Wildfire 3
Finist
Установил сегодня новую вышедшую версию F000, опять была задница с лицензией :blink: , пришлось заново вытаскивать с сайта PTC.
Вручена награда читаем правила п15
2 all Заканчивайте с кряками.
Изменено пользователем Booster
2zeppelin
Description
Granite-based Cross-Release Interoperability (referred to hereafter as GCRI) was developed based on PTC’s Granite Interoperability Kernel. The Granite Kernel, the fundamental cornerstone of Pro/ENGINEER’s geometry model, is a software library that has the ability to read (or write) geometry, geometry attributes, layer information, user-defined parameters, and assembly structure from (or to) a Pro/ENGINEER part (.prt) or assembly (.asm) file without Pro/ENGINEER being present.
PTC has created a Granite plug-in module to replace the neutral file approach to cross-release interoperability in Pro/ENGINEER Wildfire 3.0. This plug-in module can be provided to a Wildfire 2.0 user and, when installed in the Wildfire 2.0 loadpoint, will allow that Wildfire 2.0 user to read the Wildfire 3.0 model directly via Granite. This is without the need for the Wildfire 3.0 user to create an intermediate neutral file. All of the information that can be read from the Pro/ENGINEER model by the Granite kernel can now be leveraged by the Wildfire 2.0 user.
A unique feature of GCRI is the ability of Wildfire 3.0 users to take new features that have been added to the image model by the Wildfire 2.0 user and graft those features onto the original, fully-featured master model. This is very similar to how a UDF works, except references need not be selected for the UDF to be placed; GCRI functions handle this placement automatically.
Additional Information
GCRI Setup
Before setting up GCRI, the application component "readnewermodels.dll", which is not yet shipped to customers, will need to be obtained. Please contact Asa Trainer, Product Management, PTC (atrainer@ptc.com, 781-370-6258) in order get access to a ProjectLink project to download and evaluate this capability. The subject of any emails should be "GCRI".
Note that GCRI is currently only available for Windows and Sun platforms.
Additional information can be found in the GCRI White Paper which is also available (and will be continually updated) in the aforementioned ProjectLink project.
1) Obtain the Wildfire 3.0 "readnewermodels.dll" application component and place this application component in the <machine_type>/obj directory below the Wildfire 2.0 loadpoint as shown below.
For example: <loadpoint>/i486_nt/obj/readnewermodels.dll
2) Add the following config options to the Wildfire 2.0 config.pro PRIOR to launching Wildfire 2.0.
topobus_enable yes
atb_show_log off
atb_auto_check_on_update off
atb_auto_check_on_retrieve on
3) Add the following config option to the Wildfire 3.0 config.pro PRIOR to launching Wildfire 3.0.
cri_grafting_enable yes
4) Launch Wildfire 2.0 and check to see that the #File > #Associative Topology Bus is available.
5) Validate the installation by checking for the following:
When a Wildfire 3.0 model is retrieved in Wildfire 2.0, the message "You are opening a Pro/ENGINEER Part created in Pro/E Wildfire 3.0. Would you like to proceed opening it as a granite model?".
After retrieving a Wildfire 3.0 model in Wildfire 2.0, select any feature, RMB > #Info > #Feature. Under the "Comments" section, the message "FEATURE IS READ-ONLY" is displayed.
GCRI Operational Use
There are three elements in the workflow for GCRI. They are:
1) The reading of a newer release model into an older release;
2) The use of ATB functionality to check the status of a model read using GCRI or updating such a GCRI model to match its master model;
3) The grafting of features, added to the GCRI model, back onto the master model from which it was created.
