Создать дуги по 3-м точкам (NX Open)
i.m.p
Помогите с описанием переменных в команде extern UFUNEXPORT int UF_CURVE_create_arc_3point
tag_t point1, /* <I> tag of start point */
tag_t point2, /* <I> tag of end point */
tag_t point3, /* <I> tag of middle point */
UF_CURVE_limit_p_t limit_p[2], /* <I> extension limits */
tag_t support_plane, /* <I> tag of support plane of the arc */
logical is_asso, /* <I> true - if associative, false - if not associative */
tag_p_t arc_feature_id /* <O> if is_asso == TRUE - object identifier of new associative arc feature
if is_asso == FALSE - object identifier of new associative arc */
Интересует UF_CURVE_limit_p_t limit_p[2].
Напишите примерчик задания переменных.
Попробовал так
/* TODO: Add your application code here */
	double point_coords[3];
	tag_t point1, point2, point3;
	UF_CURVE_limit_p_t limit[2];
	double origin_point[ 3 ];
	double plane_normal[ 3 ];
	tag_t plane_tag;
	logical is_asso = TRUE;
	tag_t arc_feature_id;
	point_coords[0] = 0.0; point_coords[1] = 0.0; point_coords[2] = 0.0;
	UF_CALL(UF_CURVE_create_point (point_coords, &point1 ));
	point_coords[0] = 100.0; point_coords[1] = 0.0; point_coords[2] = 0.0;
	UF_CALL(UF_CURVE_create_point (point_coords, &point2 ));
	point_coords[0] = 50.0; point_coords[1] = 30.0; point_coords[2] = 0.0;
	UF_CALL(UF_CURVE_create_point (point_coords, &point3 ));
	origin_point[0] = 0.0; origin_point[1] = 0.0; origin_point[2] = 0.0;
	plane_normal[0] = 0.0; plane_normal[1] = 0.0; plane_normal[2] = 1.0;
	UF_CALL(UF_MODL_create_plane (origin_point, plane_normal, &plane_tag ));
	limit[0] = (UF_CURVE_limit_p_t)malloc(sizeof(UF_CURVE_limit_t));
	limit[0]->limit_type = UF_CURVE_limit_value;
	limit[0]->limiting_obj = NULL_TAG;
	limit[0]->value = 0.0;
	limit[0]->help_data.help_data_type = UF_CURVE_help_data_none;
	limit[0]->help_data.parameter = 0.0;
	//limit[0]->help_data.value[0] = 0.0; limit[0].help_data.value[1] = 0.0; limit[0].help_data.value[2] = 0.0;
	limit[1] = (UF_CURVE_limit_p_t)malloc(sizeof(UF_CURVE_limit_t));
	limit[1]->limit_type = UF_CURVE_limit_value;
	limit[1]->limiting_obj = NULL_TAG;
	limit[1]->value = 0.0;
	limit[1]->help_data.help_data_type = UF_CURVE_help_data_none;
	limit[1]->help_data.parameter = 1.0;
	//limit[1]->help_data.value[0] = 0.0; limit[0].help_data.value[1] = 0.0; limit[0].help_data.value[2] = 0.0;
	UF_CALL(UF_CURVE_create_arc_3point (point1, point2, point3, limit, plane_tag, is_asso, &arc_feature_id ));
	free(limit);
При выполнении NX построил точки и плоскость и.... получил ошибку
*** ERROR code 1105004 at line 110 in c:\visual studio projects\arc_3point\arc_3point\arc_3point.cpp:
+++ The first parameter passed in was invalid
UF_CURVE_create_arc_3point (point1, point2, point3, limit, plane_tag, is_asso, &arc_feature_id );
Сильно удивился!
    • Maik812
      есть версия SW2014 и ниже (там в старой версии есть бибилиотека фаил выбран и он юзается его можно поменять от другой версии , но не просто все так как приложение на 18 закончелось). Для F3 Солид-расширения в настройках меняете не листером а прогой и ссылку на нее (СВ вьювер например) ДЛЯ второго окна быстрого простмотра я ставил плагин IEView и там прям вот работать можно было. вопрос какая винда и СВ увас. Ну и не кто не теребит и не просит просмотрщиков. Есть галка в настройках средствами Exploer но там плохие картинки для эскизов только . еще IEView
      Неужто прочитал справку
      "Эх, малыш, не в пирогах  портфолио счастье."
    • Бестолковый
      @maxx2000 Портфолио есть, по запросу в ЛС могу выслать, выкладывать сюда "простыню" смысла не вижу.   @4Zzz Что и в какую сторону менять - не совсем понятно, так что пусть всё будет так как оно есть ;)
    • Нафаня
      Всем у кого текли слёзы от размера линий в арткам. Их можно сделать по толще. Настройка на скриншотах ниже.
    • Nod801
      @Aurifer Первое что приходит на ум ... у подсборки пробовал включить режим "мягкой сборки" ... если да но трабла осталась, то нужно смотреть\щупать твою всю сборку ... так трудно что-либо говорить
    • Kasper
      Не подскажите есть ли плагин в ТС для быстрого просмотра формата solidworks?
    • Aurifer
      Редактировал отдельно подсборку открывая через Windows. Потом открываю главную сборку, выходит сообщение "модели изменились, перестроить?", соглашаюсь, ошибка.  Редактировал прямо из основной сборки, кнопкой "редактировать сборку" в дереве построений. Эффект тот же.  Из ограничений, каркас на котором крепятся валы, выбираю ПКМ - "зафиксированный". Чтобы остальные детали (подсборки) двигались относительно валов. И в то же время в "свойства компонента" - "решить как" - ставлю "свободно". Чтобы валы можно было сдвигать/раздвигать между собой. Если решить как, ставлю "точно", то опять же ошибка перестроения.  P.s: Картинку мою видно? Как то криво у меня отображает.
      редактировать можно по-разному, в контексте сборки, либо сделав подсборку активной и редактируется уже в контексте подсборки. А так всё что понятно что ты в сборке наложил ограничения, потом открыл подсборку и в ней наложил ограничения и у тебя естественно возник конфликт.
    • Aurifer
      Добрый день, подскажите что я делаю не так.  Имеется такая сборка: Расстояние между валами не фиксировал, чтобы потом сопряжения сделать по факту. Сборку сделал. Теперь задача сохранить деталь (подсборку) с зафиксированными валами. Но вот не задача.Редактирую подсборку прямо из сборки, делаю валы зафиксированными. Но при открытии файла вне сборки, валы фиксированны, но не в тех местах как в сборке, а в тех где они были до вставки в сборку.  Ладно, опять открываю эту подсборку, делаю в ней сопряжение "граничащее расстояние" . Расстояние оставляю, то которое программа автоматически подставила. Сохраняю. Основная сборка пытается перестроиться и выпадают ошибки, что нельзя решить данные сопряжения!  Пробовал измерить расстояние на ответной части и вбить вручную, ошибки перестроения.  Любые попытки зафиксировать эти валы или их кронштейны приводят к ошибкам перестроения.
