постпроцесор
qwweasd
Добрый день. Господа вопрос к знатокам по постпроцессорам. Есть станок (SUPER Mini mill HAAS) из Power Mill сохраняется постпроцессором Fanuc1 (тип файла "PMOPT" (.pmopt)) подскажите как сохранить (УП) из ArtCam для этого станка. Возможно кто то уже сталкивался с этой проблемой и есть готовое решение. Постпроцесор в текстовом режиме.
<?xml version="1.0" encoding="UTF-8"?>
<pmp:option-file xmlns:pmp="urn:aerokom">
<pmp:header>
<pmp:version value="3,0,2,5" pmpost="4,50,1,55602"/>
<pmp:history created="1128084049015" lm="1279265245453" author="Umakant" customer="----" mtool="---" controller="Fanuc" csoft="---" lastuser="Администратор" mtoolmodel="---" spnote="Required PMPost version : PM-Post 4.00 CodeBase 21303 and Above">
<pmp:notes><![CDATA[Delcam PostProcessor : Standard Post for "Fanuc" Controller.
This post is supporting to :
1. Only suitable for 3 axis
2. Arc output in 'I J K' format
3. MM or INCH type output
4. Drilling Cycles supported :
Single peck G81
Deep Drill G82
Chip Break G83
Tapping G84
Ream G85
Counter Bore G86
Bore 3 G87
Bore 4 G88
Bore 5 G89
This post is not-supporting to :
1. Splinemill is not supported
2. Drilling cycles which are not supported :
Drill Deep 2
Rigid Tapping
Helical
Reverse Helical
Helical Clockwise
Reverse Helical Clockwise
]]></pmp:notes>
<pmp:revision date="1151576877343" author="Update info"><![CDATA[
CODEBASE 0171.
New Euler conventions are supported.
CODEBASE 0178.
Commands have a new option: 'Disallow'.
CODEBASE 0183.
Parameters 'Primary Angle', 'Secondary Angle' and so on have been replaced by the corresponding 'Machine ...' parameters.
CODEBASE 0184.
You can now use user commands as command items.
CODEBASE 0185.
A new parameter 'RTCP Mode' is available.
CODEBASE 0191.
A new parameter 'Tool Cutting Length','Tool Taper Angle','Tool Tip Radius X','Tool Tip Radius Y','Toolpath Type' are available.
Parameter 'Recommended Length' has been renamed to 'Tool Overhang'.
Parameter 'Part Number' has been renamed to 'Program Number'.
Parameter 'Cutting Strategy' has been renamed to 'Toolpath Cutting Strategy'.
CODEBASE 0193.
The Settings page now includes an 'ACC' (Automatic Coordinate Control) tab.
The 'Set Workplane ON' and 'Set Workplane OFF' commands have been added.
On the 'Settings'/'Multiaxis Configuration' page a new option of 'Use ZERO Tool Length' replaces 'Tool Length Compensation'. The values are interchanged : ON -> OFF and OFF -> ON.
Template machine kinematics are now based on the MTD schema.
CODEBASE 0195.
