Ошибка в постпроцессировании
Servius
Доброго времени суток,
Не могу разобраться почему пост в одном случае считывает ускоренное перемещение, а в другом нет.
Для примера взял разфрезеровку отверстия за два прохода.
В CLSF формате перемещение на ускоренной подаче по Z между проходами есть:
TOOL PATH/HOLE_MILLING,TOOL,MILL
TLDATA/MILL,10.0000,0.0000,75.0000,0.0000,0.0000
MSYS/1.8563,1.7862,75.0000,1.0000000,0.0000000,0.0000000,0.0000000,1.0000000,0.0000000
$$ centerline data
PAINT/PATH
PAINT/SPEED,10
PAINT/COLOR,186
RAPID
GOTO/0.0000,0.0000,10.0000,0.0000000,0.0000000,1.0000000
PAINT/COLOR,211
RAPID
GOTO/0.0000,0.0000,1.0000
PAINT/COLOR,42
FEDRAT/MMPM,250.0000
CIRCLE/1.2500,0.0000,1.0000,0.0000000,0.0000000,-1.0000000,1.2500,0.0600,0.5000,10.0000,0.0000
GOTO/1.2500,-1.2500,1.0000
GOTO/2.5000,0.0000,1.0000
PAINT/COLOR,31
CIRCLE/0.0000,0.0000,-5.0000,0.0000000,0.0000000,-1.0000000,2.5000,0.0600,0.5000,10.0000,0.0000,TIMES,6
GOTO/2.5000,0.0000,-5.0000
GOTO/0.0000,2.5000,-5.0000
GOTO/-2.5000,0.0000,-5.0000
GOTO/0.0000,-2.5000,-5.0000
PAINT/COLOR,37
CIRCLE/1.2500,0.0000,-5.0000,0.0000000,0.0000000,-1.0000000,1.2500,0.0600,0.5000,10.0000,0.0000
GOTO/1.2500,1.2500,-5.0000
GOTO/0.0000,0.0000,-5.0000
PAINT/COLOR,211
RAPID
PAINT/COLOR,42
CIRCLE/2.5000,0.0000,1.0000,0.0000000,0.0000000,-1.0000000,2.5000,0.0600,0.5000,10.0000,0.0000
GOTO/2.5000,-2.5000,1.0000
GOTO/5.0000,0.0000,1.0000
PAINT/COLOR,31
CIRCLE/0.0000,0.0000,-5.0000,0.0000000,0.0000000,-1.0000000,5.0000,0.0600,0.5000,10.0000,0.0000,TIMES,6
GOTO/5.0000,0.0000,-5.0000
GOTO/0.0000,5.0000,-5.0000
GOTO/-5.0000,0.0000,-5.0000
GOTO/0.0000,-5.0000,-5.0000
PAINT/COLOR,37
CIRCLE/2.5000,0.0000,-5.0000,0.0000000,0.0000000,-1.0000000,2.5000,0.0600,0.5000,10.0000,0.0000
GOTO/2.5000,2.5000,-5.0000
PAINT/COLOR,211
RAPID
PAINT/SPEED,10
PAINT/TOOL,NOMORE
END-OF-PATH
После постпроцессирования уже нет:
1 BEGIN PGM MODEL11 MM
2 BLK FORM 0.1 Z X0. Y0. Z0.
3 BLK FORM 0.2 X0. Y0. Z0.
4 * -----------------------------------
5 * MILL - T0 (HOLE_MILLING)
