открытие dwg в UG
crit
Открываю автокадовский файл в ug. А вместо шрифтов всякая казябра. Как можно решить эту проблему?
Изменено пользователем crit
... Как можно решить эту проблему?
Вот, попалось на глаза :-)
Character Font Mapping for DXFDWG
The DXFDWG translator (introduced in UG V18) allows users to control text character font
mappings for both import and export. The default font mappings are listed below.
Create a Custom Character Font Mapping File
Create a file mapping to meet your needs. Specify all the fonts or just a few -- any fonts not
mapped will use the standard mappings.
Identify your character font mapping file in the dxfdwg.def file by adding the line:
CHARACTERFONT_MAPPING_FILENAME=<location_of_user_font_mapping_file>
For example, if your character font mapping file was d:\my_folder\my_fonts.lis, add:
CHARACTERFONT_MAPPING_FILENAME= d:\my_folder\my_fonts.lis
For a given direction, the last font mapping specified shall take effect when duplicates exist.
Syntax Rules
All mapping statements must follow the specified syntax:
direction_keyword : source_setting = destination_setting.
Use import (ACAD to UG) or export (UG to ACAD) for the direction_keyword.
Mark comment lines with an exclamation point (!) at the beginning and end of the line. For
example:
! UG to ACAD character font mappings !
Aspect Ratio Option
You may optionally add a fixed aspect ratio to be used with a mapping at the end of the
mapping statement. For example, to cause all DXF/DWG text in txt.shx font to be mapped to
UG "blockfont" font with a fixed aspect ratio of 0.8, the line would read:
import : "txt.shx" = "blockfont" , 0.8
For mappings that do not have the aspect ratio specified, the translator will evaluate the same
for each text.
Default Character Font Mapping for Import (ACAD to UG)
import : "swisscbo.ttf" = "aurora"
import : "swissbo.ttf" = "lubalin"
import : "swissbo.ttf" = "lubalins"
import : "bgothm.ttf" = "ballfont"
import : "bgothl.ttf" = "ballfont"
import : "arial.ttf" = "iso-1"
import : "dutchi.ttf" = "cyrillic"
import : "cour.ttf" = "cyrillicf"
import : "romans.shx" = "ge_font5"
import : "greekc.shx" = "greekfont"
import : "isocp.shx" = "iso_font"
import : "tt0596m_.ttf" = "helios"
import : "gothice.shx" = "oldenglish"
import : "simplex.shx" = "pwfont"
import : "scriptc.shx" = "script"
import : "impact.ttf" = "helvet"
import : "DEFAULT" = "blockfont" (this will set the default font to be used when a mapping is not
found for a ACAD font while importing)
Default Cahracter Font Mapping for Export (UG to ACAD)
export : "blockfont" = "txt.shx"
export : "aurora" = "swisscbo.ttf"
export : "lubalin" = "swissbo.ttf"
export : "lubalins" = "swissbo.ttf"
export : "ballfont" = "bgothm.ttf"
export : "iso-1" = "arial.ttf"
export : "chinesef" = "arial.ttf"
export : "cyrillic" = "dutchi.ttf"
export : "cyrillicf" = "cour.ttf"
export : "full_leroy" = "arial.ttf"
export : "futura" = "swisscbo.ttf"
export : "ge_font5" = "romans.shx"
export : "greekfont" = "greekc.shx"
export : "iso_font" = "isocp.shx"
export : "helios" = "tt0596m_.ttf"
export : "helios_con_it" = "tt0596m_.ttf"
export : "helvet" = "tt0596m_.ttf"
export : "leroy" = "arial.ttf"
export : "oldenglish" = "gothice.shx"
export : "pwfont" = "simplex.shx"
export : "script" = "scriptc.shx"
export : "helvet" = "impact.ttf"
export : "cadds4" = "arial.ttf"
export : "DEFAULT" = "simplex.shx" (this will set the default font to be used when a mapping is
not found for a UG font)
А какая версия NX?
По-моему работает только для анлийских настроек ВИНДЫ и NX
Syntax Rules
example:
Aspect Ratio Option
for each text.
