Solidworks 2006, Sp04
Привет !
Сегодня провел апгрейд SolidWorks 2006 с SP03 на SP04.
Несколько моментов, которые удивили:
1. В окне OPEN каждый файл имеет миниатюрную копию сохраненного изображения вместо пиктограммы. Понять где модель, где сборка, где чертеж - невозможно .
2. В чертеже все линки не меняют цвет. Как было в SolidWorks 2001 .
В режиме "Редактировать основную надпись"
P.S. Может кто-то выложит:" Что исправляет SP04 ?"
Вот скопировал все исправления с оффсайта
SolidWorks 2006 SP 4.0
SPR # Description
79344 Pattern components do not follow their seed component Mate definition when using DerivedHolePattern (hole wizard)
101287 Error message that assembly equations are read only due to assembly name change never goes away even after save/reopen
137584 Easier editing and copying of custom file properties.. (including delete)
152744 Design Table does not pick up config descriptions.
184204 Provide a scale option for DXF/DWG for Task Scheduler
185145 Feature suppression state of features in this part is not following configuration setting in design table
188770 Ability to bump revisions via the API.
190359 Need API to get/set base scale when exporting to DXF/DWG
194960 No way to customize in Hole Callout as desired for JIS holes
197670 User-defined properties are not displayed in BOM when drawings are opened lightweight
200819 Dual dimension tolerance precision is dictated by the document properties overriding the properties of the specific dimension
205277 Section view label for DIN standard drawing is not correct.
207959 Custom textures with Japanese filenames are not accepted
210772 If a Hole Wizard hole is patterned and that pattern is patterned again, then callouts on the second pattern cannot be defined by Hole Wizard
211527 The hole callout will only display dimension information in the section view of this part drawing. There is no hole wizard information.
212279 DWG files created from Task Scheduler with True Type font option turned on still export with ACAD fonts. Works correctly in SolidWorks.
216364 'Exclude from bill of materials' option in the properties of a component is not effective when using Excel based BOM
217266 Mate tool is unavailable in this assembly
217820 Leading zeros setting not followed in hole callout.
219060 SWPipeLength is the only custom property available in the property manager for this BOM column
225459 Revision Table can have a column be set to look at a custom property, but no custom property info seems to get pulled.
230510 Ends of slot invert when adding slot library feature as per the 2005 What's New.
230742 Annotations on sheet format hide but do not gray scale to be shown with Hide/show annotations
235775 Section view doesnot update when view orientation in model file is changed
241900 Shaded Cosmetic Threads cause significant performance degradation when rotating/panning weldment parts containing many bodies.
242431 When SolidWorks office Pro license already issued issue another Office pro license rather than a PDMWorks Stand-alone license
242604 Cosmetic thread not displayed in the section view of some drawing.
244364 Print extents does not print at the right zoom level, it leaves large margins around the drawing and doesn't match the zoom extents of ACAD
247697 Halos not working for dimensions / notes displayed in section view hatch in this drawing
249711 Copy settings wizard does not as default work with UNC coded paths.
252274 MassProperty::SetAssignedMassProp should work on assemblies
252386 Rebuild icon never goes away on a particular part in an assembly
256631 Balloon disappears if open detached drawing with no model loaded.
263645 If Cosmetic Threads are inserted in drawing of setting "High quality" cosmetic threads display, Cosmetic Threads are not correctly displayed
264450 Problem with holewizard feature - Cosmetic Thread dissapears on forced rebuild.
264597 Saving a general table template with text in it does not retain the text
269326 Equations not being renamed properly after Copy Document with children in SW Explorer.
275982 Shaded detail view has visible facets
276876 Error updating PDMWorks local view icon (local view is shown with white up arrow in a green circle - local version is newer than the vault version)
276928 'Send to back' on bitmap in drawing causes JPEG or TIFF output of bitmap to be flipped upside down.
