Поясните пожалуйста:
Выбор делаю с помощью "PropertyManagerPageSelectionbox"
На кнопку поставил:
Private Sub PropertyManagerPage2Handler9_OnButtonPress(ByVal Id As Long)
Dim swSelMgr                     As SldWorks.SelectionMgr
Dim swBody                        As SldWorks.Body2
Dim i                                    As Integer
Dim swError                       As Long
Dim BazaMat                 As String
Dim NameMat                 As String
BazaMat = "solidworks materials.sldmat"
NameMat = "Клен" ' ЛЮБОЙ МАТЕРИАЛ
Set swSelMgr = swModel.SelectionManager
For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
Set swBody = swSelMgr.GetSelectedObject6(i, -1)
swError = swBody.SetMaterialProperty("", BazaMat, NameMat)
Next i
End Sub
В открытом файле сборки не работает. В детали Да.
Изменено пользователем maikl_lug
Ребята есть часть кода:
swModel = ((IModelDoc2)(swApp.NewDocument("C:\\Solidworks Library\\templates\\Сборка.asmdot", 0, 0, 0)));
swModel = ((IModelDoc2)(swApp.ActivateDoc2("Assem1", false, longstatus)));
swAssembly = ((AssemblyDoc)(swModel));
swAssembly.InsertNewPart2(textBox2.Text, selectFace());
Где textBox2.Text:
private void button3_Click(object sender, EventArgs e)
            Stream myStream;
            SaveFileDialog saveFileDialog1 = new SaveFileDialog();
            saveFileDialog1.Filter = "sldWork files (*.sldprt)|*.sldprt|All files (*.*)|*.*";
            saveFileDialog1.FilterIndex = 1;
            saveFileDialog1.RestoreDirectory = true;
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                if ((myStream = saveFileDialog1.OpenFile()) != null)
                    // Code to write the stream goes here.
                    textBox2.Text = saveFileDialog1.FileName;
                    myStream.Close();
selectFace()
private object selectFace()
            String assyName = swModel.GetTitle().ToLower().Contains(".sldasm")
                          ? swModel.GetTitle().Remove(swModel.GetTitle().LastIndexOf("."))
                          : swModel.GetTitle();
            for (int i = 0; i < 100; i++)
                Boolean bRet = swModel.Extension.SelectByID2(partNameNumber1 + "-" + i.ToString() + "@" + assyName, "COMPONENT", 0, 0, 0, false, 0, null, 0);
                if (bRet)
                    break;
            SelectionMgr swSelMgr = (SelectionMgr)swModel.SelectionManager;
            Component2 myOldComp = (Component2)swSelMgr.GetSelectedObject6(1, -1);
            if (myOldComp != null)
                swPart = myOldComp.GetModelDoc2() as PartDoc;
                if (swPart != null)
                    IEntity face = (IEntity)swPart.GetEntityByName("Number1", (int)swSelectType_e.swSelFACES);
                    if (face != null)
                        face = myOldComp.GetCorresponding(face) as IEntity;
                        face1 = face.Select4(false, null);
            return face1;
Проблема состоит в том, что при компиляции и отладке деталь так и не создается в сборке, методы button3_Click (textBox2.Text) и selectFace() передают значение в InsertNewPart2 но деталь все равно не создается... Может быть я как-то неправильно использую метод InsertNewPart2? В справке что-то ничего очевидного я не нашел...
PS Если нужно могу скинуть весь код...
Спасибо.
@@Almo
swAssembly.AddComponent4
И, кстати, swAssembly.InsertNewPart2 возвращает ErrorCode. Попробуйте так:
swInsertNewPartErrorCode_e errorCode = (swInsertNewPartErrorCode_e)swAssembly.InsertNewPart2(textBox2.Text, selectFace());
И посмотрите что там возвращается.
streamdown, а как мне в AddComponent4 запихнуть ссылку на поверхность получаемую методом selectFace() если AddComponent4 на вход принимает координаты?
@@Almo
Погодите, так вам нужно именно создать деталь в контексте сборки? Тогда с AddComponent я погорячился))
Что возвращает errorCode ? Вы попробовали как я показал?
Да, необходимо создать деталь в контексте сборки с указанным путем сохранения на указанной поверхности другой детали.
errorCode возвращает - swInsertNewPartError_FileAlreadyExists, это я так понимаю означает что деталь уже создана?
Хм... а не получается ли это из-за того, что метод button3_Click создает уже готовый файл с расширением sldprt а метод InsertNewPart2 пытается создать его же в свою очередь? Если так, то как бы мне запихнуть в InsertNewPart2 свой путь сохранения и имени будущей детали?
