Не могу разобраться с поворотной осью
3d_killer
Для примера можно как-то так попробовать:
          ;---------          Homing & Zero Returning axis             ---------
               ;--------- Instructions and explaination of definition below ---------
    ;  Format: [x][integer:][Prepstr :][AxisStr1 ;][AxisStrN]
    ;  x       = Putting 'x' as the first character means "Homing Mode" must be set for each line (i.e. 'x2:G00 :Z0 ;3:G00 :X-15.0 ' )
    ;  integer = Homing Output Mode (1=G28, 2=G28 G91, 3=G53 Non-Modal, 4=G53 Modal, 5=G30, 6=G30 G91, 7= any string)
    ;  PrepStr = Sets the code(s) for the begging of line used for Homing Axis (i.e. 'G00')
    ;  AxisStr = Homing Axis Definition (i.e. 'Z0.0', 'H0.0 W0.')
    ;  Note: You can define up to 49 "Homing Lines" seperated by ";"
    ;  Note: Only use ";" if using more then 1 "Homing Line"
    ;  Note: Define string as empty '' to ignore Specific Homing Definition
    sHomestrUpperBegin    = '3:G00 X0.;G00 Z0. '  ; Program Upper Turret Begin Homing Definition
    sHomestrLowerBegin    = '3:G00 X0.;G00 Z0. '  ; Program Lower Turret Begin Homing Definition
    sHomestrtc            = '3:G00 X0.;G00 Z0. '                           ; Tool Change Homing Definition
    sHomestrUpperEnd      = '3:G00 X0.;G00 Z0. '         ; Program Upper Turret Homing Definition
    sHomestrLowerEnd      = '3:G00 X0.;G00 Z0. '         ; Program Lower Turret Homing Definition
    sHomestrstpsame       = '3:G00 X0. '                 ; M00 Same Tool Homing Definition
    sHomestrstpdiff       = '3:G00 X0. '                 ; M00 Different Tool Homing Definition
или так:
;Homing Format Definitions
    ;[integer:][Prepstr :][AxisStr1 ;][AxisStrN]
    ;integer = Homing Output Mode (1=G28, 2=G28 G91, 3=G53 Non-Modal, 4=G53 Modal 5= anystring)
    ;PrepStr = Sets the code(s) for the begging of line used for Homing Axis (i.e. 'G00')
    ;AxisStr = Homing Axis Definition (i.e. 'Z0.0', 'H0.0 W0.')
    ;Note: You can define up to 49 "Homing Lines" seperated by ";"
    ;Note: Only use ";" if using more then 1 "Homing Line"
    ;Note: Define string as empty '' to ignore Specific Homing Definition
    sHomestrbegin         = ''                   ; Program Begin Homing Definition
    sHomestrSpecial       = '1:G00 :U0.0 '                  ; Special circumstance Homing Definition ( If needed)
    sHomestrtc            = '5:G00 :X6. Z8. '                           ; Tool Change Homing Definition
    sHomestrend           = '5:G00 :X6. Z8. '                    ; Program End Homing Definition
    sHomestrstpsame       = '1:G00 :U0.0 '                 ; M00 Same Tool Homing Definition
    sHomestrstpdiff       = '1:G00 :U0.0 '                 ; M00 Different Tool Homing Definition
Пробуйте варианты
Вот еще вариант:
    sHomestrUpperBegin    = '1:G00 :U0.;W0.'                 ; Program Upper Turret Begin Homing Definition
    sHomestrLowerBegin    = ''                               ; Program Lower Turret Begin Homing Definition
    sHomestrtc            = '1:G00 :U0.;W0. '                ; Tool Change Homing Definition
    sHomestrUpperEnd      = '1:G00 :U0.;W0.  '               ; Program Upper Turret Homing Definition
    sHomestrLowerEnd      = ''                               ; Program Lower Turret Homing Definition
    sHomestrstpsame       = '7:G53 G00 X0. '                 ; M00 Same Tool Homing Definition
    sHomestrstpdiff       = '7:G53 G00 X0. '                 ; M00 Different Tool Homing Definition
Изменено пользователем sennik53
у меня тоже примерно такая же проблема . вот скачал постпроцессор чуть выше. детали стали в размер. я не понял как повернуть ось вдоль оси Y. подскажите пожалуйста
29 минут назад, doctorbit сказал:
В файле станка попробуй изменить вектор оси А в направлении той оси которой тебе надо!
3 минуты назад, doctorbit сказал:
я правельно понимамаю, что это надо делать вот тут?
ДА, но почему у вас такие лютые смещения в графе Rotation Point ?
может я не прав, но вот схематично стол изображен, с поворпотной осью, тоже схематично. я указал там ость передней бабки с отступом от нее немного, это не правильно ?
27 minutes ago, Frezer_PU said:
ДА,
как только я меняю направление, solidcam выдает ошибку что выбраный путь инструмента на для 4-х осевого станка. просит проверить machinID
1 час назад, doctorbit сказал:
Выдает ошибку при попытке вывода УП или при сохранении файла станка после правки?
