SolidWorks 2010 beta
Вот нашел интерестную инфомацию может, кто еще не видел
There are three Beta releases of SolidWorks 2010 currently scheduled. The tentative schedule is as follows:
SolidWorks 2010 Beta 1: 06/08/09 - 07/03/09
SolidWorks 2010 Beta 2: 07/06/09 - 07/24/09
SolidWorks 2010 Beta 3: 07/27/09 - 08/14/09
SolidWorks 2010 - The Quick List
* New Display Box for View Mates with Separater Bar. Lots of new functionality with this new display box!
* Mirror Components - You can choose from different options for component positions. All the mirrored components appear under a Mirror Components feature. Components are fully defined…no additional Mates necessary!
* Simulation - Solution Optimization options that will allow you to resize the model based on properties defined. Example would be setting a specific volume…then let SolidWorks find the optimal model parameters! It looked like you could set several parameters for optimizations.
* Multi-Bodies allowed in Sheet Metal parts! You can also mix Sheet Metal and Weldment features with no issues! Also better DXF output options for sheet metal flat patterns.
* New Reference Plane options! The interface for Plane creation looks similar to the 3D Sketch Plane creation process. New options include Midplanes and Tangency to two faces and Tangent to face plus parallal (or angled) to another Plane. The Plane creation options appear as you select entities.
* Assembly Visualization - Sort assembly components by custom properties and other parameters. Many options with this and you can use it to control the model visibility. Model color displays can be used in this and can be based on ranges. You can output the component lists to Excel! You can modify custom properties in this interface as well. (This might be my favorite feature shown!)
* Configuration Builder - You can build a form with something that looks like the Property Tab Builder and then use this form to easily create configurations. You can set it up any way you want with Yes/No answers and custom fields. VERY COOL! Allows you to configure on the fly too!
* Drawing Annotations - GTol, Surface Finish, and Datums can be attached ANYWHERE to dimension extension lines. You can combine notes with a simple drag and drop! This looked REALLY nice! Perhaps this will allow you to store custom notes individually in the Design Library then add them one by one?
* Drawing Balloons - User input Balloon size (using a number). Youc an also automatically show the Quantity beside the Balloon just by clicking turning on the option!
* Drawing Dimensions - New heads up display that allows you to modify the dimension, tolerance, and other day all in one window without having to step through the PropertyManager. Also - When you add dimensions to a drawing, other dimensions will now automatically shift outward or inward keeping the proper spacing!
* Drawing Center Marks - You can add Center Marks AFTER dimensions are created and the dimension extension lines will automatically trim to the Center Mark!
* Drawing Tables - Excel table functionality through all SolidWorks tables!
* Heres a BIG ONE - Direct Editing - Enhanced Move Face tools that allow you to move imported features on the fly all from the Graphics area. There was also a new direct editing tool that allowed you to modify patterns of holes in an imported part all at once! The UI looks to be using the Instant3D rulers. The direct editing tools did create features in the tree which will allow users to easily revert back to the original imported state.
* Enterprise PDM - Replicate Toolbox data across mulitple vaults! - Converting Data and Print Jobs can now be managed on a server.
* Full Machine Simulation that is integrated with National Instruments LabView!
Вот ежли б рядом перевод положить - было бы интересно, а так просто красиво....
Некоторые слова знакомы (например - Enterprise PDM), остальное только со словарём - лень...
Неужто сделают возможным зеркалить детали сборке с полностью определенными Mate! :clap_1:
Ежели сделают - переползу с 06.
После попытки перевода в Сократе - туману ещё больше...
Наиболее понятно
* Предприятие PDM - Копирует данные Инструментария через mulitple хранилища! - Преобразование Данных и Рабочие места Распечатки могут теперь управлялись в сервере.
* Полное Машинное Моделирование, которое интегрировано в Национальные Инструменты LabView!
Переводить тех текст лектронным болваном - бесполезно. :blink:
Про ПДМ - не совсем в курсе темы, но там про данные Тулбокса, которые могут храниться на нескольких волтах, конвертация и распечатка производиться под управлением сервера.
Еще пишут, что листовые детали теперь могут быть многотельными, и возможно использование листовых фичей совместно со сварочными (типа сварку на гнутых листовых можно будет применять?!).
Допуски формы, шероховатости и базы теперь можно будет привязывать к размерам (даешь шероховатость на диаметре?!).
Новое меню позволить изменять размеры, допуски не вызывая меню свойств. Также при добавлении размера на чертеже другие будут перестраивать свое положение автоматически.
Екселевские функции будут работать в таблицах SW.
