Что за файлы?
Pro\E 2001 при сохранения файлов чертежей создает файл *.pic.* в 2000ш2 у меня такого небыло.
Что это за зверь такой и с чем его едят, и самое главное как с ним бороться?
может это картинка для отображения в каком-нибудь окне "открой файл" и тп.
когда-то в автокаде практиковалось нечто подобное... :g:
попробуй переименовать: посмотри, что выйдет.
А НЮХ, КАК У СОБАКИ :bleh:
To Export a Drawing as an Image File
You can capture the current screen using the Save a Copy command, or you can "plot" any number of the drawing sheets to an image file using the Print command.
The following types of image files are supported:
JPG - Compressed file for Web viewing (Plot Only)
TIFF - Detail-rich image file suitable for printing (Screen capture or Plot)
PIC - A proprietary PTC format. used for file previews, picture-to-file comparisons and the Model View program.
To save a TIFF file of the current screen:
Click File > Save a Copy. The Save a Copy dialog box opens.
Under New Name, enter the desired new file name.
From the Type list, select TIFF.
Click OK .You prompted "Pop the current window?" Click Yes. The file is created.
To plot a whole sheet (or sheets) as a TIF or JPG file:
Click File > Print. The Print dialog box opens.
Click Destination > Add Printer Type > TIFF or JPEG.
Check To File.
Click OK. The Print to File dialog box opens.
Use the dialog box to name the new file. Click OK. The new image file is created.
To save a sheet as a .PIC file
From the Type list, select Picture (*.pic).
Click OK .The file is created in the current working directory with the .pic extension. The default file name is the name of the drawing.
А ГЛАЗ, КАК У ОРЛА :rolleyes:
To Compare a Drawing to a Saved Image File
You can compare a drawing sheet to a previously saved .pic file of the sheet. (Use the File > Save As command to save .pic files.) You can compare the whole sheet or use any portion of it in magnification.
Click Analysis > Compare Sheet to Picture. The File Open dialog box opens.
Select the .pic file to compare.
The pic file is "layered" over the drawing page. Common items are suppressed, and any different items, either added or deleted, are shown.
To return to the current drawing click Repaint.
spread like wildfire - распространяться со сверхъестественной быстротой ( о слухах, сплетнях и т. п. )
шибко шустрый
GPN
файлы в прошке с расширением *.pkg?
Прошестрил весь веник нашел только один к прошке не имеет ни малейшего отношения
А у меня в ProE таких файлов нет.
Нашел только такое расширение в перечне типов файлов(не помню где брал):
*.pkg - AppleLink package compression format These files are decodable by StuffIt Expander.
Отбой воздушной тревоги!!
*.pkg никакого отношения к проне не имеет!!
Ну, случайно в зип попало...
Случайно, млин... :mad:
Прощения за беспокойство просящий :surrender:
    • Артур8991
    • soldo
    • ak762
    • Ander
    • ak762
    • soldo
