HSMWorks для Solid Works
  Copyright (C) 2012-2018 by Autodesk, Inc.
  All rights reserved.
  Mazak post processor configuration.
  $Revision: 41970 20accf76973c3fed9fea790116dce754957c853a $
  $Date: 2018-05-08 10:24:57 $
  FORKID {62F61C65-979D-4f9f-97B0-C5F9634CC6A7}
// ATTENTION: parameter F86 bit 6 must be on for G43.4
description = "Mazak";
vendor = "Mazak";
vendorUrl = "http://www.autodesk.com";
legal = "Copyright (C) 2012-2018 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 24000;
longDescription = "Generic milling post for Mazak.";
extension = "eia";
programNameIsInteger = true;
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  writeMachine: true, // write machine
  writeTools: true, // writes the tools
  preloadTool: true, // preloads next tool on tool change if any
  showSequenceNumbers: true, // show sequence numbers
  sequenceNumberStart: 10, // first sequence number
  sequenceNumberIncrement: 5, // increment for sequence numbers
  optionalStop: true, // optional stop
  separateWordsWithSpace: true, // specifies that the words should be separated with a white space
  useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
  useParametricFeed: false, // specifies that feed should be output using Q values
  showNotes: false, // specifies that operation notes should be output.
  usePitchForTapping: false // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your CNC control must be setup for pitch mode!
// user-defined property definitions
propertyDefinitions = {
  writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
  writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
  preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", type:"boolean"},
  showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
  sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
  sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
  optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
  separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
  useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
  useParametricFeed:  {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
  showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
  usePitchForTapping: {title:"Use pitch for tapping", description:"Enables the use of pitch instead of feed for the F-word in canned tapping cycles. Your CNC control must be setup for pitch mode!", type:"boolean"}
// samples:
// throughTool: {on: 88, off: 89}
// throughTool: {on: [8, 88], off: [9, 89]}
var coolants = {
  flood: {on: 8},
  mist: {on: 7},
  throughTool: {on: 51},
  air: {on: 52},
  airThroughTool: {on: 130},
  suction: {},
  floodMist: {},
  floodThroughTool: {},
  off: 9
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-:#";
var gFormat = createFormat({prefix:"G", decimals:1});
var mFormat = createFormat({prefix:"M", decimals:0});
var hFormat = createFormat({prefix:"H", decimals:0});
var dFormat = createFormat({prefix:"D", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var ijkFormat = createFormat({decimals:6, forceDecimal:true}); // unitless
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 2 : 3), forceDecimal:true});
var pitchFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-99999999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G93-94
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = gMotionModal;
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
// fixed settings
var firstFeedParameter = 100;
var useMultiAxisFeatures = true;
var forceMultiAxisIndexing = false; // force multi-axis indexing for 3D programs
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var currentWorkOffset;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
var maximumCircularRadiiDifference = toPreciseUnit(0.005, MM);
var retracted = false; // specifies that the tool has been retracted to the safe plane
  Writes the specified block.
function writeBlock() {
  if (!formatWords(arguments)) {
    return;
  if (properties.showSequenceNumbers) {
    writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
    writeWords(arguments);
  Writes the specified optional block.
function writeOptionalBlock() {
    var words = formatWords(arguments);
    if (words) {
      writeWords("/", "N" + sequenceNumber, words);
  } else {
    writeWords2("/", arguments);
function formatComment(text) {
  return "(" + filterText(String(text).toUpperCase(), permittedCommentChars) + ")";
  Output a comment.
function writeComment(text) {
  writeln(formatComment(text));
function onOpen() {
  if (properties.useRadius) {
    maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
  if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-360, 360], preference:1});
    var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-360, 360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(0); // TCP mode
  if (!machineConfiguration.isMachineCoordinate(0)) {
    aOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(1)) {
    bOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(2)) {
    cOutput.disable();
  if (!properties.separateWordsWithSpace) {
    setWordSeparator("");
  sequenceNumber = properties.sequenceNumberStart;
  if (programName) {
    var programId;
    try {
      programId = getAsInt(programName);
    } catch(e) {
      error(localize("Program name must be a number."));
      return;
    if (!((programId >= 1) && (programId <= 99999999))) {
      error(localize("Program number is out of range."));
      return;
    var o4Format = createFormat({width:4, zeropad:true, decimals:0});
    var o8Format = createFormat({width:8, zeropad:true, decimals:0});
    var oFormat = (programId <= 9999) ? o4Format : o8Format;
    if (programComment) {
      writeln("O" + oFormat.format(programId) + " (" + programComment + ")");
