Инженер-расчетчик (Дубай, ОАЭ)
Добрый день!
Ищу инженера-расчетчика (желательно прочниста) в группу моделирования в международную компанию. Английский хотя бы среднего уровня обязательно, поэтому описание на английском
Dubai, UAE
Engineer – R&D modelling
Job description
KEY ACCOUNTABILITIES:
·        Develops and validates the models and do calculations of thermo-electric, thermo-mechanic, electromagnetic, MHD and CFD fields in aluminium reduction cells and other equipment related with the smelter, carbon, cast house or alumina technology.
·        Interacts with Technical Consultants, Material Suppliers, Operations, Process Control, Process Development, Engineering and IT departments for the various modelling activities.
·        Keeps abreast of technological developments by attending technical seminars, symposia, reading specialized technical publications, coordinating effectively with technical consultants, academics, universities, and suppliers so that company remains competitive by using best ideas/practices.
MINIMUM QUALIFICATIONS & SKILLS:
·        Bachelor’s degree in Engineering/Metallurgy/Material Science discipline from a recognised institution/ university
·        Three (3) years’ relevant work/research experience in the modelling area. Better 5 years
·        Good knowledge of ANSYS Mechanical or CFD, ANSYS SpaceClaim, ANSYS Meshing. Skills for fast preparation geometry and mesh
·        Good knowledge of physics
·        Experience in thermo-mechanical modelling is a big advantage
·        A sharp mind and ability to learn fast.
·        Experienced user of MS Office tools
·        Gathering, documenting, preserving, retrieving, analysing and summarising data
·        Self-confidence, have a professional approach and be an open-minded team player ready to learn and work under pressure
·        Good communication and interpersonal skills
·        ENGLISH intermediate (at least)
·        High attention to details
·        Any experience in metallurgy and especially in Aluminium reduction process will be a plus.
Emirates Global Aluminium (EGA) is one of the largest primary aluminium producers in the world. Work in Modelling group of the R&D department. www.ega.ae (you can check company profile in LinkedIn and Instagram as well)
Working days Sunday to Thursday 7:30 - 16:00. Medical insurance. Annual leave. In general good social package. Paid relocation from overseas (tickets for you and family).
Probation period – minimum 3 months, max 6 months
Good salary level (немного обсуждалось в соседней теме)
You can send your CV to aarkhipov@ega.ae or ask your questions here
Самое главное:
  1. умение хорошо и быстро готовить модели,
  2. понимание физики
  3. и знание ANSYS.
Если у кандидата хорошие знание по первым двум пунктам, то рассмотрим и со знанием других пакетов. По опыту знаю, что если у человека есть мозги пересадить с одного пакета на другой не такая уж большая проблемма.
  • 4 месяца спустя...
    • статист
