Вывод описания в шапку программы
Как бы научиться средствами PowerMill выводить в шапку программы описание минимальной и максимальной высот хода фрезы??
Ну как научиться...доки читать надо, посты сочинять, пробовать их)).
Например в доках есть все, что вам нужно:
 Variable List Continued (3)
Variable Name
Use and Function
LastTool
Last Load Tool number ( Last tool in the series to be used )
LoopCounter
Returns the number of passes in the " repeat " loop function
MaxX ; MaxY ; MaxZ
The overall Maximum limit values of travel for X, Y and Z
usually used in comments at tape start, or for DUCT block size )
MinX : MinY : MinZ
The overall Minimum limit values of travel for X, Y and Z
Minutes
Time of Day Minutes
MinorWord
Values from CLdata associated with a particular function ( Rarely used now )
ModelX : ModelY :
ModelZ
Give access to the coordinates in the model system in all circumstances.  These were introduced for a specific operational debug and as such will not normally be of general use
Month
The current month ( numerical  e.g.  04 for April  )
MoveComponentType
This is still under development
MoveMinorType
MoveType
This checks the type of tool path movement ( MoveType = 11 connection moves ; MoveType = 10  5axis moves )  For full list seeWhat’s New
NextAngle
The next angle defined
NextTool
The tool number of the next load tool to be used ( Used for preselection )
NextToolPath
The next tool path to the current one.
NumberPecks
Number of pecks in a drilling cycle
NumberToolPaths
Returns the number of toolpaths in the CLdata file ( used in " repeat " function )
NumberTools
Returns the number of tools in the CLdata file ( used in " repeat " function )
OldX ; OldY ; OldZ ;
OldAz ; OldEl
The last positional axis move
OptionFileName
This should be used in conjunction with DPversion as a verification that the correct Option has been used to produce the NC output.
OutputWorkPlaneName
The PowerMill NC program Output WorkPlane
PartID
part identification string. This may be obtained from the DUCT PARTNO cldata record, PowerMILL Part Name, the configuration file, or prompted for at run time ( Except prompts are ignored if posted via PowerMILL, or will cause PowerMill to hang )
PartID[ 5 ]
This is similar to above, but has the added flexibility to select the starting point in the Part Identification string via the [ value ].    In the example the 5th character in the Part Name will be the start point, and the number of characters output will be limited by the field width of the carrier word.  ( ID PartID[5] )
PeckDepth
Drilling cycle peck depth ( Incremental )
Pitch
Returns the Pitch setting in PowerMill Tap Cycles
Plunging
Check for Plunge move.
Т.е. все-таки одним повермилом не обойдешься, нужно постпроцессор править. Понятно. Благодарю
    • eljer0n
    • mrVladimir
      а как вы taxid фирмы нашли?
      с него родимого
    • Grundick
    • eljer0n