    } else {
      writeln("O" + oFormat.format(programId));
  } else {
    error(localize("Program name has not been specified."));
    return;
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (properties.writeMachine && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  // dump tool information
  if (properties.writeTools) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        var comment = "T" + toolFormat.format(tool.number) + " " +
          "D=" + xyzFormat.format(tool.diameter) + " " +
          localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
        if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
          comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
          comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
        comment += " - " + getToolTypeName(tool.type);
        writeComment(comment);
  if (false) {
    // check for duplicate tool number
    for (var i = 0; i < getNumberOfSections(); ++i) {
      var sectioni = getSection(i);
      var tooli = sectioni.getTool();
      for (var j = i + 1; j < getNumberOfSections(); ++j) {
        var sectionj = getSection(j);
        var toolj = sectionj.getTool();
        if (tooli.number == toolj.number) {
          if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) ||
              xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) ||
              abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) ||
              (tooli.numberOfFlutes != toolj.numberOfFlutes)) {
            error(
              subst(
                localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."),
                sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)),
                sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1))
            return;
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  // absolute coordinates and feed per min
  writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(94), gPlaneModal.format(17), gFormat.format(49));
  switch (unit) {
  case IN:
    writeBlock(gUnitModal.format(20));
    break;
  case MM:
    writeBlock(gUnitModal.format(21));
    break;
  onCommand(COMMAND_START_CHIP_TRANSPORT);
function onComment(message) {
  writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
  aOutput.reset();
  bOutput.reset();
  cOutput.reset();
function forceFeed() {
  currentFeedId = undefined;
  feedOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
  forceXYZ();
  forceABC();
  forceFeed();
var currentSmoothing = false;
function setSmoothing(mode) {
  if (mode == currentSmoothing) {
    return;
  currentSmoothing = mode;
  writeBlock(gFormat.format(5), mode ? "P2" : "P0");
function FeedContext(id, description, feed) {
  this.id = id;
  this.description = description;
  this.feed = feed;
function getFeed(f) {
  if (activeMovements) {
    var feedContext = activeMovements[movement];
    if (feedContext != undefined) {
      if (!feedFormat.areDifferent(feedContext.feed, f)) {
        if (feedContext.id == currentFeedId) {
          return ""; // nothing has changed
        forceFeed();
        currentFeedId = feedContext.id;
        return "F#" + (firstFeedParameter + feedContext.id);
    currentFeedId = undefined; // force Q feed next time
  return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
  activeMovements = new Array();
  var movements = currentSection.getMovements();
  var id = 0;
  var activeFeeds = new Array();
  if (hasParameter("operation:tool_feedCutting")) {
    if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
      var feedContext = new FeedContext(id, localize("Cutting"), getParameter("operation:tool_feedCutting"));
      activeFeeds.push(feedContext);
      activeMovements[MOVEMENT_CUTTING] = feedContext;
      activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
      activeMovements[MOVEMENT_EXTENDED] = feedContext;
    ++id;
    if (movements & (1 << MOVEMENT_PREDRILL)) {
      feedContext = new FeedContext(id, localize("Predrilling"), getParameter("operation:tool_feedCutting"));
      activeMovements[MOVEMENT_PREDRILL] = feedContext;
    ++id;
  if (hasParameter("operation:finishFeedrate")) {
    if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:finishFeedrate"));
      activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting")) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:tool_feedCutting"));
    ++id;
  if (hasParameter("operation:tool_feedEntry")) {
    if (movements & (1 << MOVEMENT_LEAD_IN)) {
      var feedContext = new FeedContext(id, localize("Entry"), getParameter("operation:tool_feedEntry"));
      activeMovements[MOVEMENT_LEAD_IN] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedExit")) {
    if (movements & (1 << MOVEMENT_LEAD_OUT)) {
      var feedContext = new FeedContext(id, localize("Exit"), getParameter("operation:tool_feedExit"));
      activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
    ++id;
  if (hasParameter("operation:noEngagementFeedrate")) {
    if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
      var feedContext = new FeedContext(id, localize("Direct"), getParameter("operation:noEngagementFeedrate"));
      activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting") &&
             hasParameter("operation:tool_feedEntry") &&
      var feedContext = new FeedContext(id, localize("Direct"), Math.max(getParameter("operation:tool_feedCutting"), getParameter("operation:tool_feedEntry"), getParameter("operation:tool_feedExit")));
    ++id;
  if (hasParameter("operation:reducedFeedrate")) {
    if (movements & (1 << MOVEMENT_REDUCED)) {
      var feedContext = new FeedContext(id, localize("Reduced"), getParameter("operation:reducedFeedrate"));
