Sw2004 Sp4
Грят, есть известно-где известно-что. Кто-нить качал? нормальная версия или бета? А может поставил кто без проблем на русскую версию???
Welcome to the SolidWorks Service Pack Early Visibility program. The purpose of this program is to provide extended testing by a limited number of Customers and Value Added Resellers prior to general release of a Service Pack. Thank you for your participation in this program. Please note the following:
Do not apply an Early Visibility SP to your main installation
Do not apply an Early Visibility SP to a computer that contains your main installation. You must install SolidWorks on a different computer and apply the Service Pack to this new installation. If an Early Visibility Service Pack requires a fix, you will not be able to update an installation that has been updated by an Early Visibility Service Pack.
Update to Service Pack: 2004 SP4.0
In order to update SolidWorks 2004 using a service pack, Windows Installer requires that the CDs used to install the SolidWorks application be placed in the CD drive in a specific order(disk 1, to start). You must insert the CDs in the order in which you are prompted during the update process. If SolidWorks was installed using an administrative image, the user must point to that image when the service pack is applied.
Note: The web download of SolidWorks 2004 SP0 cannot be upgraded with a service pack. This version of SolidWorks must be uninstalled, and then SolidWorks should be reinstalled from CD, or administrative image.
:g:
ай-яй-яй ... :doh:
русским языком же написано
:bleh:
зы
вольный перевод: пре-пак для фанатов
h**p://swdownload.solidworks.com/htdocs/pdownload/deploy/sw2004/sp4.0_961A71F1-A4C6-415e-8B2E-0D5D7E6E7F96/sw2004-0.0-4.0-i.exe :g:
Лекарства пока нет.
Подождем...
Есть то оно, конечно есть... Да все равно не помогает:(
Сам SP4 либо SP4.1 не ставиться на SP3. Конечно, есть такой убийственный метод - все снести, поставить SP0, скачать SP0-SP4.1 (130 мегов(!))? и поставить. Тогда работает, говорят. Но я не любиетль садо-мазо.
У меня Sw2004SP3.0 и на него сервис-пак не ставиться. Может кто решил?
Хотя, грят, скоро SP5 выходит.
ЛИЧНО поднимал сервис паки в следующей последовательности ( на туче машин) был СП 0.0 , накатил СП 0.0-2.1 , затем 2.1-3.0 ( с сайта www.solidworks2004.narod.ru ), затем 3.0 - 4.0 ( кинул добрый человек на мыло) , затем 4.0 - 4.1
Странно... У меня SW2004SP3.0
Копирую в директорию с установленной SW четыре "нэкрякнутых, даа" файла, и все равно - ни SP3.0-4.0 ни SP3.0-4.1, скачанные, кста, с solidworks.com, не ставяться. Пишут, что что-то там не соотвествует.
Изменено пользователем djrandom
ЧТО за четыре "нэкрякнутых, даа" файла ??? надо сервиспаки накатывать на не хаченный солид а крачить потом.
Поставь все заново - не кракая , а затем накати обновление . Вогзможно (скорее всего) покривел майкрософт инсталлереровский файл в винде , для солида который создается во время установки для каждого приложения ) находится в windows\installer\ , а посему солидовский СП не видит какой версии оновление уже стоит. Если это так - то гимор. У меня на одной машине вчера такое приключилось , и не удалить солид ,не установить нельзя , буду начисто систему переставлять
Четыре "нэкрякнутых, даа" файла - это те файлы, которые правит кряк для SP3.0 - автор этого патча любезно сообщил мне, какие файлы правит его патч. Вот я их и сохранил в девственном виде.
А сносить SOLID мне сильно вломы. Да и времени нема - работать надо.