Что-то про "любимый мозоль" тов. Странника: Simulation - Solution Optimization options that will allow you to resize the model based on properties defined. Example would be setting a specific volume…then let SolidWorks find the optimal model parameters! It looked like you could set several parameters for optimizations.
В общем, полный ахтунг :g:
Швы в листовом есть в 2009-м
может и в 2008-м уже было
Прошу за перевод особо не пинать, потому как английский учил *фром тзе бук* :D
Если найдете ошибки, исправляйте!
• New Display Box for View Mates with Separater Bar. Lots of new functionality with this new display box!
• Новый дисплай менеджер для просмотра привязок с разделяющей полосой. Много нового функционала с этим менеджером.
• Mirror Components - You can choose from different options for component positions. All the mirrored components appear under a Mirror Components feature. Components are fully defined…no additional Mates necessary!
• Зеркальные компоненты – можно выбрать разные опции для позиционирования компонента. Все зеркальные компоненты появляются в новои; функциональной группе *Зеркальные компоненты*. Компоненты полностью определены, не нужно дополнительных привязок
• Simulation - Solution Optimization options that will allow you to resize the model based on properties defined. Example would be setting a specific volume…then let SolidWorks find the optimal model parameters! It looked like you could set several parameters for optimizations.
• Симуляция (CAE модуль в 2009 СВ (бывший Cosmos)) – Опции оптимизации решений которые позволят изменить размер детали основанной на определенных свойствах. Примером может служить настройка специфического размера…затем СВ найдет оптимальные параметры модели! Это выглядит как устанавливать несколько параметров для оптимизации.
• Multi-Bodies allowed in Sheet Metal parts! You can also mix Sheet Metal and Weldment features with no issues! Also better DXF output options for sheet metal flat patterns.
• Мульти-тела доступны в деталях листового металла. Также возможно комбинировать функции листового металла и сварки без каких либо ограничений. Также улучшены опции вывода листовых разверток в DFX.
• New Reference Plane options! The interface for Plane creation looks similar to the 3D Sketch Plane creation process. New options include Midplanes and Tangency to two faces and Tangent to face plus parallal (or angled) to another Plane. The Plane creation options appear as you select entities.
• Новые возможности справочной плоскости! Интерфейс создания плоскости теперь похож на процесс создания плоскостей для 3Д эскизов. Новые опции включают *срединную плоскость и касательность к двум граням* и касательность к грани плюс параллельность к другой плоскости*. Опции создания плоскости появляются после выбора обЪектов.
• Assembly Visualization - Sort assembly components by custom properties and other parameters. Many options with this and you can use it to control the model visibility. Model color displays can be used in this and can be based on ranges. You can output the component lists to Excel! You can modify custom properties in this interface as well. (This might be my favorite feature shown!)
• Визуализация сборки – сортировка компонентов сборки по специальным свойствам и другим параметрам. Дальше перевести логично не удалось…
• Configuration Builder - You can build a form with something that looks like the Property Tab Builder and then use this form to easily create configurations. You can set it up any way you want with Yes/No answers and custom fields. VERY COOL! Allows you to configure on the fly too!
• Дизайнер конфигурацй – возможность создать форму с чем-либо которая похожа на закладку дизайнера свойств и затем использовать эту форму для легкого создания конфигураций. Возможность установить любой путь с ответами да/нет и специальными полями. Возможность конфигурировать *на лету*
• Drawing Annotations - GTol, Surface Finish, and Datums can be attached ANYWHERE to dimension extension lines. You can combine notes with a simple drag and drop! This looked REALLY nice! Perhaps this will allow you to store custom notes individually in the Design Library then add them one by one?
• Анотации чертежей – Gtol, шероховатость, базы могут быть привязаны в любом месте на выносной линии. Можно комбинировать заметки с *выташить вставить*! Это даст возможность хранить заметки индивидуально в библиотеке проектирования, а затем добавлять их одну за другой.
• Drawing Balloons - User input Balloon size (using a number). You can also automatically show the Quantity beside the Balloon just by clicking turning on the option!
• Чертежные позиции – пользоватыель может изменять размер *шара (позиции)*. Возможность автоматически показать количество радом с позицией (шаром) просто включая опцию.
• Drawing Dimensions - New heads up display that allows you to modify the dimension, tolerance, and other day all in one window without having to step through the PropertyManager. Also - When you add dimensions to a drawing, other dimensions will now automatically shift outward or inward keeping the proper spacing!
