Creo Parametric 3.0
Bamboo
Добрый день.
Перешел с WF5 на CREO3.0 и следующая проблема - долго думает при сохранении (похоже что регенерирует всю сборку) и задумывается при правке (тоже похоже что регенерирует).
Вот мой конфиг
drawing_setup_file C:\ptc\pro_stds\configs\1.dtl
format_setup_file C:\ptc\proeWildfire\text\1.dtl
pro_unit_length unit_mm
pro_unit_mass unit_kilogram
template_designasm C:\ptc\pro_stds\start_files\mmkgs_asm_design.asm.1
template_drawing C:\ptc\pro_stds\formats\a2h_1.frm.33
template_sheetmetalpart C:\ptc\pro_stds\start_files\mmkgs_part_sheetmetal.prt.1
template_solidpart C:\ptc\pro_stds\start_files\mmkgs_part_solid.prt.1
todays_date_note_format %dd-%Mmm-%yy
tolerance_standard iso
tol_mode nominal
weld_ui_standard iso
pro_library_dir C:\ptc\Libraries
chamfer_45deg_dim_text iso/din
allow_anatomic_features yes
allow_refs_to_geom_reps_in_drws yes
auto_show_3d_detail_items no
autobuildz_enabled yes
default_ang_dec_places 2
default_dec_places 3
default_ext_ref_scope all
disp_trimetric_dwg_mode_view no
display_planes NO
display_axes no
display_points no
fail_ref_copy_when_missing_orig no
freeze_failed_assy_comp yes
mass_property_calculate automatic
mfg_xyz_num_digits 4
mp_calc_level all_models
punch_axis_points yes
save_display yes
save_instance_accelerator explicit
save_model_display shading_low
display_coord_sys no
pro_font_dir C:\ptc\Fonts_proe
trail_dir C:\ptc\Trails
pro_symbol_dir C:\ptc\pro_stds\symbols
allow_ply_cross_section yes
sketcher_blended_background yes
sketcher_undo_stack_limit 100
sketcher_animated_modify no
sketcher_save_preview_image yes
sim_pp_background_color white
raster_plot_dpi 300
use_8_plotter_pens yes
variable_plots_in_inches no
plot_linestyle_scale 1
pro_texture_library C:\ptc\pro_stds\graphiclib
menu_show_instances no
dir_cache_max 1024
pro_material_dir C:\ptc\pro_stds\material
rename_drawings_with_object both
use_temp_dir_for_inst yes
start_model_dir C:\ptc\pro_stds\start_files
template_mfgmold C:\ptc\pro_stds\start_files\mmkgs_mfg_mold.asm
template_mfgcast C:\ptc\pro_stds\start_files\mmkgs_mfg_cast.mfg
hole_diameter_override yes
pro_group_dir C:\ptc\pro_stds\group
show_dim_sign no
accuracy_lower_bound 1e-06
start_appmgr no
model_grid_spacing 10
ang_units ang_sec
default_abs_accuracy 0.05
display_in_adding_view minimal_wireframe
parenthesize_ref_dim yes
pro_colormap_path C:\ptc\pro_stds\configs
number_user_colors 1024
color_resolution 0.01
pro_format_dir C:\ptc\pro_stds\formats
smt_allow_flip_sketch yes
pro_sheet_met_dir C:\ptc\pro_stds\bend_tables
sketcher_dimension_autolock yes
bom_format C:\ptc\pro_stds\formats\Шаблоны_таблиц\таблицы_спецификации\bom_simple.tbl.3
efx_enabled yes
acrobat_reader C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
plot_file_dir C:\ptc\pro_stds\plot_config
plot_names no
pro_plot_config_dir C:\ptc\pro_stds\plot_config
use_software_linefonts yes
pdf_use_pentable yes
pdf_linecap projecting square
pdf_linejoin bevel
mdl_tree_cfg_file C:\ptc\pro_stds\start_files\tree.cfg
search_path_file C:\ptc\Libraries\search.pro
search_path &home
regen_progress_bar embedded
quick_print_plotter_config_file C:\ptc\pro_stds\plot_config\ms_print_mgr.pcf
pro_colormap_path C:\Program Files\proeWildfire 5.0\pro_stds\symbols
pro_colormap_path C:\ptc\pro_stds\symbols
mapkey $F6 @MAPKEY_LABELСоздание pdf;~ Command `ProCmdModelOpen` ;\
pro_note_dir C:\ptc\pro_stds\notes
pro_editor_command C:\Windows\notepad.exe
part_table_editor editor
relation_file_editor editor
system_colors_file C:\ptc\pro_stds\configs\syscol_vadim.scl
default_dec_places 1
save_instance_accelerator NONE
spin_with_orientation_center no
spin_with_part_entities no
shade_quality 4
edge_display_quality high
new_layout_feature_update_state MANUAL
direct_child_of_layout_update MANUAL
bump_revnum_on_retr_regen no
а также моя система
Добрый день.