Added two parameters for drilling: 'Multi-Axis Drilling Enable' (ON/OFF), 'Avoid ACC (Automatic Coordinate Control) if possible' (ON/OFF).]]></pmp:revision>
<pmp:revision date="1151576878093" author="Update info"><![CDATA[
CODEBASE 0195
CODEBASE 0204
Added 'Tool Number Next' parameter.]]></pmp:revision>
<pmp:revision date="1161762984798" author="Update info"><![CDATA[
CODEBASE 0207
Added 'Output Point Info' parameter.]]></pmp:revision>
<pmp:revision date="1162437807878" author="Update info"><![CDATA[
CODEBASE 0208
Added 'Current User' parameter.]]></pmp:revision>
<pmp:revision date="1164612311708" author="Update info"><![CDATA[
CODEBASE 3024
Added 'disabled' attribute for blocks.]]></pmp:revision>
</pmp:history>
</pmp:header>
<pmp:configuration>
<pmp:config-time-format value="System Time"/>
<pmp:config-date-format value="System Date"/>
<pmp:config-nc-file-extension value="txt"/>
<pmp:config-units linear="THE SAME" angular="DEG"/>
<pmp:config-spline value="0"/>
<pmp:config-number-formatting decimalSeparator="." exponentLetter=""/>
<pmp:config-separator value=""/>
<pmp:config-trim-spaces value="0"/>
<pmp:config-line-end value=""/>
<pmp:config-arc-tolerance mode="0" value="0"/>
<pmp:config-wp-definition value="machine" eulerConvention="0"/>
<pmp:config-frame-number output="1" start="10" end="999999" step="10"/>
<pmp:config-arcs origin="0" min="-180" max="180"/>
<pmp:config-circular interpolation_xy="1" interpolation_xz="1" interpolation_yz="1" quadrant="0" linSource="0" minRadius="0" maxRadius="10000"/>
<pmp:config-feedrates min="1" maxRapid="999999" maxCutting="999999"/>
<pmp:config-multiaxis linearization="0"/>
<pmp:config-multiaxis-feedrate calculation="2" coefficient="0.1"/>
<pmp:config-multiaxis-drilling mxsDrillEnable="OFF" mxsDrillAvoidACC="ON"/>
<pmp:config-mtd-type value="3axis"/>
<pmp:config-mtd-path value=""/>
<pmp:config-mtd-listing value="<?xml version="1.0"?> <machine xmlns="x-schema:PowermillMachineTool"> <table_attach_point PART="table" X="0" Y="0" Z="0"/> <head_attach_point PART="head" X="0" Y="0" Z="0" I="0" J="0" K="1"/> <machine_part> <model_list> <dmt_file> <path FILE="PMPost:3-axis\symbol_head_linear_z.dmt"/> <rgb R="200" G="0" B="0"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\symbol_table_linear_x.dmt"/> <rgb R="200" G="0" B="0"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\symbol_table_linear_y.dmt"/> <rgb R="200" G="0" B="0"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\linear_table_axis_y.dmt"/> <rgb R="0" G="0" B="130"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\linear_head_axis_z.dmt"/> <rgb R="0" G="0" B="130"/> </dmt_file> </model_list> </machine_part> <machine_part> <axis> <control_info ADDRESS="Y"/> <simple_linear I="0" J="-1" K="0"/> </axis> <model_list> <dmt_file> <path FILE="PMPost:3-axis\linear_sub_table_axis_y.dmt"/> <rgb R="0" G="80" B="0"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\linear_table_axis_x.dmt"/> <rgb R="0" G="0" B="130"/> </dmt_file> </model_list> <machine_part> <axis> <control_info ADDRESS="X"/> <simple_linear I="-1" J="0" K="0"/> </axis> <model_list> <dmt_file> <path FILE="PMPost:3-axis\linear_sub_table_axis_x.dmt"/> <rgb R="0" G="80" B="0"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\table.dmt"/> <rgb R="120" G="120" B="120"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\table_sub.dmt"/> <rgb R="30" G="30" B="30"/> </dmt_file> </model_list> <machine_part NAME="table"/> </machine_part> </machine_part> <machine_part> <axis> <control_info ADDRESS="Z"/> <simple_linear I="0" J="0" K="1"/> </axis> <model_list> <dmt_file> <path FILE="PMPost:3-axis\head.dmt"/> <rgb R="80" G="80" B="80"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\head_tool.dmt"/> <rgb R="30" G="30" B="30"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\head_tool_end.dmt"/> <rgb R="30" G="30" B="30"/> </dmt_file> <dmt_file> <path FILE="PMPost:3-axis\linear_sub_head_axis_z.dmt"/> <rgb R="0" G="80" B="0"/> </dmt_file> </model_list> <machine_part NAME="head"/> </machine_part> </machine> "/>