В общем то при записи строки следующим образом
swAssembly.InsertNewPart2("C:\\Part3^Assem3.sldprt", selectFace());
errorCode возвращает swInsertNewPartError_FilePathEmpty а при отладке в окне солида видно значок выбора места вставки новой детали (типа курсор с зеленой галочкой) и для создания ее остается только кликнуть по уже подсвеченной (выбранной) грани...
Как бы добавить этот клик?)
код у вас должен быть таким
  1. //if ((myStream = saveFileDialog1.OpenFile()) != null)
    {// Code to write the stream goes here.
    //myStream.Close();}
а про выбор кромки почитайте ещё GetSpecificFeature2
Не могу понять как применить GetSpecificFeature2 касательно моей проблемы, да и вообще честно говоря не очень понятен его смысл... Не могли бы объяснить?
PS появилась идея заменить InsertNewPart2 на InsertNewVirtualPart а уже потом ее сохранять, но все же, неужели никто не использует InsertNewPart2 ?
Спасибо.
Эээх, вот умеете вы заставить поработать по средам)))
Логика у вас неправильная.
Как должно быть:
- создать сборку (swApp.NewDocument)
- вставить туда деталь с вашей Face2;
- selectFace()
- InsertNewPart
 private void button1_Click(object sender, EventArgs e)
            GetSolidworks();
//Тут создать сборку и вставить в нее деталь!!!!
            //swModel = (ModelDoc2)(swApp.NewDocument(@"D:\AddonSW\SWPlus\Шаблоны\Сборка.asmdot", 0, 0, 0));
//AddComponent("тут деталька с гранью");
            swAssembly = (AssemblyDoc)(swModel);
            Face2 rrr = selectFace();
            swInsertNewPartErrorCode_e errorCode = (swInsertNewPartErrorCode_e)swAssembly.InsertNewPart2(@"C:\oneforme.sldprt", selectFace());
private Face2 selectFace()
                Boolean bRet = swModel.Extension.SelectByID2("part" + "-" + i.ToString() + "@" + assyName, "COMPONENT", 0, 0, 0, false, 0, null, 0);
                if (bRet)
                    break;
                if (swPart != null)
                    if (face != null)
                        Face2 retFase = (Face2)face;
                        return retFase;
            return null;
Не добавлялась новая деталь у вас потому, что вы создаёте сначала новую сборку БЕЗ своей детали и пытаетесь там в пустоте искать компонент.
Как должно быть:
- selectFace()
- InsertNewPart
            GetSolidworks();
                if (bRet)
                    break;
                if (swPart != null)
                    if (face != null)
                        return retFase;
            return null;
Логика у меня была такая как вы написали, проблема как оказалось была в том, что перед вызовом InsertNewPart2 я не вызывал метод selectFace()...
Спасибо огромное за подсказку!!!!
PS когда применяется GetSpecificFeature2?))) Если можно то вкратце на пальцах)
Незачто.
огда применяется
Ну, там просто в API была ссылка на этот метод в Remarks. Надо читать.
Записал макрос.
Надо его немного подправить, на в програмирование не силён.
Суть макроса в следующем.
Делаем привязку к внешнему файлу, с темже именем как и сам файл, перестраиваем, сохраняем. и сохраняем в формат DXF с тем же именем как и файл, текущий вид.
Получается в макросе нужно сделать чтоб привязка к файлом была не жёстко по пути и имени, а брала в текущей папке, с тем же именем файла.
Sub main()
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Уравнения", "EQNFOLDER", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
longstatus = Part.SaveAs3("D:\Производство\43\29.DXF", 0, 0)
swPart = swApp.NewPart()
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameLeft = 0
myModelView.FrameTop = 22
myModelView.FrameState = swWindowState_e.swWindowMaximized
swApp.ActivateDoc2 "Чертеж1 - Лист1", False, longstatus
myModelView.FrameTop = 0
swApp.ActivateDoc2 "29", False, longstatus
Dim myView As Object
Set myView = Part.CreateDrawViewFromModelView3("D:\Производство\43\29.SLDPRT", "*Текущий", 0, 0, 0)
boolstatus = Part.DeleteNamedView(*Текущий)
End Sub
Всем привет. Нужно програмно изменить слой объекта чертежа. Ручками делается так: выбираю допустим размер, в менеджере слоев выбираю нужный слой. На скиншоте менеджер слоев внизу слева  https://yadi.sk/i/9c83uceGe3iNz
Примеры мне не помогли. Есть ChangeComponentLayer, не могу понять, как его использовать. Нашел так же команды swCommands_LayerProperties и swCommands_Layer_Select как приминить их тоже не понял.
