Удалить историю записей файла
IgP
Уважаемые коллеги!
Надо удалить историю "сохранений" prt-файла.
(та, что Main menu -> Information -> Part -> Part History...
Гл.меню -> Информация -> Деталь -> История детали)
Кто-нибудь знает способ ?
у меня в голове давний однозначный ответ - НЕТ (это невозможно ...)
но вдруг ? ....
через создание нового файла - не предлагать - знаю ....
речь о файле-шаблоне семейства ....
nut888, niki, Ug_user, uGRAF.exe, avd - что скажете ?
Файл - экспорт - деталь.
Тогда (возможно) Вам подойдет команда 'refile_part -anonymize <filename>'
Скрытый текст: Параметры
refile_part
usage: refile_part [options]
  where the [options] are:
  [<filename>]				  Refiles file <filename>.
  [-c]						  Creates components if necessary during upgrade.
  [-co]						 Compresses the part(s) when refiling.
  [-d]						  Convert all parts/UDFs in current directory.
  [-d <dirname>]				Convert all parts/UDFs in directory <dirname>.
  [-g]						  Upgrade components.
  [-l]						  Logs a short report to the syslog.
  [-l <filename>]			   Logs a short report to the syslog and <filename>.
  [-ll]						 Logs an extended report to the syslog.
  [-ll <filename>]			  Logs an extended report to the syslog 	and <filename>.
  [-o <filename>]			   Sets new file <filename> as the destination.
  [-o <dirname>]				Sets existing directory <dirname> as the destination.
  [-r]						  Prints refile_part (NX) release.
  [-s]						  Traverses subdirectories.
  [-u]						  Refiles UDF files.
  [-uo]						 Refiles UDF files only.
  [-uc]						 Uncompresses the part(s) when refiling.
  [-y]						  Fully load assembly, and refiles components that are not at the current version of NX.
  [-f]						  Used with the -y switch to force all components to be refiled.
  [-us]						 Updates the assembly structure to include any changes in lower level subassemblies.
  [-ts]						 Generates True Shape data only.
  [-nop]						Do not change file owner and protection.
  [-ndates]					 Do not change file modified date and accessed date.
  [-dwg_update]				 Force update all drawings without any fixup.
  [-cleanup]					Perform part cleanup.
  [-anonymize]				  Removes user and program version strings from part history.
  [-convert_mcs <filename>]	 Converts mating conditions to assembly constraints. Logs a constraint conversion report to <filename>.
	[-mc_parts_only]					  Used in conjunction with convert_mcs  to specify only refile parts which contain mating conditions.
	[-mc_dry_run]						 Used in conjunction with convert_mcs to do the mating condition conversion and generate the conversion report without saving any parts.
	[-mc_dont_load_referenced_geometry]   Used in conjunction with convert_mcs to not load geometry referenced by the mating conditions being converted. Note this will bypass constraint conversion checking.
  [-regen_lw]				   Force all lightweight bodies in the specified part to be regenerated. The faceting parameters previously used to create each body will be used again. Note: For assembly level representations the regeneration operation will be executed only if the source componen parts are loaded. The -y switch can be used to ensure the components are loaded. This option is now done by default for parts saved prior to NX7.5.
  [-regen_lw_def_tol]		   Same as -regen_lw except that with this option the faceting parameters on the existing body will be ignored and the default system or user specified (if defined in the customer defaults) faceting parameters will be utilized.
Семейство сохраняется, а история детали после очистки выглядит так:
Отчет об истории сохранения детали
Файл детали: bolt7798-70.prt
 Версия  Время записи		   Платформа	 Пользователь	 Программа
Загружен						NT x64				  NX 8.0.3.4
	  538  01 04 2013 13:32	 NT x64
	  537  22 08 2008 16:23	 NT Intel
	  536  22 08 2008 13:50	 NT Intel
	  535  22 09 2008 13:50	 NT Intel
		2  02 10 2002 11:01	 NT Intel
		1  02 10 2002 10:25	 NT Intel
Замечание; Эта деталь было до этого сохранена без всяких изменений
Последнее существенное изменение имело место в следующей версии: 537
Я пытался разобраться с этим, пока ничего не накопал. Через UGOPEN можно прочесть history, можно даже удалить какую-то запись (тут я обрадовался), удаление происходит только в том списке, который прочитал. Сама история части недоступна для редактирования. Мне недоступна, вао всяком случае.
Спасибо.
Когда сам писал программы, помню что так и было ....
с одной стороны всё логично весь ЖЦ файла,
но иногда хочется от этого избавиться ...
поэтому и спрашиваю, может кто что хитросделанное (тайное) знает, умеет ...