А какая версия NX?
Nx 4 и 7.5.
вроде бы я посмотрел эти шрифты есть.. как добавить к примеру такие как isocteui,GOST_TYPE A все они ttf...я так понимаю по хорошему NX понимает шрифты только fnx ,sbf, которые в папке ugfonts
Зачем такие мучения, осмелюсь у вас узнать, или Вы экспериментатор?! )))
... как добавить к примеру такие как isocteui,GOST_TYPE A все они ttf...
В указанном файле добавляете строку со своими шрифтами:
import : "йййййййййй.ttf" = "ёёёёёёёёё"
    • Нафаня
      Всем у кого текли слёзы от размера линий в арткам. Их можно сделать по толще. Настройка на скриншотах ниже.
    • Nod801
      @Aurifer Первое что приходит на ум ... у подсборки пробовал включить режим "мягкой сборки" ... если да но трабла осталась, то нужно смотреть\щупать твою всю сборку ... так трудно что-либо говорить
    • Kasper
      Не подскажите есть ли плагин в ТС для быстрого просмотра формата solidworks?
    • Aurifer
      Редактировал отдельно подсборку открывая через Windows. Потом открываю главную сборку, выходит сообщение "модели изменились, перестроить?", соглашаюсь, ошибка.  Редактировал прямо из основной сборки, кнопкой "редактировать сборку" в дереве построений. Эффект тот же.  Из ограничений, каркас на котором крепятся валы, выбираю ПКМ - "зафиксированный". Чтобы остальные детали (подсборки) двигались относительно валов. И в то же время в "свойства компонента" - "решить как" - ставлю "свободно". Чтобы валы можно было сдвигать/раздвигать между собой. Если решить как, ставлю "точно", то опять же ошибка перестроения.  P.s: Картинку мою видно? Как то криво у меня отображает.
      редактировать можно по-разному, в контексте сборки, либо сделав подсборку активной и редактируется уже в контексте подсборки. А так всё что понятно что ты в сборке наложил ограничения, потом открыл подсборку и в ней наложил ограничения и у тебя естественно возник конфликт.
    • Aurifer
      Добрый день, подскажите что я делаю не так.  Имеется такая сборка: Расстояние между валами не фиксировал, чтобы потом сопряжения сделать по факту. Сборку сделал. Теперь задача сохранить деталь (подсборку) с зафиксированными валами. Но вот не задача.Редактирую подсборку прямо из сборки, делаю валы зафиксированными. Но при открытии файла вне сборки, валы фиксированны, но не в тех местах как в сборке, а в тех где они были до вставки в сборку.  Ладно, опять открываю эту подсборку, делаю в ней сопряжение "граничащее расстояние" . Расстояние оставляю, то которое программа автоматически подставила. Сохраняю. Основная сборка пытается перестроиться и выпадают ошибки, что нельзя решить данные сопряжения!  Пробовал измерить расстояние на ответной части и вбить вручную, ошибки перестроения.  Любые попытки зафиксировать эти валы или их кронштейны приводят к ошибкам перестроения.
    • SAVASTEEV
      Всем привет, у фанука есть цикл G72 очень удобный цикл когда нужно отрезным резцом сделать какие-либо проточки контура, а как можно задать такую же обработку на сиеменсе? Стойка siemens 808d ? То есть создаю нужный контур, но какой вариант обработки нужно указать? Либо как правильно нужно задать контур, попробовал разные варианты у меня резец выходит либо в заготовку (по симуляции), либо идет как проходной резец (типа как по тому же циклу G71 фанучному)   Буду благодарен за помощь, так-как вручную прописывать и рассчитывать все контуры такое себе.... В 840 и в 828 стойки вроде можно выбрать вариант проточки продольная либо поперечная, но вот как сделать это в 808....
      установить сверхкомпактные противовесы из обеднённого урана  а если серьёзно, то рассмотреть верньерный механизм
      а вы на манометр при резке посмотреть не пробовали?
      Ха, точно. Я почему-то был уверен, что это только для аналоговых шпинделей. Спасибо! Это согласование датчика
