Вопрос
Здравствуйте подскажите где искать делаю УП в Powermill на 3 оси 3D выборка . И у меня начинают двигателя шаги пропускать. А в арткаме все нормально работает.
:0001
N10( NC FILE : ????? ????????? R3 ????? 1-1???? fanyk1 )
N20( DATE : 31.05.13 & TIME - 14:30:50 )
N30( PMPost VERSION : 6.2.2327.0 )
N40( MACHINE TOOL : --- & MODEL : --- )
N50( CONTROLLER : Fanuc & SERIES : --- )
N60( OPTION FILE : Fanuc )
N70( OUTPUT WP : 1 )
N80( OUTPUT UNITS : MM )
N90G91G28X0Y0Z0
N100G40G17G80G49
N110G0G90
N120( ================= )
N130( TOOLPATH : 1 )
N140( STRATEGY USED : Offset_area_clear )
N150( TOOLPATH WP : 1 )
N160( ================= )
N170( TOOL TYPE : TAPERSPHERICAL )
N180( TOOL NAME : R3 )
N190( TOOL DIA.: 6 & TIP RAD.: 3 & LENGTH : 30 )
N200T1M6
N210G54G90
N220S1500M3
N230M8
N240G0X0Y-249.961
N250G43Z49.763H1
N260X22.647Y-20.546
N270Z44.763
N280G1Z34.793F3000
N290Y-17.919
N300G3G17X21.842Y-17.114I-.805J-.805
N310G1X19.092Y-17.113
N320G3X18.77Y-17.767I-.805J-.805
N330G1X19.034Y-18.112
N340X19.394Y-18.602
N350X19.732Y-19.108
N360X20.835Y-20.837
N370X21.482Y-21.959
N380X22.025Y-23.134
N390X22.086Y-23.283
N400G3X22.648Y-23.172I-.805J-.805
N410G1X22.647Y-20.546
N420G0Z49.763
N430X1.698Y-98.218
N440Z44.763
N450G1Z34.793
N460X1.694
N470X1.691
N480X.968Y-98.221
N490X-.01Y-98.214
N500X-.987Y-98.183
N510X-1.697Y-98.152
N520G3X-2.469Y-98.891I-.805J-.805
N530G1X-2.468Y-253.501
N540G3X-1.699Y-254.248I-.805J-.805
N550G1X-1.011Y-254.227
N560X0Y-254.213
N570X1.012Y-254.228
N580X1.701Y-254.249
N590G3X2.469Y-253.502I-.805J-.805
N600G1X2.467Y-98.991
N610G3X1.698Y-98.218I-.805J-.805
N620G2X-.887Y-96.72I-.805J-.805
N630G3X-3.414Y-95.126I-.805J-.805
N640G1X-3.55Y-95.115
N650X-4.586Y-95.012
N660G3X-5.352Y-95.704I-.805J-.805
N670G1X-5.351Y-256.757
N680G3X-4.597Y-257.423I-.805J-.805
N690G1X-3.938Y-257.34
N700G2X2.185Y-257.17I-.805J-.805
N710G1X3.223Y-257.244
N720X3.934Y-257.306
N730X4.589Y-257.37
N740G3X5.353Y-256.677I-.805J-.805
N750G1X5.35Y-95.866
N760G3X4.585Y-95.16I-.805J-.805
N770G1X3.882Y-95.217
N780G2X-2.14Y-95.229I-.805J-.805
N790G1X-3.414Y-95.126
N800X-3.672Y-95.057
N810X-3.89Y-94.902
N820X-6.949Y-91.765
N830G3X-8.232Y-92.211I-.805J-.805
N840G1X-8.235Y-92.244
N850Y-92.277
N860Y-260.303
N870G3X-7.48Y-260.912I-.805J-.805
N880G1X-6.173Y-260.637
N890X-5.547Y-260.514
N900G2X2.333Y-260.069I-.805J-.805
N910G1X3.419Y-260.158
N920X5.175Y-260.355
N930X6.915Y-260.659
N940X7.494Y-260.778
N950G3X8.236Y-260.174I-.805J-.805
N960G1X8.234Y-92.472
N970G3X7.482Y-91.838I-.805J-.805
N980G1X6.815Y-91.951
N990G2X-2.008Y-92.35I-.805J-.805
N1000G1X-2.671Y-92.298
N1010X-4.767Y-92.082
N1020X-6.849Y-91.761
N1030X-7.482Y-91.647
N1040G3X-8.232Y-92.211I-.805J-.805
N1050G2X-9.734Y-94.443I-.805J-.805
N1060G3X-11.119Y-96.748I-.805J-.805
N1070G1X-11.118Y-264.294
N1080G3X-10.4Y-264.798I-.805J-.805
N1090G1X-9.861Y-264.604
N1100X-8.067Y-264.031
N1110X-6.236Y-263.592
N1120X-5.126Y-263.368
N1130G2X2.099Y-262.941I-.805J-.805
N1140G1X3.185Y-263.029
N1150G2X9.89Y-264.485I-.805J-.805
N1160G1X10.401Y-264.669
N1170G3X11.119Y-264.165I-.805J-.805
N1180G1X11.117Y-88.724
N1190G3X10.381Y-88.167I-.805J-.805
N1200G1X9.804Y-88.33
N1210G2X-1.861Y-89.473I-.805J-.805
N1220G1X-2.518Y-89.42
N1230G2X-9.793Y-88.141I-.805J-.805
N1240G1X-10.38Y-87.98
N1250G3X-11.119Y-88.542I-.805J-.805
N1260G1Y-96.748
Мб допуск на обработку поставить побольше?
