Completion Project Engineer (only Aerospace)
Job Description
 Be focal point for project leader, manage all engineering-interfaces and represent project-specific engineering
 Manage the project activities which are performed by the involved engineering departments, monitor and supervise these activities in terms of workflow, schedule and cost
 Optimize and strength collaboration between engineering, logistics and production department (for instance by monitoring and controlling technical drawing process, or overseeing process of production material ordering)
 Adjust and maintain Engineering Project Plan for assigned VIP Aircraft outfitting project
 Organize and lead project engineering team meetings, assign action items and track execution
 Anticipate, analyze and report potential engineering project risks and countermeasures to project leader
Profile
 Engineering Degree (mechanical, aeronautical construction) or equivalent education in aircraft outfitting
 Professional: min. of 8 years Industrial/Engineering environment – preferably aviation industry completion (deep knowledge of the requirements in his/her field of experience)
 Project & Process Management: Set-up, management, monitoring, controlling large projects of high complexity.
 Interdisciplinary & Intercultural: Activity monitoring, controlling, coordination, or follow-up within interdisciplinary and intercultural project stakeholders (e.g. CH, FR, GER, UK, US).
company offer competitive salary package
Please send in English to info@eone.com.ua
www.eone.com.ua
      Здесь https://disk.yandex.ru/d/il8bxSu41Kw0Bw можно скачать Начальный курс по ТФ Максимова и Протасовой. Курс старый, но для старта вполне подойдет.
    • Говорящий Огурец
      Вряд ли это радиатор как "вещь в себе". Скорее поверю, что это некая интегрированная в корпусную деталь структура. И не всегда возможна обработка дисковыми фрезами, хотя она, из моей практики, самая производительная. Если говорить про обработку концевушками, то есть специальные стратегии обработки высоких нежестких ребер, когда чередуется черновая и чистовая обработка, послойно и в определенном порядке, с целью минимизировать отгибы и вибрации. Где-то у меня даже картинки были с описанием, но что-то не могу их найти... :(
      Забавно          Аккуратнее надо с выбором курсов.
      А на дне закон Архимеда не действует ?    https://ru.wikipedia.org/wiki/Закон_Архимеда     :)    https://upload.wikimedia.org/wikipedia/commons/transcoded/3/3c/Закон_Архимеда.webm/Закон_Архимеда.webm.720p.vp9.webm
      Давно бы уже экструзией давили и только контактную сторону обрабатывали.
    • Orchestra2603
      Хотите сказать, что если маленький воздушный шарик надутый придавить ко дну до верха наполненной ванны, то он не всплывет? Для того, чтобы под днищем подлодки ликвидировать давление, там должна быть полная герметичность. Как только туда хоть сколько-нибудь воды затечет, очень быстро там давление жидкости станет ro*g*h, и если баластные цистерны обеспечивают положительную плавучесть, подлодка начнет всплывать неизбежно.   Они действительно сейчас не ложатся на дно (хотя раньше в прошлом это кстати не запрещалось), но делают это из чисто практических соображений.
    • a_schelyaev
      а) Гидростатический столб считается от нулевого уровня, в котором и нужно обозначить величину плотности. б) Если брать текущую релизную версию 22, то в "Результатах" есть переменная Расход массовый и Расход объемный, который берется в сечении - плоскости или с ГУ. Все само считает.
      Там курс аж на пол-года. Тяжело с этим ТФ.
    • SAPRonOff
      вот тут знакомые преподаватели, Пильщиков - победитель WorldSkills Russia
      ну тут имхо похожая ситуация как с подлодками: пока подлодка плавает в толще моря/окияна, то на неё действует выталкивающая сила, ~ равная разности гидростатических давлений между верхом и низом. Но если подлодка сядет на дно, то она уже всплыть не сможет без исп-я спец. средств, ибо снизу воды уже нету, и на неё будет сверху давить вся толща воды (по идее когда она садится на дно давление скачкообразно должно увеличиваться). В случае с вашей подводной трубой - обратная ситуация: грунт под трубой размывается, труба всплывает.  Так что с точки зрения физики тут всё ок. Потери устойчивости не будет, но трубопровод изогнётся к верху. Прогиб можно посчитать, если приложить сверху и снизу разность гидростатич. давл-я.