Reading a Wildfire 3.0 model into a Wildfire 2.0 Session:
Select #File > #Open. From within the File Open dialog, select any Pro/ENGINEER part or assembly file for opening. If the user selects a part or assembly that is either Wildfire 2.0 or earlier, it will be read into session directly. If a Wildfire 3.0 part or assembly file is selected, the normal error message, “<model_name> cannot be retrieved”, will be replaced by the message "You are opening a Pro/ENGINEER Part created in Pro/E Wildfire 3.0. Would you like to proceed opening it as a granite model?", indicating that the model is a GCRI model, and asking for confirmation to open it. This confirmation is simply to inform the user that they are opening a GCRI model, not a native one, and that certain model behavior and content differences exist between these two model types.
Performing an ATB Check Status or Update Operation:
Although the Wildfire 2.0 user does not own the fully featured model, the model can still be used for any other downstream use. Examples of such use include Pro/MECHANICA analyses, cable routing, manufacturing, annotation, rendering, or even the addition of new modeling features. Because of ATB associativity, rapid updating of the model based on changes made to its master model are handled quickly and easily.
The normal flow of operations here are to check the status of the GCRI model relative to its master model. Click #File > #ATB > #Check Status. The ATB functionality in Pro/ENGINEER will check the status of the Wildfire 2.0 image model relative to its Wildfire 3.0 master model. The result will be a change in the color of the ATB icon for that part from blue to red (and the presentation of a warning message in the message bar) if the model is out-of-date relative to its master model. The user can choose to act on that notification right away or simply wait until a more convenient time to perform the second operation, the update.
To update the model, click #File > #ATB > #Update. The ATB functionality will replace the existing Wildfire 2.0 image model with the latest version of the Wildfire 3.0 master model and reattach, automatically, any Wildfire 2.0 features added to the model. Similarly, any downstream uses of the updated image model (manufacturing, analysis, routing) will associatively update.
For more information the ATB and how to customize ATB operations using config settings, refer to the Pro/ENGINEER Help Center.
Grafting Features added in Wildfire 2.0 back onto the Wildfire 3.0 Master Model:
Once features are created in Wildfire 2.0 and the model is saved, those features can be grafted back onto the original Wildfire 3.0 model. Retrieve the original Wildfire 3.0 master model. Click #File > #Graft Features, and within the File Open dialog, select the Wildfire 2.0 image model that corresponds to the master model in session.
В WildFire3.0 можно сразу сохранить чертеж в PDF - Save as PDF. Только вот как установить при выводе толщину линий?
Так не сохраняет - вот и все впечатления...
<{POST_SNAPBACK}>
Странно.. :g:
Некоторое время назад где-то здесь (не нашел где) кто-то утверждал, что сохраняет.. с сохранением дерева модели.. :rolleyes:
<{POST_SNAPBACK}>
Именно в 2001 или это относится и к WF1, WF2 ?
Через "Сохранить копии" нету возможности выбирать формат сохранения. Да и врятли младшие версии поймут некоторые созданные фичеры в WF3.
Тупой машинный перевод части текста, представленного выше SVB:
Ptc создавал модуль гранита вставляемый для того чтобы заменить нейтральный подход к архива крест-vypuskaet interoperability в Pro/ENGINEER Wildfire 3.0. Этот вставляемый модуль можно снабдить потребитель Wildfire 2.0 и, после того как я устанавливан в loadpoint Wildfire 2.0, позволит тому потребителю Wildfire 2.0 прочитать модель Wildfire 3.0 сразу через гранит. Это без потребности для потребителя Wildfire 3.0 создать промежуточный нейтральный архив. Вся из информации можно прочитать от модели Pro/ENGINEER стерженем гранита могут теперь быть leveraged потребителем Wildfire 2.0.
Как можно понять, речь, похоже, идет только о WF2 и в том смысле, что нужно для него устанавливать какое-то дополнение, позволяющее читать и, возможно, редактировать файлы WF3.. :g:
....и, возможно, редактировать файлы WF3....
Увы....Без возможности.
Все улучшение только в том, что:
....без потребности для потребителя Wildfire 3.0 создать промежуточный нейтральный архив....
Вот соответствующий TPI:
TPI_132326.pdf