<pmp:config-multiaxis-tolerance source="1" linear="0.001" angular="0.001"/>
<pmp:config-drill-clear-plane origin="4" negative="0"/>
<pmp:config-drill-first-depth origin="0" negative="0"/>
<pmp:config-drill-hole-top origin="0" negative="0"/>
<pmp:config-drill-peck-depth negative="0"/>
<pmp:config-drill-total-depth origin="4" negative="0"/>
<pmp:config-drill-retract-2nd-height origin="0" negative="0"/>
<pmp:config-retract-reconfig limitMode="stop_program" minMode="0" rotateLimit="3" reconfigMode="simple" withdrawal="100" plungeDistPerc="10" retractRateMode="0" retractRate="1" plungeRateMode="0" plungeRate="1"/>
<pmp:config-automatic-coordinate-control accEnable="0" accPreset="acc_preset_3axis" cfg3axis="acc_cfg_3axis_fff" cfg3plus2="acc_cfg_3plus2_fff" cfgMultiaxis="acc_cfg_multiaxis_fff"/>
<pmp:config-machine-attach-point mapoPointType="tool_tip" mapo3AxisTT="OFF"/>
</pmp:configuration>
<pmp:parameters>
<pmp:format name="Default format" outputToTape="1" dependency="2" incremental="0" sign="0" leadZeros="0" trailZeros="0" intZero="1" decZero="3" exponent="0" widthMode="0" width="9" decSep="1" mZeroString=";not-used" mDecPlaces="3" mScale="1" iZeroString=";not-used" iDecPlaces="3" iScale="1">
<pmp:group id="XP" prefix="" postfix="" outputted="1">
<pmp:group-value state="OFF"/>
<pmp:group-value state="ON" init="true"/>
</pmp:group>
<pmp:group id="MW" prefix=" " postfix="" outputted="1">
<pmp:group-value state="ON"/>
<pmp:group-value state="OFF" init="true"/>
</pmp:group>
<pmp:group id="MK" prefix="" postfix="">
<pmp:group-value state="CUTTING"/>
<pmp:group-value state="LINK"/>
<pmp:group-value state="APPROACH"/>
<pmp:group-value state="RETRACT"/>
<pmp:group-value state="PLUNGE"/>
<pmp:group-value state="LEAD_IN"/>
<pmp:group-value state="LEAD_OUT"/>
<pmp:group-value state="CYCLE_LINK"/>
<pmp:group-value state="CYCLE_PLUNGE"/>
<pmp:group-value state="CYCLE_RAPID"/>
<pmp:group-value state="CYCLE_OUTPUT"/>
<pmp:group-value state="JOINUP_3AXIS"/>
<pmp:group-value state="JOINUP"/>
<pmp:group-value state="LEAD"/>
</pmp:group>
<pmp:param id="XB" prefix="X" postfix=""/>
<pmp:param id="YB" prefix="Y" postfix=""/>
<pmp:param id="ZB" prefix="Z" postfix=""/>
<pmp:param id="AW" prefix="X" postfix=""/>
<pmp:param id="BW" prefix="Y" postfix=""/>
<pmp:param id="CW" prefix="Z" postfix=""/>
<pmp:param id="WX" prefix=" A" postfix=""/>
<pmp:param id="WY" prefix=" B " postfix=""/>
<pmp:param id="WZ" prefix=" C" postfix=""/>
<pmp:param wp-axis="X" linear="1" id="guid8B2D113BBE0A401197D5CD2AE762CFA0" prefix="" postfix=""/>
<pmp:param axis="X" linear="1" id="guid845F95D6A5B94c12BEEF339E2AEFB38B" prefix="" postfix=""/>
<pmp:param wp-axis="Y" linear="2" id="guid4BE2E8668E094b6c9356FBDF30937CD9" prefix="" postfix=""/>
<pmp:param axis="Y" linear="2" id="guid1A6C3042C77C4283B5EFD4E3917E7DF8" prefix="" postfix=""/>
<pmp:param wp-axis="Z" linear="3" id="guidA6A703AD49134cddA0E55FC2A426EA6D" prefix="" postfix=""/>
<pmp:param axis="Z" linear="3" id="guid98E3CE4D91EF437bB017EE688E91B670" prefix="" postfix=""/>
</pmp:format>
<pmp:format name="Block Number" outputToTape="1" dependency="2" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="3" decZero="3" exponent="0" widthMode="0" width="9" decSep="0" mZeroString=";not-used" mDecPlaces="0" mScale="1" iZeroString=";not-used" iDecPlaces="0" iScale="1">
