installation's guide
su*
How to installation Unigraphics NX v2.0 Final (By Mr.T Create on 22 Aug 2003)
Step 1 (Setting Microsoft Loopback Adapter & Find Server Name or Host Name)
Note : Base on Windows 2000 / XP
01. Install Microsoft Loopback Adapter *** See below.
Open Microsoft Loopback Adapter to using this by double click on "Local Area Connection"
Control Panel ==> Network Connections ==> Local Area Connection
02. Open Command Prompt
Start ==> Programs ==> Accessories ==> Command Prompt
and typing this "ipconfig/all" you will get the value see below.
C:\>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : teeny
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Loopback Adapter
Physical Address. . . . . . . . . : 02-00-4C-4F-4F-50
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Autoconfiguration IP Address. . . : 169.254.25.129
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
*** You will get the Host Name & Physical Address (HostID)
Host Name (Server Name) ==> teeny
Physical Address (HostID) ==> 02004C4F4F50
Step 2 (Setup Unigraphics NX 2.0)
Note : NTFS File system
Preparation Harddisk Space on Directory C:\Program Files\EDS\Unigraphics NX 2.0\
(C:\Program Files\EDS\Unigraphics NX 2.0\ == 2.08 GB == 2.16 GB Size on disk)
(954 MB (974 MB size on disk) for Program)
(984 MB (0.98 GB size on disk) for Program & Translators)
(Documentation Help v2.0 == 241 MB == 281 MB Size on disk) (Dir UGDOC)
(Manufacturing Process Aid Wizard NX v2.0 == 909 kB or 1.18 MB Size on disk) (Dir UGPROCESS_AID)
(Mold Wizard NX v2.0 == 427996 kB == 407 MB or 416 MB Size on disk) (Dir moldwizard)
(Progressive Die Wizard NX v2.0 == 528540 kB == 503 MB or 514 MB Size on disk) (Dir pdiewizard)
(Weld Assistant NX v2.0 == 2.43 MB or 2.89 MB Size on disk) (Dir UGWELD)
Part 1 (Programs)
01. Insert CD-ROM to CD-ROM Drive program will Auto-Run \Launch.exe (Click on Install Unigraphics NX)
or manual installation from directory \ugnx020\setup.exe by clicking on it.
02. (Unigraphics NX 2.0 Setup) (Welcome to the InstallShield Wizard for Unigraphics NX 2.0) ==> Next
03. (Installation Options) ==> Custom ==> Next
04. (Unigraphics NX - Custom Installation) ==> Selection all install products
[x] Unigraphics CAD/CAM/CAE
[x] Administration Tools
[x] Native Language Menus
[x] Machining - Postprocessor
[x] Mechanisms
[x] Plotter Software
[x] Post Builder
[x] ProductVision Translators
[x] Punchpress
[x] UG Release Information
[x] UG Alliance - UG Partners
[x] UG Automotive
[x] UG Catia Translator
[x] UG Checkmate
[x] UG Expression Manager
[x] Unigraphics FLEXlm Licensing
[x] UG Imageware Integration
[x] UG Manager
[x] UG Open API - User Function
[x] UG Open API - Plus
[x] UG Photo Realistic Rendering
[x] UG Quick Check
[x] UG Quick Stack
[x] User Tools Sample Files
[x] UG Structures
[x] UG Studio
[x] UG Tips
[x] UG Web Interface Samples
[x] UGfold - Plat Patterns
[x] UG Routing Mechanical
[x] UG Routing Electrical
[x] UG PCB Exchange
Destination Folder ==> C:\Program Files\EDS\Unigraphics NX 2.0 ==> Next
05. (Unigraphics NX Language Selection) ==>
[x] English
[ ] French
[ ] German
[ ] Italian
[ ] Japanese
[ ] Korean
[ ] Russian
[ ] Spanish
[ ] Simplified Chinese
==> Next
06. (FLEXlm Server Name(s)) ==> Server(s): 27000@teeny (My server name is : teeny) ==> Next
07. (Confirm Setup Information) ==> Next
08. (Installation complete) ==> Unigraphics NX 2.0 is now installed on you computer.
