Контактная задача
Как определить площади контакта при давлении одного тела на другое, в ansys версии 18?https://fex.net/294333308941?fileId=433521091
Изменено пользователем intruder777
8 hours ago, intruder777 said:
в ansys версии 18?
https://i.imgur.com/s4JSeiv.png
!contact area macro
!This macro extracts the contact area from a group of elements
!The resulting value is listed in the command object in the solution branch
!User must have a named selection called cnt_press_edges, scoped to one or more edges or faces in this case
!These faces must have contact elements otherwise the results will return zero
!If user is using program controlled for contact behavior, ANSYS may internally flip the contact and target (auto symmetric). If this happens, the results will be returned as zero
!In this case the user has to make sure that edges picked for the named selection have contact elements.
!Here are some options;
!If behavior is set to program controlled and results come back as zero, then go to the named selection and pick the opposing face
!If behavior is set to asymmetric, then just make sure the named selection points to the same faces as contact faces in the contact definition
!If behavior is set to symmetric, then run and record the contact area, save this number, then in the named selection, select the opposing face instead,
!rerun, extract the contact area, add to the first contact area from the prior step, and divide by two. This will give an average of the contact area
!Sean Harvey - ANSYS Inc.
!Rev 1.0 -  Original release  11/4/2013
!Rev 1.1 -  Modified by piden 22/4/2018
!user assumes all responsbility from use of the macro
resume
set,last                                !set the last results, change as needed!!!  Especially if multi results sets
allsel
*get,num_el,elem,0,count                !get number of contact elements selected
*get,start_id,elem,0,num,min            !get id of first contact element
*dim,cnt_area,array,num_el              !dimension the contact area array
cmsel,s,cnt_press_edges                 !select nodes of interest. Need face name selection on area of interest
esln,s,1                                !select elements attached to these nodes
esel,r,ename,,174                       !reselect the contact elements. Change element type if needed
*vget,elem_sel,elem,start_id,esel       !create mask vector of selected 1=selected -1=not selected
allsel
*vabs,1
*vmask,elem_sel                         !turn on mask
*vscfun,elem_tot_area,sum,elem_area     !sum the area of the contact elements
etable,carea,nmisc,58                   !get the contact area. Refer to HELP to find proper nmisc value for CAREA for chosen element
*vget,cnt_area,elem,start_id,etab,carea !store in array
*vscfun,tot_area,sum,cnt_area           !sum the contact area
my_contact_area = tot_area              !output variable tot_area
Ansys 19.0
https://i.imgur.com/6PXMsUx.png
@piden Спасибо, а можно понять что такое 174 и 58? почему здесь
"esel,r,ename,,174 " две запятых?
Реально крутая штука спасибо! Буду пробовать разобраться!
А что с сеткой? У меня правильно была?
Как насчет настроек контакта? Они правильные?
Ну, контакт с ними считается. А площадь - я не пробовал, свои поставил. Изменил behavior = unsymmetric.
Да, можно. Открой хелп и прочти про элемент CONTA174. И найди, что для этого элемента выводит nmisc 58.
Желтым было выделено то, что я изменил в исходном скрипте.
Приходилось видеть и красивее... Но как по мне - покатит.
9 minutes ago, intruder777 said:
две запятых?
в APDL если параметр пропускаешь, то используется значение по-умолчанию.
Например
k,1,0,0,0 - создается точка с номером 1 и коорд. (0,0,0)
а
k,,0,0,0 создаст еще одну точку в этом же месте, но номер ей присвоит автоматом. В данном случае 2.
@piden
esln,s,1
Нужно ли изменить здесь cnt_press_edges на
cnt_area?
Нет! Просто скопируй скрипт себе и замени тот, что был, на этот. И больше в скрипте ничего не трогай)
1 час назад, piden сказал:
А что делает команда k,,,, ?
создается точка с коорд. (0,0,0). Номер присваивается автоматически.
А команда
k,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
делает за тебя расчет, пишет отчет и получает зп. Главное, пару лишних зпт не добавить. А то пойдет и спустит всё на женщин и вино...
Изменено пользователем piden
12 минуты назад, piden сказал:
А команда
по умолчанию..
пишет отчет
по умолчанию...
получает зп
по умолчанию.
13 минуты назад, piden сказал:
А команда
делает за тебя расчет, пишет отчет и получает зп. Только не всегда срабатывает(
А если я з/п сам хочу получить, какие запятые не нужно ставить?
Вот ради этих сакральных знаний люди и изучают apdl годами!
Только что, piden сказал:
2 минуты назад, Mrt23 сказал:
Нигде. Надо в параметрах запуска вместо "-$" использовать ключ "+$"
Например "+$1000"
Нда. А говорят рыбаки суеверный народ :biggrin:
4 minutes ago, Mrt23 said:
Не тем софтом занимался:(
Вишь, а в бабакусе-то вашем все ключи через "-"!  Тота и оно!
Например "+$1000"
Борман походу к БД бухгалтерии доступ получил....
@pidenА заделись ресурсами, которые читаешь/мониторишь по поводу CAE, а?
Если не сложно конечно.
Да я никакие не мониторю) Когда что-то нужно - в гугл вбиваю и ищу.
Мониторю только официальные порталы ансиса / симулии / альтаира на предмет выхода новых туторов. Но я их, увы, не выполняю, а складываю в сундучок)
Блин,  такая же фигня. Папка customer portal уже неприлично разрослась((
      да у вас очень древний чемоданчик думаю из 90-х ну его ломать не жалко но если все уже заменили с рабочего то тут даже не знаю что и посоветовать....
    • stanislavz
      Спасибо за ответ. Так этот и был заказан на запас. В машине живой рабочий. Носителя нету, все в памяти hm628128-10 + ээпром.
    • ispite
    • ddm
    • sklide008
    • sklide008
    • stanislavz