<pmp:param id="N" prefix="N" postfix=""/>
</pmp:format>
<pmp:format name="Initial Co-ordinates" outputToTape="2" dependency="0" incremental="0" sign="0" leadZeros="0" trailZeros="0" intZero="2" decZero="2" exponent="0" widthMode="0" width="9" decSep="1" mZeroString="0" mDecPlaces="3" mScale="1" iZeroString="0" iDecPlaces="4" iScale="1">
<pmp:param id="XF" prefix="X" postfix=""/>
<pmp:param id="YF" prefix="Y" postfix=""/>
<pmp:param id="ZF" prefix="Z" postfix=""/>
<pmp:param id="X" prefix="X" postfix=""/>
<pmp:param id="Y" prefix="Y" postfix=""/>
<pmp:param id="Z" prefix="Z" postfix=""/>
</pmp:format>
<pmp:format name="M Code Auxilliary" outputToTape="2" dependency="0" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="3" decZero="3" exponent="0" widthMode="0" width="9" decSep="0" mZeroString=";not-used" mDecPlaces="0" mScale="1" iZeroString=";not-used" iDecPlaces="0" iScale="1">
<pmp:group id="SE" prefix="M" postfix="" outputted="1">
<pmp:group-value state="CW" init="true">3</pmp:group-value>
<pmp:group-value state="CCW">4</pmp:group-value>
</pmp:group>
<pmp:group id="CO" prefix="M" postfix="" outputted="1">
<pmp:group-value state="ON">8</pmp:group-value>
<pmp:group-value state="OFF" init="true">9</pmp:group-value>
<pmp:group-value state="FLOOD">7</pmp:group-value>
<pmp:group-value state="MIST">7</pmp:group-value>
<pmp:group-value state="TAPPING">8</pmp:group-value>
<pmp:group-value state="VACUUM">7</pmp:group-value>
<pmp:group-value state="THROUGH"/>
<pmp:group-value state="AIR"/>
<pmp:group-value state="DOUBLE"/>
</pmp:group>
<pmp:param id="S" prefix="S" postfix=""/>
</pmp:format>
<pmp:format name="Part Name" outputToTape="1" dependency="2" incremental="0" sign="0" leadZeros="0" trailZeros="0" intZero="1" decZero="1" exponent="0" widthMode="1" width="40" decSep="1" mZeroString=";not-used" mDecPlaces="3" mScale="1" iZeroString=";not-used" iDecPlaces="4" iScale="1">
<pmp:param id="PA" prefix="O000" postfix=""/>
</pmp:format>
<pmp:format name="Processing Mode" outputToTape="2" dependency="2" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="3" decZero="3" exponent="0" widthMode="0" width="9" decSep="0" mZeroString=";not-used" mDecPlaces="0" mScale="1" iZeroString=";not-used" iDecPlaces="0" iScale="1">
<pmp:group id="MM" prefix="G" postfix="">
<pmp:group-value state="LIN">1</pmp:group-value>
<pmp:group-value state="RAP">0</pmp:group-value>
<pmp:group-value state="CW">2</pmp:group-value>
<pmp:group-value state="CCW">3</pmp:group-value>
<pmp:group-value state="SPL">7</pmp:group-value>
<pmp:group-value state="CYC"/>
</pmp:group>
<pmp:group id="PL" prefix="G" postfix="">
<pmp:group-value state="XY">17</pmp:group-value>
<pmp:group-value state="XZ">18</pmp:group-value>
<pmp:group-value state="YZ">19</pmp:group-value>
</pmp:group>
</pmp:format>
<pmp:format name="Tool Attributes" outputToTape="1" dependency="0" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="1" decZero="3" exponent="0" widthMode="0" width="9" decSep="1" mZeroString=";not-used" mDecPlaces="3" mScale="1" iZeroString=";not-used" iDecPlaces="4" iScale="1">
<pmp:param id="TN" prefix="T" postfix=""/>
<pmp:param id="TL" prefix=" & LENGTH : " postfix=""/>
<pmp:param id="TD" prefix=" TOOL DIA.: " postfix=""/>
<pmp:param id="TS" prefix=" TOOL NAME : " postfix=""/>
<pmp:param id="TI" prefix=" TIP RAD.: " postfix=""/>
<pmp:param id="TT" prefix=" TOOL TYPE : " postfix=""/>
<pmp:param id="TB" prefix="H" postfix=""/>
</pmp:format>
