Ассоциативный отрезок средствами UG Open
jREj
Здравствуйте! Нужно построить ассоциативный отрезок (набор отрезков) программным методом из точек. Точки уже построены вручную. В справке нашел функцию UF_CURVE_create_line_arc. Ей надо передать указатель на структуру.... В этом проблема. Структура показана ниже:
struct UF_CURVE_line_arc_s
   UF_CURVE_line_arc_type_t		curve_type;	 /* Type of curve to create i.e. line/arc */
   UF_CURVE_asso_arc_subtype_t  arc_constraint_subtype; /* The subtype of curve */
   UF_CURVE_constraint_t		constraints[3];		/* Array of constraint to be satisfied.
																				 * Two constraints in case of line.
																				 * Two constraints in case of arc by center.
																				 * Three constraints in case of arc.
   UF_CURVE_limit_t			 limits[2];					   /* The start and end limits of the curve */
   tag_t						plane_of_curve;					 /* Plane on which curve must lie.
																				   * If NULL_TAG, plane will be infered.
																				   * Else all the object in the constraints
																				   * array above will be projected on the plane.
   logical						complement;							  /* False - Default arc will be created.
																						 * True  - Complement of default arc will be
																						 * Used only in ARC.
   logical						closed;		  /* False - Arc bounded by limits above will be
												* True  - Full circle will be created.
												* Used only in ARC.
   logical					 is_associative; /* true if associative, false if not associative */
typedef struct UF_CURVE_line_arc_s UF_CURVE_line_arc_t, *UF_CURVE_line_arc_p_t;
1-й вопрос: Третий и четвертый члены структуры: вложенные структуры или массивы структур???
Сами структуры показаны ниже. Для третьего члена:
struct UF_CURVE_constraint_s
   UF_CURVE_constraint_type_t	constraint_type;  /* The type of constraint */
   UF_CURVE_end_type_t			end_type;		 /* The end to which this constraint must be applied*/
  tag_t						object_tag;	   /* Object with which the constraint is to be applied. */
   double						 value;			/* If constraint needs a value then
															   * use this field, ex. UF_CURVE_angle
																* UF_CURVE_radius type constraints.
   UF_CURVE_help_data_t		help_data;		/* help data when constraint is tangent / normal */
typedef struct UF_CURVE_constraint_s UF_CURVE_constraint_t, *UF_CURVE_constraint_p_t;
Для четвертого:
struct UF_CURVE_limit_s
   UF_CURVE_limit_type_t		limit_type;  /* Type of limit */
   double								   value;	   /* Value by which to extend
																  * in case of UF_CURVE_limit_value.
																  * In case of arc/circle the value
																  * should be in degrees.
   tag_t									   limiting_obj;				/* The object upto which the end must be extended
   UF_CURVE_help_data_t		help_data;	/* help data when limit is up to an object */
typedef struct UF_CURVE_limit_s UF_CURVE_limit_t, *UF_CURVE_limit_p_t;
Вот часть кода:
static void do_ugopen_api(void)
char cue[] = "Выберите точки";
	char title[] = "Выберите точки";
	int response, count, i;
	tag_p_t objects; //адресса точек
	tag_t line1;  // тег линии.
	UF_CURVE_line_arc_t line_parameters[MAX_POINTS];	//создаю массив структур
	if((UF_CALL(UF_UI_select_with_class_dialog(
		  cue, title, UF_UI_SEL_SCOPE_WORK_PART_AND_OCC,
		  init_proc, NULL , &response, &count, &objects))) == 0)   //выбираю объекты, в частности точки
		 if (response == UF_UI_OK && count > 0)
			 for (i=0; i<count; i++)  // исходя из количества точек строю нужное количество отрезков.
				 line_parameters[i].curve_type = UF_CURVE_asso_line;
				 line_parameters[i].constraints[0].constraint_type = UF_CURVE_coincident;
				 line_parameters[i].constraints[0].end_type = UF_CURVE_start;
				 line_parameters[i].constraints[1].constraint_type = UF_CURVE_along_x;
				 line_parameters[i].constraints[1].end_type = UF_CURVE_end;
				 line_parameters[i].limits[0].limit_type = UF_CURVE_limit_value;
				 line_parameters[i].limits[0].value = -100.00;
				 line_parameters[i].limits[1].limit_type = UF_CURVE_limit_value;
				 line_parameters[i].limits[1].value = 100.00;
				 line_parameters[i].plane_of_curve = NULL_TAG;
				 line_parameters[i].is_associative = TRUE;
				 UF_CALL(UF_CURVE_create_line_arc (&line_parameters[i], &line1));
		UF_DISP_set_highlight(objects[i], 0);
			UF_free(objects);
Код компилируется , при запуске в ЮГ выходит меню, точки выбираются и далее ошибка, которую выводит UF_CALL. Что то вроде: "memory access violation" в функции UF_CURVE_create_line_arc.
Пробовал отдельно создавать структуры для третьего и четвертого членов.
Типа такого:
UF_CURVE_constraint_t  constraint_X_start = { UF_CURVE_coincident,UF_CURVE_start};
И обращаться:
 line_parameters[i].constraints[0] = constraint_X_start
Если делать так, то Вижуалка ругается, говорит : "левый операнд должен быть левосторонним значением"
Покажите как правильно обращаться к членам подструктур третьего и четвертого членов структуры UF_CURVE_line_arc_s, чтобы задать им нужные значения.
