E-04  02:26:00 3.653E-09        8821  1.681E+06  1.614E+06
***WARNING:  Step  1, Increment109844:    4 material point(s) failed to
            converge in the material constitutive routines.
***ERROR: Excessive rotation of node number PART-1-1.5671
***ERROR: Excessive rotation of node number PART-1-1.5672
***ERROR: Excessive rotation of node number PART-1-1.5720
***ERROR: Excessive rotation of node number PART-1-1.5721
***ERROR: Excessive rotation increments at 4 nodes
***ERROR: The fatal error will generate a new field output in the last
          increment. All variables applicable to the current procedure and
          material type(s) will be written to the output database.
   109846  3.800E-04 3.800E-04  02:27:55 1.000E-14        5555  4.388E+11  3.620E+14
Restart Number  1 at 3.79958E-04
A special ODB Field Frame with all relevant variables was written at     3.800E-04
SUMMARY FOR STEP 1
   The maximum number of points that failed to converge in the material
  constitutive routines was       4 in increment  109844.
  The material constitutive routines failed to converge in 2 increments.
  THE ANALYSIS HAS NOT BEEN COMPLETED
Программа Вам сообщает, про недопустимо большую ротацию узла 5671 в детали PART1.1
1. посмотрите, что  там в модели с ним, может визуально и определите.
2. проверьте на напутали Вы единицы измерения, когда заполняли карту материала.
3. Посмотрите что стоит в *.dat файле, какая там ошибка.
Просто до этого программа считалась, сейчас я ставлю ее на расчет но выдается ошибка. Можно ли отправить вам программу может вы посмотрите, если вам не сложно?
Если раньше считалось, то нужно смотреть что Вы поменяли?
Там ошибка.  Выкладывайте сюда, если не секрет, дайте и другим пользователям Вам помочь.
В том то и дело, что ничего не изменяла, просто поставила заново на расчет.
 Скажите пожалуйста, а как тут отправлять файлы?
В том то и дело, что ничего не изменяла, просто поставила заново на расчет. Скажите пожалуйста, а как тут отправлять файлы?
так не бывает. Что то поменялось, версия программы или комп.
Архивируете файл в ZIP к примеру и загрузите, через "расширенную форму"
Вот ссылка, https://cloud.mail.ru/public/BELa/9ycWD3c8u
У меня нет возможности там скачивать. Сожалею.
А где загрузить через расширенную форму, я просто не вижу? какой значок?
Вы когда на сообщение отвечаете, то нажимаете кнопку "отправить", рядом есть кнопка " расширенная форма", нажимаете туда и там есть "Прикрепить файлы" .
Выберите файл и жмите "загрузить".
Изменено пользователем Vova
Вы когда на сообщение отвечаете, то нажимаете кнопку "ответить", рядом есть кнопка " расширенная форма", нажимаете туда и там есть "Прикрепить файлы" .
SPIF.rar
@Elena Rukavichko, вы переделываете чью-то чужую задачу? Какова цель расчета?
PS
Интересные амплитуды:
PPS переделал амплитуды, погасил второй шаг и constraint equation = все считается.
PS
Задача моя,мне необходимо для научной работы промоделировать получение полусферы. Цель: получение равнотолщинной полусферы.
Подскажите пожалуйста как вы смогли вывести в Abaqus графики амплитуд?
И что вы исправили в них для получения расчета, и скажите пожалуйста, что значит погасил второй шаг?
Piden, у вас вся посчиталась задача? просто я когда ставлю на расчет он тоже сначала считает, но потом ошибку выдает
Мне нужно конвертировать модель , ГУ не понял, зачем два STEP , тоже не понял.   В моделе много не нужной информации, типа три контакта, хотя вроде как он один.
Просто я делала по видео уроку, так как никто больше помочь мне в этом не смог. Видимо поэтому там много всего лишнего добавила.
А  конвертировать?  То есть надо записать в другом формате?
Да, я использую сторонний препроцессор, он не всегда "берет" всю информацию из *.inp файла. Piden тут помощник всяко эффективней будет для Вас.
Я оставил только перемещение пуансона по Z, на 4 мм. Так что технически у меня уже другая задача)
Графики рисовал в матем. пакете. Можно в экселе такое изобразить. Просто абакус не рисует 3d графики. Ну, или я не знаю, как это сделать)
Лучше тогда дали бы уже ссылку на видео-урок, раз по нему все сделали.
Если вы оставили только перемещение по z, то как возможно получить полусферу?
Ссылка на видеоурок