<pmp:format name="Circular Interpolation" outputToTape="1" dependency="2" incremental="1" sign="0" leadZeros="0" trailZeros="0" intZero="2" decZero="2" exponent="0" widthMode="0" width="9" decSep="1" mZeroString="0" mDecPlaces="3" mScale="1" iZeroString="0" iDecPlaces="4" iScale="1">
<pmp:param id="I" prefix="I" postfix=""/>
<pmp:param id="J" prefix="J" postfix=""/>
<pmp:param id="K" prefix="K" postfix=""/>
</pmp:format>
<pmp:format name="Comment 1" outputToTape="1" dependency="2" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="1" decZero="3" exponent="0" widthMode="0" width="9" decSep="1" mZeroString="1" mDecPlaces="3" mScale="1" iZeroString="1" iDecPlaces="4" iScale="1">
<pmp:group id="UE" prefix=" OUTPUT UNITS : " postfix="">
<pmp:group-value state="MM">MM</pmp:group-value>
<pmp:group-value state="INCH">INCHES</pmp:group-value>
</pmp:group>
<pmp:param id="ST" prefix="" postfix=""/>
<pmp:param id="TP" prefix=" TOOLPATH : " postfix=""/>
<pmp:param id="MN" prefix=" MACHINE TOOL : " postfix=""/>
<pmp:param id="VA" prefix=" MODEL : " postfix=""/>
<pmp:param id="CN" prefix=" CONTROLLER : " postfix=""/>
<pmp:param id="CS" prefix=" SERIES : " postfix=""/>
<pmp:param id="PM" prefix=" PMPost VERSION : " postfix=""/>
<pmp:param id="VC" prefix=" OPTION FILE : " postfix=""/>
<pmp:param id="SF" prefix=" STRATEGY USED : " postfix=""/>
<pmp:param id="NC" prefix=" NC FILE : " postfix=""/>
<pmp:param id="WN" prefix=" TOOLPATH WP : " postfix=""/>
<pmp:param id="WI" prefix=" OUTPUT WP : " postfix=""/>
<pmp:param id="NO" prefix=":000" postfix=""/>
</pmp:format>
<pmp:format name="Comment 3 DateTime" outputToTape="1" dependency="2" incremental="0" sign="2" leadZeros="1" trailZeros="0" intZero="2" decZero="3" exponent="0" widthMode="2" width="2" decSep="0" mZeroString=";not-used" mDecPlaces="0" mScale="1" iZeroString=";not-used" iDecPlaces="0" iScale="1">
<pmp:param id="GY" prefix="." postfix=""/>
<pmp:param id="GM" prefix="." postfix=""/>
<pmp:param id="GD" prefix=" DATE : " postfix=""/>
<pmp:param id="GH" prefix=" TIME - " postfix=""/>
<pmp:param id="GT" prefix=":" postfix=""/>
<pmp:param id="GS" prefix=":" postfix=""/>
</pmp:format>
<pmp:format name="Comment 2" outputToTape="1" dependency="0" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="1" decZero="3" exponent="0" widthMode="0" width="9" decSep="1" mZeroString=";not-used" mDecPlaces="3" mScale="1" iZeroString=";not-used" iDecPlaces="3" iScale="1">
<pmp:param id="TM" prefix=" CUTTING TIME : " postfix=""/>
<pmp:param id="SG" prefix=" TOTAL CUTTING TIME : " postfix=""/>
</pmp:format>
<pmp:format name="Drilling Cycle Parameter" outputToTape="1" dependency="2" incremental="0" sign="0" leadZeros="0" trailZeros="0" intZero="2" decZero="2" exponent="0" widthMode="0" width="9" decSep="1" mZeroString="0" mDecPlaces="3" mScale="1" iZeroString="0" iDecPlaces="4" iScale="1">
<pmp:group id="SJ" prefix="G" postfix="">
<pmp:group-value state="NONE"/>
<pmp:group-value state="SINGLE_PECKING">81</pmp:group-value>
<pmp:group-value state="DEEP_DRILL">83</pmp:group-value>
<pmp:group-value state="DEEP_DRILL_2"/>
<pmp:group-value state="BREAK_CHIP">82</pmp:group-value>
<pmp:group-value state="TAPPING">84</pmp:group-value>
<pmp:group-value state="RIGID_TAPPING"/>
<pmp:group-value state="HELICAL"/>
<pmp:group-value state="REVERSE_HELICAL"/>
<pmp:group-value state="REAM">85</pmp:group-value>
<pmp:group-value state="COUNTER_BORE">86</pmp:group-value>
<pmp:group-value state="BORE_3">87</pmp:group-value>
<pmp:group-value state="BORE_4">88</pmp:group-value>
<pmp:group-value state="BORE_5">89</pmp:group-value>
<pmp:group-value state="HELICAL_CLOCKWISE"/>
<pmp:group-value state="REVERSE_HELICAL_CW"/>
<pmp:group-value state="PROFILE"/>