279433 The Exclude Fasteners option for a drawing section view does not exclude 'create copy' Toolbox parts
279672 Editing the master part of a mirrored component causes mates to lose references
279886 View border size changes after Inserting Area Hatch/Fill in this detail view.
280729 'Rebuild necessary' symbols remain on the routing subassemblies even after rebuild
281197 Support for pre-defined views in an international language operating environment
281336 Rebuild flag does not go for any conduit assembly
281737 Saving BOM to CSV file : SolidWorks should recognise and use seperator for language of OS as per MS Applications.
284527 Balloon item numbers do nut update when Weldment Cut List is sorted into different order.
284977 UG NX3 file attached opens with no solids in SolidWorks 2006 SP 0.0
285038 Need a way to delete documents in the vault through the API.
289171 Support the import of newer Inventor version files. ( 8 - 10 )
289683 Drawing's references properties must be updated before the drawing is being checked in
289872 Changing a library feature configuration can result in duplicate feature and sketch names in a part.
290108 Rearranging columns order in reporting dialog is not maintained in output csv or txt file
290301 Installation of SolidWorks SolidNetWork License manager USB dongle and Remote desktop to Win2003 server does not find the dongle
290606 Adding a sub-assembly via AddComponent4 results in sub-assembly components that cannot be used until a rebuild is called Applies to adding components in general.
291907 Cannot change mouse cursor.
292548 Route does not start from the C point where 'start route' command was initiated. It starts from the first C point.
292779 'Read from file' Revision is not accepted if Lifecycle is enabled in Vaultadmin
293234 When save drawing as dwg/dxf only 2 gtol values are exported – not all
293426 Please install the PDMWorks API help to \common files\solidworks shared
293974 Creating Relative view to Weldment model displays hidden cosmetic threads.
294865 Shaded drawing views that also contain sketches are shown incorrectly when saved as TIF. Lots of extra lines appear.
295619 Drawing views are not created when starting the model view function in a drawing and selecting a component from an open assembly FM
296195 Japanese version SW fails to import DXF file for sheet format.
297574 Show thumbnail graphics in windows explorer does not show thumbnail in Explorer
297590 Custom property includes units for select properties, request ability to disable
297601 Can't print OLE object inserted from Excel
298160 Save and Print events not raised in VB6 clients (.net okay)
298965 Accessing the view tab in document information freezes both eDrawings and SolidWorks
299196 File size of drawing continues to grow after multiple saves past file shadowing limits.
299428 Document Information, View of attached drawing no longer displays sheet format picture and excel table in PDMWorks 2006 SP 3
299580 Assembly window display data disappears after doing certain file open and close operations with a lightweight drawing and referenced files.
300107 Sketch dimensions disappear when zooming while in edit component mode of assembly
300348 'SolidWorks is unable to obtain required memory.' error while zooming into OLE object in drawing
300836 Print PDF created from Save as PDF adobe produces thinner lines than Bluebeam PDFs or native SolidWorks Print
301697 Installation of SolidWorks 2006 SP3.1 through upgrade process may not recognize the Original CD
303701 Cannot print High Quality A0 drawing with shaded views, right hand side of the print output is blank.
305686 Embed font option in save as PDF with adobe does not embed all fonts, only Microsoft standard fonts, not SolidWorks fonts
306677 After activating SolidWorks/Office/Premium 2006 SP3.4, fail to save as eDrawings/IGES/STEP/ACIS/DWG, etc. (Error: A101, 2)
307886 Hole wizard holes : ISO drill sizes are ignoring decimal values (for ex. Dia. 6.3 is measured as 6). Related to Swedish regional settings.
Приветствую всех.
Не смотря на то, что SolidWorks выпустил SP4.1 в догонку SP4.0, впечатлению от четвертого с/пака самые хорошие. На данный момент, я считаю, что SW2006SP4.0 - лучшее, что есть :surrender: (у меня :smile: ). Серьезных глюков не заметил.
Аналогичное мнение - серьезных глюков также не заметил. SW2006 sp4 работает стабильно, ещё не разу не вылетел...
Вместо сохранения я вообще через виртуальный принтер Adobe PDF печатаю. Никто ососбо не жалуется. После какого-то SP(2-ого или 3-его), была такая бяка. Вот так и обошел.