      activeMovements[MOVEMENT_REDUCED] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedRamp")) {
    if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
      var feedContext = new FeedContext(id, localize("Ramping"), getParameter("operation:tool_feedRamp"));
      activeMovements[MOVEMENT_RAMP] = feedContext;
      activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
      activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
      activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedPlunge")) {
    if (movements & (1 << MOVEMENT_PLUNGE)) {
      var feedContext = new FeedContext(id, localize("Plunge"), getParameter("operation:tool_feedPlunge"));
      activeMovements[MOVEMENT_PLUNGE] = feedContext;
    ++id;
  if (true) { // high feed
    if (movements & (1 << MOVEMENT_HIGH_FEED)) {
      var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
      activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
    ++id;
  for (var i = 0; i < activeFeeds.length; ++i) {
    var feedContext = activeFeeds;
    writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
  if (!forceMultiAxisIndexing && is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
    return; // ignore
  if (!((currentWorkPlaneABC == undefined) ||
        abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
        abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
        abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
    return; // no change
  onCommand(COMMAND_UNLOCK_MULTI_AXIS);
  if (useMultiAxisFeatures) {
    if (abc.isNonZero()) {
      writeBlock(gFormat.format(68.2), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "A" + abcFormat.format(abc.x), "B" + abcFormat.format(abc.y), "C" + abcFormat.format(abc.z)); // set frame
      writeBlock(gFormat.format(53.1)); // turn machine
    } else {
      writeBlock(gFormat.format(69)); // cancel frame
  } else {
    writeBlock(
      gMotionModal.format(0),
      conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
      conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
      conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
  onCommand(COMMAND_LOCK_MULTI_AXIS);
  currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
  var W = workPlane; // map to global frame
  var abc = machineConfiguration.getABC(W);
  if (closestABC) {
    if (currentMachineABC) {
      abc = machineConfiguration.remapToABC(abc, currentMachineABC);
    } else {
      abc = machineConfiguration.getPreferredABC(abc);
  } else {
  try {
    abc = machineConfiguration.remapABC(abc);
    currentMachineABC = abc;
  } catch (e) {
    error(
      localize("Machine angles not supported") + ":"
      + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
      + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
      + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
  var direction = machineConfiguration.getDirection(abc);
  if (!isSameDirection(direction, W.forward)) {
    error(localize("Orientation not supported."));
  if (!machineConfiguration.isABCSupported(abc)) {
    error(
      localize("Work plane is not supported") + ":"
  var tcp = false;
  if (tcp) {
    setRotation(W); // TCP mode
  } else {
    var O = machineConfiguration.getOrientation(abc);
    var R = machineConfiguration.getRemainingOrientation(abc, W);
    setRotation(R);
  return abc;
function isProbeOperation() {
  return hasParameter("operation-strategy") && (getParameter("operation-strategy") == "probe");
function onSection() {
  var insertToolCall = isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  retracted = false;
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  var newWorkPlane = isFirstSection() ||
    !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
    (currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
      Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
    (!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
    (!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
      getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
  if (insertToolCall || newWorkOffset || newWorkPlane) {
    // stop spindle before retract during tool change
    if (insertToolCall && !isFirstSection()) {
      onCommand(COMMAND_STOP_SPINDLE);
    writeRetract(Z);
    zOutput.reset();
  writeln("");
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
  if (properties.showNotes && hasParameter("notes")) {
    var notes = getParameter("notes");
    if (notes) {
      var lines = String(notes).split("\n");
      var r1 = new RegExp("^[\\s]+", "g");
      var r2 = new RegExp("[\\s]+$", "g");
      for (line in lines) {
        var comment = lines[line].replace(r1, "").replace(r2, "");
        if (comment) {
  if (insertToolCall) {
    forceWorkPlane();
    setCoolant(COOLANT_OFF);
    if (!isFirstSection() && properties.optionalStop) {
      onCommand(COMMAND_OPTIONAL_STOP);
    if (tool.number > 100000000) {
      warning(localize("Tool number exceeds maximum value."));
    writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
    if (tool.comment) {
      writeComment(tool.comment);
    var showToolZMin = false;
    if (showToolZMin) {
      if (is3D()) {
        var zRange = currentSection.getGlobalZRange();
        var number = tool.number;
        for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
          if (section.getTool().number != number) {
            break;
          zRange.expandToRange(section.getGlobalZRange());
        writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
    if (properties.preloadTool) {
      var nextTool = getNextTool(tool.number);
      if (nextTool) {
        writeBlock("T" + toolFormat.format(nextTool.number));
      } else {
        // preload first tool