<pmp:group-value state="PROFILE_CW"/>
<pmp:group-value state="FINE_BORING"/>
<pmp:group-value state="CYCLE_1"/>
<pmp:group-value state="CYCLE_2"/>
<pmp:group-value state="CYCLE_3"/>
<pmp:group-value state="CYCLE_4"/>
<pmp:group-value state="CYCLE_5"/>
<pmp:group-value state="CANNED_CYCLE_OFF">80</pmp:group-value>
</pmp:group>
<pmp:param id="FD" prefix="Z" postfix=""/>
<pmp:param id="DI" prefix="Q" postfix=""/>
<pmp:param id="DT" prefix="Z" postfix=""/>
<pmp:param id="CP" prefix="R" postfix=""/>
<pmp:param id="DW" prefix="P" postfix=""/>
</pmp:format>
<pmp:format name="Feedrate" outputToTape="2" dependency="2" incremental="0" sign="2" leadZeros="0" trailZeros="0" intZero="1" decZero="3" exponent="0" widthMode="0" width="9" decSep="1" mZeroString=";not-used" mDecPlaces="3" mScale="1" iZeroString=";not-used" iDecPlaces="4" iScale="1">
<pmp:param id="F" prefix="F" postfix=""/>
<pmp:param id="CF" prefix="F" postfix=""/>
</pmp:format>
<pmp:format name="G Code Preparatory" outputToTape="2" dependency="2" incremental="0" sign="0" leadZeros="0" trailZeros="0" intZero="3" decZero="3" exponent="0" widthMode="0" width="9" decSep="0" mZeroString=";not-used" mDecPlaces="0" mScale="1" iZeroString=";not-used" iDecPlaces="0" iScale="1">
<pmp:group id="CU" prefix="G" postfix="" outputted="1">
<pmp:group-value state="ON">41</pmp:group-value>
<pmp:group-value state="OFF" init="true">40</pmp:group-value>
<pmp:group-value state="LEFT">41</pmp:group-value>
<pmp:group-value state="RIGHT">42</pmp:group-value>
</pmp:group>
<pmp:group id="TC" prefix="G" postfix="">
<pmp:group-value state="ON">43</pmp:group-value>
<pmp:group-value state="OFF">49</pmp:group-value>
</pmp:group>
<pmp:group id="ZT" prefix="G" postfix="" outputted="0">
<pmp:group-value state="ON">49</pmp:group-value>
<pmp:group-value state="OFF" init="true">43</pmp:group-value>
</pmp:group>
</pmp:format>
</pmp:parameters>
<pmp:commands>
<pmp:command id="PS" state="active">
<pmp:definition>
<pmp:block>
<pmp:description><![CDATA[]]></pmp:description>
<pmp:cmd-item-text dependency="0">
<pmp:text><![CDATA[%]]></pmp:text>
</pmp:cmd-item-text>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="N" outputToTape="0" longBlock="0"/>
<pmp:cmd-item-param id="NO" dependency="0"/>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[(]]></pmp:text>
<pmp:cmd-item-param id="NC"/>
<pmp:cmd-item-text dependency="-1">
<pmp:text><![CDATA[ )]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="GD"/>
<pmp:cmd-item-param id="GM"/>
<pmp:cmd-item-param id="GY"/>
<pmp:text><![CDATA[ &]]></pmp:text>
<pmp:cmd-item-param id="GH"/>
<pmp:cmd-item-param id="GT"/>
<pmp:cmd-item-param id="GS"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="PM"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="MN"/>
<pmp:cmd-item-param id="VA"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="CN"/>
<pmp:cmd-item-param id="CS"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="VC"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="SG" outputToTape="0"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="WI"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="UE"/>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G91G28X0Y0Z0]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G40G17G80G49]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G0G90]]></pmp:text>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="PE" state="active">
<pmp:definition>
<pmp:block>
<pmp:text><![CDATA[G91G28]]></pmp:text>
<pmp:cmd-item-param id="Z" outputToTape="1">
<pmp:item-value type="1"><![CDATA[0]]></pmp:item-value>