да при попытке генерации УП
  • 5 лет спустя...
Использую спиральные траектории на 4 оси, и в процессе обработки накручивается значительно количество градусов, при переходе на следующую стратегию приходится ждать пока ось вернется в нулевое значение.
Подскажите как продолжить обработку с уже накрученной траектории?
это проблема по моему решается по G28 A0 Почитай какие параметры отвечают за то что бы обнуление было по короткому пути.
Пререпробовал все возможные варианты хоминга в постпроцессоре, не получилось сделать продолжение обработки с накрученной траектории.
Пока переключил стратегии обработки со спирали на зигзаг.
Постпроцессор во вложении, возможно более опытные коллеги смогут реализовать продолжение обработки без возврата в ноль.
DDCS3.1_4y_axes_A21.gpp
Да я попробую сделать ось вращения с диапазоном 360.
Но как это сделать на базе поста тоже пока не разобрался(
В процессе, решение мне нравится.
у меня  DDCSV1.1. всё прекрасно работает, правда через ESPRIT :beach:
1 час назад, Sabadash сказал:
На базе поста Вы сможете сделать одну деталь. А при обработке следующей что получится?- будет мотать 20000 градусов назад. Так ведь? Настройкой это меняется. Где то я задавал этот вопрос и мне назвали ее номер.
12 минут назад, Клиент сказал:
При обработке следующей детали обнуляется позиция при привязке заготовки.
Машинные координаты будут с накопленной траекторией, да.
там 32 битное число, это несколько млрд градусов, я пока за смену накручивал только 1 млн XD
Вот пример из Autodesk Fusion 360
A0 только убираю вручную, не разобрался еще что в посте генерит эту строчку...
1 минуту назад, mannul сказал:
@Sabadash Неужели на хаасе нет параметров для настройки оси от 0 до 360? Не верю.
У меня Delta NC300 A MI стойка(
      В сущности, все надстройки(модули) это всего лишь надстройки на базовый функционал, он призваны просто сократить рутину нажатия овердохрена кнопок. Можно обойтись без них только базовыми функциями. Проектируешь модель, по модели делаешь модель отливки, проектируешь литниковую систему, вычитаешь это всё из двух полуформ- получаешь полость для заливки пенопласта. А с учётом того что есть пенопласты которые расширяются при спекании литниковой системой можно вообще пренебречь.
      Попробуй на станке. Здесь кстати подача для поворотки пересчитывается через формулу, как через G93 только без G93  test.nc
    • ALBUS9927
      Доброго дня, коллеги! Очень интересует вопрос проектирования пресс-форм для ЛВМ ( а конкретно для турбинных лопаток) в программе Компас 3д. Насколько это программа адаптировано для этого ( используя только базовый модуль, без блоков "Пресс-формы 3Д" и "Пресс-формы 3Д Express")? Возможно у кого есть литература или методики на эту тему. А так же буду рад если вы поделитесь вашим личным опытом в данной теме.
      Файлы журнала на выбранном вами языке можно корректировать и дописывать. Есть сайт англицкий про журналирование там много готовых примеров их можно скачивать и пробовать у себя.  Вообщем это много более широкий инструмент чем максроы
    • andrei4ik
      Никто не подскажет где найти симулятор гибочного станка....Есть вариант MBand но он платный как я понимаю
    • IgP
      Если вы это уже один раз сделали, то это правильное направление: У вам будет кнопка, по которой будет выполняться написанное вами действие( активации вида с тем именем которое там будет указано) Одна кнопка - одно нажатие - в моём варианте три клика (может оно вам  и не надо?) Макрос в NX - по сути, это программа для выполнения. Но создаётся она самим NX-ом записывая ваши действия. Макро-файл - это текстовый файл можно его посмотреть, можно его даже в этом текстовом редакторе редактировать. а вот написать самому с чистого листа, я так даже и не пытался ... Описание команд - есть в документации на NX (по F1/Неlp). Журнал - ну типа, похоже на макрос. а по сути, современный способ написания программ в NX. Настраиваете журнал на язык программирования , в котором хотите получить текст ваших действий. Запускаете процесс "журналирования" - выполняете в NX необходимые вам действия - получаете файл с текстом-заготовкой программы. Если в качестве языка выберите Basic - сможете сразу и выполнить его, без компиляции. насколько я понимаю с Python также. Как-то так ... кратенько.
    • Sabadash
      Вот пример из Autodesk Fusion 360 A0 только убираю вручную, не разобрался еще что в посте генерит эту строчку... У меня Delta NC300 A MI стойка(
    • Sabadash
      При обработке следующей детали обнуляется позиция при привязке заготовки. Машинные координаты будут с накопленной траекторией, да. там 32 битное число, это несколько млрд градусов, я пока за смену накручивал только 1 млн XD
