Редактирование схемы
В существующей базе у объектов Item есть атрибут object_name с длиной строки 32. Возможно ли увеличить длину строки до 128?
скоре нет.
но для таких нужд создается свой класс с нужными вам атрибутами и подсовывается нужному типу.
...Возможно ли увеличить длину строки до 128?
Смотрим переменные, но очень внимательно!!!!!
TC_Allow_Longer_ID_Name
Description
Determines whether the byte size for item names and IDs are 32-byte or 128-byte. The larger byte size gives you greater item naming flexibility. This is particularly useful when working with multi-byte languages where one character occupies multiple bytes.
Using 128-byte functionality creates the following impacts:
You must recompile any customized code which uses the affected attributes.
The Teamcenter Integration for NX I-deas integration size limit of 80 bytes can be exceeded by Teamcenter.
Multi-Site Collaboration customers must deploy consistent byte-size functionality across sites. A warning will display if a 128-byte site sends an item ID longer than 32 bytes to a 32-byte site.
Enabling 128-byte functionality increases the size of the class attributes listed below from 32 to 128 bytes.
Class
Class attribute
Size change
Item
Item_ID
from 32 to 128
WorkSpaceObject
Object_Name
from 32 to 128*
Audit_Log
Name
from 32 to 128*
Classification
ICM0 table
from 32 to 161
PublicationRecord
ID pubr_object_id
POM_stub
object_id
from 128 to 161
Class
Class attribute
Size change
PublicationRecord
pubr_object_id
from 32 to 256
PublicationRecord
pubr_object_name
from 32 to 256
Class
Class attribute
Size change
GDEOccurrence
occ_name
from 32 to 128
Class
Class attribute
Size change
SingleFileRecovery
object_name
from 32 to 128
ItemMaster
previous_item_id
from 32 to 128
Class
Class attribute
Size change
EPMTaskTemplate
EPMTaskTemplate template_name
from 32 to 128
Note:
The following constants will be changed from 32 to 128. Site customizations should be using these constants. If so, all that is required is a re-compile. Sites using a hard-coded value of 32 need to manually change the value of 32 to 128.
ITEM_id_size_c
ITEM_name_size_c
WSO_name_size_c
WSO_NAME_SIZE
ITEM_ID_SIZE
ITEM_NAME_SIZE
Valid Values
true
Enables 128–byte functionality.
false
Enables 32–byte functionality.
Default Values
false
Scope
Site preference
А где это смотреть?
Правка - параметры, далее закладка "Индекс", ищем параметр: "TC_Allow_Longer_ID_Name" и устанавливаем в значение = 128
Но если Вы работаете с промышленной базой и CAD, то нужно очень внимательно к этому относиться. Подумать 7 раз и один раз исправить :-)
Смотрите документацию!!!!
Видимо в 8 версии (2002 года которая) такого пункта нет. Может такая опция указывается в каком нибудь файле? Типа .iman_env или еще где. Документации к сожалению нет.
Вы бы версию тимцентра указывали...
В TC UA (т.е. TC2007 и TC8 и выше) это меняется элементарно через преференсы.
В младших версиях тимцентра энжинеринг, типа 8, 9, 2005, насколько я знаю длину айтем_ид поменять нельзя, но можно создать свой атрибут и использовать его (и продумать решение гемороя с которым можете столкнуться например в тех же CADах).
