Продам Итальянские шпиндели автосмена
Продам шпиндели Коломбо с ручной и авто смена
RS 120 - 255 000 рублей
HSD Es 929- 275 000 Рублей
RV 6 Кв 90 000 руб
RS 5.5 90 000 руб.
Сергей 8-913-716-32-84
sep16@mail.ru
Manual Tool Change Fan Cool RV series
1. Manual Tool Change RV 55/2 25 FP1 CPE20 DX, 1KW, 24000RPM, ER20, 380V, 400Hz, 2 Poles, Drawing 55E557
2. Manual Tool Change RV 73/2 FP1 CPE25 DX, 2.2KW, 24000RPM, ER25mini, 220V/380V, 400Hz, 2 Poles, Drawing 73E478
3. Manual Tool Change RV90/2 FP1 CPE25DX, 3.5KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E809
4. Manual Tool Change RV90/2 FP1CPE25DX, 4.4KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E810
5. Manual Tool Change RV90/2 FP1 CPE25DX, 5.5KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E810
6.Manual Tool Change RV90/240 FP1 SB CPE32DX, 6KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 90E1413
7. Manual Tool Change RV110/22FP1SBCPE32DX, 7.5KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 110273
8. Manual Tool Change RV 135/22 40 FP1 CPE32 DX, 9KW, 18000RPM, ER32, 220V/380V, 300Hz, 2 Poles, Drawing 135282
Manual Tool Change Electric Fan Cool RS Series
9. Manual Tool Change RS 55/2 25 FP1 CPE20 DX, 1KW, 24000RPM, ER20, 380V, 400Hz, 2 Poles, Drawing 55E703
10. Manual Tool Change RS 73/2 FP1 CPE25 DX, 2.2KW, 24000RPM, ER25mini, 380V, 400Hz, 2 Poles
11. Manual Tool Change RS90/2 FP1 SB CPE25DX, 3KW, 18000RPM, ER25, 220V/380V, 300Hz, 2 Poles, Drawing 90E1002
12. Manual Tool Change RS 90/2 FP1 SB CPE25 DX, 4.1KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E1003
13. Manual Tool Change RS90/2 FP1 SB CPE25 right, 5.5KW, 24000RPM, ER25, 220V/380V, 400Hz, 2 Poles, Drawing 90E1003.
14. Manual Tool Change RS 90/2 40 FP1 SB CPE32 DX, 6KW, 24000RPM, ER32, 220V/380V, 400Hz, 2 Poles, Drawing 90E1413
15. Manual Tool Change RS 110/22 FP SB CPE32 DX, 7.5KW, 24000RPM, ER32, 220V/380V, 400Hz, 2 Poles, Drawing 110598
16. Manual Tool Change RS 120/22 40 FP1 CPE32 DX, 9Kw, 24000RPM, ER32, 220V/380V, 800Hz, 4 Poles, Drawing 1200030
Auto Tool Change Electric Fan Cool Series
17. Auto Tool Change RS 90/22FP1-3 ISO30 CR PDE SF, 2.2KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 302156
18. Auto Tool Change RS110/22 40 FP1 ISO30 CR PDE SF, 5.5KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 301542
19. Auto Tool Change RS110/22 40 FP1 ISO30 CR PDE SF, 7.4KW, 18000RPM, 380V, 300Hz, 2 Poles, ISO30, Drawing 301542
20. Auto Tool Change RS120/2250FP1HSKF63CRPDE, 7.4KW, 24000RPM, 380V, 800Hz, 4 Poles, HSKF-63, Drawing 63F0722
21. Auto Tool Change RS120/2250FP1HSKF63CRPDE, 10KW, 18000RPM, 380V, 600Hz, 4 Poles, HSKF-63, Drawing 63F0722
22. Auto Tool Change RV110/22 35 FP1 ISO30 CR PDE SF, Fan cooled, equipped with copper rotor, ISO30 clamping group, 4 sensors,10 HP 7,4 KW (S1) 18.000/24.000 rpm, 380V 300/400Hz 2 poles, Drawing 30407
23. For Compressed Air Cooling Auto Tool Change 4.5KW, The part number is RC 110/22 35 FP1 ISO 30 CR PDE. Power: 4.5KW Speed: 24000RPM Voltage: 380V, ISO30,Poles:, Compressed Air Cool
24. RV90/22 35 FP1 ISO25 CR PD SF Fan cooled,
equipped with ISO25 clamping group, 4 sensors 4.1 KW (S1), 18.000/24.000 rpm, 380V 300/400Hz 2 poles Drawing 25073
RA 90/22 30 FP1 CPE25 DX Power: 4HP Speed: 18000RPM
Voltage: 380V ER25 Liquid Cooling Drawing 90A060
RA120/225AXHSKF63CRPD, 7.4KW авто смена водное охлождение
    • Orchestra2603