Наверное, у вас количество кадров на один и тот же отрезок траектории в PM больше, чем в Арте.
На оси Y два двигателя стоит портал идет в перекос. Так жэ слышно когда это происходит.
Где это ставится?
apanovic
Сказали бы, что обрабатываете. Может для вашей фрезы 6мм? глубина 5мм или подача 3000 великоваты?
Где это ставится?
Под рукой PM нет. Ставится в параметрах траектории вверху слева. Но, чем больше допуск, тем хуже траектория.
На черновую 0,1-0,2. На чистовую 0,01-0,05.
Хотя, мб это и не панацея.
А в ArtCAM тоже выводятся кадры с круговой интерполяцией? Если нет, то круговую в PowerMILL не использовать. На станках круговая из PowerMILL практически не отрабатывается, проверено. Возникает ошибка "Конечная точка не лежит на окружности". Или поиграться параметрами станка. Тем более, что на Y два двигателя. И синхронизация должна быть очень точной. А у вас, похоже, при малых перемещениях по окружности двигатели несинхронно и работают.
Двигателя работают хорошо. Когда ставишь простую растровую выборку все хорошо. а когда надо по слоя 3D выборку тогда начинаются проблемы с пропусками шагов. К стати по всем осям.
По-моему, этот вопрос я встречал на другом форуме. Проблема здесь в некорректно заданных круговых интерполяциях. Во всяком случае, Fanuc и Fanuc-оподобные контроллеры с таким кодом работать не будут.
Т.е. реально одна колона двигается, а другая стоит? Если это так, то Вам надо ремонтировать станок. Если же стойка не успевает отрабатывать большое количество кадров, то движения происходят дерганые. Надо удалять люфты в осях. Либо если можно пренебречь высокой точностью использовать G64 или G63 (точно не помню).
Прогнал кусок вашей программы, через симулятор - дуги отрабатываются не корректно, какие-то ломаные. Скорее всего у Вас неправильный пост. Если его скинете, могу посмотреть в понедельник.
Не согласен. Работает нормально, проверено на многих стойках.
<noindex>http://yadi.sk/d/jHuNrUpW5NMpO</noindex>
<noindex>http://yadi.sk/d/Abc3UHrR5NMpo</noindex>
Спасибо за ранее. Вот этими постами пробую работать.
И я на те же грабли. (Почёсывая ушибленное место). С точностью вывода в nc файл поигрались и третий год не вспоминаем.
Сделал новую УП
O0001
N10( NC FILE : 1-1 )
N20( DATE : 02.03.12 & TIME - 14:08:37 )
N50( CONTROLLER : Fanuc & SERIES : OM )
N60( OPTION FILE : FanucOM_mach3?? 3??? )
N80( UNITS USED : MM )
N90G40G17G80G49
N100G0G90Z49.763
N110( ================================ )
N120( TOOLPATH : 1 )
N130( STRATEGY USED : Offset_area_clear )
N140( TOOLPATH WP : 1 )
N150( ================================ )
N160( TOOL TYPE : TAPERSPHERICAL )
N170( TOOL NAME : R3 )
N180( TOOL DIA.: 6 ; TIP RAD.: 3 & LENGTH : 30 )
N190T1M6
N200G54G90
N210S1500M3
N220M8
N230G0X0Y249.961
N240G43Z49.763H1
N250X-29.371Y150.065
N260Z44.763
N270G1Z36.923F2000
N280Y147.63F3000
N290X-29.331Y147.588
N300X-29.288Y147.626
N310X-29.087Y149.654
N320X-29.079Y149.719
N330X-29.068Y149.783
N340X-28.701Y151.526
N350X-28.703Y151.696
N360X-28.777Y151.849
N370X-28.86Y151.956
N380X-29.048Y152.205
N390X-29.225Y152.463
N400X-29.27Y152.531
N410X-29.332Y152.554
N420X-29.371Y152.501
N430Y150.065
N440G0Z49.763
N450X-28.728Y140.474
N460Z44.763
N470G1Z36.923F2000
N480X-28.76Y140.54F3000
N490X-28.795Y140.612
N500X-28.851Y140.64
N510X-28.89Y140.591
N520Y139.797
N530X-28.851Y139.748
N540X-28.793Y139.775
N550X-28.667Y140.03
N560X-28.63Y140.188
N570X-28.667Y140.347
N580X-28.728Y140.474
N590X-28.774Y140.722