• Размеры чертежа – новый дисплай позволяющий изменять размер, толеранции, и другие все в одном окне, без перехода по менеджеру свойств. Также – добавляя размер на чертеже, другие размеры автоматически переключатся наружу или внутрь сохраняя точное расстояние
• Drawing Center Marks - You can add Center Marks AFTER dimensions are created and the dimension extension lines will automatically trim to the Center Mark!
• Обозначения центров отверстий – можно добавить обозначениа центра после создания размера, выносные линии автоматически обрезаются до обозначения центра
• Drawing Tables - Excel table functionality through all SolidWorks tables!
• Чертежные таблицы – функционал Excell во всех таблицах СВ
• Heres a BIG ONE - Direct Editing - Enhanced Move Face tools that allow you to move imported features on the fly all from the Graphics area. There was also a new direct editing tool that allowed you to modify patterns of holes in an imported part all at once! The UI looks to be using the Instant3D rulers. The direct editing tools did create features in the tree which will allow users to easily revert back to the original imported state.
• Прямое редактироване – улучшена функция *переместить грань* которя позволит перемещать грани импортированных моделей *на лету* в графической зоне. Также новая функция прямого редактирования которя позволит редактировать массив отверстий в импортированной модели все за раз! Пользовательский интерфайс будет похож на принцип линейки в Instant 3D. Прямое редактирование будет добавляться в дерево конструирования, всегда можно будет вернуться в начальную стадию
• Enterprise PDM - Replicate Toolbox data across mulitple vaults! - Converting Data and Print Jobs can now be managed on a server.
• Enterprise PDM – возможность копировать данные в несколько хранилишь. Конвертирование и печать может управляться на сервере.
• Full Machine Simulation that is integrated with National Instruments LabView!
• Полная машинная симуляция интегрированная вместе с LabView!
Долго они к этому шли... А вот до ординатно-угловых размеров путь, видать, еще длиннее. (кивок в сторону Странника)
Что то много кивков в мою сторону.
Может кто ещё и подскажет откуда дистрибутивчик беты можно взять, особенно если за тестирование ещё и кое-что заплатят. :wink:
А пока вот ещё убойные вопросы:
1. Попадание поверхности в библиотеку проектирования как фичеры, если они и в этом релизе не сделали, то сразу :thumbdown:
2. Логические операторы в уравнениях - просто стыдно что этого до сих пор нету.
3. Функционал датчиков, особенно в комбинации с конвертами и ещё в этой части что нового.
4. Конверт как базовый элемент автокомпонента, если не работает, то просто никаких более комментариев.
Не обижайтесь, я не со зла....
Собственно и не обижаюсь, но про тестирование говорю вполне серьёзно.
Люди из SWR, это напрямую обращено к вам.
И я бы тоже с удовольствием потестировал, но причем тут SWR ?
Такое разве бывало?
Такое разве бывало?
Может кто ещё и подскажет откуда дистрибутивчик беты можно взять, особенно если за тестирование ещё и кое-что заплатят. wink.gif
Для тестирования у меня знаний маловато (глубоко не лазил), но поиграть с новой версией тоже не против...
И я бы тоже с удовольствием потестировал, но причем тут SWR?
Вообще говоря, где ж ещё бета версию искать, как не у официального диллера?
В прошлые годы бетта версию раздавали прямо с сайта в штатах. Нужно было только заполнить анкету и дать номер своей лицензии. Если вы легальный пользователь, на мыло приходила лицензия под бетту, а скачивать сам дистрибутив нужно было с их FTP.
А разве в таблицах переменных нельзя вставить внешнюю функцию написанную в Basic. Вроде это же было, или нет?
В таблицах-то можно, но `Странник` вроде как спрашивал об уравнениях.
Насчет уравнений, из Helpa`a SW :
При указании размеров модели можно также использовать функцию Visual Basic IIf. Эта функция возвращает одно из двух значений в зависимости от оценки выражения. Например, если указано уравнение "D1@Sketch1" = (IIf("D1@Sketch4">15, 20, 10)) + 8, тогда...
Маловато вообще-то...
В VB ведь есть еще другие Logical Operators
And Operator
Eqv Operator
Imp Operator
Not Operator
Or Operator
Xor Operator
And Operator
Eqv Operator
Imp Operator
Not Operator
Or Operator
Xor Operator
Есть уверенность, что они не работают? Сказать про них ни чего не могу не пробовал.
Например, об округлении в нужную сторону и с нужным количеством знаков тоже в справке ни слова, однако вот: http://fsapr2000.ru/index.php?showtopic=28232
Я тоже не пробовал...
Если работают - значит это хорошо :-)