        var section = getSection(0);
        var firstToolNumber = section.getTool().number;
        if (tool.number != firstToolNumber) {
          writeBlock("T" + toolFormat.format(firstToolNumber));
      forceSpindleSpeed ||
      isFirstSection() ||
      (rpmFormat.areDifferent(tool.spindleRPM, sOutput.getCurrent())) ||
      (tool.clockwise != getPreviousSection().getTool().clockwise)) {
    if (tool.spindleRPM < 1) {
      error(localize("Spindle speed out of range."));
      return;
    if (tool.spindleRPM > 99999) {
      warning(localize("Spindle speed exceeds maximum value."));
    writeBlock(
      sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4)
    if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) {
      // writeBlock(mFormat.format(xxx)); // shortest path traverse
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  var workOffset = currentSection.workOffset;
  if (workOffset == 0) {
    warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
    workOffset = 1;
  // alternatively use 54.2
  if (workOffset > 0) {
    if (workOffset > 6) {
      var code = workOffset - 6;
      if (code > 48) {
        error(localize("Work offset out of range."));
        return;
      if (workOffset != currentWorkOffset) {
        writeBlock(gFormat.format(54.1), "P" + code);
        currentWorkOffset = workOffset;
    } else {
        writeBlock(gFormat.format(53 + workOffset)); // G54->G59
  forceXYZ();
  if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
    // set working plane after datum shift
    if (currentSection.isMultiAxis()) {
      forceWorkPlane();
      cancelTransformation();
    } else {
      var abc = new Vector(0, 0, 0);
        var eulerXYZ = currentSection.workPlane.getTransposed().eulerZYX_R;
        abc = new Vector(-eulerXYZ.x, -eulerXYZ.y, -eulerXYZ.z);
      } else {
        abc = getWorkPlaneMachineABC(currentSection.workPlane);
      setWorkPlane(abc);
  } else { // pure 3D
    var remaining = currentSection.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return;
    setRotation(remaining);
  // set coolant after we have positioned at Z
  setCoolant(tool.coolant);
  if (false) {
    if (hasParameter("operation-strategy") && (getParameter("operation-strategy") != "drill")) {
      setSmoothing(true);
    } else {
      setSmoothing(false);
  forceAny();
  var initialPosition = getFramePosition(currentSection.getInitialPosition());
  if (!retracted && !insertToolCall) {
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
  // assumes a Head configuration uses TCP on a Fanuc controller
  var offsetCode = 43;
    if (machineConfiguration.isMultiAxisConfiguration() && (currentSection.getOptimizedTCPMode() == 0)) {
      offsetCode = 43.4;
    } else if (!machineConfiguration.isMultiAxisConfiguration()) {
      offsetCode = 43.5;
    // turn
    var abc;
    if (currentSection.isOptimizedForMachine()) {
      abc = currentSection.getInitialToolAxisABC();
      // position
      writeBlock(
        gFormat.format(offsetCode),
        aOutput.format(abc.x), bOutput.format(abc.y), cOutput.format(abc.z)
    } else {
      var d = currentSection.getGlobalInitialToolAxis();
      // position
      writeBlock(
        "I" + xyzFormat.format(d.x), "J" + xyzFormat.format(d.y), "K" + xyzFormat.format(d.z)
    writeBlock(
      xOutput.format(initialPosition.x),
      yOutput.format(initialPosition.y)
    writeBlock(
  } else {
    if (insertToolCall || newWorkOffset || retracted || (!isFirstSection() && getPreviousSection().isMultiAxis())) {
      var lengthOffset = tool.lengthOffset;
      if (lengthOffset > 512) {
        error(localize("Length offset out of range."));
        return;
      writeBlock(gPlaneModal.format(17));
      if (!machineConfiguration.isHeadConfiguration()) {
        writeBlock(
          gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
        writeBlock(gMotionModal.format(0), gFormat.format(offsetCode), zOutput.format(initialPosition.z), hFormat.format(lengthOffset));
      } else {
        writeBlock(
          gFormat.format(offsetCode), xOutput.format(initialPosition.x),
          yOutput.format(initialPosition.y),
    } else {
      writeBlock(
  if (properties.useParametricFeed &&
      (getParameter("operation-strategy") != "drill") && // legacy
      !(currentSection.hasAnyCycle && currentSection.hasAnyCycle())) {
    if (!insertToolCall &&
        activeMovements &&
        (getCurrentSectionId() > 0) &&
        ((getPreviousSection().getPatternId() == currentSection.getPatternId()) && (currentSection.getPatternId() != 0))) {
      // use the current feeds
    } else {
      initializeActiveFeeds();
  } else {
    activeMovements = undefined;
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(0.001, seconds, 99999.999);
  writeBlock(gFeedModeModal.format(94), gFormat.format(4), "P" + milliFormat.format(seconds * 1000));
function onSpindleSpeed(spindleSpeed) {
  writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
  forceXYZ(); // force xyz on first drill hole of any cycle
  return [xOutput.format(x), yOutput.format(y),
    zOutput.format(z),
    "R" + xyzFormat.format(r)];
function onCyclePoint(x, y, z) {
  gRetractModal.reset();
  if (isFirstCyclePoint()) {
    repositionToCycleClearance(cycle, x, y, z);
    // return to initial Z which is clearance plane and set absolute mode
    var F = cycle.feedrate;
    var P = (cycle.dwell == 0) ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
    switch (cycleType) {
    case "drilling": // use G82
    case "counter-boring":
      var d0 = cycle.retract - cycle.stock;
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82),
        getCommonCycle(x, y, z, cycle.retract),
        conditional(P > 0, "P" + milliFormat.format(P)),
