Completion Project Engineer (only Aerospace)
Job Description
 Be focal point for project leader, manage all engineering-interfaces and represent project-specific engineering
 Manage the project activities which are performed by the involved engineering departments, monitor and supervise these activities in terms of workflow, schedule and cost
 Optimize and strength collaboration between engineering, logistics and production department (for instance by monitoring and controlling technical drawing process, or overseeing process of production material ordering)
 Adjust and maintain Engineering Project Plan for assigned VIP Aircraft outfitting project
 Organize and lead project engineering team meetings, assign action items and track execution
 Anticipate, analyze and report potential engineering project risks and countermeasures to project leader
Profile
 Engineering Degree (mechanical, aeronautical construction) or equivalent education in aircraft outfitting
 Professional: min. of 8 years Industrial/Engineering environment – preferably aviation industry completion (deep knowledge of the requirements in his/her field of experience)
 Project & Process Management: Set-up, management, monitoring, controlling large projects of high complexity.
 Interdisciplinary & Intercultural: Activity monitoring, controlling, coordination, or follow-up within interdisciplinary and intercultural project stakeholders (e.g. CH, FR, GER, UK, US).
company offer competitive salary package
Please send in English to info@eone.com.ua
www.eone.com.ua
    • статист
