Продам Итальянские шпиндели автосмена
Продам шпиндели Коломбо с ручной и авто смена
RS 120 - 255 000 рублей
HSD Es 929- 275 000 Рублей
RV 6 Кв 90 000 руб
RS 5.5 90 000 руб.
Сергей 8-913-716-32-84
sep16@mail.ru
Manual Tool Change Fan Cool RV series
1. Manual Tool Change RV 55/2 25 FP1 CPE20 DX, 1KW, 24000RPM, ER20, 380V, 400Hz, 2 Poles, Drawing 55E557
2. Manual Tool Change RV 73/2 FP1 CPE25 DX, 2.2KW, 24000RPM, ER25mini, 220V/380V, 400Hz, 2 Poles, Drawing 73E478
3. Manual Tool Change RV90/2 FP1 CPE25DX, 3.5KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E809
4. Manual Tool Change RV90/2 FP1CPE25DX, 4.4KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E810
5. Manual Tool Change RV90/2 FP1 CPE25DX, 5.5KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E810
6.Manual Tool Change RV90/240 FP1 SB CPE32DX, 6KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 90E1413
7. Manual Tool Change RV110/22FP1SBCPE32DX, 7.5KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 110273
8. Manual Tool Change RV 135/22 40 FP1 CPE32 DX, 9KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 135282
Manual Tool Change Electric Fan Cool RS Series
9. Manual Tool Change RS 55/2 25 FP1 CPE20 DX, 1KW, 24000RPM, ER20, 380V, 400Hz, 2 Poles, Drawing 55E703
10. Manual Tool Change RS 73/2 FP1 CPE25 DX, 2.2KW, 24000RPM, ER25mini, 380V, 400Hz, 2 Poles
11. Manual Tool Change RS90/2 FP1 SB CPE25DX, 3KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E1002
12. Manual Tool Change RS 90/2 FP1 SB CPE25 DX, 4.1KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E1003
13. Manual Tool Change RS90/2 FP1 SB CPE25 right, 5.5KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E1003.
14. Manual Tool Change RS 90/2 40 FP1 SB CPE32 DX, 6KW, 24000RPM, ER32, 220V/380V, 400Hz, 2 Poles, Drawing 90E1413
15. Manual Tool Change RS 110/22 FP SB CPE32 DX, 7.5KW, 24000RPM, ER32, 220V/380V, 400Hz, 2 Poles, Drawing 110598
16. Manual Tool Change RS 120/22 40 FP1 CPE32 DX, 9Kw, 24000RPM, ER32, 220V/380V, 800Hz, 4 Poles, Drawing 1200030
Auto Tool Change Electric Fan Cool Series
17. Auto Tool Change RS 90/22FP1-3 ISO30 CR PDE SF, 2.2KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 302156
18. Auto Tool Change RS110/22 40 FP1 ISO30 CR PDE SF, 5.5KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 301542
19. Auto Tool Change RS110/22 40 FP1 ISO30 CR PDE SF, 7.4KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 301542
20. Auto Tool Change RS120/2250FP1HSKF63CRPDE, 7.4KW, 24000RPM, 380V, 800Hz, 4 Poles, HSKF-63, Drawing 63F0722
21. Auto Tool Change RS120/2250FP1HSKF63CRPDE, 10KW, 18000RPM, 380V, 600Hz, 4 Poles, HSKF-63, Drawing 63F0722
22. Auto Tool Change RV110/22 35 FP1 ISO30 CR PDE SF, Fan cooled, equipped with copper rotor, ISO30 clamping group, 4 sensors,10 HP 7,4 KW (S1) 18.000/24.000 rpm, 380V 300/400Hz 2 poles, Drawing 30407
23. For Compressed Air Cooling Auto Tool Change 4.5KW, The part number is RC 110/22 35 FP1 ISO 30 CR PDE. Power: 4.5KW Speed: 24000RPM Voltage: 380V, ISO30,Poles:, Compressed Air Cool
24. RV90/22 35 FP1 ISO25 CR PD SF Fan cooled,
equipped with ISO25 clamping group, 4 sensors 4.1 KW (S1), 18.000/24.000 rpm, 380V 300/400Hz 2 poles Drawing 25073
RA 90/22 30 FP1 CPE25 DX Power: 4HP Speed: 18000RPM
Voltage: 380V ER25 Liquid Cooling Drawing 90A060
RA120/225AXHSKF63CRPD, 7.4KW авто смена водное охлождение
    • sloter
      В этом случае (при импорте) можно проще (раз связь с исходными построениями всё равно потеряна). При открытии  IGES зайти в Параметры и поставить галку "Импортировать несколько тел как детали".    В вышеуказанном способе поверхности перенесутся. Правда они все могут содержаться в какой то одной детали. Но правильная структура сборки на данном этапе, как я понял, вам не важна. Если поверхностей не сильно много, то может устроит.
    • Jenny
    • Павлуха
    • Бестолковый
    • igor555
    • Vengeance
    • Давид
    • the Devil incarnate