Пробовал
            doc_md_ext.SelectAll(); // выделить все
            sw.Command(1151, ""); // потом выбрать слой
не помогло. Что я делаю не так?
Может кто нибудь покажет рабочий код, изменяющий слой?
Изменено пользователем sova2004
Ну так а если sw.Command(1151, "LayerName")
Тоже как то интересовался этим вопросом. Быстро ответа не нашёл.
Попробовал. Не помогло. Подставил и имя слоя, и цифру 1(в надежде что это единственный слой), и цифру 3(в надежде что есть еще два системных), и цифру 2 (на всякий случай), также вставил туда  слой как объект. Так же не помогло. Пробовал и со свойствами слоя. Может есть еще варианты?
Layer layer1;
LayerMgr doc_layer;
doc_layer = (LayerMgr)doc_model.GetLayerManager();
layer1 = doc_layer.GetLayer(textBox1.Text); // предварительно создается слой с именем из textBox1.Text и делается активным(текущим)
sw.Command(1151, layer1);
Заглянул в справку. Не понимаю в чём у вас проблема?
//Добавим список слоев
LayerMgr lMgr = (LayerMgr)swModel.GetLayerManager();
Object[] layers = lMgr.GetLayerList();
comboBox1.Items.AddRange(layers);
//Переместим размер на нужный слой
String currentLayerName = "AM_5";
DisplayDimension dim = (DisplayDimension)swModel.SelectionManager.GetSelectedObject6(1, -1);
Annotation myAnn = dim.GetAnnotation();
myAnn.Layer = currentLayerName;
Где то так для размеров:
private void cmdNewLayer_Click(object sender, EventArgs e)
    SldWorks swApp = GetActiveSolidWorks();
    if (swApp == null)
        return;
    IModelDoc2 swModel = swApp.IActiveDoc2;
    if (swModel == null)
        string message = "Загрузите документ SolidWorks-а!";
        MessageBox.Show(message, "Warning!", MessageBoxButtons.OK, MessageBoxIcon.Warning);
        return;
    int docType = swModel.GetType();
    if (docType != (int)swDocumentTypes_e.swDocDRAWING)
        string message = "Функция выполняется только с документами чертежей (*.slddrw)!";
        return;
    ISelectionMgr swSelMgr = swModel.ISelectionManager;
    int countObj = swSelMgr.GetSelectedObjectCount();
    for (int i = 1; i <= countObj; i++)
        swSelectType_e selType = (swSelectType_e)swSelMgr.GetSelectedObjectType2(i);
        switch (selType)
            case swSelectType_e.swSelDIMENSIONS:
                    IDisplayDimension swDisplayDimension = swSelMgr.GetSelectedObject5(i) as IDisplayDimension;
                    IAnnotation swAnnot = swDisplayDimension.IGetAnnotation();
                    swAnnot.Layer = "DIM"; // Имя слоя
                break;
P.S. Опередили.
Спасибо Вам большое streamdown и Shvg. Помогло. Проблема была в моем не понимании, связать DisplayDimension и Annotation. DisplayDimension к стати тоже пере этим пробовал, а до Annotation так и не дошло дело.
Доброго времени суток.
Вкратце есть форма (см.рис1) алгоритм работы которой следующий:
1. указывается путь к фланцу с помощью кнопки "фланец"
2. нажимается кнопка "button4" которая должна считать конфигурации фланцы и "запихнуть" их в "comboBox1".
    Реализацию кнопки button4 смотрите в спойлере ниже:
private void backgroundWorker1_DoWork(object sender, DoWorkEventArgs e)
            if (button4_Click_Click == true) // флаг для кнопки button4, до ее нажатия button4_Click_Click = false
                Process[] processes = Process.GetProcessesByName("SLDWORKS");
                foreach (Process process in processes)
                    //Searching the sld procceses and kill them if there exist
                    process.CloseMainWindow();
                    process.Kill();
                //Starting solidWorks
                Object processSW = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("SLDWORKS.Application"));
                swApp = (SldWorks)processSW;
                swApp.Visible = true;
                //Opening flange and getting of configuration
                String asd = pathOfFlange.Text;
                IModelDoc2 swModelFlange = (IModelDoc2)swApp.OpenDoc6(asd, 1, 2, "", 0, 0);
                ConfigurationManager swConfMgr = default(ConfigurationManager);
                swConfMgr = (ConfigurationManager)swModelFlange.ConfigurationManager;
                object[] configNameArr = null;
                configNameArr = (object[])swModelFlange.GetConfigurationNames();
                foreach (String flangeConf in configNameArr)
                    comboBox1.Items.Add(flangeConf);
                    int comLength = comboBox1.Items.Count;
                    int confLength = configNameArr.Length;
                    if (comboBox1.Items.Count == configNameArr.Length)
                        break;
            else
                MessageBox.Show("Нажмите применить");
3. после чего выбирается необходимая конфигурация фланца в выпадающем комбобоксе
4. создается патрубок с помощью кнопки "патрубок"
5. нажимается кнопка "выполнить" и тд...