В версии Creo М030 есть такие проблемы на конфиге по умолчанию. Ставьте М020 или вот http://cccp3d.ru/topic/58519-download-software-creo-parametric-proengineer/?p=669987 может там поправили.
Добрый день.
Вот мой конфиг
tol_mode nominal
display_planes NO
display_axes no
display_points no
save_display yes
!save_model_display shading_low
raster_plot_dpi 300
!dir_cache_max 1024
show_dim_sign no
start_appmgr no
ang_units ang_sec
afx_enabled yes
plot_names no
pdf_linejoin bevel
!search_path &home
!regen_progress_bar embedded
part_table_editor editorove
shade_quality 4
regen_solid_before_save no
а также моя система
search_path &home  весь home перебирает, зачем?
А если там прожектов на 100500 терабайт
Попробуйте
Пытаюсь пересесть сразу с WF4 на Creo3...  :doh:
1.Как почистить рабочую папку от старых версий файлов? Раньше при выборе "Удалить - Старые версии..." была строка, в которую по умолчанию выводилось имя открытой модели (сборки, обработки) в виде "деталь.prt". И после отработки этой команды из папки удалялись файлы "деталь.prt.1","деталь.prt.2","деталь.prt.3"... и т.д. Оставалась только последняя деталь с максимальным индексом "*.prt.index". Теперь при вызове этой команды Creo зачем-то предлагает удалять старые версии детали только с определенным индексом, например "деталь.prt.9" В результате из папки ничего не удаляется, а файлы "деталь.prt.1","деталь.prt.2","деталь.prt.3" и т.д. остаются на месте.
2. Вырвать глаза дизайнеру интерфейса за голубые иконки на светлобелосером фоне. Ужас.
3. Риббон - тут всё понятно. Отключил сразу же.
4. Панель с настройками переходов обработки теперь жестко закреплена внизу. После того, как привык к верхней - это жутко бесит, особенно на большом мониторе.
5. Раньше, чтобы быстро изменить параметры любого перехода в обработке достаточно было в дереве на нём правой кнопкой "Изменить..." и ты уже в окошке параметров меняешь что нужно. Теперь под правой кнопкой пункт Edit Step, внутри которого выпадающая менюшка, и только там находится "Править параметры шага". Нафига было закапывать??? +одно лишнее действие.
6. Можно ли настроить положение "Диспетчера процессов" в обработке? Если через диспетчер процессов заходить в правку перехода, то это окошко выскакивает в правом нижнем углу экрана и закрывает кнопки с галочкой и крестиком, чтобы принять сделанные изменения. Приходится постоянно сворачивать его или двигать. Раньше ткнул мышкой в основное окно и это ушло на задний план, а теперь оно продолжает быть поверх всех окон. Задолбало. Приходится делать столько лишних ненужных действий.
7. Переходы обработки. Часть переходов редактируется как и раньше - через меню в правой части экрана, часть - в нижней панели. Нафига было вообще менять? Или если взялись менять, то поменяли бы всё. И опять, чтобы добраться до параметров обработки нужно снова одно лишнее действие совершить - сначала нажать вкладку "параметры", а потом внизу зеленую кнопку править параметры обработки.
8. Виды обработки превратились в ряд еле различающихся иконок.(когда было прописано в правой менюшке "черновая, чистовая, профиль... и т.д." было в 100 раз удобнее, быстрее и понятнее). А теперь путаница в картинках.
9. Ради эксперимента запустил просчёт одной и той же траектории в WF4 и Creo3 (поверхность сферической фрезой по линиям реза, шаг задал поменьше, чтобы дольше считал). Траектория получилась цифра в цифру. Creo3 считал почти в 2 раза дольше. чтозафигня?????
1. Да вроде удаляет все версии, как и раньше.
О команде Purge или программах для очистки папки от старых версий слышали?
