Update failed for the Solution component in System Coupling
supwgeneral
Здравствуйте
1. Я новичок в ANSYS
2. Решаю задачу двусторонней связи деформации ленты от давления жидкости (воды)
3. Основываюсь на данном видеоуроке http://www.cadfem-cis.ru/service/video/single/artcl/cadfem-vl1217/
4. С ошибкой в прошлый раз мне помогли! Спасибо! http://cccp3d.ru/topic/76918-%D0%BF%D1%80%D0%BE%D0%B1%D0%BB%D0%B5%D0%BC%D0%B0-%D1%81-mesh/
5. При старте расчета появляется следующая ошибка:
  1. Error!    Update failed for the Solution component in System Coupling.  The coupled update for System, Transient Structural, threw an exception.    D3    06.12.2015 19:02:03
Error!    System coupling run completed with errors.  System Coupling Service reported: System coupling run aborted by user or due to fatal error:   Please do not save the project if you would like to recover to the last saved state.        06.12.2015 19:00:38
Error!    A solver failure occurred during the run in the Transient Structural system        06.12.2015 19:00:34
Error!    An error occurred inside the SOLVER module: general error.        06.12.2015 19:00:30
Error!    An unexpected error has occurred: The given key was not present in the dictionary.        06.12.2015 19:00:06
6. В   Transient Structural написано следующе:
*** FATAL ***                           CP =       0.922   TIME= 19:00:29
 MAPDL is unable to connect to the system coupling service on
 telecommand.telemetry.microsoft.com through port 49750.  Please check
 ANSYS execution options -schost and -scport for a System Coupling
 analysis and ensure that the host name and the port number are
 correct.
 *** FATAL ***
 Random read error on unit=     16 possible corrupt or missing file.
 I/O status error=      0
 The above error is non-recoverable by ANSYS
 ANSYS run terminated by the indicated error
Почистил файл HOSTS и расчет пошел
Но возникла новая ошибка:
  1. Error! Update failed for the Solution component in System Coupling.  The coupled update for System, Fluid Flow (Fluent), threw an exception. D3 06.12.2015 19:44:34
  2. Error! Update of the Solution component in System Coupling failed: The coupled update for System, Fluid Flow (Fluent), threw an exception. D3 06.12.2015 19:44:31
  3. Error! A solver failure occurred during the run in the Fluid Flow (Fluent) system 06.12.2015 19:44:27
  4. Error! System coupling run completed with errors.  Transient Structural (Solution 1) reported: Element 3870 (type = 1, SOLID186) (and maybe other elements) has become highly distorted.  Excessive distortion of elements is usually a symptom indicating the need for corrective action elsewhere. Please do not save the project if you would like to recover to the last saved state. 06.12.2015 19:44:21
Здравствуйте
1. Я новичок в хирургии
2. Делаю операцию по аортокоронарному шунтированию
3. Основываюсь на данном видеоуроке h_ttps://www.youtube.com/watch?v=ptc7GpkPXbU
4. С ошибкой в прошлый раз мне помогли! Спасибо! h_ttps://www.youtube.com/watch?v=nQn1Qgj6g7Y
5. При операции пациенты постоянно умирают. Прямо надоело уже! Подскажите, как быть!!
Намек понятен?
ЗЫ
Сообщение с формой элементов = сетка в прочностном анализе деформируется настолько сильно, что продолжать расчет невозможно.
Изменено пользователем piden
Здравствуйте
Намек понятен?
ЗЫ
Намек понятен.
Но разве не то он и форум? Вам спасибо за ответ.
Но дело в том что большие деформации здесь и должны происходить. (файл проекта https://drive.google.com/file/d/0B56J7fVxIgbyZ0RRWENRRmxmZnc/ )
Намек понятен.
Судя по
вы не поняли ни-че-го...
Кстати, не сочли бы за труд поделиться вашими взглядами по поводу "для чего нужен форум"? А то вот такой вопрос меня тоже занимает.
форум ведь для того и создан, чтобы делиться мнениями и помощью более опытных участников
:wink:
    • nein
      Здравствуйте. Станок MIKRON UM 900 S TNC426. Если в программе много коротких перемещений, станок вибрирует и качество поверхности - плохое. Менял стратегию обработки - при более-менее длинных отрезках ситуация улучшается. Думаю, что почему-то станок делает остановки между кадрами.  Подскажите, пожалуйста, где в параметрах это можно проверить и исправить. Спасибо.
    • advocut
      @hlibhlib спасибо, стало понятнее. Наконец-то источник по операции Stock Model.
      доктор вам надо лучше анализировать. если вы отключите линейку то у вас останется только датчик мотора и никакие люфты не будут оказывать влияние на на значение позиции считанное с датчика мотора поэтому для проверки и люфтов и то что это не привод резонирует просто отключают линейку и оставляют semiclosed loop. tckb dfv yflj сохранить fullclosed loop и исключить резонанс тогда вы включаете функцию dual position feedback и задаете значение тау . в общем тренируйтесь в понимании того что очевидно но не признается вами под разными предлогами что затягивает дискуссию и отнимает время.   в какой плоскости повернут стол те оси и нужно компенсировать у Виктора это плоскость zy как по вашему компенсации устраняют неперпендикулярность осей именно их взаимным перемещением. яркий пример это токарный станок с осью y где она конструктивно не перпендикулярна но при обработке она перемещается так что перпендикулярность соблюдается.
    • Nikollay
      К примеру печатная плата с кучей покупных элементов информации о весе которых нет. Подгонять плотность под каждую плату плохое решение.
    • sloter
      Например, наложить взаимосвязь Концентричность между центром строящегося отверстия и кромкой имеющегося в другой детали.
      Правильно, терпи. Гляди дома не так вонять будет.
      Бывает, что залипает один концевой и получается, что в одном из положений оба концевика сработавшие Вы проверили, что именно один сработал, а второй отжат? Вообще конечно, ладдер ответ даст, чего не хватает  Вот пример как искать катушку аварии в ладдере
      Чот не понятно кто куда подъезжает ?
    • OlgaKubrik
      Спасибо огромное! Помогло! Нюансы, о которых в комментариях ниже, пока не понятны, не очевидны, я ни разу пока не пользовалась этими инструментами, но все равно спасибо всем за отклик
    • Metal_Cutter
      "Магазин втянут", концевики у магазина проверяли, в порядке.