      матрица жесткости не будет. Но матрица K-lambda*M будет, если lambda есть собственное значения. Просто по определению, т.к. определитель должен быть равен нулю. Вам чтобы найти собственные вектора в любом случае придется решать недоопределенную вырожденную СЛАУ. Какое же это тогда закрепление по-вашему?,
    • Radon
      Если в рабочий диапазон частот вращения ротора попадает критическая частота вращения ротора с изгибной формой колебаний, то конструктором проводится частотная отстройка. Одним из способов частотной отстройки является применение в опорах дополнительных упругих элементов, которые выводят такую критическую частоту из рабочего диапазона. Однако при этом в рабочем диапазоне могут оставаться критические частоты вращения с другими формами колебаний. Если не применять специальные мероприятия, то на соответствующих этим критическим частотам вращения резонансных режимах могут наблюдаться повышенные вибрации. (Леонтьев КОНСТРУКЦИЯ И РАСЧЕТ ДЕМПФЕРНЫХ ОПОР РОТОРОВ ГТД)   Скорее всего да, у нас её так называют. Те м более A Campbell diagram plot represents a system's response spectrum as a function of its oscillation regime. Или например тут https://ipi1.ru/images/PDF/2017/104/opredelenie-rezonansno.pdf или тут http://www.unn.ru/pages/issues/vestnik/99999999_West_2013_1(3)/1.pdf линии гармоник, неправильно, линии собственных частот Для изотропных (осесимметричных) систем, т.е. систем, у которых в плоскости, перпендикулярной оси вращения ротора, характеристики ротора не зависят от направления, колеюания на критических частотах обратная прецессия не возбуждается собственной неуравновешенностью ротора. Возбуждение таких колебаний возможно лишь в случае наличия анизотропии жёсткости, либо когда на ротор вращающийся с частотой w, действует нагрузка, вращающаяся с частотой w в другую сторону. А причём тут преднапряжённое состояние то? Колёса вообще можно заменить точечными массами с соответствующими моментами инерции (какое уж тут преднапряжённое состояние), преднапряжённое состояние к гироскопическим моментам не имеет никакого отношения
      @kasstet Можете выкладывать картинки прямо в форуме (после 10 ответов в ветках форума):
    • Пингвинчик
      Мы не делаем УП. Технологи требуют выпуск КД где в листах нанесены предварительные отверстия.  Не могу ничего сказать, непосредственно на станках не работаю.
    • Богоманшин Игорь
      Допуск на размер фаски 1-3 мм +-0,2 мм. Назначаете фаску 1.5, делают по нижнему допуску, т.е. 1.3. Нитка резьбы (глубиной 1.3) окажется на ребре фаски, при нарезании еще выдавит. Понятно, что станок с ЧПУ может и с нулевым допуском сделать, но, все же, лучше сделать так, чтоб гарантированно получить "красивый" результат, независимо от оборудования и степени криворукости исполнителя.
      Не знаю как у вас, но часто ТТ заканчиваются фразой: остальное по ОСТ4 Г0.070.014, ОСТ4 Г0.070.015, где:   Если есть ГОСТ на детали часов, где это прописано, то возможно. Ваше утверждение в данном случае ни чем не подтверждено, ссылок на нормативные документы вами не представлено.
      Medidata Selected by Worldwide Clinical Trials to Accelerate Trials and Transform Patient Experience Просмотр полной статьи
      У вас не будет нулевых частат, а первые собственные частоты будут равны 100. Матрица жесткости не будет вырождена. И можно спокойно делать численную факторизацию. А этот сдвиг и есть закрепление...
    • fenics555
      Так попробуйте из карбида вольфрама. Мы раньше пользовались dormer, теперь приходится пробовать из Китая, но там и цена конечно смешная.  ПС: "Твердосплавный экструзионный кран" Вам в помощь для поиска!
    • kasstet
      https://postimg.cc/gallery/6vDZ34S   Или так.