8. Те иконки что на риббоне поддаются настройке (маленькая или большая с названием или без).
Про Purge читал, но не пользовался... привык юзать штатную кнопку "удалить старые версии". :)
Настраивать риббон?... спасибо, неее, ....фтопку! :wallbash:
вообще мне  его замысел непонятен - зачем прятать кнопки под закладки, да ещё и делать разноразмерные иконки? чтобы мозг сломать в поисках нужной кнопки? ну, я думаю, об этом на форуме уже много писали, поэтому не буду повторяться :rolleyes:
Не получается создать локальную обработку по предыдущему переходу (черновая выборка окна). Делаю всё, как обычно делал в WF4 - пишет, невозможно создать траекторию. :((
если тебе лень один раз постараться для себя любимого, то что уж говорить...
Купил новую машину, и вместо того, чтобы сесть и поехать с прежней скоростью, нужно перекрутить руль и педали на место, т.к. педали на заводе прикручены под капотом, а руль в багажнике. И колёса подрегулировать под один размер, т.к. они зачем-то разные... вот так мне видится история с риббоном.
Привычка - сложная штука. Когда на старом интерфейсе за годы работы все действия настолько доведены до автомата, что иногда даже не смотришь куда нажимаешь - тут на обычных привычных вещах начинается полный ступор.
Ну, еще раз повотрюсь, что вопросы к интерфейсу - это лирика...  :smile: можно долго развивать эту тему.
Помогите, кто чем может, с локальной обработкой, пожалуйста :worthy:
А в чем вопрос-то?
А в чем вопрос-то?
Вопрос в том, как заставить работать локальную обработку по предыдущему шагу?
Черновая обработка кармана с припуском 1 мм большой фрезой D25 - всё хорошо работает.
Локальная обработка того же кармана с припуском 0,5 фрезой меньшего диаметра D10 - "траектория инструмента не может быть создана".
Что может быть не так?
Пример в приложении:
pack.zip
День добрый! Посмотрел вашу обработку и тоже не смог получить локальную обработку по предыдущему шагу, менял и точность модели с относительной на абсолютную и заново создавал подобную деталь и обработку. Я сейчас редко делаю обработку в CREO, в основном в нём модели строю, а обрабатываю в другой CAM. У вас какой билд установлен? У меня сейчас М030. Возможно это баг этого билда. Попробуйте М040. Но скорее всего, мы с вами что-то не так делаем, подождем когда другие скачают и посмотрят.
Тоже думал, что это косяк какой-то версии, но пробовал в 3 разных, и F000, и М030, сейчас М040 - везде всё одинаково не работает. :(
Забудьте как страшный сон CAM-модуль в Pro/E и Creo, считать в нем сложные формообразующие - это какой-то геморрой одновременно с простатитом, PTC в этом модуле ничего нового не делает уже давно и причем они это знают и как всегда одни отговорки. Ранее у них была очень перспективная система - Toolmaker, но тема заглохла, а в 2009 году компания NC Graphics вообще выкупила исходный код и теперь этот продукт развивается под другим брендом - NCG CAM или DEPOCAM в зависимости от реселлера. Единственное конкретное преимущество у cam-модуля от PTC  - это прямой интерфейс с 3d-моделью.
Ситуация с локальной обработкой такова:
в Creo 3.0 объемное фрезерование это не тоже самое что было раньше.
Поэтому локальное фрезерование после объемной сбоит.
РТС рекомендует создать объемное фрезерование старого образца. Для этого нужно включить опцию enable_classic_nc_steps yes
Создать объемку старого образца а потом применить локальное фрезерование.
Когда исправят - Написали в C3M050
Изменено пользователем zeppelin
Может кто знает. Я часто из Прое чтобы передать файлы на сторону делаю файлы парасолид т.е. x_t. И каждый раз он создает еще log файл который мне нафиг не нужен. Может есть какая то опция которая может отменить этот log файл?
А как теперь в Creo3 в режиме сборки переименовать конкретную деталь ?
Раньше была возможность выбора переименования любой детали.
Не вызывать-же нужную деталь и уже в режиме детали выполнять переименование !!??
Господа!
Меня этот вопрос очень напрягал, регулярно возникает
такая необходимость.
Оказалось все просто и удобно.
После команды "переименовать" жмем "ОК" и появляется окно,
в котором преименовываются все файлы.
