фаска в NX OPEN API
Помогите сделать фаску
theProgram = new Program();
Tag UFPart1;
string name1 = "model_k";
int units1 = 1;
theUfSession.Part.New(name1, units1, out UFPart1);
int D = 25;
int d = 9;
int b = 14;
int T = 10;
int t = 7;
int F = 1;
int L = T - t;
double[] l1_endpt1 = { 0, d/2, 0.00 };
double[] l1_endpt2 = { L, d/2, 0.00 };
double[] l2_endpt1 = { L, d/2, 0.00 };
double[] l2_endpt2 = { L, b/2, 0.00 };
double[] l3_endpt1 = { L, b/2, 0.00 };
double[] l3_endpt2 = { T, b/2, 0.00 };
double[] l4_endpt1 = { T, b/2, 0.00 };
double[] l4_endpt2 = { T, D/2, 0.00 };
double[] l5_endpt1 = { T, D/2, 0.00 };
double[] l5_endpt2 = { 0, D/2, 0.00 };
double[] l6_endpt1 = { 0, D/2, 0.00 };
double[] l6_endpt2 = { 0, d/2, 0.00 };
UFCurve.Line line1 = new UFCurve.Line();
UFCurve.Line line2 = new UFCurve.Line();
UFCurve.Line line3 = new UFCurve.Line();
UFCurve.Line line4 = new UFCurve.Line();
UFCurve.Line line5 = new UFCurve.Line();
UFCurve.Line line6 = new UFCurve.Line();
line1.start_point = new double[3];
line1.start_point[0] = l1_endpt1[0];
line1.start_point[1] = l1_endpt1[1];
line1.start_point[2] = l1_endpt1[2];
line1.end_point = new double[3];
line1.end_point[0] = l1_endpt2[0];
line1.end_point[1] = l1_endpt2[1];
line1.end_point[2] = l1_endpt2[2];
line2.start_point = new double[3];
line2.start_point[0] = l2_endpt1[0];
line2.start_point[1] = l2_endpt1[1];
line2.start_point[2] = l2_endpt1[2];
line2.end_point = new double[3];
line2.end_point[0] = l2_endpt2[0];
line2.end_point[1] = l2_endpt2[1];
line2.end_point[2] = l2_endpt2[2];
line3.start_point = new double[3];
line3.start_point[0] = l3_endpt1[0];
line3.start_point[1] = l3_endpt1[1];
line3.start_point[2] = l3_endpt1[2];
line3.end_point = new double[3];
line3.end_point[0] = l3_endpt2[0];
line3.end_point[1] = l3_endpt2[1];
line3.end_point[2] = l3_endpt2[2];
line4.start_point = new double[3];
line4.start_point[0] = l4_endpt1[0];
line4.start_point[1] = l4_endpt1[1];
line4.start_point[2] = l4_endpt1[2];
line4.end_point = new double[3];
line4.end_point[0] = l4_endpt2[0];
line4.end_point[1] = l4_endpt2[1];
line4.end_point[2] = l4_endpt2[2];
line5.start_point = new double[3];
line5.start_point[0] = l5_endpt1[0];
line5.start_point[1] = l5_endpt1[1];
line5.start_point[2] = l5_endpt1[2];
line5.end_point = new double[3];
line5.end_point[0] = l5_endpt2[0];
line5.end_point[1] = l5_endpt2[1];
line5.end_point[2] = l5_endpt2[2];
line6.start_point = new double[3];
line6.start_point[0] = l6_endpt1[0];
line6.start_point[1] = l6_endpt1[1];
line6.start_point[2] = l6_endpt1[2];
line6.end_point = new double[3];
line6.end_point[0] = l6_endpt2[0];
line6.end_point[1] = l6_endpt2[1];
line6.end_point[2] = l6_endpt2[2];
Tag[] objarray1 = new Tag[7];
theUfSession.Curve.CreateLine(ref line1, out objarray1[0]);
theUfSession.Curve.CreateLine(ref line2, out objarray1[1]);
theUfSession.Curve.CreateLine(ref line3, out objarray1[2]);
theUfSession.Curve.CreateLine(ref line4, out objarray1[3]);
theUfSession.Curve.CreateLine(ref line5, out objarray1[4]);
theUfSession.Curve.CreateLine(ref line6, out objarray1[5]);
double[] ref_pt1 = new double[3];
ref_pt1[0] = 0.00;
ref_pt1[1] = 0.00;
ref_pt1[2] = 0.00;
double[] direction1 = { 1.00, 0.00, 0.00 };
string[] limit1 = { "0", "360" };
Tag[] features1;
theUfSession.Modl.CreateRevolved(objarray1, limit1, ref_pt1, direction1, FeatureSigns.Nullsign, out features1);
theProgram.Dispose();
catch (NXOpen.NXException ex)
// ---- Enter your exception handling code here -----
return retValue;
Фаску не обязательно делать операцией "фаска" в твоём случае проще было бы её заменить простой линией в эскизе, которая после вращения стала бы фаской. Но если по заданию необходимо создание фаски именно "фаской", то приведу код:
Tag feat1 = features1[0];
Tag cyl_tag, obj_id_camf, blend1;
Tag[] Edge_array_cyl, list1, list2;
