i have problem with dnc 80 cybelec
in the upper right corner it says (DPRAM: NO ENC SIGNATURE) and if i press AUTO / AUTO-SEMI / MANUAL.
there notification (ENC NOT CONNECTED) what is problem r and what is the solution
https://fil.email/vg60Vi8E
However the massage ENC NOT CONNECTED will appear and it will not
be possible to work with the machine.
To reactivate the INTERNAL machine peripheral, you must:
- Select MACHINE INTERNAL.
- Initialize the ENC by pressing INIT ENC, Action menu.
thank you for reply
As a result of the delay in a reply from me .A problem has been resolved of  (DPRAM: NO ENC SIGNATURE)
But I have another problem,after complete indexing,there is no displacement on the upper table when the pedal is pressed
also the key number 3 when i turns to position 3 is not working (I can't change anything).
6 часов назад, abdushibi сказал:
How was this problem solved?
pic1.jpgpic-2.jpgpic-3.jpgpic-4.jpgpic-5.jpgpic-6.jpgI checked the key on the tests page and i found the following
when the key in postion 1 (see pic 1), on the tests page,  is zero see pic 2
when the key in postion 2 (see pic 3), on the tests page,  is 2 see pic 4
when the key in postion 3 (see pic 5 ), on the tests page,  is 2 see pic 6
There are 4 wires 0 (common), 1, 2 and 3.
1. 0 + 1 = 1 position
2. 0 + 2 = 2 position
3. 0 + 3  and 1 + 2 = 3 position
You have no 1 and 3 position.
So I think, that there is the problem with the 1-st wire.
41 минуту назад, abdushibi сказал:
In your opinion, what is the solution to this problem?
I think, that you have to dismount the front panel and check the 1-st wire.
i did ,there are four wires As you said i tested with avometer
are ok  when i turn key to postilion 1  there contact between wire 0 and 1
also   between 0 and 2  also between 0 and 3
i mean also when i turn key to psition  2 there contact between 0 and 2 also when turn  to pisition 3
33 минуты назад, abdushibi сказал:
what will be do to solve this problem i need position 3.
You have to use the different connection between the wires to find psition 3.
      Допилил. Поддерживает многолистовые чертежи Начинает работу при нажатии на кнопку макроса: -при нахождении измененных (установлена галочка "Измененное значение") размеров окрашивает их в красный цвет; -если с измененного размера снята галочка "Измененное значение", т.е. он стал обычным - цвет становится обычным; -по окончании работы в сообщении выводится статистика найденных измененных размеров, если они есть. Тестировался на sw2016 и sw2020. ChangeColorForOverridedDimensions.zip
      Я скорее согласен с Надеждой Януарьевной
    • Koels
      Мотора 54 градуса, что на 6 градусов больше соседнего станка, вентеляторы в норме да. Ещё хочу сравнить нагрузку координаты с соседним станком, но пока не дают. У этих двух станков проблемы с охлаждением, на соседнем стоит автомобильный радиатор для охлаждения масла. xD
      Dassault Systèmes Reports Solid First Quarter Results And Reaffirms Full-Year Objectives Просмотр полной статьи
    • Ninja
    • Ninja
      В зимнее время водители устанавливают на колёса специальные цепи против скольжения. В мире разработано множество видов цепей и способов их установки. Японцы применяют "цепи Абэ". Кто этот великий инженер? Это знаменитый японский писатель Кобо Абэ. Для уединенного писательского труда Абэ купил домик в горах. А в горах зима ранняя, снежная, затяжная. Без цепей на колёсах можно и улететь с обрыва. Абэ периодически заводил машину и спускался в долину. Почту получить/отправить, в магазине продукты купить, ящик рисовой водки. (Известное дело: насухую великую книгу не напишешь). В долине приходилось цепи снимать. По правилам цепи запрещается применять при отсутствии на дороге снежного покрова. В те времена для установки/снятия цепи требовалось домкратом поднимать каждое колесо. В машине 4 колеса. Товарищу Абэ приходилось корячиться с домкратом. При этом в самых нелитературных выражениях комментируя политику правящей партии и все домкраты в мире. Купил в магазине бухлишко-закусь. Поехал домой в горы. А там снег, скользко. Цепи требуются. Опять писатель и драматург Абэ домкрат крутит. Всё это насмерть надоело Абэ. Обратился к компаниям-производителям: придумайте способ установки цепей без домкрата! Но производители ничего не придумали. Или не захотели. Тогда Абэ сам придумал способ установки цепей без необходимости поднимать колесо. Послал изобретение на конкурс. И неожиданно получил призовое место и патент. Новый способ установки цепей быстро завоевал популярность. Так и пошло у японцев - "цепи Абэ". Кобо Абэ не получил Нобелевскую премию по литературе. Уже выдвигался, уже все были уверены в том, что он её получит. Но не успели, писатель умер. А это всё дурацкие цепи виноваты. Сколько времени он потерял в установке/снятии цепей? Сколько времени, вместо того чтобы писать, он крутил домкрат? Вот и не успел. https://ru.ruwiki.ru/wiki/Абэ,_Кобо
    • Koels
    • mrVladimir
    • Slavdos