To start Unigraphics NX use Start Menu -> Programs. ==> OK
09. (InstallShield Wizard Complete) ==> [x] Yes, I want to restart my computer now. ==> Finish
10. You computer now reboot.
Part 2 (Documentation)
01. Insert CD-ROM DISC 2 of "Documentation Help" to CD-ROM Drive
and go to directory \ugdoc020\program files\EDS\Unigraphics NX 2.0\
02. Copy directory "UGDOC" in to install directory
OK, you will get the direcotry (UGDOC) inside
C:\Program Files\EDS\Unigraphics NX 2.0\UGDOC\
and the directory (html_files) inside
C:\Program Files\EDS\Unigraphics NX 2.0\UGDOC\html_files\
03. OK, Now you prompt to see the HELP for UGS NX v2.0 on
03.1 Help ==> On Context... (or Press F1)
03.2 Help ==> Documentation....
03.3 Help ==> Release Notes...
03.4 Help ==> What's New Guide...
Step 3 (Configuration the License File)
01. Copy \crack\ugnx2.lic from CD-ROM to directory
C:\Program Files\EDS\Unigraphics NX 2.0\UGFLEXLM\ugnx2.lic
and edit with NotePad
02. Change the first line of ugnx2.lic by replace the "this_host" with "You server name"
(My server name is "teeny") and save it.
From
SERVER this_host ANY 27000
DAEMON uglmd
To
SERVER teeny ANY 27000
VENDOR uglmd
03. Setting you "Enviroment Variables" to
LM_LICENSE_FILE = 27000@server_name
By ==> Control Panel ==> System ==> Advanced ==> Environment Variables ==> System variables ==> New
Variable ==> LM_LICENSE_FILE
Value ==> 27000@teeny
==> OK ==> OK ==> OK
04. Click on C:\Program Files\EDS\Unigraphics NX 2.0\UGFLEXLM\lmtools.exe
or
Click on Start ==> Programs ==> Unigraphics NX 2.0 ==> FLEXlm Tools ==> lmtools
[service/License File] (1st Tab)
[x] Configuration using Services
[Config Services] (7th Tab)
Service Name ==> Unigraphics NX 2.0 (Typing this)
Path to the lmgrd.exe file ==> C:\Program Files\EDS\Unigraphics NX 2.0\UGFLEXLM\lmgrd.exe
Path to the license file ==> C:\Program Files\EDS\Unigraphics NX 2.0\UGFLEXLM\ugnx2.lic
Path to the debug log file ==> C:\Program Files\EDS\Unigraphics NX 2.0\UGFLEXLM\debug.log
[x] Use Services
Press "Save Service" ==> Yes
[start/Stop/Reread] (4th Tab)
Press "Start Server" before using Unigraphics NX 2.0
Press "Stop Server" after using Unigraphics NX 2.0
05. Open Unigraphics NX 2.0 by
Click on Start ==> Programs ==> Unigraphics NX 2.0 ==> Unigraphics NX
06. Enjoy !!!
How to installation Network adapters (Microsoft Loopback Adapter)
Note: This process for installation with no network card (LAN card).
Setting Microsoft Loopback Adapter on Windows 2000
01. Control Panel
02. Add/Remove Hardware
03. (Welcome to the Add/Remove Hardware Wizard) ==> Next
04. (Choose a Hardware Task) ==> Add/Troubleshoot a device ==> Next
05. New Hardware Detection (Searching...) ; Waiting a minute
06. (Choose a Hardware Device) ==> Devices: Add a new device (Select on 1st line) ==> Next
07. (Find New Hardware) ==> No, I want to select the hardware from a list ==> Next
08. (Hardware Type) ==> Hardware types: Network adapters (Select from list) ==> Next
09. (Select Network Adapter) ==>
Manufacturers: Microsoft
Network Adapter: Microsoft Loopback Adapter
==> Next
10. Start Hardware Installation ==> Next ==> Finish
Setting Microsoft Loopback Adapter on Windows XP
01. Control Panel
02. Add Hardware ==> Next
03. Yes, I have already connected the hardware ==> Next
04. Installed hardware : Add new hardware device (Selection last in-line) ==> Next
05. Install the hardware that I manually select from a list (Advanced) ==> Next
06. Common hardware types : Network adapters ==> Next
07. Manufacturer ==> Selection Microsoft
Network Adapter : ==> Microsoft Loopback Adapter
==> Next ==> Next ==> Finish
08. The new hardware has been added on
09. To disable the Local Area Connection Status Clicking on button
General ==> Disable
To enable the Local Area Connection Status Clicking on icon
Note:
After installation Network adapters (Microsoft Loopback Adapter)
See your Control Panel on Network and Dial-up Connections for
a new ICON add as "Local Area Connection"
Mr.T (Email : teenyleeman@yahoo.com, cadcamware@yahoo.com, teenyleeman@hotmail.com)
Извиняюсь, но зачем это нужно??? Установка ничем не отличется от установки UG NX v1.0
А там и так всё было ясно - просто "как две копейки в профиль" :bleh:
В общем :thumbdown:
    • anykeyto
    • Sivolap36
    • Рома калужский
    • Горыныч
    • anykeyto