N600X-28.685Y140.957
N610X-28.59Y141.188
N620X-28.615Y141.437
N630X-28.718Y141.739
N640X-28.807Y142.045
N650X-29.078Y143.046
N660X-29.19Y143.511
N670X-29.275Y143.983
N680X-29.286Y144.055
N690X-29.331Y144.091
N700X-29.371Y144.049
N710Y137.4
N720X-29.331Y137.352
N730X-29.276Y137.382
N740X-28.463Y139.358
N750X-28.446Y139.398
N760X-28.427Y139.438
N770X-28.123Y140.047
N780X-28.088Y140.2
N790X-28.126Y140.352
N800X-28.193Y140.48
N810X-28.421Y140.951
N820X-28.615Y141.437
N830X-28.655Y141.748
N840X-28.557Y142.045
N850X-28.454Y142.339
N860X-28.473Y142.65
N870X-28.614Y143.171
N880X-28.817Y144.171
N890X-28.891Y145.188
N900X-28.904Y146.593
N910X-28.902Y146.649
N920X-28.895Y146.749
N930X-28.618Y149.551
N940X-28.613Y149.594
N950X-28.606Y149.637
N960X-28.589Y149.736
N970X-28.181Y151.668
N980X-28.183Y151.831
N990X-28.257Y151.977
N1000X-28.344Y152.081
N1010G2G17X-29.742Y154.731I5.533J5.533
N1020G1X-29.762Y154.801
N1030X-29.812Y154.834
N1040X-29.851Y154.789
N1050Y134.848
N1060X-29.812Y134.801
N1070X-29.759Y134.832
N1080X-29.496Y135.583
N1090X-28.053Y139.104
N1100X-28.035Y139.144
N1110X-28.016Y139.183
N1120X-27.573Y140.073
N1130X-27.541Y140.22
N1140X-27.581Y140.366
N1150X-27.654Y140.493
N1160X-28.052Y141.31
N1170X-28.344Y142.17
N1180X-28.473Y142.65
N1190G0Z49.763
N1200X-1.98Y38.676
N1210Z44.763
N1220G1Z36.923F2000
N1230Y37.918F3000
N1240X-1.941Y37.823
N1250X-1.846Y37.784
N1260X.883Y37.783
N1270X.929Y37.823
N1280X.897Y37.874
N1290X.734Y37.923
N1300X-.476Y38.313
N1310X-1.672Y38.747
N1320X-1.858Y38.818
N1330X-1.941Y38.808
N1340X-1.98Y38.734
N1350Y38.676
N1360X-2.044Y38.407
N1370X-2.221Y38.195
N1380X-2.397Y37.983
N1390X-2.461Y37.714
N1400Y37.437
N1410X-2.421Y37.342
N1420X-2.326Y37.303
N1430X2.326
N1440X2.421Y37.342
N1450X2.461Y37.437
N1460Y37.798
N1470X2.422Y37.912
N1480X2.322Y37.978
N1490X2.134Y38.027
N1500X-.051Y38.676
N1510X-2.188Y39.467
N1520X-2.339Y39.529
N1530X-2.422Y39.521
N1540X-2.461Y39.447
N1550Y37.714
N1560X-2.549Y37.467
N1570X-2.774Y37.332
N1580G3X-2.892Y36.852I5.533J5.533
N1590G1X-2.852Y36.83
N1600X-2.807Y36.822
N1610X2.807
N1620X2.902Y36.862
N1630X2.941Y36.957
N1640Y38.176
N1650X2.902Y38.288
N1660X2.803Y38.353
N1670X2.616Y38.4
N1680G2X-2.672Y40.192I5.533J5.533
N1690G1X-2.82Y40.257
N1700X-2.902Y40.249
N1710X-2.942Y40.177
N1720X-2.941Y36.957
N1730X-2.928Y36.899
N1740X-2.892Y36.852
N1750X-2.811Y36.727
N1760X-2.82Y36.577
N1770X-2.803Y36.417
N1780X-2.66Y36.342
N1790X3.288
N1800X3.382Y36.381
N1810X3.422Y36.476
N1820Y38.557
N1830X3.383Y38.669
N1840X3.283Y38.732
N1850X3.097Y38.777
N1860G2X-2.924Y40.829I5.533J5.533
N1870G1X-3.301Y40.999
и срыв идет со строки где есть I5.533J5.533
что это такое где искать?
Вот это новость... А я то кучу станков из-под мила (с круговой интерполяцией естественно) кручу и не знаю... :smile:
Ребята, настраивайте правильно постпроцессор... И все получится. :wink:
Посты рабочие, прогонял через них свои программы, траектория процессируется правильно. Но не со 100% уверенностью, т.к. я пишу в DuctPost, а не в PostProcessor.
Из второй траектории (одна из дуг):
N1570X-2.774Y37.332
дугу по такими координатами построить не возможно, вторая точка лежит не на окружности.
Можете скинуть проект, чтобы иметь картину целиком. Ранее с таким не сталкивался. Может получиться разобраться, в чем проблема.
<noindex>http://yadi.sk/d/q-soYpeI5SQyI</noindex>
А может как нибудь отключить эти дуги ?
Подскажите где искать? Изменено пользователем apanovic