Читал книги по Си/Си++, но там примеры не совсем похожи на то что здесь.
Или может кто подскажет как соорентировать неассоциативный отрезок относительно РСК. В функции UF_CURVE_create_line нет таких параметров :(
Всем заранее спасибо!!!
P.S. Может посоветуйте дельную книгу, где есть что-то похожее.
Изменено пользователем jREj
Коллеги! Можете прояснить из-за чего выходит такая ошибка?
*** ERROR code 11 at line 130 in c:\work\nx open and grip\x86\uf_curve_line_arc\uf_curve_line_arc\uf_curve_line_arc.c:
+++ Internal error: memory access violation
UF_CURVE_create_line_arc (&line_parameters, &line1);
Обычно, неправильная работа с указателями...
Спасибо, будем разбираться с указателями...
Вроде разобрался с указателями и получилось задать нужные значения членам структуры UF_CURVE_line_arc_s. Кроме двух членов вложенной структуры UF_CURVE_constraint_s. Эти члены - object_tag для начала и конца отрезка. Я правильно понимаю, что если мне необходимо построить ассоциативный отрезок из ассоциативной точки вдоль оси X РСК, то я для начала отрезка должен записать в структуру тег точки, а для конца - тег РСК???
Тег точки я выдергиваю при помощи функции UF_UI_select_with_class_dialog. Тег РСК при помощи UF_CSYS_ask_wcs. Записываю их в структуру. Но при вызове функции UF_CURVE_create_line_arc выходит ошибка:
*** ERROR code 660008 at line 239
+++ Object supplied is of the wrong type.
UF_CURVE_create_line_arc(line_data_p, &line2);
Я так понимаю что с объектами что-то не так. Пробовал определять тип и подтип объектов функцией UF_OBJ_ask_type_and_subtype, все нормально объекты соответствуют типам (целым числам), которые описаны в uf_object_types.h.
При выводе членов структуры в листинг, при помощи таких инструкций:
UF_CALL(UF_UI_open_listing_window());
sprintf(buffer,"тег %d constraints[0].object_tag = %d\n\n",i,line_data_p->constraints[1].object_tag);
UF_CALL(UF_UI_write_listing_window(buffer));
Значения объектов адекватные, например 29600, а не миллиардные....
Значения перечислимых типов данных тоже нормальные, как в справке к NX.
Подскажите, что не так....
Вот часть кода:
		 if (response == UF_UI_OK && count > 0 && count <= MAX_POINTS)
	UF_CALL(UF_CSYS_ask_wcs(&wcs_tag));				 //определяем тег РСК
//Присваиваем членам структуры нужные значения
		 line_data_p[i] = &line_data[i];				   // инициализирую указатель на структуру
	line_data_p[i]->curve_type = UF_CURVE_asso_line;
	line_data_p[i]->constraints[0].constraint_type = UF_CURVE_coincident;
	line_data_p[i]->constraints[0].end_type = UF_CURVE_start;
	line_data_p[i]->constraints[0].object_tag = objects[i];	 // Присваиваем тег точки члену object_tag структуры
	line_data_p[i]->constraints[1].constraint_type = UF_CURVE_along_x;
	line_data_p[i]->constraints[1].end_type = UF_CURVE_end;
	line_data_p[i]->constraints[1].object_tag = wcs_tag;	  // Присваиваем тег РСК члену object_tag структуры
	line_data_p[i]->limits[0].limit_type = UF_CURVE_limit_to_constraint;
	//line_data_p[i]->limits[0].value = -100.0;
	line_data_p[i]->limits[1].limit_type = UF_CURVE_limit_value;
	line_data_p[i]->limits[1].value = 100.0;
	line_data_p[i]->plane_of_curve = NULL_TAG;
	line_data_p[i]->is_associative = TRUE;
		UF_CALL(UF_CURVE_create_line_arc(line_data_p[i], &line2));
		 UF_free(objects);
Может перед записью тега в структуру нужно с ним что-то сделать??? Может функция sprintf проводит форматирование и в листинг выходит нужное число, а в структуру тот же объект но значение у него не то...
Помогите пожалуйста, никак не могу понять в чем дело, в справке ничего не нашел по этому поводу... :sad::cry_1:
Вот часть кода:
		 UF_free(objects);
Мой совет
Постройте руками свой отрезок и с помощью программирования и NXDegaber посмотрите как он устроен
Анализ по типам как Вы привели недостаточен
Точка кроме всего прочего может быть смартом - У Вас это не проверяется (UF_SO)
Объект может иметь статус (UF_OBJ)
Вообще сомнительный способ создания ассоциативного отрезка
Делается это все не так а с помощью UF_UDOBJ
Всем спасибо за советы. Построил набор ассоциативных отрезков :smile:
Проблема была в следующем: вместо тега РСК нужно было отправить тег направления. (Пояснили на форуме программистов). Это сделал при помощи функции из группы UF_SO. Тема закрыта.
какая принципиальная разница между смарт-объектом и ассоциативным объектом???
