проблема с макросами
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim FeatureData As Object
Dim Feature As Object
Dim Component As Object
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Part.ClearSelection2 True
Part.CreateCircle 0, 0, 0, 0.02243070422535, -0.0169214084507, 0
Part.CreateCircle 0, 0, 0, 0.0129861971831, -0.01337971830986, 0
Part.ActiveView().ZoomByFactor 1.01
Part.InsertSketch2 True
boolstatus = Part.Extension.SelectByID2("Дуга2@Эскиз1", "EXTSKETCHSEGMENT", -0.001943030284829, 0.002285745679694, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Дуга1@Эскиз1", "EXTSKETCHSEGMENT", -0.002593892442302, 0.003044950245533, 0, True, 0, Nothing, 0)
Part.ShowNamedView2 "*Триметрия", 8
boolstatus = Part.Extension.SelectByID2("Эскиз1", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
Part.SelectionManager.EnableContourSelection = 1
boolstatus = Part.Extension.SelectByID2("Эскиз1", "SKETCHCONTOUR", 0, 0, 0, True, 4, Nothing, 0)
Part.FeatureManager.FeatureExtrusion2 True, False, False, 0, 0, 0.01, 0.01, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, 1, 1, 1, 0, 0, False
Part.SelectionManager.EnableContourSelection = 0
boolstatus = Part.Extension.SelectByID2("", "FACE", 0, 0.003494960490627, -7.513467563172E-04, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Точка1@Исходная точка", "EXTSKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
Part.CreatePlaneAtSurface3 0, False, False, False, 0.7853981633975, True
boolstatus = Part.Extension.SelectByID2("Плоскость1", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.CreateLine2(-0.003, 0.01343714498129, 0, -0.003, -0.01256147671741, 0).ConstructionGeometry = True
Part.SetPickMode
Part.CreateLine2(0.01269945861493, 0, 0, -0.02006488627437, 0, 0).ConstructionGeometry = True
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Точка1@Исходная точка", "EXTSKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
End Sub
Ошибка на строке:
В чем может быть проблема? Макрос был создан системой автоматически.
Проверь, есть ли такое имя плоскости ("Плоскость1"), которую выбираешь в строке
А так макрос у меня проходит.
да, проблема в плоскости... в макросе почему-то не сгенерировано ее создание, плоскость создавала через справочную геометрию.
Такое ощущение, что sw игнорирует это событие. И в код макроса ни чего не вставляет.
Как создать плоскость программным путем?
Ну например:
retval = ModelDoc2.CreatePlaneAtOffset3 ( val, flipDir, autoSize )
Только, как я понял, в макросе был выбор именно "Плоскость1"
Именно так она и называлась. В этой ф-ции можно вставить название плоскости?
Что значат параметры этой ф-ции?
      Вы ж меня собрались сводить на современные станки, а тут выясняется, что уже им как минимум 20 лет Если рука упрется в инструмент, ничего страшного не случится. На 1/8 отворачивают, потому что руке нужно время остановится, и неважно есть там тормоз или нет. А вот если в результате супертонких настроек для экономии 200 мсек, упадет фреза, стоимостью как сэкономленное время за 100 лет, вот это будет номер
      вы можете предполагать все что угодно но рука должна быть не в зоне шпинделя а конкретно четко давать сигнал на разжим в строго определенной позиции и при этом шпиндель должен успеть разжаться когда рука начинает движение вниз по траектории. вы много чего подозреваете а я обслуживаю эти станки в течении 20 лет и ваше   0 целых, хрен десятых это с десяток градусов. вы забываете о скорости с которой движется рука.   настраивается не мотор а кулачки по фазам движения а они стоят на редукторе и мотором вы ничего не настроете  тут про 1\8 оборота имеется ввиду когда уже найден нужный угол но можно и без этого обойтись.
      ой да ладно, доступ он будет делать. скачал в магазине хром расширение и сделал
    • filsan
      Благодарю. Попробую выше упомянутыми инструментами. Правда с дополнительными графиками и пользовательским анализом придется повозиться. Придется-таки делать доступ на народный ресурс за справкой))
      В вашей документации однозначно сказано, что если инструмент выпадает, то произведите настройку Это не противоречит моему утверждению, что цанга должна открываться тогда и только тогда, когда рука в зоне шпинделя, то есть в зоне, где исключается выпадение инструмента    И 1/8 оборота мотора, это сколько в градусах поворота руки? Подозреваю, что 0 целых, хрен десятых
      нет там тормоза он включается только в конце цикла. это целиком динамический процесс. да вы равно не поймете- это же не логично а спец оправка по вашему зачем?? это подача сигнал на разжим шпинделя регулируется и если неправильно отрегулируете то инструмент либо выпадет либо будет выдирать.
      Так это и есть условие "рука в зоне шпинделя" То есть зона, где инструмент гарантированно не выпадает А отвернуть на 1/8, потому что тормоз накладывается
      а вам что логику ладдера в мануале описывать надо? вот специально для вас
      CGTech с гордостью представляет новейший релиз VERICUT версии 9.5. VERICUT – это ведущее в отрасли решение для симуляции, верификации и оптимизации таких процессов как обработка металла, аддитивное производство, гибридное производство и композиты. Это независимое автономное ПО, которое легко интегрируется со всеми основными системами CAM и управления инструментом, а также с существующими УП, даже с теми, которые были отредактированы или созданы средствами, отличными от CAM. Смотреть полностью
      Можете показать мануал, где это описано? Экскурсий не надо. Достаточно привести документальные доказательства