</pmp:cmd-item-param>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G49H0]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G28]]></pmp:text>
<pmp:cmd-item-param id="X" outputToTape="1">
<pmp:cmd-item-param id="Y" outputToTape="1">
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[M99]]></pmp:text>
</pmp:block>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BR" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="MM"/>
<pmp:cmd-item-param id="CU"/>
<pmp:cmd-item-param id="X" outputToTape="1"/>
<pmp:cmd-item-param id="Y" outputToTape="1"/>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G43]]></pmp:text>
<pmp:cmd-item-param id="Z" outputToTape="1"/>
<pmp:cmd-item-param id="TB"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="RM" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="X"/>
<pmp:cmd-item-param id="Y"/>
<pmp:cmd-item-param id="Z"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="LM" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="F"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="LF" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="TT"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="TS"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="TD"/>
<pmp:cmd-item-param id="TI"/>
<pmp:cmd-item-param id="TL"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="N" longBlock="0"/>
<pmp:cmd-item-param id="TN"/>
<pmp:text><![CDATA[M6]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:text><![CDATA[G54G90]]></pmp:text>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="LT" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="CO" dependency="0">
<pmp:item-value type="1"><![CDATA[OFF]]></pmp:item-value>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="KC" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="PL"/>
<pmp:cmd-item-param id="I"/>
<pmp:cmd-item-param id="J"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="JC" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="K"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="IC" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="SY" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="CF" outputToTape="0" outputNext="1"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CY" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CS" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="SJ" dependency="0"/>
<pmp:text><![CDATA[G99]]></pmp:text>
<pmp:cmd-item-param id="DT"/>
<pmp:cmd-item-param id="CP"/>
<pmp:cmd-item-param id="CF" outputToTape="1"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CD" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="DI"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CE" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CB" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CT" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CA" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CH" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CG" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BA" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BB" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BC" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BD" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="BE" state="active">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="SA" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="SC" state="disallowed" disallowedMessage="Not Supported Cycle.">
<pmp:definition>
<pmp:block>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="EY" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="SJ" dependency="0">