Вопрос состоит в следующем:
- как бы мне разбить работу этой программы на потоки. Мне кажется необходимо пункт 2 вынести в отдельный поток, что я и сделал с помощью класса backgroundWorker, но при компиляции выскакивает ексепшн " Недопустимая операция в нескольких потоках: попытка доступа к элементу управления 'comboBox1' не из того потока, в котором он был создан". Как мне синхронизировать эти потоки (главный и бекнраунд), или быть может как-то по другому реализовать исполнение кнопки button4 . Мб есть какой то другой алгоритм получения списка конфигураций, я буду признателен за пример кода.
Спасибо.
    • Cefius
      Добрый день! Интересует макрос сохраняющий тела из многотела в стп формат. У вас есть такой? Можете поделиться за вознаграждение?
    • Bellka
      станок был выкуплен и попал мне в руки, сейчас работает но тем кто его пытался ломать чинить точно спасибо не скажу
    • Девочка_конструктор
      Подскажите пожалуйста, как вы задаете тепловые трубки для расчета теплоотвода? Как отдельное тело (например, из меди), отдельно пористую среду и отдельно течение жидкости (в таком случае сложно задать конвекцию жидкости, тем более она у меня осуществляется без учета гравитации) / или как тепловую трубку? Тогда вопрос, как выбирать поверхности теплопоглощения и поверхности теплоотвода, если по сути это одни и те же поверхности, только в одном месте они поглощают тепло, в другом - отдают.  Считаю радиоэлектронный модуль, у меня микропроцессоры мощностью более 60 Вт нагреваются до 150 градусов. Хочу оценить влияние тепловой трубки, помогла бы она в этой ситуации отвести тепло должным образом или нет. Но гравитацию использовать не могу, конструкция не позволяет. Следовательно, нужно как-то разумно задать пористую среду для тепловой трубки, чтобы конденсат жидкости возвращался в зону нагрева. Помогите
      Этот вариант хорош ещё тем, что сечение всегда будет ориентировано по нормали к цилиндру - не будет никаких перекосов на стенках. Но есть подозрение, что на цилиндре эта схема будет сложнее, чем на плоскости, поскольку края каждого "следующего" сечения наезжают на "предыдущее" (за счет изгиба стенки цилиндра). И точки касания двух стенок расположены не на диаметре шара, а на некой хорде, не проходящей через центр.
    • andrei4ik
      ну я же не новую деталь создаю... но щас гляну конечно но хз нет не хранит.... ошибка никуда и не ушла, и кажу более... если я добавляю какую сборку в главную сборку тот все детали в добавленной сборке становятся сокращенными
      можно и по линии сделать фрезой диаметром меньше чем паз
      зачем вообще считать то что априори не требует расчёта? Там чтобы что-то согнуть веса будут к тонне приближаться
    • persona1980_1
      Можно еще воспользоваться пользовательским анализом для создания дополнительных графиков и их уже учитывать при протягивании сечения как у вас на картинке (не по нормали к траектории). Там высота сечения будет меняться в зависимости от этого дополнительного графика.
      @filsan цилиндрическая. Я бы отдал модель, да Крео 11. Цилиндр, его пересекает поверхность, поверхность утолщаю с вычитанием материала. получаются два разорванных фрагмента, затем через всё вытянул цилиндр диаметром чуть меньше начального. Можно заморочиться построить поверхность с диркой, повлияет только на число фичеров в дереве
      Рекомендовал бы удалить ветки реестра с настройками всех версий (возможно программа при запуске пытается стянуть настройки с другой версии в дополнении к основной), а потом поставить программу с нуля. Так же после настройки стоит сохранить настройки программы через Мастер настроек Solidworks, что бы при сбое можно было восстановить все ваши настройки, а не настраивать всё с нуля (это долго и нудно).   Это есть, но всё же первая настройка настройка, так понял, работает и надо просто добавить все кнопки сразу. А если вызвать настройку повторно, то все пользовательские кнопки остаются, но пусты, в них нет данных для запуска и они не отображаются на работающей панельки.   Как вариант загнать нужные кнопки во всплывающую панельку вызываемую клавишей "S" на клавиатуре.
