This is your PTC Technical Support Email subscription
Number Product Description
Article_CS98410
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 How to set default font for 3D dimensions, 3D annotations notes in Creo Elements/Pro 5.0
Article_CS6367
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 Behavior of active drawing model in Creo Parametric 2.0
Article_CS57825
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 About limitation of characters in text note in sketch mode in Creo Parametric
Article_CS55959
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 No Edit Definition option after click the right mouse button on model features in Creo Elements/Pro
Article_CS50736
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 In Pro/ENGINEER Wildfire 5.0, new background color from active window is not kept if we activate another window after adding view's ligths or scene.
Article_CS43376
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 How to create a machined endmill cut in a cylinder wall in Pro/ENGINEER Wildfire 4.0
Article_CS28948
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 How to define a flexible component in an assembly in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
Article_CS15431
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 How to show Pro/PIPING specific parameters also in extracted solid models in Creo Elements/Pro 5.0
Article_CS127335
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 How to show different quantity values for each assembled instance of a single component in Assembly repeat region BOM table
Article_CS127129
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 ProDrawingDimCreate() API cannot create a radius dimension (Creo Elements/Pro)
Article_CS127104
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 The Pro/ENGINEER icon is not correct for that Pro/ENGINEER file with version number
Article_CS126394
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 Is it possible to create snap line in 3D annotation just like in drawing in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
Article_CS124586
Pro/ENGINEER and Creo Elements/Pro Wildfire 5.0 How to copy detail items in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
Article_CS108301
Pro/ENGINEER and Creo Elements/Pro Wildfire 4.0 How to control cabling location node size in drawing in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
PS Может кого из россиян командируем в PTC, командовать Email subscription
PTC Technical Support for RUSSIA? А то шлют и шлют на басурманском диалекте
Кого еще так производственно заспамяли? :blink::g:
bomber
да не возьмут они русского на такую должность, там по инструкции работать нужно, а наши от души работают.
да и спамик это нормальный, веселее, когда пакет лицензий нужно на новую версию перевести, например FW4 и FW5 на крео 1 или 2, там они вообще тупят по страшному...
      а как вы taxid фирмы нашли?
      с него родимого
    • Grundick
