Ошибка Workbench 12
При сохранении любого проекта в Workbench, в который входит раздел Engineering Data (там где материал задается) вылетает следующая ошибка
System.NullReferenceException: Object reference not set to an instance of an object.
at Ans.EngineeringData.Commands.LibraryManager.Receive(IEvent eventInfo)
at Ans.Core.Events.EventObserverProxy.Receive(IEvent eventInfo)
at Ans.Core.Events.EventInvoker.Invoke()
at Ans.Core.Events.EventPublishHelper.InvokeDelegate(EventInvoker invoker, Boolean wait)
--- Ans.Core.Events.EventPublishFailedException: Object reference not set to an instance of an object.
at Ans.Core.Events.EventPublishHelper.RethrowExceptions(Boolean wait)
at Ans.Core.Events.EventManager.FireEvent(List`1 observers, IEvent eventInfo, Boolean wait)
at Ans.Core.Events.EventManager.PublishEvent(IEvent eventInfo, List`1 matchingProxies, Boolean wait)
at Ans.Core.Events.EventManager.PublishAndWait(IEvent eventInfo)
at Ans.Core.Persistence.Commands.SaveCommand.ProjectSave()
at Ans.Core.Persistence.Commands.SaveCommand.Execute(CommandContext context)
at Ans.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: Object reference not set to an instance of an object.
Command: Save(FilePath="D:/sdfs.wbpj", Overwrite=True)
at Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.Core.Persistence.Commands.SaveCommand.InvokeAndWait(ICommandContext context, IProgressMonitor progressMonitor, String FilePath, Boolean Overwrite)
at Ans.UI.Standard.ProjectOperationUtility.ProjectSaveAs(GuiOperationContext context)
at Ans.UI.Standard.SaveProjectAsOperation.Invoke(GuiOperationContext context)
at Ans.UI.UIManager.<>c__DisplayClass9.<InvokeOperation>b__8()
at Ans.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages)
Причем сначала установки все работало, ошибка появилась спустя неделю. Весь интернет перерыл, подобное есть у многих, но конкретного решения проблемы не нашел. Ансис x64, Windows XP x64. Все имена на латинице. Может кто знает в чем дело?
лицензия закончилась.
кстати да, это очень может быть, я как то и не подумал в этом направлении. Спасибо большое
я так понял это часть лицезии закончилась? Mechanical APDL нормально работает, CFX и Fluent тоже. Не работает Engineering Data
Изменено пользователем Starshoy
это предположение. попробуйте установите на другом компьютере.
Поставьте на другом компутере на полностью английскую винду, используйте нормальный дистрибутив (Ansys v12.1, лучше ставить 64x на 64-битную винду). В 12.0 полно багов, возможно это один из них. Проблемы должны исчезнуть. Если не получится (а получается у всех).. то сами понимаете, причина заключается только в ВАС самих.
Установил ANSYS 12.1 x64
WB запускается но если я выберу,например, DM то при загрузке модуля вылетает такая ошибка.
Оффтоп. (Борман)
Вот кто знает, как решить проблему. Запускаю в СFX связанный FSI расчет, но при запуске Ansys ( имеется ввиду для прочностной части задачи) вылетает ошибка ANSYS Solver terminated unexpectedly with return code 3840. Отдельно расчет в CFX проходит без проблем. Я конечно понимаю, что где то в настройках multifield решателя ошибка, но где непонятно. В хелпе что то найти не могу что это за код ошибки такой 3840. Если кто знает, хотя бы где искать расшифровку кода подскажите. Или возможно это связано с тем, что у меня запущен BladeGen, TurboGrid, CFX и на запуск Ansys не хватает лицензии?
если бы у вас не хватало лицензий, то он бы прямо об этом и написал бы. можете попробовать запустить, например, 2 механикала на счет одновременно. первый начнет считаться, а во втором выскочит ошибка, о нехватке лицензий.
у вас какая-то другая причина
при загрузке Workbench каждый раз вылазит такая ошибка:
Problematic URL in 'Custom RSS Feed Address' in 'Project Management' options
<noindex>http://www.ansys.com/rss/ansys-news.rss</noindex>
подскажите как устранить
эта ошибка не помешает вам проявить свои незаурядные способности, ANSYS сообщает о том, что не может получить новостную рассылку с сайта. Не обращайте на это внимания.
