Жесткость контакта a.к.а contact stiffness
Во многих системах динамического моделирования при взаимодействии тел необходимо указывать такую величину как жесткость контакта (contact stiffness)... Если не трудно подскажите в какиех пределах изменяется подобная величина допустим при контакте пар сталь по стали, сталь по бронзе...В какой литературе это можно подглядеть? :wink:
Contact stiffness зависит и от материалов, участвующих в контакте, и от размера елементов на контактирующих поверхностях. Вот, например, как это дело объяснено в ANSYS Structural Analysis Guide... Прошу прощения, что по-английски - у меня другого нет.
You need to supply a value for the contact stiffness, KN. (There is no default value supplied for KN.) KN should be large enough that it reasonably restrains the model from over-penetration, yet it should not be so large that it causes ill-conditioning. For most contact analyses, you can estimate values for KN as follows:
KN fEh
where:
f =
Factor that controls contact compatibility. This factor will usually be between 0.01 and 100; using f = 1 is often a good starting value.
E =
Young's Modulus (if you have contact between two different materials, consider using the smaller value of E).
h =
Characteristic contact "length." The value you use here depends on the particular geometry of your problem:
In 3-D configurations, h should be equal to a typical contact target length (that is, the square root of the target area) or a typical element size. For most flexible-to-flexible contact problems, you will usually find that the average size of elements in contact will be nearly equal to the average target length. In situations in which the target lengths differ significantly from typical element sizes, you should use the typical element size for h.
In 2-D plane stress or plane strain applications, let h = 1 for plane strain and plane stress without thickness input, and let h = "thickness" for plane stress with thickness input.
In 2-D axisymmetric analyses, let h equal the average radius where you expect contact to occur.
    • ALEX 141
      Прямо для всех 0i-TF и 0i-TD с такой же РГ и таким же сервоусилителем.   Чёт вы цитату не оттуда выдернули.
    • vad0000
      - Раньше было. Насос включается и выключается этой кнопкой - Сейчас. После подачи питания, насос сразу включается. Отключается также этой кнопкой.   Все правильно?
      Ели Солид не потеряет связи той сборки с исходной многотельной деталью, то все изменения в многотельной детали отразятся в деталях сборки.
      Скорее всего TOOLBOX вы не найдёте.  такие вещи покупались под конкретные проекты, а насколько мне известно, не было продано в России ни одного экземпляра Sinumerik ONE не в составе станка. К тому же надо точно знать версию портала, в котором писался проект для станка, чтобы его успешно  выгрузить. (проект) Или же надо иметь исходый проект PLC.  Есть некоторый опыт в отладке проекта для 840DSL в портале 15.1. Там NCU c контроллером 319PN/DP. Если нет исходного проекта, выгрузить его из контроллера не получается. К обращению из программы к входам\выходам.  В программе можно обращаться к дискретным входам\выходам NCK, вида $A_IN[x] и $A_OUT[x] коих имеется 32 входа и 32 выхода. Это всё есть в документации. Но для этого в PLC должно быть что-то типа этого: A I 4.3 =  DB10.DBX[х], A I 4.4 =  DB10.DBX[х] и т.д, для входов, и соответственно A DB10.DBX[х] = Q5.3 для выходов например. Тогда можно будет прописывать условия в вашем цикле, например: IF  $A_IN[x] = 0 GOTO N10 ELSE GOTO N20 ENDIF В вашем случае вам надо настроить задержку выполнения дальнейших действий через G4 Fхх в цикле где у вас выполняется М71. Так будет проще всего. А если хотите  по датчику, то надо редактировать PLC. Просто так туда лезть крайне не рекомендуется
    • Катугин
      Думаю вряд ли вы последовательно делали такое количество тел. Возможно в многотельную деталь добавляете готовые тела, а те в свою очередь также могут быть много тельными. Я к примеру раньше вставляя какой нибудь узел доставшийся от товарищей, получал большой список твердых тел. Стал смотреть там куча шайбочек, винтиков, гаечек и т.д. и т. п.. После чего решил в больших проектах, где не нужно разбивать вставляемый многотел, стараюсь скомбинировать в одно или минимум тел.    Преобразовать это дело в сборку не всегда полезно. В многотеле проще отредактировать сразу несколько тел, уже потом перевести в сборку.
      а если отключить итерации?
    • alexashh
      Работаю в разных программах и столкнулся с похожей проблемой - в разном софте вращение и панорамирование завязаны на разные сочетания и при одновременной работе невероятно путаешься. Решил проблему покупкой мыши с двумя боковыми кнопками(Xiaomi Mi Dual Mode Silent, если кому-то интересно. Мышь хорошая, но мелковата для длительной работы) и программой X-Mouse Button Control. Там назначил профили для каждого приложения так чтобы панорамирование было на боковую кнопку. Мне очень удобно, а программа занимает 4 Мб оперативной памяти (интересно сколько занимает софт от мышек logi)
    • SecretOON
      Нет насос включается и отключается кнопкой,как на фото выше(раньше этой кнопкой можно сразу два дела делать-вкл и отк насос и мотор, одновременно естественно),аварийной отключают сам мотор. В понедельник выйду на работу,предоставлю фото 8 страницы.
      Либо оригинальный оператор подвинул датчик.
      В таком случае придётся лезть в логику и прописывать правильно логику, чтобы было ожидание по датчику зажима
