Ansys Fluent with a Native GPU Solve
VICT0R_1945
VICT0R_1945
A coefficient showing approximately how many times the calculation on all logical CPUs is slower than the calculation on 1 logical processor and all cores of the video card.
Example.
Video Card: RTX 3090 Ti 24 GB GDDR6X with 10752 CUDA cores and a frequency of 1.86 GHz.
Processor: i9-12900K with 24 logical processors + 64 GB DDR4 RAM with a frequency of 2133 MHz.
For easy reading, the time for which 100 iterations were performed by the solver is summarized in a table indicating the configuration of the settlement home station.
P.S. The formula is true only for IT systems with similar indicators of frequency and memory bandwidth as the author!
Edited by VICT0R_1945
VICT0R_1945
Hi guys. If you were careful enough, you should have replaced the typo in the formula. I am sending an edited version for everyone to see.
VICT0R_1945
20 часов назад, an_rushin сказал:
не желаете сформулировать вопрос?
You probably misunderstood the idea of me creating a topic on the forum. I will share with you the link of my overseas colleagues: Upgrade to Ansys Fluent with a Native GPU Solver?
an_rushin
не понимаю сути темы или вопроса или еще чего-то, не понимаю, зачем писать по-английски, если очевидно, что этот язык не родной, зачем вставлять ссылки на неработающие или запертые ресурсы, но в наше странное время возможно все.
VICT0R_1945
8 часов назад, an_rushin сказал:
I understood you. That's right, English is not my native language. I am from a country that was formerly part of the USSR. The essence of the topic is that with the help of a video card, you can speed up the calculation in Fluent by about 20-40 times.
P.S. We are talking about comparing the performance of top-end video cards and processors, from Nvidia and Intel, respectively.
Jesse
3 минуты назад, VICT0R_1945 сказал:
Bull$hit:biggrin:
VICT0R_1945
4 минуты назад, Jesse сказал:
Bull$hit:biggrin:
You are apparently not familiar with this test, I suggest you familiarize yourself: Ansys Fluent Performance
    • mrvcf1
      @Дмитрий Гайдай просто дугу построй с касательностью и совпадением.
    • Дмитрий Гайдай
      Попробовал показать что я имею ввиду
    • Дмитрий Гайдай
      При работе с эскизами в модели не хочет. По крайней мере инструментом скругление. Единственный +- адекватный способ который пока что нашел - строить скругление (ту билиберду которую он дает), а потом через редактирование параметров кривой задавать вручную касательность в крайних точках и через положение средней точки +- подгонять положение дуги и ее радиус под нужный. Не идеально, но как минимум аналитическая плавность обеспечивается.
    • mrvcf1
      @Дмитрий Гайдай все строит.
    • Tad
    • Дмитрий Гайдай
      Господа, прошу вашей помощи. Есть аналитически плавная кривая, состоящая из эллипса, дуги окружности и скругления между ними.  Для понимания о чем речь При попытке повторить энтот профиль в NX 10.0 все упирается в скругления. NX наотрез отказывается строить смешанное сопряжение, и устраивает только внешнее. В итоге получается разного рода билиберда В прошлом вместо эллипса была окружность, тогда скругления он еще хоть как-то ставил. И то с миллионной попытки. Теперь вообще наотрез отказывается.   Куда тыкнуть этого немецкого болванчика чтобы построить смешанное сопряжение? Вариант "на глаз построить что-то похожее на скругление" не рассматриваю, нужна именно аналитически плавная геометрия.   P.S. смешанное сопряжение это вот:
    • areg
      Здравствуйте! Прошу расценить стоимость и срок изготовления заготовок для деталей, изображенных на чертежах. Стоимость, срок изготовления штампов и сколько поковок они смогут изготовить прошу сообщить отдельной строкой. Количество 2000 штук каждой детали. Если предложите скидку возможно размещение у вас заказа на 10000 шт. единовременно. Чертеже не очень качественные, если возникнут по ним вопросы — пишите — дам пояснения. Так же интересуют специалисты в этой области на предмет платных консультаций, так как заказчик хочет освоить эту технологию. Предложения в личку.
      Некоторые метчики, развёртки имеют рабочий конец не тупой с центровочным ортверстием, а заострённый. Из-за этого ими и чертят и используют как керн. Всё в пределах нормы.
    • vasillevich68
      Не все тут так просто. Если спать перед обедом, то можно проспать обед, и тогда будет нечего обедать. Короче, всё, как с той булевой операцией
      Cмотреть почему нет этого сигнала по логическому уравнению! Хотя тут писали Как вы нашли этот бит подсказали?
