Ansys Fluent with a Native GPU Solve
VICT0R_1945
A coefficient showing approximately how many times the calculation on all logical CPUs is slower than the calculation on 1 logical processor and all cores of the video card.
Example.
Video Card: RTX 3090 Ti 24 GB GDDR6X with 10752 CUDA cores and a frequency of 1.86 GHz.
Processor: i9-12900K with 24 logical processors + 64 GB DDR4 RAM with a frequency of 2133 MHz.
For easy reading, the time for which 100 iterations were performed by the solver is summarized in a table indicating the configuration of the settlement home station.
P.S. The formula is true only for IT systems with similar indicators of frequency and memory bandwidth as the author!
Изменено пользователем VICT0R_1945
Hi guys. If you were careful enough, you should have replaced the typo in the formula. I am sending an edited version for everyone to see.
20 часов назад, an_rushin сказал:
не желаете сформулировать вопрос?
You probably misunderstood the idea of me creating a topic on the forum. I will share with you the link of my overseas colleagues: Upgrade to Ansys Fluent with a Native GPU Solver?
не понимаю сути темы или вопроса или еще чего-то, не понимаю, зачем писать по-английски, если очевидно, что этот язык не родной, зачем вставлять ссылки на неработающие или запертые ресурсы, но в наше странное время возможно все.
8 часов назад, an_rushin сказал:
I understood you. That's right, English is not my native language. I am from a country that was formerly part of the USSR. The essence of the topic is that with the help of a video card, you can speed up the calculation in Fluent by about 20-40 times.
P.S. We are talking about comparing the performance of top-end video cards and processors, from Nvidia and Intel, respectively.
3 минуты назад, VICT0R_1945 сказал:
Bull$hit:biggrin:
4 минуты назад, Jesse сказал:
Bull$hit:biggrin:
You are apparently not familiar with this test, I suggest you familiarize yourself: Ansys Fluent Performance
Also, colleagues, I suggest you read this article: Unleashing the Full Power of GPUs for Ansys Fluent, Part 2
      Это надо сидеть и разбираться с логикой, которая в ладдере прописана разработчиками. Возможно, что править надо. Комментарии там на английском, вам повезло. В Яндексе задавать вопросы бесполезно на этот счет
    • Mixon513
      Подскажите где нужно менять параметры. Или как задать вопрос яндексу?
    • Vengeance
      У нас на дусане револьверка крутится, когда рука опущена, один раз оператор крутанул, повезло что вращение оказалось против часовой, q-setter просто "подпрыгнул"
      У вас там есть Р0225 (T_NO_PE_DSP) Полагаю, что в ней обрабатывается отображение на дисплее
    • SAPRonOff
      либо СКМыши нажмите и там  под курсором появится вариант выбора в виде списка; либо ПКМ - другой : и там тоже будет список рядом лежащих линий.
      У меня LadderIII старый, не открывает. Надеюсь коллеги подтянуться и кто-то посмотрит формирование номера на дисплее.
    • gemini74
    • alex0800