Сегодня такой нюанс обнаружил: в SW2006 (по крайней мере в сп4) изменились принципы работы с памятью в чертежах. При неотсоединенном чертеже файл подкачки растет и никогда не убывает. доходит c 400-500 Мб у только что открытого до 3.6 Гб и SW виснет надолго или навсегда. Тот же чертеж отсоединенный - стабильно держит файл подкачки 700-800 Мб. Правда в другом окне держу решенную модель сборки, для которой чертеж.
В 2005, а кажется и раньше, в отсоединенном чертеже большой сборки вообще ничего сделать нельзя было - на любой чих загружалась модель, потом выгружалась - и так десятки минут на одно движение мышкой. Спасался неотсоединенными.
Т.е. стало наоборот.
Приветствую всех.
Самый главный глюк для меня-глюк при сохранении в pdf.Поэтому снес этот SP
Я лично уже давненько, еще с SW2004, использую, как и katalex-3, - виртуальный принтер Adobe PDF (Adobe Acrobat 6.0 Pro). Все работает четко и без глюков :smile: . Плюс, так еще мы решили вопрос с выводом на печать больших чертежей (у нас принтеры на А4 и А3).
ber2004
Того, что ты описываешь, у нас нет :g: .
Всем привет! Что сказать впечатления у меня от SP4 хорошие но не очень. Возникла такая фишка что SW падает постоянно но думаю что это просто напросто от системы все идет, так как были глюки с системой и как то все лень ее переустановить. А так все нормально ... вперед и с песней
Приветствую всех.
Дело в том, что SP4.0 стоит у меня на домашнем компе, и на работе на соседнем :sad: . На моем же рабочем SP4.0 присутствует лишь на виртуальном компе (я на нем провожу ПИОНЕР-установку).
В реальности на работе я работаю в SP2.0 (SW не откатывается в 0.0, а без этого не могу накатить SP4.0; и как пишет dinu:
SP2.0 - сплошной глюк! Слетает чаще, чем начальник ходит курить, а курит он часто :smile: .
Вобщем, жду не дождусь передышки в работе, чтоб переустановить все...
<{POST_SNAPBACK}>
Все еще интереснее: при этом оперативка расходуется не более чем на половину (один гиг из 2-х простаивает) и процессор занят на 40-60% не более!! Это в отсоединенном чертеже с модели более тысячи компонентов, много разрезов. Работает неспешно, но работает. Пока чертеж был неотсоединенным - своп рос неукротимо и после 3.5 гигов или тормозило или вываливалось. Видимо они (на пару с Win64) больше не могут свопа при физической оперативке 2 Гб.
Рост свопа напомнил мне М-Десктоп (3-й еще), который аналогично терял память и приходилось каждые 15-20 минут его перезапускать. Именно тогда я узнал, что такое своп-файл. Оттого на Солид и перешел ;-)
Интересно. а кто-нибудь использует ключ /3GB в WinXP SP2, выделяющий дополнительно 1 Гб памяти под приложения?
Пока не жалуюсь.
При возникновении проблемы с отваливанием папки ГОСТ в браузере солида проверьте файл Toolbox.ini. Пропишите в нем путь к папке Solidworks Data (по умолчанию C:\Program Files\Common Files\Solidworks Data)
Читаю и ужасаюсь...
Как ни прискорбно это для SolidWorks, но моя "конторка" явно ничего не проиграла проигнорировав 2006 релиз. ;)
Может подскажешь как, где, зачем его использовать.
Читаю и ужасаюсь...
Да ничего вроде ужасного. Проблемы всегда были, есть и будут. Представьте себе программу, которая устраивала бы абсолютно всех, без глюков и мелких недоработк. Фантастика!!! На сегодняшний день, естественно...
Читаю и ужасаюсь...
Представим что sw2001 работает на ура, будет ли фарма покупать лицензионный 2006 за 16тбаков если там добавили маршрут. Конечно некоторые умеют и снег зимой продавать...
Собственно говоря, SolidWorks-2001+ был не плох, а все последующиее релизы были соответственно лучше предыдущего, но обещанного скачка на уровень систем "тяжёлого" класса не произошло, а вот трудности с установкой и "заплатками" что называется "на лице". Для предприятий имеющих порядка сотен рабочих мест это уже весьма чувствительно.