<pmp:item-value type="1"><![CDATA[CANNED_CYCLE_OFF]]></pmp:item-value>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CC" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="MM" outputToTape="1" dependency="0"/>
<pmp:cmd-item-param id="F" outputToTape="1"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="FC" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="CU" outputToTape="1" dependency="0">
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CO" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="CO" outputToTape="1" dependency="0"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="CR" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="CO" outputToTape="1" dependency="0">
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="ON" state="active">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="N" outputToTape="0" dependency="0" longBlock="0"/>
<pmp:cmd-item-param id="S" outputToTape="1"/>
<pmp:cmd-item-param id="SE" outputToTape="1">
<pmp:item-links>
<pmp:item-link id="S" sign="1"/>
</pmp:item-links>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="ST" state="inactive">
<pmp:definition>
<pmp:block>
<pmp:cmd-item-param id="ST"/>
<pmp:text><![CDATA[)]]></pmp:text>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="TP" state="active">
<pmp:definition>
<pmp:block>
<pmp:text><![CDATA[( ================= )]]></pmp:text>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="TP"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="SF"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="TM" outputToTape="0"/>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="WN"/>
</pmp:block>
<pmp:block>
</pmp:block>
<pmp:block>
<pmp:cmd-item-param id="MM" outputToTape="0" outputNext="1"/>
<pmp:cmd-item-param id="SJ" outputToTape="0" outputNext="1"/>
<pmp:cmd-item-param id="PL" outputToTape="0" outputNext="1"/>
<pmp:cmd-item-param id="F" outputToTape="0" outputNext="1"/>
</pmp:block>
</pmp:definition>
</pmp:command>
<pmp:command id="TI" state="inactive">
<pmp:definition>
<pmp:block>
<pmp:text><![CDATA[]]></pmp:text>
</pmp:block>
</pmp:definition>
</pmp:command>
</pmp:commands>
<pmp:structures/>
<pmp:tables/>
<pmp:script language="JScript"><![CDATA[//===============================================================================================
// Who || When || What
]]></pmp:script>
</pmp:option-file>
наверно нужен постпроцессор fanuc, для artcama. Повермилл и арткам две разные программы так что я думаю что и поспроцессоры у каждого свои..
вот пост для арткама для хааса, положить надо в ..\ArtCAM 2008\postp
расширение файла
*.con
DESCRIPTION = "Haas-mm(mm) (*.NCC)"
FILE_EXTENSION = "NCC"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [s|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.1]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Arc Centre Cordinates
FORMAT = [i|@|I|1.3]
FORMAT = [J|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "%"
START = "G00G17G40G80G90"
START = "T[T]M6 "
START = "M03 "
START = "G54G90X0Y0"
START = "G43[ZH]H[T]M8"
; Program moves
RAPID_RATE_MOVE = "G0[X][Y][Z]"
FIRST_FEED_RATE_MOVE = "G1[X][Y][Z][F]"
FEED_RATE_MOVE = "[X][Y][Z]"
FIRST_CW_ARC_MOVE = "G2[X][Y][J][F]"
CW_ARC_MOVE = "G2[X][Y][J]"
FIRST_CCW_ARC_MOVE = "G3[X][Y][J][F]"
CCW_ARC_MOVE = "G3[X][Y][J]"
; Cutter Compensation Support
CCOMP_LEFT = "G1[CCL][X][Y][F]"
CCOMP_RIGHT = "G1[CCR][X][Y][F]"
CCOMP_OFF = "[CCO][X][Y]"
; Toolchange
TOOLCHANGE = "G00G91G28Z0M09"
TOOLCHANGE = "M01"
TOOLCHANGE = "T[T]M6"
TOOLCHANGE = "M03"
TOOLCHANGE = "G54G90X0Y0"
TOOLCHANGE = "G43[ZH]H[T]M8"
; End of file
END = "G00G91G28Z0M09"
END = "M2"
END = "%"
Изменено пользователем trigius
    • Рома калужский
    • Горыныч
    • anykeyto
