Обработчики В "конструкторе Процессов" Tce2005
Или хотя бы опишите обработчик ECM-add-affected-irs-as-target - сам пытаюсь сделать справочник из английской версии, а с этим встрял (
спасибо labslo, но в этой документации не оказалось нужной инфы.
обращаюсь к знатокам английского! помогите понять что здесь написано:
Attaches all affected revisions of the targeted EC Revision as the target object of the EC process. The EPM-attach-item-revision-targets handler must be added after this handler to attach BOM View Revisions (and other specification attachments) of affected revisions as target objects of the EC process.
If you want a new process initiated for each affected revisions of the targeted EC Revisions, use the ECM-start-new-sub-processes.
SYNOPSIS
ARGUMENTS
None.
PLACEMENT
May be placed multiple times in a process, depending on the requirements of the EC process. If the process allows the user to add affected revisions, then this handler must be placed accordingly to ensure newly added revisions are attached as target objects of the EC process.
RESTRICTIONS
Revisions of Affected/Solution item revisions are expected to be in only one process at a time; this handler will not add a new status when either an Affected or Solution item revision is selected as a target attachment.
Do not use this handler with non-EC processes.
    • статист