Радикального, по сравнению с SolidWorks-2005, выигрыша SolidWorks-2006 не имел, хотя преимущества были несомненно. Можно сказать призводная роста снизилась, да и направления развития выбираются фирмой DS достаточно странные. Может не хотят CATIA "подставлять"...
Посмотрим, что будет в SolidWorks-2007.
Лично мне SolidWorks кажется несколько похожей на достигший своего потолка самолётик - лезть ещё выше пытается, пыхтит, пожирает кучу ресурсов, а того и гляди в штопор свалится.
Кстати, если система требует 5 "заплаток" на релиз и то вызывает нарекания - это уже называется скорее выжималовкой денег из добросовестного покупателя, чем необоснованно завышеной скоростью выхода очередной версии.
Изменено пользователем Странник
Присоединяюсь. И где бы сейчас тогда был бы этот форум? Да и жизнь (работа в SW) была бы скучнее... :smile::smile::smile:
      все идеи описаны в руководстве фанука. отправляйте в ремонт . мы отправляли в ремонт оба блока при ошибке рекуперации 7 у вас четкая ошибка 1 сверхток на линии dc источник ошибки силовой блок psm - поменяйте его с соседнего станка только целиком.
    • Клиент
      Может быть, Вы сразу сделали все идеально?  А где все берут MC2024? - тоже нужно новые версии установить
    • Anatlijj8
      Добрый день. Скажите сразу встроенная в солидворкс какая версия идёт?  Скажите как-то можно где-то скачать версию про?
    • Lev72rus
      Есть ли более свежая ссылка на видео? Похожая беда сейчас
    • bard
      Странно, как-то. Кто Вам разрешит отгружать изделия (не важно) какие по безлитерной документации? Кто Вам разрешит использовать в литерованном изделии безлитерные части? Если Вы приняли неверные технические решения, как Вы про это узнаете не проведя испытания?
    • vad0000
      Не важно, Не нужен output при зелёной и красной кнопки.
    • ispite
      Всем привет, спасибо за ответы, но просто так не удалось создать сборку, солид выдавал ошибку. Пришлось Сохранить как IGES (файл разросся до 920 МБ), потом открыл как деталь (в нейстало шустрее работать), нажал "создать сборку" и она создалась! НО она создалась без поверхностей, а они тоже нужны Всем привет, спасибо за ответы, но просто так не удалось создать сборку, солид выдавал ошибку. Пришлось Сохранить как IGES (файл разросся до 920 МБ), потом открыл как деталь (в ней появились Тела и Поверхности и стало шустрее работать), нажал "создать сборку" и она создалась! НО она создалась без поверхностей, а они тоже нужны. Как создать сборку с телами и поверхностями? Пробовал в детали сохранить поверхности, но оно как будто работает наоборот и все поверхности стирает.  PS удалите плз предыдущий ответ, я его случайно отправил.
    • Alexey8107
      Всем доброго дня. Имеется ивановский обрабатывающий центр ИС-800, в нем установлены: PSM-45HVi A06B-6120-H045 SPM-30HVi A06B-6121-H030#H550 Возникла авария 9030 Overcurrent in the converter input circuit. Если смотреть В-65285 в этом случае на PSM должна отображаться 1, а на SPM - 30. Так оно и есть на самом деле. Документ ссылается на пункт 3.1.1, в свою очередь этот пункт говорит о неисправности PSM и следует проверить Входящее питание. Скорее всего здесь имеется ввиду питание управления, оно 240 В и стабильно Рекомендуют проверить реактор. Сразу откидываем, т.к. дело до включения силового питания еще даже не доходит, МСС отключен. Да и реактор штатный, всю жизнь работал с этим реактором. Проверить IGBT. Проверить проверил как мог, на КЗ, но дело до силовухи еще не доходит, ее питания еще нет и физически включиться не может из за MCC(ну это естественно, блок в аварии). Принципиально все рекомендации. На LEADWELL была похожая ситуация, на торможении шпинделя на PSM помнится выпадала авария 1, а на шпинделе не помню уже что. Тоже думали на PSM, а судя по всему мозг вынимал рекуператор в SPM. Т.