Деление программ.
И приходится довольствоваться полуфабрикатами на 90-99% выдающих нужный код, за которым "глаз да глаз".
"С плохим аккумулятором - это не езда" :wink: (С) "Берегись автомобиля"
Ну если ни кто не предумал более удобного метода решения проблеммы то вот.
Function GetNUM(srch)
a = InStr(strInput, srch)
if a>0 then
b=0
do while ((mid(strInput,a+b+1,1)>="0" and mid(strInput,a+b+1,1)<="9") or mid(strInput,a+b+1,1)="." or mid(strInput,a+b+1,1)="-")
b = b+1
loop
GetNUM = mid(strInput,a,b+1)
end if
End Function
Function StrPad(str,n,c)
a = str
for i = len(str) to (n-1)
a = c & a
next
StrPad = a
End Function
Function ToHex(num)
ToHex = LCase(StrPad(hex(CInt(num)),4,"0"))
End Function
set args = Wscript.Arguments
BaseFileName = args(1)
Folder = args(0)
WriteFolder = Folder &"\" & BaseFileName & "_files"
CurrFile = 1
Set fso = CreateObject("Scripting.FileSystemObject")
if not fso.FolderExists(WriteFolder) then
Set fol = fso.CreateFolder(WriteFolder)
set fol = Nothing
end if
Set tf = fso.OpenTextFile(WriteFolder &"\"& BaseFileName & CStr(CurrFile) ,2,true)
Set rf = fso.OpenTextFile(Folder &"\" & BaseFileName,1)
LastCommand = ""
HeaderLine = ""
LastG88 = ""
LastX = ""
LastY = ""
LastZ = ""
LineCount = 0
while not rf.AtEndOfStream
strInput = rf.ReadLine
if HeaderLine = "" then
HeaderLine = strInput
SecondLine = strInput
ThirdLine = strInput
end if
x = GetNUM("X")
if x<>"" then LastX = x
y = GetNUM("Y")
if y<>"" then LastY = y
z = GetNUM("Z")
if z<>"" then LastZ = z
If left(strInput,3) = "G88" Then
a = InStr(UCase(strInput), "X")
LastG88 = left(strInput, a-1)
end if
tf.WriteLine strInput
LineCount = LineCount + 1
If LineCount>1750 Then
tf.WriteLine "M2"
tf.Close
CurrFile = CurrFile + 1
LineCount = 0
tf.WriteLine HeaderLine
tf.WriteLine SecondLine
tf.WriteLine ThirdLine
tf.WriteLine LastG88 & LastX & LastY & LastZ
end if
wend
rf.Close
set rf = Nothing
tf.Close
set tf = Nothing
set fol = Nothing
set fso = Nothing
Изменено пользователем Roz
    • Nastyrnuy
    • paull3
    • Nastyrnuy
      Не обращал внимание, но наверняка менялся. А когда я платы FROM/SRAM местами на двух станках менял, для них вообще все ID должны поменяться. Ни разу сертификат не слетал
      @Viktor2004 вы же знаете как... а cncid менялось при  этом
      Как попробовать? Платы поменять? Так уже менял много раз.
    • Рома калужский
      Здравствуйте. У кого есть токарник, подскажите как заставить его работать по программе, с не вращающимся шпинделем, но работающем в режиме оси "С". А то всегда ругается на то, что нет вращения Сразу ответ на вопрос "а зачем это надо?" - мне нужно поставить метки (точки)