6 PLANE RESET STAY
7 / M140 MB MAX
8 M309
9 TOOL CALL 0 Z S0
10 L A+0.0 C+0.0 FMAX
11 CYCL DEF 7.0
12 CYCL DEF 7.1 X0
13 CYCL DEF 7.2 Y0
14 CYCL DEF 7.3 Z0
15 L M126
16 L X+0.0 Y+0.0 Z10. FMAX M3
17 M8
18 L Z1. FMAX
19 CC X1.25 Y+0.0
20 C X1.25 Y-1.25 DR+ F250.
21 CC X1.25 Y+0.0
22 C X2.5 Y+0.0 DR+
23 CC X+0.0 Y+0.0
24 CP IPA2160. IZ-6.
25 CC X+0.0 Y+0.0
26 C X+0.0 Y2.5 DR+
27 CC X+0.0 Y+0.0
28 C X-2.5 Y+0.0 DR+
29 CC X+0.0 Y+0.0
30 C X+0.0 Y-2.5 DR+
31 CC X+0.0 Y+0.0
32 C X2.5 Y+0.0 DR+
33 CC X1.25 Y+0.0
34 C X1.25 Y1.25 DR+
35 CC X1.25 Y+0.0
36 C X+0.0 Y+0.0 DR+
38 CC X2.5 Y+0.0
39 C X2.5 Y-2.5 DR+
40 CC X2.5 Y+0.0
41 C X5. Y+0.0 DR+
42 CC X+0.0 Y+0.0
43 CP IPA2160. IZ-6.
44 CC X+0.0 Y+0.0
45 C X+0.0 Y5. DR+
46 CC X+0.0 Y+0.0
47 C X-5. Y+0.0 DR+
48 CC X+0.0 Y+0.0
49 C X+0.0 Y-5. DR+
50 CC X+0.0 Y+0.0
51 C X5. Y+0.0 DR+
52 CC X2.5 Y+0.0
53 C X2.5 Y2.5 DR+
54 CC X2.5 Y+0.0
55 C X+0.0 Y+0.0 DR+
56 L Z10. FMAX
57 M5 M9
58 / M140 MB MAX
59 M309
60 L A+0.0 C+0.0 FMAX
61 M1
62 M30
63 END PGM MODEL11 MM
Получается, что до операции и после ускоренные перемещения считываются постом, а внутри операции нет.
Изменено пользователем Servius
001.jpgПопробуйте включить review tool и посмотреть что происходит во время постпроцессирования на этой конкретной строке, там будет видно кто виноват. С ним и нужно будет разбираться, но очевидно что это блоки Rapid Moves, можно попробовать поставить на них опцию "Force output" и посмотреть даст ли это какой-либо результат.
Изменено пользователем urlerbro
В посте используется блок helix_move.
Не могу добавить скриншот отладчика, ошибка вылетает.
В программе пропущена строка 37. В ней отладчик пишет: N37 L Z FMAX и похоже удаляет кадр т.к. нет значения координаты.
Во всех переменных значение координаты присутствует, а вот Адреса Z=10 нет. Очень странно.
Не могу прогнать операцию через постпроцессор. nx 10
постбилдером открывается
в других операциях та же ошибка
Режимы заданы , но возможно нужно что то дописать в состояние диапазона , пробовал  поменять режим вывода с частота вращения на SFM  но результата не дало.
3 часа назад, Tibet сказал:
ПП ранее работал? Если можно, то скиньте глянуть.
5 часов назад, Tibet сказал:
У вас нет файла *.cdl в директории указанной в сообщении об ошибке. Самое простое действие - это его туда скопировать.
Где находится папка $ugii_cam_library_installed_machines_dir?
Изменено пользователем Tibet
2 часа назад, Tibet сказал:
Обычно тут C:\Program Files\Siemens\NX 10.0\MACH\resource\library\machine\installed_machines
В 27.12.2016 в 12:23, Servius сказал:
Есть такая проблема в Heidenhain. Я в PB_CMD_helix_move специально дополнительное ускоренное перемещение прописывал. Теперь иногда строки подходов-отходов дублируются, если сразу много отверстий по спирали обрабатываются, но по мне - пусть будут две одинаковые строки, чем вообще ни одной.
Я решил проблему тем, что включил обязательный вывод координат X, Y, Z. Координаты теперь дублируются, но пускай уж лучше так.
В 29.12.2016 в 22:33, vicebear сказал:
Проблема решается простым добавлением строки MOM_force once Z в конец PB_CMD_helix_move.
Найдено решение
6 часов назад, Servius сказал:
У меня там через LBL CALL сделано, чтобы обойти ограничение 5400 градусов, поэтому просто не решается.
1 час назад, vicebear сказал:
Ага, Хайден не Сименс, это в Сименсе всё просто :))
15 минут назад, grOOmi сказал:
Во-во, меня уже лет 20 интересует - почему 5400, почему 15 оборотов? Что ж там у них за затык такой в ПО нерешаемый, который из стойки в стойку кочует? Интересно, в TNC-620 тоже такая же фигня или решили вопрос?
30 минут назад, vicebear сказал:
В руководстве к 640 вон чего пишут
    • IGor2D
    • Gmv
    • Gmv
    • ID_Hacker