        feedOutput.format(F),
        conditional(d0 > 0, "D" + milliFormat.format(d0))
      break;
    case "chip-breaking":
      if (cycle.accumulatedDepth < cycle.depth) {
        expandCyclePoint(x, y, z);
      } else {
        var tz = cycle.incrementalDepth;
        // var d0 = (cycle.chipBreakDistance != undefined) ? cycle.chipBreakDistance : machineParameters.chipBreakingDistance;
        var k0 = cycle.retract - cycle.stock;
        // d0 not supported
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
          "Q" + xyzFormat.format(tz),
          // conditional(d0 > 0, "D" + xyzFormat.format(d0)), // use parameter F12
          conditional(k0 > 0, "K" + xyzFormat.format(k0))
      break;
    case "deep-drilling":
      // d0 not supported
      if (cycle.dwell > 0) { // not supported by cycle
      } else {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
      break;
    case "tapping":
      if (properties.usePitchForTapping) {
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 84),
          pitchOutput.format(tool.threadPitch)
        forceFeed();
      } else {
        F = tool.getTappingFeedrate();
        writeBlock(
      break;
    case "left-tapping":
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(74),
        forceFeed();
      } else {
        writeBlock(
      break;
    case "right-tapping":
        writeBlock(
          gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84),
        forceFeed();
      } else {
        writeBlock(
      break;
    case "fine-boring":
      // TAG: add support for counterclockwise direction
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76),
        "Q" + xyzFormat.format(cycle.shift),
      break;
    case "back-boring":
      var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
      var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
      var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(87),
        getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom),
      break;
    case "reaming":
      var f1 = cycle.retractFeedrate;
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85),
        conditional(f1 != F, "E" + feedFormat.format(f1)),
      break;
    case "stop-boring":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86),
      break;
    case "manual-boring":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(88),
      break;
    case "boring":
      writeBlock(
        gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89),
      break;
    default:
  } else {
    if (cycleExpanded) {
    } else {
      var _x = xOutput.format(x);
      var _y = yOutput.format(y);
      var _z = zOutput.format(z);
      if (!_x && !_y && !_z) {
        switch (gPlaneModal.getCurrent()) {
        case 17: // XY
          xOutput.reset(); // at least one axis is required
          break;
        case 18: // ZX
          zOutput.reset(); // at least one axis is required
          break;
        case 19: // YZ
          yOutput.reset(); // at least one axis is required
          break;
      writeBlock(_x, _y, _z);
function onCycleEnd() {
  if (!cycleExpanded) {
    writeBlock(gCycleModal.format(80));
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
    forceFeed();
function onLinear(_x, _y, _z, feed) {
  var f = getFeed(feed);
  if (x || y || z) {
      var d = tool.diameterOffset;
      if (d > 512) {
        warning(localize("The diameter offset exceeds the maximum value."));
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        dOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
        break;
      case RADIUS_COMPENSATION_RIGHT:
        dOutput.reset();
        writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
        break;
      default:
        writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
    } else {
      writeBlock(gMotionModal.format(1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      forceFeed(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
    return;
    var a = aOutput.format(_a);
    var b = bOutput.format(_b);
    var c = cOutput.format(_c);
    writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
  } else {
    forceXYZ();
    var i = ijkFormat.format(_a);
    var j = ijkFormat.format(_b);
    var k = ijkFormat.format(_c);
    writeBlock(gMotionModal.format(0), x, y, z, "I" + i, "J" + j, "K" + k);
  forceFeed();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
    error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
    return;
    if (x || y || z || a || b || c) {
      writeBlock(gMotionModal.format(1), x, y, z, a, b, c, f);
    } else if (f) {
      } else {
  } else {
    forceXYZ();
    if (x || y || z || i || j || k) {
      writeBlock(gMotionModal.format(1), x, y, z, "I" + i, "J" + j, "K" + k, f);
    } else if (f) {
      } else {
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
  if (isSpiral()) {
    var startRadius = getCircularStartRadius();
    var endRadius = getCircularRadius();
    var dr = Math.abs(endRadius - startRadius);
    if (dr > maximumCircularRadiiDifference) { // maximum limit
      linearize(tolerance); // or alternatively use other G-codes for spiral motion
      return;
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  var start = getCurrentPosition();
  if (isFullCircle()) {
    if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
      return;
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else if (!properties.useRadius) {
    case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else { // use radius mode
    var r = getCircularRadius();
    if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
      r = -r; // allow up to <360 deg arcs
    case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    default:
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    for (var c in coolantCodes) {
      writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
function getCoolantCodes(coolant) {
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (!coolantOff) { // use the default coolant off command when an 'off' value is not specified for the previous coolant mode
    coolantOff = coolants.off;
  if (isProbeOperation()) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode) {
    return undefined; // coolant is already active
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF)) {
    multipleCoolantBlocks.push(mFormat.format(coolantOff));
  var m;
  if (coolant == COOLANT_OFF) {
    m = coolantOff;
  switch (coolant) {
  case COOLANT_FLOOD:
    if (!coolants.flood) {
      break;
    m = coolants.flood.on;
    coolantOff = coolants.flood.off;
    break;
  case COOLANT_THROUGH_TOOL:
    if (!coolants.throughTool) {
      break;
    m = coolants.throughTool.on;
    coolantOff = coolants.throughTool.off;
    break;
  case COOLANT_AIR:
    if (!coolants.air) {
      break;
    m = coolants.air.on;
    coolantOff = coolants.air.off;
    break;
  case COOLANT_AIR_THROUGH_TOOL:
    if (!coolants.airThroughTool) {
      break;
    m = coolants.airThroughTool.on;
    coolantOff = coolants.airThroughTool.off;
    break;
  case COOLANT_FLOOD_MIST:
    if (!coolants.floodMist) {
      break;
    m = coolants.floodMist.on;
    coolantOff = coolants.floodMist.off;
    break;
  case COOLANT_MIST:
    if (!coolants.mist) {
      break;
    m = coolants.mist.on;
    coolantOff = coolants.mist.off;
    break;
  case COOLANT_SUCTION:
    if (!coolants.suction) {
      break;
    m = coolants.suction.on;
    coolantOff = coolants.suction.off;
    break;
  case COOLANT_FLOOD_THROUGH_TOOL:
    if (!coolants.floodThroughTool) {
      break;
    m = coolants.floodThroughTool.on;
    coolantOff = coolants.floodThroughTool.off;
    break;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  if (m) {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(mFormat.format(m));
    } else {
    currentCoolantMode = coolant;
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
var mapCommand = {
  COMMAND_STOP:0,
  COMMAND_OPTIONAL_STOP:1,
  COMMAND_END:2,
  COMMAND_SPINDLE_CLOCKWISE:3,
  COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
  COMMAND_STOP_SPINDLE:5,
  COMMAND_ORIENTATE_SPINDLE:19,
  COMMAND_LOAD_TOOL:6
function onCommand(command) {
  switch (command) {
  case COMMAND_STOP:
    writeBlock(mFormat.format(0));
    forceSpindleSpeed = true;
    return;
  case COMMAND_COOLANT_ON:
    setCoolant(COOLANT_FLOOD);
    return;
  case COMMAND_COOLANT_OFF:
    return;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_LOCK_MULTI_AXIS:
    // writeBlock(mFormat.format(47)); // 4th axis
    return;
  case COMMAND_UNLOCK_MULTI_AXIS:
    // writeBlock(mFormat.format(46)); // 4th axis
    return;
  case COMMAND_START_CHIP_TRANSPORT:
    return;
  case COMMAND_STOP_CHIP_TRANSPORT:
    return;
  case COMMAND_BREAK_CONTROL:
    return;
  case COMMAND_TOOL_MEASURE:
    return;
  var stringId = getCommandStringId(command);
  var mcode = mapCommand[stringId];
  if (mcode != undefined) {
    writeBlock(mFormat.format(mcode));
  } else {
    onUnsupportedCommand(command);
function onSectionEnd() {
  // only if G43.4/G43.5 is used
  if (currentSection.isMultiAxis() && !currentSection.isOptimizedForMachine()) {
    writeBlock(gFormat.format(49));
  if (((getCurrentSectionId() + 1) >= getNumberOfSections()) ||
      (tool.number != getNextSection().getTool().number)) {
    onCommand(COMMAND_BREAK_CONTROL);
  forceAny();
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  if (arguments.length == 0) {
    error(localize("No axis specified for writeRetract()."));
    return;
  var words = []; // store all retracted axes in an array
  for (var i = 0; i < arguments.length; ++i) {
    let instances = 0; // checks for duplicate retract calls
    for (var j = 0; j < arguments.length; ++j) {
      if (arguments == arguments[j]) {
        ++instances;
    if (instances > 1) { // error if there are multiple retract calls for the same axis
      error(localize("Cannot retract the same axis twice in one line"));
      return;
    switch (arguments) {
    case X:
      words.push("X" + xyzFormat.format(machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : 0));
      break;
    case Y:
      words.push("Y" + xyzFormat.format(machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : 0));
      break;
    case Z:
      words.push("Z" + xyzFormat.format(machineConfiguration.getRetractPlane()));
      retracted = true; // specifies that the tool has been retracted to the safe plane
      break;
    default:
      error(localize("Bad axis specified for writeRetract()."));
      return;
  if (words.length > 0) {
    writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), words); // retract
  zOutput.reset();
function onClose() {
  writeln("");
  onCommand(COMMAND_COOLANT_OFF);
  writeRetract(Z);
  zOutput.reset();
  setWorkPlane(new Vector(0, 0, 0)); // reset working plane
  if (machineConfiguration.hasHomePositionX() || machineConfiguration.hasHomePositionY()) {
    writeRetract(X, Y);
  onImpliedCommand(COMMAND_END);
  onImpliedCommand(COMMAND_STOP_SPINDLE);
  writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
Вот последний MAZAK (2 дня назад опубликованный). Он должен быть 5-ти координатный. Опробуй.
https://forums.autodesk.com/t5/hsm-post-processor-forum/bd-p/218
Вот еще форум по постпроцессорам HSM. Можно кое-что там выудить. Нужно только зарегитрироваться для большей доступности к данным.
5 часов назад, sennik53 сказал:
Спасибо большое! Лазил, ничего полезного не нашел.
