Pro/program
Nils
Как с помощью Pro/Program можно подавить элемент(необходимо,чтобы для d>5,его не было,а после появлялся) через Family Table,не катит, нужно именно,чтобы соблюдалось такое условие.Подскажите плиз,буду благодарен.
Да выражение само то понятно,а вот куда его ставить? и как правильно потом запустить?
Пример файла:
VERSION
REVNUM 476
LISTING FOR GENERIC PART VTULKA_18430
INPUT
END INPUT
ADD FEATURE (initial number 1)
INTERNAL FEATURE ID 1
TYPE = DATUM PLANE
NAME = DTM1
FEATURE IS IN LAYER(S) :
DATUMS - OPERATION = SHOWN
END ADD
ADD FEATURE (initial number 2)
INTERNAL FEATURE ID 4
TYPE = DATUM PLANE
NAME = DTM2
END ADD
ADD FEATURE (initial number 3)
INTERNAL FEATURE ID 6
TYPE = DATUM PLANE
NAME = DTM3
END ADD
ADD FEATURE (initial number 4)
INTERNAL FEATURE ID 15
PARENTS = 1(#1) 4(#2) 6(#3)
TYPE = COORDINATE SYSTEM
NAME = CS0
END ADD
ADD FEATURE (initial number 5)
INTERNAL FEATURE ID 19
PROTRUSION: Revolve
NO. ELEMENT NAME INFO STATUS
1 Attributes One Side Defined
2 Section Sk. plane - Surface DTM3 of feat #3 (DATUM PLANE) Defined
3 Direction Defined
4 Angle Angle = 360 degrees Defined
SECTION NAME = S2D0001
FEATURE'S DIMENSIONS:
d0 = 0.19 General_Dims Dia
d1 = 5 General_Dims Dia
d2 = 2.8 General_Dims Dia
d3 = 0.6 General_Dims
d4 = 30
d5 = 4 General_Dims
d6 = 1.5 General_Dims
d7 = 0.2 General_DimsR
d8 = 0.2 General_DimsR
d9 = 0.2 General_DimsR
END ADD
ADD FEATURE (initial number 6)
INTERNAL FEATURE ID 249
PARENTS = 19(#5)
ROUND: General
1 Round Type Simple Defined
2 Attributes Constant, Edge Chain Defined
3 References Defined
4 Radius Value = 0.2000 Defined
5 Round Extent Optional
6 Attach Type Make Solid - Feature has solid geometry Defined
d20 = 0.2 General_DimsR
END ADD
ADD FEATURE (initial number 7)
INTERNAL FEATURE ID 184
PARENTS = 4(#2) 19(#5) 6(#3)
CUT: Revolve
3 MaterialSide Inside section Defined
4 Direction Defined
5 Angle Angle = 360 degrees Defined
SECTION NAME = S2D0003
d15 = 45
d16 = 0.2 General_DimsR
d17 = 2 General_Dims Dia
d18 = 1 General_Dims
d19 = 0.5 General_DimsR
END ADD
ADD FEATURE (initial number 8)
INTERNAL FEATURE ID 108
CUT: Revolve
4 Direction Defined
SECTION NAME = S2D0002
d10 = 0.49 General_Dims Dia
d11 = 0.2 General_DimsR
d12 = 60
d13 = 1 General_Dims
END ADD
MASSPROP
END MASSPROP
Вот такая деталька,мне нужно,чтобы feature (initial number 3),зависел от размера d2.
Куда прописать-это выражение?Пробывал в разные места,результата нет
IF выражение
TYPE = DATUM PLANE
NAME = DTM3
END ADD
END IF
Если выражение истинно, выполняется добавление фичера.
Спасибо за советы...
Все разобрался,в ней можно делать много чего интересного....
<{POST_SNAPBACK}>
Можно, конечно. Только не забывайте комментарии писАть, а то потом и сами разобраться не сможете.
Наблюдение:
Если подавляются фичеры в модели, то в уравнениях, прежде чем обращаться на их параметры/размеры, необходимо ставить проверку на условие их наличия(не погашения), но если запустить проверку уравнений(а не регенерацию модели), то проверяться будут ВСЕ уравнения. Если в уравнениях будут присутствовать параметры/размеры подавленных - возникнут "вопросы". :sad:
Кстати, о комментариях: при редактировании программы детали/сборки русскоязычные комментарии сбрасываются в казябры, потом назад дороги нет. :wallbash:
Приходится обходиться латиницей.
Кто может подсказать, как забороть данный глюк?
