открытие dwg в UG
crit
Открываю автокадовский файл в ug. А вместо шрифтов всякая казябра. Как можно решить эту проблему?
Изменено пользователем crit
... Как можно решить эту проблему?
Вот, попалось на глаза :-)
Character Font Mapping for DXFDWG
The DXFDWG translator (introduced in UG V18) allows users to control text character font
mappings for both import and export. The default font mappings are listed below.
Create a Custom Character Font Mapping File
Create a file mapping to meet your needs. Specify all the fonts or just a few -- any fonts not
mapped will use the standard mappings.
Identify your character font mapping file in the dxfdwg.def file by adding the line:
CHARACTERFONT_MAPPING_FILENAME=<location_of_user_font_mapping_file>
For example, if your character font mapping file was d:\my_folder\my_fonts.lis, add:
CHARACTERFONT_MAPPING_FILENAME= d:\my_folder\my_fonts.lis
For a given direction, the last font mapping specified shall take effect when duplicates exist.
Syntax Rules
All mapping statements must follow the specified syntax:
direction_keyword : source_setting = destination_setting.
Use import (ACAD to UG) or export (UG to ACAD) for the direction_keyword.
Mark comment lines with an exclamation point (!) at the beginning and end of the line. For
example:
! UG to ACAD character font mappings !
Aspect Ratio Option
You may optionally add a fixed aspect ratio to be used with a mapping at the end of the
mapping statement. For example, to cause all DXF/DWG text in txt.shx font to be mapped to
UG "blockfont" font with a fixed aspect ratio of 0.8, the line would read:
import : "txt.shx" = "blockfont" , 0.8
For mappings that do not have the aspect ratio specified, the translator will evaluate the same
for each text.
Default Character Font Mapping for Import (ACAD to UG)
import : "swisscbo.ttf" = "aurora"
import : "swissbo.ttf" = "lubalin"
import : "swissbo.ttf" = "lubalins"
import : "bgothm.ttf" = "ballfont"
import : "bgothl.ttf" = "ballfont"
import : "arial.ttf" = "iso-1"
import : "dutchi.ttf" = "cyrillic"
import : "cour.ttf" = "cyrillicf"
import : "romans.shx" = "ge_font5"
import : "greekc.shx" = "greekfont"
import : "isocp.shx" = "iso_font"
import : "tt0596m_.ttf" = "helios"
import : "gothice.shx" = "oldenglish"
import : "simplex.shx" = "pwfont"
import : "scriptc.shx" = "script"
import : "impact.ttf" = "helvet"
import : "DEFAULT" = "blockfont" (this will set the default font to be used when a mapping is not
found for a ACAD font while importing)
Default Cahracter Font Mapping for Export (UG to ACAD)
export : "blockfont" = "txt.shx"
export : "aurora" = "swisscbo.ttf"
export : "lubalin" = "swissbo.ttf"
export : "lubalins" = "swissbo.ttf"
export : "ballfont" = "bgothm.ttf"
export : "iso-1" = "arial.ttf"
export : "chinesef" = "arial.ttf"
export : "cyrillic" = "dutchi.ttf"
export : "cyrillicf" = "cour.ttf"
export : "full_leroy" = "arial.ttf"
export : "futura" = "swisscbo.ttf"
export : "ge_font5" = "romans.shx"
export : "greekfont" = "greekc.shx"
export : "iso_font" = "isocp.shx"
export : "helios" = "tt0596m_.ttf"
export : "helios_con_it" = "tt0596m_.ttf"
export : "helvet" = "tt0596m_.ttf"
export : "leroy" = "arial.ttf"
export : "oldenglish" = "gothice.shx"
export : "pwfont" = "simplex.shx"
export : "script" = "scriptc.shx"
export : "helvet" = "impact.ttf"
export : "cadds4" = "arial.ttf"
export : "DEFAULT" = "simplex.shx" (this will set the default font to be used when a mapping is
not found for a UG font)
А какая версия NX?
По-моему работает только для анлийских настроек ВИНДЫ и NX
Syntax Rules
example:
Aspect Ratio Option
for each text.
А какая версия NX?
Nx 4 и 7.5.
вроде бы я посмотрел эти шрифты есть.. как добавить к примеру такие как isocteui,GOST_TYPE A все они ttf...я так понимаю по хорошему NX понимает шрифты только fnx ,sbf, которые в папке ugfonts
Зачем такие мучения, осмелюсь у вас узнать, или Вы экспериментатор?! )))
... как добавить к примеру такие как isocteui,GOST_TYPE A все они ttf...
В указанном файле добавляете строку со своими шрифтами:
import : "йййййййййй.ttf" = "ёёёёёёёёё"
    • mmaag
      Да, это из nc63 для one. Остальное надо смотреть в каталоге NC62, 63. Там описано много всякого виртуального софта, думаю, найдёте ссылки на что надо, если оно существует.
      Это для sinumerik one? У 808 и 828 плк s7-200
    • mmaag
      https://www.dex.siemens.com/industrialsoftware/machine-tool-software/run-myvirtual-machine-operate?viewState=DetailView&cartID=&portalUser=&store=&cclcl=en_US&selected=industrialsoftware
      Я говорю про полноценный эмулятор, чтобы я на виртуальной панели чпу на кнопку нажимал и в виртуальном ладдере этот сигнал обрабатывался
    • Andrey_kzn
      В Step7 есть симулятор, называется PLCSim, работает хорошо, часто им пользуюсь. Особенно удобно, когда надо проверить какую-нибудь одну функцию, отладить её, а потом добавить в рабочий проект.
      *SP - feed hold, сигнал в ладдере G8.5 (должен быть равен 1 для нормальной работы) SRN - program restart, сигнал G6.0 в ладдере (должен быть равен 0 для нормальной работы) Сигнал с датчика касания вероятно воздействует нас эти сигналы
    • cnckarat
      Доброго времени суток, возникла проблема со станком, не выходит в референтные точки, выдает ошибку DS0021 START ERROR (ONE TOUCH MACRO), нашли описание ошибки, операция запуска макропрограммы не может быть принята 1) сигнал задержки подачи *sp равен 0. 2) генерируется сигнал тревоги. 3) сигнал srn равен 1. Станок benzinger со стойкой fanuc series 310is model a5, от куда начинать и что делать, пока не знаем. Найти sp и srn на станке не можем. В чем может быть проблема? От куда начинать и куда копать по данному вопросу? Вдруг кто сталкивался.
      Мысли были попробовать, но поиск по этой теме не дал результата, поэтому не пробовал