  Показать содержимое
vendor = "Mazak";
extension = "eia";
properties = {
// samples:
var coolants = {
  flood: {on: 8},
  mist: {on: 7},
  air: {on: 52},
  suction: {},
  floodMist: {},
  off: 9
// circular output
// fixed settings
// collected state
var sequenceNumber;
var currentFeedId;
    return;
  } else {
    if (words) {
  } else {
  Output a comment.
function onOpen() {
    aOutput.disable();
    bOutput.disable();
    cOutput.disable();
  if (programName) {
    var programId;
    try {
    } catch(e) {
      return;
      return;
    } else {
  } else {
    return;
    if (vendor) {
    if (model) {
    if (description) {
    var zRanges = {};
    if (is3D()) {
        } else {
  if (false) {
            error(
              subst(
            return;
        return;
  switch (unit) {
  case IN:
    break;
  case MM:
    break;
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
  aOutput.reset();
  bOutput.reset();
  cOutput.reset();
  feedOutput.reset();
  forceXYZ();
  forceABC();
  forceFeed();
    return;
  this.id = id;
  this.feed = feed;
        forceFeed();
  var id = 0;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    ++id;
    return; // ignore
    } else {
  } else {
    writeBlock(
  if (closestABC) {
    } else {
  } else {
  try {
  } catch (e) {
    error(
    error(
  var tcp = false;
  if (tcp) {
  } else {
    setRotation(R);
  return abc;
  retracted = false;
    writeRetract(Z);
    zOutput.reset();
  writeln("");
    if (comment) {
    if (notes) {
        if (comment) {
    forceWorkPlane();
    if (tool.comment) {
    if (showToolZMin) {
      if (is3D()) {
            break;
      if (nextTool) {
      } else {
      isFirstSection() ||
      return;
    writeBlock(
  // wcs
    workOffset = 1;
      if (code > 48) {
        return;
    } else {
  forceXYZ();
      forceWorkPlane();
    } else {
      } else {
      setWorkPlane(abc);
  } else { // pure 3D
      return;
  if (false) {
      setSmoothing(true);
    } else {
  forceAny();
      offsetCode = 43.4;
      offsetCode = 43.5;
    // turn
    var abc;
      // position
      writeBlock(
    } else {
      // position
      writeBlock(
    writeBlock(
    writeBlock(
  } else {
        return;
        writeBlock(
      } else {
        writeBlock(
    } else {
      writeBlock(
        activeMovements &&
    } else {
  } else {
    zOutput.format(z),
      writeBlock(
      break;
      } else {
        // d0 not supported
        writeBlock(
      break;
      // d0 not supported
      } else {
        writeBlock(
      break;
    case "tapping":
        writeBlock(
        forceFeed();
      } else {
        writeBlock(
      break;
        writeBlock(
        forceFeed();
      } else {
        writeBlock(
      break;
        writeBlock(
        forceFeed();
      } else {
        writeBlock(
      break;
    case "fine-boring":
      writeBlock(
      break;
    case "back-boring":
      writeBlock(
      break;
    case "reaming":
      writeBlock(
      break;
    case "stop-boring":
      writeBlock(
      break;
      writeBlock(
      break;
    case "boring":
      writeBlock(
      break;
    default:
  } else {
    } else {
        case 17: // XY
          break;
        case 18: // ZX
          break;
        case 19: // YZ
          break;
  if (x || y || z) {
      return;
    forceFeed();
  if (x || y || z) {
      if (d > 512) {
        dOutput.reset();
        break;
        dOutput.reset();
        break;
      default:
    } else {
  } else if (f) {
    } else {
    return;
  } else {
    forceXYZ();
  forceFeed();
    return;
    } else if (f) {
      } else {
  } else {
    forceXYZ();
    } else if (f) {
      } else {
  if (isSpiral()) {
      return;
    return;
      return;
    case PLANE_XY:
      break;
    case PLANE_ZX:
      break;
    case PLANE_YZ:
      break;
    default:
    case PLANE_XY:
      break;
    case PLANE_ZX:
      break;
    case PLANE_YZ:
      break;
    default:
    case PLANE_XY:
      break;
    case PLANE_ZX:
      break;
    case PLANE_YZ:
      break;
    default:
    return undefined;
  if (!coolants) {
  var m;
    m = coolantOff;
  switch (coolant) {
  case COOLANT_FLOOD:
      break;
    break;
      break;
    break;
  case COOLANT_AIR:
      break;
    break;
      break;
    break;
      break;
    break;
  case COOLANT_MIST:
      break;
    break;
      break;
    break;
      break;
    break;
  if (!m) {
    m = 9;
  if (m) {
      for (var i in m) {
    } else {
  return undefined;
var mapCommand = {
  COMMAND_STOP:0,
  COMMAND_END:2,
  COMMAND_LOAD_TOOL:6
  switch (command) {
  case COMMAND_STOP:
    return;
    return;
    return;
    return;
    return;
    return;
    return;
    return;
    return;
    return;
  } else {
  forceAny();
    return;
        ++instances;
      return;
    case X:
      break;
    case Y:
      break;
    case Z:
      break;
    default:
      return;
  zOutput.reset();
  writeln("");
  writeRetract(Z);
  zOutput.reset();
    writeRetract(X, Y);
Он почти как стандартный "Фанук". Проблема в том что руками править УП приходится. А так все работает. Мы готовы оплатить работу по настройке поста, вопрос кто? Или не "парится" и солидкам осваивать (настраивать$). Просто HSM в свое время привлек готовыми постами на уже имеющийся станок и простотой. А этот появился недавно.
