Как создать в Adams функцию от времени (табличную)?
Обычно в любом пакете функция задается так.
1. Задаем имя функции
2.Заполняем таблицу
F t
0 0
10 0.1
10 0.2
0 0.3
0 0.4
3.Выбираем узлы.
И все.
Как задавать постоянную силу в Adams - понятно, для этого Help не нужен.
В Help-е по Adams-у нам говорят - "Вы можете задать любую функцию в Построителе функций.", а как это сделать не говорят. :confused_1::thumbdown:
Подскажите пожалуйста! :helpsmilie:
Отрывок из Help-a Adams
Defining Force Magnitude
When defining a force’s magnitude, you can either define it as one resultant magnitude along a direction, or you can resolve the resultant into as many as three components that are associated with the three mutually perpendicular axes of a particular coordinate system.
You can define force magnitudes in Adams/View in the following ways:• Enter values used to define stiffness and damping coefficients. In this case, Adams/View automatically makes the force magnitude proportional to the distance and velocity between two points. The coefficients represent the proportionality constants. You specify coefficients for flexible connectors, such as spring-dampers and beams. You can also specify these values for applied forces.
• Enter a function expression using the Adams/View library of built-in functions. You can enter expressions for all types of applied forces. Built-in functions include the types listed below. For more information on using expressions and available functions, see Function Builder.
• Displacement, velocity, and acceleration functions that allow the force to be related to the movement of points or bodies in the system. Examples include springs and viscous dampers.
• Force functions that allow the force to depend on other forces in the system. An example would be a Coulomb friction force that is proportional to the normal force between two bodies.
• Mathematical functions, such as sine and cosine, series, polynomials, and steps.
• Spline functions that allow the force to depend on data stored in lookup tables. Examples of these include motors using torque-speed curves or nonlinear bushings whose stiffness is not entirely linear.
• Impact functions that make the force act like a compression-only spring-damper that turns on and off as bodies intermittently contact one another.• Enter parameters that are passed to user-written subroutines that are linked to Adams/View. You can enter parameters for all types of applied forces. You can also enter parameters to a subroutine for the field flexible connector to create a nonlinear force between two parts. For more information on how to use subroutines to define your force magnitudes, see the Subroutines section of the Adams/Solver online help.
Скорее всего "Spline functions" - это то, что нужно, но все равно не понятно чего и как.
Методом научного тыка определено, что в Adams есть переменная time
Fuction Builder когда щелкаем на математическую функцию SIN записывает ее как sin(x)
Таким образом, при модификации силы можно вместо постоянного числа записать следующее выражение:
sin(time) или например 0.5-sin(time*2) и это работает.
Однако это не совсем то, что нужно. Необходимо чтобы сила действовала, например в течении 2 сек., а потом ее значение было равно 0.
Cosmos Motion от солидворкс поддерживает некоторые функции ADAMS. Так что, предполагаю, в Адамсе эти функции должны быть тем более.
Вот эти функции: <noindex>http://www.kxcad.net/SolidWorks/COSMOSMoti...d_functions.htm</noindex>
Функция IF должна подойти.
Спасибо! - работает :worthy:
Формат функции
If(x:x1,x2,x3)
x - произвольная переменная
x1-значение для x<0
x2-значение для x=0
x3-значение для x>0
таким образом
воздействие силы в течение 2 секунд можно задать так
if(time-2:10,0,0)
Изменено пользователем element
а теперь немного извращенный способ задать силу на временном отрезке от A до B
if((min(time,A)-A)+(max(B,time)-B):значение до AB,значение на AB,значение после AB)
пример с реальными цифрами в интервале времени от 2 до 3 сек.
if((min(time,2)-2)+(max(3,time)-3):0.02,9.81,0.03)
    • куркуль
      В системе управления неправильно настроено максимальное количество инструментов (должно быть установлено на 4 или 6).Информация о ПЛК Адрес ПЛК: DB1600.DBX3.0подпрограмма: ОСНОВНОЕ (OB1)исправление Проверьте правильность настройки MD14510[20] (максимальное количество инструментов). Каждый производитель прописывает по своему. на своего монстра ищи документацию.
    • Den4ik85
      ошибка 700024 "Отрегулируйте счетчик магазина инструментов", станок Microcut mu-5x а как это сделать-неизвестно(
      @Павлуха ну хотеть не вредно. вредно не хотеть
    • Павлуха
      Я эту модельки видел на фрилансе. За 3 копейки хотели.
      @Павлуха не, он как то спрашивал про реверс джойстика уже, чёт там писал про доработку под себя любимого, под какой то свой проект.
    • Павлуха
      Наберут проектов на фрилансе, потом прибегают с вопросами...
      уменьшить число эскизов. достаточно 2 эскизов определяющих сечение и 2 направляющих кривых. при необходимости можно вставить промежуточные сечения.     https://youtu.be/crNGgk-6Umo?si=Li6xWjdq6epnINS9 https://youtu.be/d6hm2VLhJdw?si=qLGV1FPkfmfhUZto
      @AlexKaz@Борман @Fedorи все неравнодушные! :-) У меня вот такой 9-ти ступенчатый насос  Вот что пишут Биргер, Шорр, Иосилевич  в своём справочнике по Дет.маш.:  Т.е. как раз мой случай описывается..   Вот что пишут в публикации Nelson, F. C. (2007). "Rotor dynamics without equations" из англояз. журнальчика: Гироскопический эффект особенно ярко себя проявляет, если полярный момент инерции диска намного больше пол. мом. ин. вала. Сделал оценки: Масса вала у меня 186 кг, полярный мом. ин. = 182 кг*м2 Масса одного колеса 16 кг, полярный мом. ин. = 0.3 кг*м2 Т.е. пол. мом. ин. всех колёс ~ на 2 порядка меньше пол. мом. ин. вала. Да и в оригинальной публикации Кэмпбелла там речь про проблему вибрации паровых турбин шла, а там совсем не как у меня :-) Учитывая всё вышесказанное, могу ли забить на эти клятые гироскопические эффекты и посчитать обычный модальник? Если да, то тут возникает щепетильный вопрос.. Ведь в ТЗ стоит требование заказчика "необходимо построить диаграмму Кэмпбелла". Если правильно понимаю, Диаграмма Кэмпбелла подразумевает, что на графике обязательно должна быть вилка для прямой (FW) и обратно (BW) прецессии. В моём же случае вилка практически выродится в почти горизонтальную прямую, т.е. для всех частот вращения вала насоса у меня будет практически неизменная частота с копеечным влиянием гироскопики и прецессии, т.е. что-то вроде этого: Как думаете, не слишком ли нелепо будет дать такую "кастрированную" диаграмму Кэмпбелла?) Или лучше просто как обычно дать список первых СЧ, показать пару картинок форм?
      Вот тут пишут, что эта опция напрямую связана с учётом гироскопики для вращающихся роторов. А то что у вас выше в обычной линейной статике с активной этой опцией получались нулевые перемещения/напряжения легко объяснить: сила Кориолиса - это про силы инерции (силы кориолиса) при движении тела во вращающейся системе отсчёта. В статике нет движения, значит нет и силы соотв-но :-)
    • Den4ik85
      microcut mu-5x, инструкция утрачена к сожалению