int ecount;
theUFSession.Modl.AskFeatBody(feat1, out cyl_tag);
theUFSession.Modl.AskBodyEdges(cyl_tag, out
Edge_array_cyl);
theUFSession.Modl.AskListCount(Edge_array_cyl, out
ecount);
ArrayList arr_list1 = new ArrayList();
ArrayList arr_list2 = new ArrayList();
for (int ii = 0; ii < ecount; ii++)
Tag edge;
theUFSession.Modl.AskListItem(Edge_array_cyl, ii,
out edge);
if (ii == 0)
arr_list1.Add(edge);
list1 = (Tag[])arr_list1.ToArray(typeof(Tag));
string offset1 = FA; //одна длина фаски
string offset2 = FA;//другая
string ang = "45";
theUFSession.Modl.CreateChamfer(3, offset1, offset2, ang,
list1, out obj_id_camf);
попробовал что-то не получается, и из примера по лабораторным работам (здесь где-то выкладывали) тоже не понял, может неправильно вставлял в код, можешь полный составить код, а то я слабоват в этом.
help!
Изменено пользователем an842
А вот уже место фаски я лично делал простым перебором. Тоже не не понял ещё, как определить именно нужную грань.
    • vasillevich68
      Передайте, что ни чего страшного не будет. Максимум, что может произойти, так это, в один прекрасный момент вал лопнет, и датчики вибрации дадут команду на остановку насоса
      Но ведь токовый сигнал надо  для начала в цифровой преобразовать Поэтому полный цикл преобразования не может быть быстрее аналоговой части У тиристорных приводов частота отклика не более 30Гц, но это не из-за ОУ, а из-за принципа работы приводов Да у обычного 741 частота 1Мгц Насколько это быстрее 32нс?     @gudstartup Аналоговая цепь всегда быстрее цифровой Так и живем Честно говоря я обескуражен Ведь тут же даже житейская логика говорит о том, что цифровая цепь привода не может быть быстрее аналоговой, просто потому что аналоговая является подсистемой цифровой цепи   Аналоговый вычислитель всегда выиграет по скорости у цифрового аналога Точность может быть ниже, но скорость всегда выше Сравните скорость работы сумматора на ОУ и на процессоре И оставьте свои ужимки, противно смотреть Или вы продолжатель дела "короля саркастических ужимок" (с)?
      с люфтами эта функция никак не борется она их пропускает гася резонанс ни насколько обработка контура тока длится 32нс попробуйте это сделать на ваших оу. @Guhl отдыхайте вы явно перегрелись у вас аналоговый процессор
      Вы хотя бы в курсе насколько быстрее аналоговая цепь, чем цифровая?
      вы хотя бы в курсе сколько длится в сигнальном поцессоре servo фанук обработка контура тока и сколько это было на ваших допотопных приводах и какие скорости и точность контура сейчас достижимы ,благодаря этому. добейтесь этого на ваших аналоговых схемах с оу и я сниму перед вами шляпу. полностью некорректное сравнение.
      Можно заменить гнутый швеллер на прямоугольную тонкостенную трубу. Если не стоит задача всё гнуть самостоятельно.
      Большие люфты вызывают колебания. Причем эти люфты возникают не только при смене направления движения, а при других условиях. Путем борьбы с люфтами, борятся с колебаниями Для этого и есть dual position feedback  Ну вот видите, уже лучше. Борьба с люфтами - борьба с колебаниями Так для чего нужен dual position feedback? Назовите вы ее хоть чертом лысым, но она как боролась с люфтами, так и борется
      а вам для чего писать то вы все равно читать не можете. для кого я   приводил описание функции и раздел к которым она отнесена уважаемыми вами японцами.   потому что он приводит к вибрациям!!!! я от вас просто офигиваю ну нельзя же так упорствовать в очевидном!!
      А зачем же они упоминают люфт?
      а где ваши аргументы? я вам приводил и формулы и выдержки из текста но вы адепт собственных измышлений и упорно называете функцию подавления резонанса функцией  компенсации люфта. контуры тока были у всех  без него вы не сможете мотором управлять а вот скорости другое дело. как всегда все путаете.