Сделайте официальный запрос в Аutodesk. Под вас подстроят постпроцессор. А редактировать постпроцессор можно в Visual Studio Code. Особенно фрезерный.;)
Изменено пользователем psix1488
Вот еще форум по постпроцессорам HSM. Можно кое-что там выудить. Нужно только зарегиcтрироваться для большей доступности к данным.
https://cloud.mail.ru/public/5GqF/mGVRLmGeF
Остается одно - перевести данный продукт и самому откорректировать постпроцессор.
В 10.05.2018 в 16:12, psix1488 сказал:
Как раз там во второй главе про редактирование постпроцессоров расписано.
Не мой случай:biggrin:. Я в этом мало что шарю, основная работа 12-14 часов в день отбирает и краю этому не видно. Проще на аутсорсинг. Есть у кого желание за вознаграждение HSM или SolidCam пост поправить?
  • 1 год спустя...
Добрый день коллеги
Есть у кого то еще интерес к данной программе. У меня после повторной установки спустя пару лет, опять появился интерес.
Есть интересные моменты которые хочется обсудить.
На иностранных форумах данной программе уделяют внимание.
С Уважением Евгений
Тоже пользую, но пока не до конца понятна структура языка постпроцессора и некоторые моменты по созданию траекторий.
  • 6 месяцев спустя...
Здравствуйте, други!
Очень нужно научиться делать деталюгу (как во вложении)
(Заготовка - толстостенная труба, зажимается в патрон четвертой (поворотной) оси. Дальше торцевание,внешний рельеф (конусы, фаски, канавка под прокладку) и отрез обрабатываются, практически как на токарном станке, только вместо резца, работает фреза (2мм)).
HSMWorks -> Mach3
Две недели штудирования мануалов и просмотров обучалок с ютуба, ни к чему, кроме головной боли и окончательного отупения не привели..
Если не очень напряжно, пожалуйста, прикрутите нужные стратегии к файлу во вложении (или к любому другому, в качестве примера)
Помогите, товарищи,  ибо чувствую, что ждет меня психиатричка..
п.с.
Думал, что для этих целей существует обработка Rotary, но, по каким-то причинам, именно её у меня в меню не оказалось :(
деталюга.SLDPRT
В 04.12.2019 в 20:26, mrg сказал:
Судя по по отсутствию ответов спустя 6 дней - выполнение в HSMWorks трех САМЫХ БАЗОВЫХ вещей, таких как 1-торцовка заготовки, 2-проход в размер и 3-отрезка уже готовой детали - отсутствуют как класс?!!
Возможно я не правильно понимаю саму суть обработки на ЧПУ, но как можно выполнять дальнейшую обработку, если деталь не в размере?
Болванка может быть криво отрезана - так?
Диаметр болванки совершенно не обязательно будет в размер детали (скорее всего с запасом) - так?
Болванка скорее всего будет не идеально круглой/ровной - так?
Патрон обязательно сколько - нибудь бьет - так?
Может быть существуют какие-то (сугубо ЧПУшные методы) где эти вещи не нужны?
https://cloud.mail.ru/public/6rZQ/wWps422a7
Перевод 2019 года (HSMWORKS2019) (мой перевод)
  • 4 месяца спустя...
Господа!
А свои приложения в этой САМ писать можно?
Какие минимальные требования к ПК?
Токарный модуль есть?
Спасибо!
  • 5 месяцев спустя...
Доброго всем, дня!
Коллеги, тут есть кто то, кто может поделиться постом для Sinumerik 828D для HSMworks 2020?
  • 3 года спустя...
Приветствую!
Вопрос, установил 2 версии HSMWorks 2021/2024 и 2 версии SolidWorks2021/2023, подскажите как настроить, чтобы при запуске HSMWorks 2021 программа запускалась в SolidWorks2021, у меня почему-то запускается HSMWorks 2024 и в SolidWorks 2021 и в SolidWorks 2023, хотелось чтобы при запуске HSMWorks 2021 программа запускалась в SolidWorks2021, в общем то для этого и устанавливались 2 версии, но запускается корректно только HSMWorks 2024 и в SolidWorks 2021 и в SolidWorks 2023?
А  HSMWorks 2021 ни в какую ?
@ilya ni а там разве не в настройках солида в меню "приложения" настраивается, какой HSM будет запускаться?
Могу лишь выбрать то что по умолчанию подхватывается HSMWorks 2024 ставя галочки в чекбоксах.
Вот как выбрать или настроить чтобы HSMWorks 2021 запускался, эта версия то установилась ведь на комп, но не запускается, как будто ее нет?
