Autodesk Simulation vs. Solidworks Simulation
Yes, agree, CFdesign bought the (calculation) code only and their user interface is reasonable (i.e. user friendly), but the stability and the results are crap. I am talking about thermal simulations in convection cooling mode. Never got realistic results. Also the price is about 5 times higher than Floworks
    • david1920
    • david1920
    • eljer0n
