i have problem with dnc 80 cybelec
in the upper right corner it says (DPRAM: NO ENC SIGNATURE) and if i press AUTO / AUTO-SEMI / MANUAL.
there notification (ENC NOT CONNECTED) what is problem r and what is the solution
https://fil.email/vg60Vi8E
However the massage ENC NOT CONNECTED will appear and it will not
be possible to work with the machine.
To reactivate the INTERNAL machine peripheral, you must:
- Select MACHINE INTERNAL.
- Initialize the ENC by pressing INIT ENC, Action menu.
thank you for reply
As a result of the delay in a reply from me .A problem has been resolved of  (DPRAM: NO ENC SIGNATURE)
But I have another problem,after complete indexing,there is no displacement on the upper table when the pedal is pressed
also the key number 3 when i turns to position 3 is not working (I can't change anything).
6 часов назад, abdushibi сказал:
How was this problem solved?
pic1.jpgpic-2.jpgpic-3.jpgpic-4.jpgpic-5.jpgpic-6.jpgI checked the key on the tests page and i found the following
when the key in postion 1 (see pic 1), on the tests page,  is zero see pic 2
when the key in postion 2 (see pic 3), on the tests page,  is 2 see pic 4
when the key in postion 3 (see pic 5 ), on the tests page,  is 2 see pic 6
There are 4 wires 0 (common), 1, 2 and 3.
1. 0 + 1 = 1 position
2. 0 + 2 = 2 position
3. 0 + 3  and 1 + 2 = 3 position
You have no 1 and 3 position.
So I think, that there is the problem with the 1-st wire.
41 минуту назад, abdushibi сказал:
In your opinion, what is the solution to this problem?
I think, that you have to dismount the front panel and check the 1-st wire.
i did ,there are four wires As you said i tested with avometer
are ok  when i turn key to postilion 1  there contact between wire 0 and 1
also   between 0 and 2  also between 0 and 3
i mean also when i turn key to psition  2 there contact between 0 and 2 also when turn  to pisition 3
33 минуты назад, abdushibi сказал:
what will be do to solve this problem i need position 3.
You have to use the different connection between the wires to find psition 3.
