определение типа операции в C#
Помогите пожалуйста. Нужно определить в C#, к какому типу(mill_multi-axis или mill_contour) относится операция SurfaceContour. Какой метод или класс это делает?
Изменено пользователем Kadet
Не знаю как там в решётках, но в UG опене есть UF_OPER_ask_oper_type
возвращает
#define UF_machining_operation_type			 100
#define	UF_mach_instanced_oper_subtype			  1
#define	UF_mach_orphan_oper_subtype				 2
#define	UF_mach_oldopr_subtype					 10	   /* Obsolete */
#define	UF_mach_pocket_subtype					110
#define	UF_mach_surface_contour_subtype		   210
#define	UF_mach_vasc_subtype					  211
#define	UF_mach_cavity_milling_subtype			260
#define	UF_mach_face_milling_subtype			  261
#define	UF_mach_volumn_milling_subtype			262
#define	UF_mach_zlevel_milling_subtype			263
#define	UF_mach_fb_hole_milling_subtype		   264
#define	UF_mach_plunge_milling_subtype			265
#define	UF_mach_vazl_milling_subtype			  266
#define	UF_mach_turn_rough_subtype				510
#define	UF_mach_turn_finish_subtype			   520
#define	UF_mach_turn_teachmode_subtype			530
#define	UF_mach_turn_thread_subtype			   540
#define	UF_mach_turn_cdrill_subtype			   550
#define	UF_mach_turn_auxiliary_subtype			560
#define	UF_mach_hole_making_subtype			   600
#define	UF_mach_wedm_subtype					  700
#define	UF_mach_mill_ud_subtype				   800
#define	UF_mach_gmc_subtype					   900
#define	UF_mach_probing_subtype				  1000
#define	UF_mach_mill_mc_subtype				  1100
#define	UF_mach_lathe_mc_subtype				 1200
#define	UF_mach_wedm_mc_subtype				  1300
#define	UF_mach_lathe_ud_subtype				 1400
#define	UF_mach_wedm_ud_subtype				  1500
#define	UF_mach_mass_edit_subtype				1600
#define	UF_mach_thread_milling_subtype		   1700
#define	UF_insp_tolerance_subtype				1800
#define	UF_insp_path_subtype					 1900
#define	UF_insp_output_subtype				   2000
#define	UF_insp_misc_subtype					 2100
#define	UF_insp_align_subtype					2200
#define	UF_insp_sensor_subtype				   2300
#define	UF_insp_construct_subtype				2400
#define	UF_insp_bounding_feature_subtype		 2500
#define	UF_insp_feature_subtype				  2600
#define	UF_mach_cylinder_milling_subtype		 2700
#define	UF_mach_canned_cycle_subtype			 2800
210 это типа mill_contour, а 211 - mill_multi-axis. Подтип берем UF_OBJ_ask_type_and_subtype.
Пишу без проверки
возвращает
Пишу без проверки
Вот как оказывается. То что мне надо
int type,subType;
 theUfSession.Obj.AskTypeAndSubtype(oper.Tag, out type, out subTupe);
Спасибо большое!!!!!!! Я на этот метод обратил внимание, но что за значения он выдает понял только после приведенной Вами таблицы.
Еще вопрос появился, не подскажите, как сделать, что бы в clsf файл выводилась окружность полностью, а не по квадратным
    • OliverTwist
    • Alexandr97
    • Shura762
      Ну не знаю. У нас в свое время было таких ИС-800 8 шт. Один из них самый первый был с круглым магазином на 32 инструмента, привода сименс, ЧПУ балт систем. Если к чпу и приводам претензий не было, то к механике были серьезные вопросы. А вот остальные 7 все как один, 64 инструмента, фанук везде и вся, датчики, линейки, энкодеры ханденхайн, к механике особых претензий уже нет, да, бывают поломки, периодически по мере необходимости меняем опоры качения и прочее... Да, есть слабые места, например упорный подшипник ШВП оси Z, периодически дохнет из за попадания сож и Z начинает дергаться как эпилептик, приходится менять. Все эти станки работают с 2007-2010 годов в три смены без остановок. Из крупных поломок за все это время, материнка в одном УЧПУ померла, на одном стол вырвало, на одном PSM смачно взорвался и вот сейчас похоже этот же восстановленный PSM взбрыкнул. Мелочовку типа порванных РВД и ремонтов по причине естественного износа, типа замены опор качения я не считаю. Бывает индуктивные датчики летят, приходится менять, но это еще мельче и устраняются в течение часа со всеми перекурами когда карта сигналов и мест установки датчиков есть. К тому же эти станки до сих пор держат свою геометрическую точность, периодически проверяем их. Точнее сначала оператор начинает замечать что то не то, потом мы смотрим что не то, ремонтируем и проверяем  Но у нас преимущество, у нас есть очень грамотный и опытный станочник, он с закрытыми глазами находит неисправности, да и станки эти знает вплоть до каждого винтика. Ну и само собой по мере необходимости и шпиндели отправляем в ремонт. Правда последний раз эта организация нам так восстановила шпиндель на токарный LEADWELL, что точил вместо круга непонятно что. Разобрали и ужаснулись, подшипники стоят неправильно, кольца вообще не там где должны быть, какие то медные проставки, которых там сроду не должно быть... Пришлось самим в срочном порядке пересобирать правильно и каким то чудом шпиндель заработал как и должен. Каким чудом я не знаю, но тем не менее работает уже год. Претензий нет. В те времена, когда их было 8 шт, а токарных LEADWELLов больше 20, еще некоторые и с барфидерами, так я чаще ремонтировал барфидеры, чем ИС-800. Да, сейчас настал кризис, часть станков продали, часть работников сократили, и их осталось всего 3 штуки.
    • Tad
    • zwg