к. на шине 500 вольт на торможении шпинделя напряжение вылетало далеко за 500 вольт выше. Здесь тоже нечто подобное, SPM опрокидывает PSM в аварию. Вобщем при включении питания станка, запитывается только управление на PSM, а он в свою очередь раздает 24 вольта на все остальные блоки по CXA2A, если все нормально и ЧПУ включена, замыкается контакт МСС, разрешая подачу силового питания на PSM. Шаги загрузки на полностью исправном станке PSM    SPM   -          A   -         50   -         12(или 18)   -         -- После включения ЧПУ и подачи силового питания   0         0 У нас PSM    SPM   -          A   -         50   -         12(или 18)   1         30 Включение силовухи невозможно. Что было сделано: 1. Проверены все питания, 240 СХ1А, 24 СХА2А, силовое питание, везде порядок. 2. Проверены IGBT на PSM и SPM, явного замыкания нет. 3. Проверены обмотки серво двигателя шпинделя. На всех 0,4 ома(сопротивление щупов 0,2 + обмотки 0,2 ома). Сравнил с заведомо исправным таким же двигателем(он стоит в другом таком же станке и работает), все тоже самое, На массу КЗ нет. Да и силовухи тоже нет, так что это бессмысленно. 4. Откинул от PSM разъем СХА2А(тупо обесточил остальные блоки от 24 вольт), включил питание управления, PSM перестал опрокидываться в ошибку, на дисплее "-". Ждал долго, не опрокидывается. Силовое питание подавать не стал, ибо чревато для остальных блоков, а скидывать шинку постоянного тока честно говоря поленился. 5. С соседнего станка снял плату управления SPM и переставил в неисправный станок, по номерам они идентичные. Станок включился и даже подал силовое питание на PSM без всяких аварий. Гонял пару минут в холостую, все было нормально, но после опрокинулся с той же ошибкой 1 и 30 на PSM и SPM соответственно. 6. Взял плату управления SPM с неисправного станка и установил в исправный. Станок включился и сколько бы не гонял, и даже шпинделем крутил, не опрокидывается. Т.е. к обоим платам претензий ноль. После вернул все обратно. Исправный станок работает как ни в чем не бывало, неисправный сразу опрокидывается в аварию почти сразу после включения управляющего питания. На ЧПУ ошибка 9030 и какие то еще по осям, но они связаны с отсутствием питания на шине постоянного тока если не ошибаюсь, так что это нормально. Итого, силовуха явных признаков неисправности не имеет, и даже на какое то время с другой платой включает силовое питание(скорее всего это связано с разбросом параметров защит на разных платах). К самому PSM тоже вроде претензий не должно быть, хотя В-65285 указывает именно на него. В истории с LEADWELL точно помню, что тоже все указывало на PSM(в том числе 1 на дисплее), и даже сервисный инженер FANUC был уверен в неисправности именно PSM. По факту, неисправен был как раз SPM. К платам управления тоже никаких претензий, обе работают в исправном станке. Единственное логическое объяснение, неисправность силовухи SPM. НО!!! Шина постоянного тока даже не думает запитываться, так что и тут с опрокидыванием сразу после включения есть засада! Ну не тестирует же SPM и PSM силовую часть напряжением 24 вольта??? Ведь до включения силового питания в этом случае даже не доходит из-за аварии! Может у кого есть еще идеи или опыт устранения таких дефектов? Помнится у фанука была типовуха на платах А16В-2203-0623 с датчиками тока, они отгорали и привод отваливался в аварию по одной из фаз. Это были привода шпинделя и двух осей в одном корпусе, были такие у нас на токарных. Сервисники фанука тогда их тучами меняли... Хотя тут я думаю не наш случай
      Даже при всём при этом оно не всегда корректно работало, так что даже в старых версиях было быстрее удалить размер и потом вставить заново, чем искать эти точки размеров, а потом пытаться их привязать к новому месту.   Возможно это всего лишь глюк новой версии, в последних версиях они похоже штатно закладываются.
      @davidovka я их сразу ссыпаю в TEMP,  в тех что живы нет отметок о создании current_session.pro. Интересно что сам current_session.pro создаётся, но не обновляется дата в отличии от даты модели. Может быть и вправду менял какие нить настройки и забывал сохранить
